Help please!! (2010 Audi A6 Quattro) 3.0 Fans
Cobie90
C?ID=311736
I was driving my Audi today and notice my temp going up to hot. Both my fans come on cycle slow then stop and keep repeating like that and ac blow hit air.(Also when I turn the ac off the fan dont spin at all) im thinking either the fans are bad are the fan control module is bad. I got a fault code for the radiator fan (V7) but not the fan control module. I was wondering if any one have ever dealt with this before and can someone help me before I start purchasing parts I don't need. My scan is below. Thanks for any advice that can help me getting my car running back right.(My fans spins freely just slow but the code say its restricted are jammed.
Friday,07,August,2020,16:07:09:05661
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUKGAFB7AN036515   License Plate:
Mileage: 211360km-131333mi   Repair Order:
Chassis Type: FB-AU56 (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 47 4C 4F 52 53 55
          56 5F 62 6C 72
VIN: WAUKGAFB7AN036515   Mileage: 211360km-131333miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (CCA)       Labels:. 06E-907-551-CAJ.clb
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0050
   Revision: --H06---    Serial number:
   Coding: 0105000A190F0120
   Shop #: WSC 08175 444 103843
   VCID: 2412E4F0D2DA9EFB173-8070
006480 - Radiator Fan (V7)
               P1950 - 000 - Movement Restricted / Jammed - Intermittent
                    Mileage: 211368 km
                    Date: 2020.08.07
                    Time: 15:27:08
                    RPM: 640 /min
                    Mass Air / Rev.: 169.0 mg/str
                    Temperature: 105.0°C
                    Bin. Bits: 00000010
                    Load: 15.3 %
               U1017 - 000 -
                    Fault Status: 01101000
                    Mileage: 211368 km
                    Date: 2009.06.02
                    Time: 00:01:06
                    RPM: 1056 /min
                    Mass Air / Rev.: 109.0 mg/str
                    Temperature: 87.0°C
                    Bin. Bits: 00000010
                    Load: 6.3 %
Readiness: 1110 1101
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0010
   Revision: --H04---    Serial number:        4539555
   Coding: 0000002
   Shop #: WSC 02325 785 00200
   VCID: 2A0E0AC8B0FE488B2DF-807E
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6E86C6D84C9664ABB17-803A
                    Fault Frequency: 25
                    Reset counter: 61
                    Mileage: 208414 km
                    Date: 2020.06.24
                    Time: 18:14:05
                    Hex Value: 0x2A00
                    Hex Value: 0x4006
                    Hex Value: 0x001E
                    Hex Value: 0x30AD
                    Hex Value: 0x00FF
                    Reset counter: 24
                    Mileage: 211368 km
                    Date: 2009.06.02
                    Time: 00:01:06
                    Hex Value: 0x00C0
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x019C
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602501421794
   Coding: 0000007
   Shop #: WSC 02324 785 00200
   VCID: 2514F9F4D9E067F300D-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H03 0020
   Component: FBSAUDIC6 KSG   H03 0020
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000076    Serial number: 00000030563599
   Coding: 0524326
   Shop #: WSC 02335 785 00200
   VCID: 1D64D114F1B0AF3358D-8048
   Part No SW: 4F0 910 279 Q    HW: 4F0 907 279 A
   Component: ILM Fahrer      H24 0340
   Coding: 0139123
   VCID: 372823BC734CE563A21-8062
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
01494 - Bulb for Parking Lamps; Left (M1)
                    Fault Status: 01111011
                    Reset counter: 24
                    Mileage: 207112 km
                    Date: 2020.06.11
                    Time: 18:51:00
01498 - Bulb for Parking Lamps; Right (M3)
                    Reset counter: 24
                    Mileage: 207112 km
                    Date: 2020.06.11
                    Time: 18:51:00
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1574C9340580F77390D-8040
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FA0012RDS
   Coding: 303142373034303030314A55304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 36362EB878C61C6BB97-8062
   Subsystem 1 - Part No SW: 4F0 910 339 B    HW: 4F0 959 339 B
   Component: BF-Gewichtss.  H03 0060
   Serial number: 5810000R0000003W4J
   Serial number: 3574SRB400009FDD0ABV
   Serial number: 3584SRB400009F94E27L
   Serial number: 3516HRB402VC0AS50SV6
   Serial number: 3526HRB402VC0AS4OKNE
   Serial number: 3554NRB40000517EBB79
   Serial number: 3564NRB4000051197E1Z
12583424 - Powertrain Databus
          U0002 00 [008] - No Communications
          [High Speed CAN Communication Bus no signal/communication]
