Immobilizer issue
achuudayan
India
C?ID=327626&
Dear all,
its 2011 VW VENTO 1.6 Tdi
after key fallen in water engine will stall after 2 sec, tried with the spare key the same issue , in cluster its showing SAFE
please help
Friday,07,August,2020,20:43:45:59768
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWF11600BT069874   License Plate:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44
VIN: WVWF11600BT069874   Mileage: 71440km-44390miles
Address 01: Engine (J623-CLNA)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 NT    HW: 03L 907 425 B
   Component: R4 1.6l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110016030500080000
   Shop #: WSC 00793 648 00255
   ASAM Dataset: EV_ECM16TDI02103L906023NT 003014
   ROD: EV_ECM16TDI02103L906023CR_003.rod
   VCID: 05427F5384C85EAE20-8050
6260 - Engine Start Blocked by Immobilizer
          P1570 00 [165] - -
                    Mileage: 71447 km
                    Date: 2020.08.07
                    Time: 00:01:55
                    Engine speed: 0.00 /min
                    Coolant temperature: 59 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 12.311 V
                    Immobilizer snapshot A: 94
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6RF 907 379     HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0002
   Revision: --------
   Coding: 500200C1007300BB0A2D00E900D500004000
   Shop #: WSC 02069 000 00000
   VCID: 116A5B03CC80020E8C-8044
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6R0 907 044 G    HW: 6R0 907 044 G
   Component: Climatronic   H09 0609
   Revision: V0000000
   VCID: 373EC59B86A4FC3EE2-8062
01272 - Positioning Motor for Central Flap (V70)
                    Reset counter: 178
                    Mileage: 71447 km
                    Date: 2014.12.29
                    Time: 00:06:06
   Part No SW: 6RU 937 086 B    HW: 6RU 937 086
   Component: BCM25 IM M+4  H46 0230
   Revision: BY046001    Serial number: 0335 159110357
   Coding: 3A984ABF08A12400123000003C0B04900000414F60040000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 608C4EC773AADB8673-8034
   Subsystem 1 - Part No SW: 6R0 959 802 D    HW: 6R0 959 802 D  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3420
   Subsystem 2 - Part No SW: 6R0 959 801 ED    HW: 6R0 959 801 ED  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  023 2261
   Serial number: 13102849170216063901
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 4 - Part No: 1K8 951 171 A
   Subsystem 5 - Part No SW: 6R0 959 811 E    HW: 6R0 959 811 E
   Component: J388__TSG_HL  002 3420
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 E    HW: 6R0 959 812 E
   Component: J389__TSG_HR  002 3420
   Coding: 020000
   Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
   Component: VW10AirbagU06 H09 0020
   Revision: --------    Serial number: 003GW004L875
   Coding: 003036
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 49DAB363E8507ACE84-801C
12854016 - Databus
          [Kombi1 DLC Error]
                    Fault Frequency: 52
                    Reset counter: 218
                    Mileage: 71447 km
                    Date: 2020.08.07
                    Time: 00:15:25
   Part No SW: 6RF 920 860 B    HW: 6RF 920 860 B
   Component: KOMBI         H08 0008
   Coding: 550800
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04061
   Part No SW: 6N0 909 901     HW: 6RU 937 086
   Component: GW-K-CAN TP20 0230
   Coding: 002300
   VCID: 70AC3E87A34A6B06E3-8024
   Component: IMMO          H08 0008
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03007
Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 J    HW: 6RF 909 144 J
   Component: EPS_ECU       H26 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 53E6910B3A1C301EFE-8006
End----------(Elapsed Time: 01:10, VBatt start/end: 12.4V/12.3V)-----------
Dr Sheldon
Windsor UK
HC433554 (2nd hand?)
Measuring Blocks is your best friend here
I don't understand how the key falling in water could cause this. The transponder is passive and encased in waterproof glass pill. Moreover, the spare key didn't fall in water, right?
It's also rather puzzling that there are no fault codes in either 17-Instruments or 25-Immo.
Since it's a UDS Immobilizer, it will have to be Advanced Measuring Values.
I would put one key in, turn the ignition on, but do not try to start the engine, and make a map of all the measuring values. Then I would take that key out and repeat the process with the other key.
Post both maps here. Maybe someone will be able to see something that explains this.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Not on this key , mk6 key stile has no glass transponder , it is little micro with antenna at top.
Jetta 97
C?ID=81680
Dear all,
please help
          P1570 00 [165] - -
                    Mileage: 71447 km
                    Date: 2020.08.07
                    Time: 00:01:55
   Revision: --------
   Revision: V0000000
                    Reset counter: 178
                    Mileage: 71447 km
                    Date: 2014.12.29
                    Time: 00:06:06
   Coding: 020000
   Coding: 020000
   Coding: 003036
12854016 - Databus
          [Kombi1 DLC Error]
                    Fault Frequency: 52
                    Reset counter: 218
                    Mileage: 71447 km
                    Date: 2020.08.07
                    Time: 00:15:25
   Coding: 550800
   Coding: 002300
   Coding: 0000
If you try more then 3 times to start car with water damage key , then you probably have lock out state . I suggest leave ignition On for 1 hour with spare key and make sure you have battery charger on it , then turn igntion Off , and try after that .
Oh, that's cheesy! :mad:
achuudayan
India
C?ID=327626&
Dear all,
after removing battery cable for whole night & in morning it starts fine on the spare key, but again went to SAFE while using the waterlogged key.
Now works fine on spare key.
while i inspect the waterlogged key closely after changing with a new battery the red LED on key fob blinking on its own, will this cause the car to go in SAFE
achuudayan
India
C?ID=327626&
it works fine after disconnecting battery for whole night , but problem still showing while using waterlogged key
MasterTommy
Amsterdam
C?ID=295586
Since you have at least one working key, replace damaged one?
