Hello All,
I'm looking to do a Halogen to Bi-Xenon retrofit on a '17 NA Golf Sportwagen along with a few other upgrades. I'm curious where I can find information on the BCM's capabilities? Autoscan below:
I've checked some other Autoscans of GSW/Alltracks posted on these forums. I've seen a few with BCM 5Q0 937 087 AN and Bi-xenon headlights so I would assume it is capable, but I'd just like to double check. Normally I'd check Long code to see if Xenon was a present selection, but seeing as this is a newer VW, long coding on Cent. Elect. isn't available - And I don't know enough about the new adaptations to tell if I can check here for capabilities. Also curious if this BCM would support heated seats if I ever decided to retro-fit?
If 5Q0 937 087 AN is unable to handle this, would 5Q0 937 087 AP be able to? Any assistance is appreciated.
I'm aware i'll require other hardware and wiring pieces for the retro-fit, I'll be posting more questions related to that in a separate post dedicated to the retro-fit.
Thanks,
Sean
Tuesday,04,August,2020,22:38:43:40431
VCDS Version: 20.4.2.0 (x64)
VIN: 3VWC17AU4HM532202 License Plate:
Mileage: 65291km-40569mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: 3VWC17AU4HM532202 Mileage: 65291km-40569miles
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 K HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0003
Revision: --H13---
Coding: 091A00122424002F0000
Shop #: WSC 00066 790 00202
ASAM Dataset: EV_ECM18TFS0208V0906264K 001004
ROD: EV_ECM18TFS0208V0906264K.rod
VCID: 4487587DCF0630A677-8010
Readiness: 0010 1101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 AR HW: 09G 927 158
Component: AISIN AG6 G3 202 3198
Coding: 010200000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW23.rod
VCID: 03059B618A88F79E0E-8056
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 50367000001346
Coding: 04FA6AA12423096E4079020080C52920562490024001943400405050C002430000000012121212B835351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036.rod
VCID: 000F946D9B9EEC8613-8054
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5GM 907 426 D HW: 5GM 907 426 D
Component: AC Manuell H03 1801
Revision: 00001K04
Coding: 02020004200100000000000000000002
VCID: 49994949E824EDCE84-801C
Part No SW: 5Q0 937 087 AN HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 032 0223
Revision: -------- Serial number: C86413021700OT
ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017.rod
VCID: 071D8F71BEB0DBBE52-8052
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 161129 043 0551
Serial number: 97022066161212024516
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR076DTR
VCID: 479D4F71FE301BBE92-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000006OE3GN
Coding: 303133
Subsystem 2 - Part No SW: ----------- HW: 480 001 801 17
Serial number: 35700000000D8841E02M
Subsystem 3 - Part No SW: ----------- HW: 480 001 901 17
Serial number: 35800000000C0D8CF02Z
Subsystem 4 - Part No SW: ----------- HW: 480 402 701 17
Serial number: 3510001BF248E89303FG
Subsystem 5 - Part No SW: ----------- HW: 480 402 601 17
Serial number: 3520001B7237EE245396
Subsystem 6 - Part No SW: ----------- HW: 480 402 301 17
Serial number: 3550002C723C4E33315+
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 301 17
Component: FrontSensor_P 001 6149
Serial number: 3560002C923C4E34A137
Part No SW: 5Q0 953 507 GH HW: 5Q0 953 549 E
Revision: -------- Serial number: 02031708491150
Coding: 0410
VCID: 020B9E659592FE9605-8056
Part No SW: 5G1 920 840 B HW: 5G1 920 840 B
Component: KOMBI 244 8311
Coding: 0BB4110AA180CF0502086A001000000000000000
VCID: 2643E2F5597AE2B649-8072
Part No SW: 3Q0 907 530 B HW: 3Q0 907 530 B
Component: GW MQB Mid 514 5286
Serial number: 06031700840062
Coding: 0101000870085900FA0000081C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07025
ROD: EV_GatewNF_VW37.rod
VCID: 2E531AD5718AAAF6B1-807A
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0103
Serial number: 27160003134840116474
Coding: 31FFFF
Part No SW: 5Q0 959 393 E HW: 5Q0 959 393 B
Component: TSG FS 020 0041
Serial number: 110217060502EU
Coding: 003003200000020000000000
VCID: 41895169D014258E5C-8014
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000005474626
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 0102
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FAD67511640C3FEDA-801A
Part No SW: 5Q0 959 392 E HW: 5Q0 959 392 B
Component: TSG BFS 020 0041
Serial number: 160217060508C9
VCID: 408F546DDB1E2C8653-8014
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000005464806
Coding: 091000
Part No SW: 3Q0 035 844 A HW: 3Q0 035 844 A
Component: MU-S-S-US 710 0751
Coding: 02730200FF00000051220001001808009F0100D40120010002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 2D511DD97C8CD1EE88-8078
Subsystem 1 - Part No SW: 3G0 919 605 H HW: 3G0 919 605 H
Component: ABT_Std-2 H53 1031
Serial number: VWZ8Z9TJW024PY
B11CF 53 [009] - Deactivated
Reset counter: 151
Mileage: 65273 km
Date: 2020.08.04
Time: 20:47:02
Voltage terminal 30: 14.0 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Audio Signal: Not available
SDARS_tuner_status_2-Antenna current: 137 mA
SDARS_tuner_status_2-Reception quality: No_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
0008 - Connection between Antenna Amp 2 for Radio and Antenna
B1273 13 [009] - Open Circuit
Reset counter: 151
Mileage: 65273 km
Date: 2020.08.04
Time: 20:46:33
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
1637 - Interface for External Media
U11B8 00 [009] - No Communications
Reset counter: 151
Mileage: 65273 km
Date: 2020.08.04
Time: 20:46:33
Interface for external media: status-Status: Open circuit
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0570
Coding: 02730202C2821A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: 43855B61CA08379E4E-8016
End-------------------------(Elapsed Time: 03:54)--------------------------
Thanks,
Sean