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026092900003
   Coding: 0012141
   VCID: 2708F3FCA3EC75E3321-8072
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 983 H    HW: 4F0 920 983 H
   Component: KOMBIINSTR.   H08 0144
   Revision: 00000000    Serial number: CN450YEA9
   Coding: 8BD60A050B00CF05020201
   Shop #: WSC 02391 823 56573
   VCID: 313C1DA491283B53EC5-8064
                    Fault Frequency: 28
                    Reset counter: 2
                    Mileage: 206890 km
                    Date: 2020.06.09
                    Time: 11:31:26
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L09A1700BA
   Coding: 000303
   VCID: 392C25844958F313545-806C
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790931568
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Fault Frequency: 30
                    Reset counter: 2
                    Mileage: 206890 km
                    Date: 2020.06.09
                    Time: 11:31:25
                    Bin. Bits:    01111
                    Voltage: 13.80 V
                    Count: 7
                    Bin. Bits:    10011
                    Time: 25.40 s
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010017085
   Coding: 00581B00004011110000
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000102168472
   Coding: 011F57204E40410001
   VCID: 46D65E7808A68CEB297-8012
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01229654010000
   Coding: 4618269
   VCID: 353429B469401773B0D-8060
                    Fault Status: 01101100
                    Reset counter: 24
                    Mileage: 208933 km
                    Date: 2020.06.29
                    Time: 14:18:38
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000041814
   Coding: 05000000
   VCID: 290CF5C4B9F84393245-807C
Address 4C: Tire Pressure II
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000509539
   Coding: 0002014
   VCID: 5EE69618BC36F42B017-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000102131826
   VCID: 45D4597435A087F320D-8010
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 211CEDE4CDC88BD37C5-8074
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0060
   Coding: 0000026
   VCID: 698CB5C475788393E45-803C
   Subsystem 1 - Part No: -----------
   Component: AFS-Modul links
   Subsystem 2 - Part No: -----------
   Component: AFS-Modul rechts
02071 - Local Databus
                    Fault Status: 11100100
                    Reset counter: 37
                    Mileage: 203136 km
                    Date: 2009.06.02
                    Time: 05:23:18
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335J-097535137
   Coding: 020000010000000000
   VCID: 1D64D114FDB0AF3358D-8048
   Part No SW: 4E0 035 664 A    HW: 4E0 035 664 A
   Component: H-BN-NA       H45 0042
   Revision: --------    Serial number: 488J/097520192
   Coding: 010200000002E1FE41000304EF6300030000
   VCID: 221EE2E8C4CE90CB65F-8076
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356JX091091752
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 T
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001422512
   Component: CD-Database  1293
                    Fault Frequency: 13
                    Reset counter: 1
                    Mileage: 209467 km
                    Date: 2020.07.10
                    Time: 10:25:09
                    Bin. Bits: 00000010 10000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000009496373
   Coding: 010E57204040220001
   VCID: 43D0476C3B94B9C30E9-8016
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J9925BW
   Coding: 1000304
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 24
                    Mileage: 211368 km
                    Date: 2009.06.02
                    Time: 02:26:30
                        Reverse OFF
                    Count: 3
   Revision:             Serial number: 0000009496374
End----------(Elapsed Time: 01:47, VBatt start/end: 12.7V/13.0V)-----------
Address 03: DTCs cleared
Address 01: DTCs cleared
Dr Sheldon
Windsor UK
HC433554 (2nd hand?)
I very much doubt that they could make the description of the fault any clearer if they tried ?
How would the ECU know that the Fan is Restricted or Jammed or Both. My guess is that the Fan Control Module is monitoring Current Draw of the Fan. Next Guess is your fan is drawing more current than it should hence that particular Code.
I would refer to a wiring diagram, activate the fans via VCDS whilst watching Power Supplies, signals and Motor Current on an oscilloscope then know with certainty where the failure is.
Cobie90
C?ID=311736
I'm not a mechanic so thats why I came to the thread because I don't know if its the driver are passenger side fan i also dont know if its the control module cause if i drive it on the road otherwise ac blow cold but if im sitting still the ac blow hot. So i just need to know if it's the fans are the fan control module.
