hello
yesterday on the way home i left a at intersection and as soon as i got to about 2500rpm the engine began to stutter and my MIL started flashing. after few seconds went away. every time i step on gas above 2500 the MIL would start flashing and go away. here is my full scan. it showed random misfire and misfire on cylinder 4. i swapped coils from 4 to 1 and now i have random and misfire on 1, and 3
Saturday,08,August,2020,07:41:55:43295
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWUK73C08P051382 License Plate:
Mileage: 154290km-95871mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWUK73C08P051382 Mileage: 154290km-95871miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404010A18070160
Shop #: WSC 00028 028 00001
VCID: 3039EE51D629C27BE3B-8064
P0300 - 001 -
Fault Status: 01100001
Mileage: 154293 km
Date: 2020.08.08
Time: 07:31:29
RPM: 3331 /min
Load: 100.0 %
Speed: 47.0 km/h
Temperature: 68.0°C
Temperature: 28.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected
Mileage: 154293 km
Date: 2020.08.08
Time: 07:31:29
RPM: 3331 /min
Load: 100.0 %
Speed: 47.0 km/h
Temperature: 68.0°C
Temperature: 28.0°C
Voltage: 14.224 V
000771 - Cylinder 3
P0303 - 008 - Misfire Detected
Fault Status: 01101000
Mileage: 154293 km
Date: 2020.08.08
Time: 07:31:29
RPM: 3419 /min
Load: 30.6 %
Speed: 49.0 km/h
Temperature: 68.0°C
Temperature: 28.0°C
Voltage: 14.351 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected
Mileage: 154293 km
Date: 2020.08.08
Time: 07:31:29
RPM: 3419 /min
Load: 30.6 %
Speed: 49.0 km/h
Temperature: 68.0°C
Temperature: 28.0°C
Voltage: 14.351 V
004688 - Fuel Level too Low
P1250 - 008 -
Mileage: 154293 km
Date: 2020.08.08
Time: 07:31:30
RPM: 3119 /min
Load: 11.4 %
Speed: 49.0 km/h
Temperature: 68.0°C
Temperature: 27.0°C
Voltage: 14.351 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 D HW: 3C0 614 109 D
Component: J104 C4 440 V2 0003
Revision: --020--- Serial number: 00000776088981
Coding: 0000345
VCID: 1F1B1DEDBBB74D034A1-804A
Part No SW: 1K0 820 047 GF HW: 1K0 820 047 GF
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 6E8530290C9D948BB17-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000005113356
Coding: 00840F0340041A28470000000F000000000859435C000100000000000000
VCID: 71BF2B551DA38B73AC5-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 020807 003 0205
Coding: 00046997
Shop #: WSC 00028
Fault Status: 00101100
Fault Frequency: 27
Reset counter: 92
Mileage: 151401 km
Date: 2020.03.19
Time: 19:36:00
Voltage: 12.30 V
Reset counter: 71
Mileage: 153531 km
Date: 2020.07.24
Time: 16:48:00
Voltage: 12.40 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 17 AIRBAG VW8R 032 2522
Revision: 13032000 Serial number: 003B2PJWXZXL
Coding: 0012599
VCID: 313FEB55DD23CB73EC5-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003NQKC
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME165A056AEÿ†63
Subsystem 5 - Serial number: A056AEÿ†6342MSME16731B5FLÿ†63
Subsystem 6 - Serial number: 31B5FLÿ†6351HTS61CGGEOO6-ÿ†63
Subsystem 7 - Serial number: GEOO6-ÿ†6361HTS6L4I4O2579ÿ†63
Subsystem 8 - Serial number: 4O2579ÿ†63727TS61CGS87V6Pÿ†63
Subsystem 9 - Serial number: S87V6Pÿ†63827TS61CGS0A67/ÿ
Subsystem 10 - Serial number: S0A67/ÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
Component: Lenksäulenmodul 006 0010
Revision: 00006000 Serial number: 3C5953507BK
Coding: 0000013
VCID: 3537DF45294BE753B0D-8060
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 F HW: 3C0 920 971 F
Component: KOMBIINSTRUMENT VD1 1216
Revision: V0002000 Serial number: 00000000000000
Coding: 0007205
VCID: 28090631EEF98ABB3BB-807C
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 E HW: 3C0 907 951
Component: J533__Gateway H10 0080
Revision: H10 Serial number: 1200P078310302
Coding: F9807F070012021002
VCID: 2313111D97DF69E36E9-8076
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1166279TRTRJ06
VCID: 6D873725019B6F9388D-8038
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 61689 001 1048576
VCID: 73B3215D67BFB9635E9-8026
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1131
Revision: 32008001 Serial number: 00000043278919
Coding: 0001205
VCID: 3B23C97D0F6F3123469-806E
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.134 H08 1901
Component: KSG PQ46 RDK 051 0221
Coding: 13910F8001862E521004141FF08A0F0E485C00
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1131
Revision: 32008001 Serial number: 00000634978919
Coding: 0001204
VCID: 3C21CA610A61361B4F3-8068
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
Component: J540 EPB3 VW-09393 0009
Revision: 008 Serial number: 00000000169747
Coding: 0000057
VCID: 290F0335F5F3B3B3245-807C
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 C HW: 1K0 035 161 C
Component: Radio DE2 014 0019
Revision: 00014000 Serial number: VWZ4Z7G6288508
Coding: 0040402
00856 - Radio Antenna
00857 - CD Changer Unit (R41)
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1118
Revision: 12006001 Serial number: 00000002365049
Coding: 0001168
VCID: 3E25C0691C7D240B617-806A
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1118
Revision: 12006001 Serial number: 00000002374822
Coding: 0001168
VCID: 3FDBBD6D1B772D036A1-806A
End----------(Elapsed Time: 01:20, VBatt start/end: 14.3V/14.3V)-----------
