Audi A6 C7 and door open warning buzzer
V3lmu
Oulu, Finland
C?ID=229426
Hey! :)
Is it possible for the Audi A6 C7 to have the warning buzzer switched off when the door is opened with the engine running?
Saturday,25,July,2020,14:34:11:00464
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: J.P - V3lmu
VIN: WAUZZZ4G1GN090083   License Plate: AUDI A6 C7
Mileage: 99570km-61869mi   Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 34 3B 42 44 46 52 53 5F 62 72
          8F 90 AC
VIN: WAUZZZ4G1GN090083   Mileage: 99570km-61869miles
Address 01: Engine (J623-CRTE)       Labels: Redir Fail!
   Part No SW: 4G2 907 311 C    HW: 4G2 907 401
   Component: 3.0TDI EDC17  X34 0007
   Revision: 92X34---
   Coding: 0A254012052601030000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
   ROD: EV_ECM30TDI011_AU57.rod
   VCID: 2517F18315611B2300D-8070
   Part No SW: 4G0 927 166 A    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0008
   Revision: --H03---
   Coding: 100001
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2B0307BB73852D53D69-807E
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 17A6DE41E8657B829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF4513E109D7031C5-8014
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01A8700E000000000000
   VCID: 7BA3F7FBC3E57DD3069-802E
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CB    HW: 4G0 820 043 CB
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 24091500111245
   Coding: 36011108210000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 619FA59341C9B7033C5-8034
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001176423902
   Coding: 2600C01400349FE08901408300001D0CCF9CC20826090201000004206101170200400024030000
   Shop #: WSC 12345 123 61029
   VCID: 71BFD5D391A90783AC5-8024
   Component: WWS57X 150808  H38 0080
   Serial number:         150903042155
   Coding: 0045F7
   Serial number: 20705292
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 30 09 2015  00000551
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: EEC84EC7000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1006NAP7
   Coding: 30333130313730323735554A304C34473053
   VCID: 3B2337FB83E5BDD3469-806E
   Serial number: 3575HRB40653KGHSE1L
   Serial number: 3585HRB40593KGHS690L
   Serial number: 3515JRB404V3J2AS4OQB
   Serial number: 3525JRB40673FSTU3PKR
   Serial number: 3554VRB40533K8QIH8G%
   Serial number: 3564VRB404V3KDM68GPO
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OIO001VK
   Coding: 000014
   VCID: 3B2337FB8365BDD3469-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 24 07 2015  G0080881
   Part No SW: 4G8 920 934 D    HW: 4G8 920 934 D
   Component: TDieRdw       H11 0104
   Revision: 07001088    Serial number: 658011015596020
   Coding: 03AF0A001B410008010200
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 323D1ADF54AF7C9B95F-8066
   Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001996509
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 382928F7B2D396CBABB-806C
   Serial number: 0917338003
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 1507250000000000013F
   Coding: 008000
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F3B13AB479D5173FA1-807A
          C10C8 00 [008] - -
                    Reset counter: 103
                    Mileage: 99376 km
                    Date: 2020.07.23
                    Time: 13:04:20
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820A8DB3
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 363526CFB8C760BBB97-8062
   Component: TSG FA        H03 0511
   Coding: 011F17014000628002080002
   VCID: 47CB5B0BCFADE933D21-8012
   Component: RCevo         H53 0202
   Revision: 00000003    Serial number: 0000251345
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D32FF8CDF84DB5DF-806E
   Revision: 00002001    Serial number: 0381549437
   Coding: 0100063800B90000C320080408010E470000000000000000000000000000
   Component: TSG BF        H03 0511
   Coding: 011F17014C00628002080002
   VCID: 46D5560FC8A7F03B297-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001604696
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0709A34D912363C8D-8078
   Part No SW: 4G1 035 182 A    HW: 4G1 035 182 A
   Component: RMC Cnct Plus H61 0139
   Coding: 0100000001E15B47482B060301010000000000
   VCID: 2019E0970AC3FE0B73B-8074
   Subsystem 1 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9464I10F2728264
   Subsystem 2 - Part No SW: 4G1 919 610 E    HW: 4G1 919 610 E
   Serial number: 90349OII000E7
   Component: TSG HL        H03 0511
   Coding: 010F15004000628002080002
   VCID: 49CF5D33D9B91F43C45-801C
   Component: TSG HR        H03 0511
   Component: RGS-VL        H14 0080
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 313F15D351A94783EC5-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152531261
   ROD: EV_RDCMA00100.rod
End----------(Elapsed Time: 01:33, VBatt start/end: 14.6V/14.6V)-----------
hadez16
C?ID=289891
Unit 46
Coding
Change Byte 15 to Hex 4F
Adaptation
Change Channel 98 from 1 to 0
morski
Cheshire UK
C?ID=90186
Or just press the < or > button on the steering wheel
V3lmu
Oulu, Finland
C?ID=229426
Unit 46
Coding
Adaptation
Are you sure this works?
Because of this, this was asked so that you no longer had to press these buttons :D
hadez16
C?ID=289891
I did this for about twelve trillion customers already.
V3lmu
Oulu, Finland
C?ID=229426
This instruction worked 100%. You don’t think how satisfied you were with this guide. No more unnecessary beeps when the door is opened. Big thanks for your help hadez16 . This is great and awesome. :thumbs:
morski
Cheshire UK
C?ID=90186
Will this work on pre & post facelift cars? Mines a 2012 and i dont have channel 98 ?
hadez16
C?ID=289891
All depends on the sw version of instrument cluster and BCM2.
If channel 98 is not present, it doesn't matter.
But due to some possible version conflicts, it could be the case that it is NOT possible to deactivate that beep
morski
Cheshire UK
C?ID=90186
understood. Thanks .
