Deleted basic Settings help!
AlanChowder
Hi all,
First post so here goes...
I deleted basic settings in 03 ABS by mistake (I know what a...) I now have a whole host of ABS related issue.
Can anyone shed any light not this situation?
I have replaced the coding with a previous saved scan so that’s ok.
I have reset the steering angle sensor although I didn’t get a “finished correctly” it cleared the fault.
Can anyone help with the remaining issues? I’ll post the scan:
Thursday,06,August,2020,09:35:40:53804
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZAUZEW139787 License Plate: GTD GOLF
Mileage: 117194km-72820mi Repair Order: 07/08/20
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
VIN: WVWZZZAUZEW139787 Mileage: 117194km-72820miles
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 EP HW: 04L 907 309 A
Component: R4 2,0L EDC H22 6283
Revision: 81H22---
Coding: 01190012034505082000
ASAM Dataset: EV_ECM20TDI01104L906021EP 002006
ROD: EV_ECM20TDI01104L906021AE.rod
VCID: 77BEEA1DCE1F68F796-8022
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 117194 km
Date: 2020.08.05
Time: 15:29:10
Engine speed: 0.00 /min
Coolant temperature: 22 °C
Intake air temperature: 22 °C
Voltage terminal 30: 11.780 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Acceleration: 0.000 m/s²
Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
Component: ESC H31 0472
Revision: 00000000 Serial number: 62563000000BA3
Coding: 01FA8AA134230975037E060841CA2980512C90C0608294F5F4605074C009
Shop #: WSC 131071 102 209715
VCID: 075E9ADDBEFF1877E6-8052
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 0
Date: 2020.08.05
Time: 01:06:54
0338 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
[inlet valve calibration data missing]
Reset counter: 0
Date: 2020.08.05
Time: 01:06:54
8299 - Databus
[FCAN: Anhaenger_01_alt veraltet bit is set]
Reset counter: 0
Date: 2020.08.05
Time: 01:06:54
C1146 02 [137] - Signal Failure
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 01:07:03
32806 - Parking Brake Motor; Left
C10BC 01 [137] - Electrical Failure
[IPB-Actuator: release: power loss: exceeds upper threshold (left)]
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 15:29:50
32951 - Control Module for Electronic Parking Brake
C10E2 54 [137] - Missing Calibration / Basic Setting
Reset counter: 0
Date: 2020.08.05
Time: 01:06:54
Part No SW: 5G0 907 044 T HW: 5G0 907 044 T
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120104202100011005000000101000
VCID: 383C29218381A78F5F-806C
Air quality sensor:
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011326901427
Coding: 03000A42C24122FB0BA44080B10C0728100A000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130907 042 0551
Serial number: 130919052941
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M09D24H10M43S00S1
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY132330RUL
Serial number: 00000000000057687578
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H02 0033
Revision: -------- Serial number: 94231326801104
Coding: 0071051001
ASAM Dataset: EV_EPHVA18AU3700000 002019
VCID: 3B36362DB2B78C97B2-806E
13637120 - Databus
[Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 00:45:47
13637426 - Databus
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 00:45:47
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 A HW: 5Q0 907 572 A
Component: ACC Bosch MQB H04 0150
Serial number: 08081376510400
Coding: 00000300FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001013
VCID: 3522201594935AE744-8060
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 00:45:47
Voltage terminal 15: 11.7 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1061 - Databus
[FAULT_CIS_EPB_ACTUATOR_FAIL]
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 00:45:47
1060 - Databus
[FAULT_CIS_EPB_FAIL]
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 00:57:43
Control Module temperature: 39 °C
Voltage terminal 15: 13.8 V
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 00:45:47
1078 - Databus
[FAULT_CIS_SAS_INIT]
Mileage: 117194 km
Date: 2020.08.05
Time: 00:45:47
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
[FAULT_CIS_TSK_IRREV_FAIL]
Reset counter: 0
Mileage: 117194 km
Date: 2020.08.05
Time: 00:45:47
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR00KDU7
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 7F4E023DE62F50B7DE-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0340
Serial number: 34169677B26091350625
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0340
Serial number: 34169676B27091370063
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 709 13
Serial number: 35767000000C52DC9D08
Subsystem 4 - Part No SW: ----------- HW: 480 000 709 13
Serial number: 358670000000463D9D0Y
Subsystem 5 - Part No SW: ----------- HW: 480 402 509 13
Serial number: 3516502AB11FBEB2A0E-
Subsystem 6 - Part No SW: ----------- HW: 480 401 909 13
Serial number: 3526502C111D152041F-
Subsystem 7 - Part No SW: ----------- HW: 480 401 909 13
Serial number: 3556502C111D1522617Z
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Mileage: 117194 km
Date: 2020.08.05
Time: 00:45:47
Part No SW: 5Q0 953 507 AG HW: 5Q0 953 549 A
Revision: -------- Serial number: 20091304221852
Coding: 0C00
VCID: 7BB6F62DF2374C97F2-802E
Part No SW: 5G6 920 970 A HW: 5G6 920 970 A
Component: KOMBI 314 2210
Coding: 27AD09002F80260001882A01000000
VCID: 2E100F7971C5693F05-807A
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0001004007
Coding: 030100040B087300EF00027E080F00010001000000000000000000000000
ROD: EV_GatewLear_009.rod
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H06 0038
Serial number: 27130001483320093373
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 0910011403
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 15091303110193
Coding: 003F0220D001048000001000
VCID: 3FCE423DA6AF90B79E-806A
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000002744856
Coding: 0D0000
Part No SW: 3Q0 909 144 D HW: 3Q0 909 144 E
Component: EPS_MQB_ZFLS 502 5011
Coding: 8101
ASAM Dataset: EV_SteerAssisMQB 009026
ROD: EV_SteerAssisMQB_009_VW37.rod
VCID: 33261E0D9AE744D76A-8066
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 23091306070982
Coding: 003F0020DE01048000801000
VCID: 3E303F39A1A599BF95-806A
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000002711358
Coding: 050000
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 029E01000B000200
VCID: 3D323835ACA382A78C-8068
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 820 A HW: 5G0 035 820 A
Component: MU-S-D-ER 040 0421
Serial number: V5C01709130125
Coding: 02730000FF00000021111201002800001F0202060100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 1F0EE2BD066FF0B7BE-804A
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H50 0022
Serial number: VWZ8Z9NJ701JA9
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0011
Serial number: 130725200472
VCID: 6B96C66D8257DC1762-803E
End----(Elapsed Time: 01:20, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
THANKS FOR ANY HELP!!!
The parking brake was the reason I was in there in the first place so that wasn’t a new fault.
Please tell us exactly what you did. There is no function that "deletes" basic settings in this ABS.
AlanChowder
Hi Uwe,
So in ABS 03 in basic setting 04 I pressed “resetting of all adaption values” after entering the security access code for 03.
This above scan is what I got after.
I know how stupid this was 😬
Thanks for your reply.
That should have given you a rather explicit warning that you probably don't want to do that. ;)
Now the hopeful thing is, you don't have a fault code for something like Invalid or Missing Dataset, so in theory, this can probably be fixed without a trip to the dealer, but I'm not sure where to even start.
AlanChowder
Ok that’s a little ray of sunshine.
Is there anyone on here who has had any experience with this? I have seen a thread where similar codes came from replacing the module but there was no resolution posted.
Would be very grateful for any insight.
Thanks.
NEtech
Denmark
C?ID=56995
Performed in [03-ABS]
Got to Adaptation and find this Channel:
IDE04774-IDE06589 Vehicle and trailer stabilization - Trailer information evaluation
and deactivate it.
Do Steering limit stop as showed here.
If DTC B1168 does not disappear, go to [44-Steering assist] and try this.
Try if these Basic Settings are possible to perform:
IDE03652-ENG98891 Basic setting for inlet/cut-out valves
Don't know procedure, would guess with engine running
IDE05060-ENG114972 Reset to factory setting of tire pressure monitoring display
IDE05335-ENG114972 Electro-mechanical parking brake function test
- Place the car on a flat surface.
- Ignition ON
- DO NOT step on the brake pedal during the basic setting.
- Open parking brake, if necessary, using the switch for the electromechanical parking brake
Remove ignition, wait 2 minutes.
AlanChowder
Thanks for your reply!
I have managed to clear all faults now, thanks for your instruction.
The brake motor and related faults cleared after fitting a new calliper motor and running basic settings.
Panic over, thanks again 👍
