2010 Seat Leon Cruise Control Switch (E45)
Baps McGinty
Ireland
C?ID=407250
Hi
My daughter has bought her first car, a 2010 Leon 1.6 Ecomotive. The car had several dash lights illuminated so was relatively well priced. Most forums suggested the steering column control unit was faulty so I replaced it with one from a scrap vehicle, same year model and the part number on the module was the same. All the lights went out apart from the ESP and TPMS warning lights. The switches on the tunnel would not switch them off. Eventually I was able to calibrate the steering angle sensor using VCDS and all lights went out. Success. Thing is the car is reporting a Cruise Control Switch (E45) as defective but the car is not fitted with Cruise Control. I got the car specs from erWin Seat and sure enough the car is not fitted with cruise control. Neither was the doner column control car.
Wondering why. Doesn't seem to affect anything although my daughter reported the steering going very stiff a few times when turning a corner at low speed. A problem I have not been able to replicate.
VIN: VSSZZZ1PZAR068638   License Plate:
Chassis Type: 1P-SE35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 61 77
VIN: VSSZZZ1PZAR068638   Mileage: 273690km-170063miles
   Part No SW: 03L 906 023 GP    HW: 03L 906 023 GG
   Component: R4 1.6l TDI   H23 9979
   Revision: --H23---    Serial number:
   Coding: 00114014030501080000
   ASAM Dataset: EV_ECM16TDI02103L906023GP 003013
   ROD: EV_ECM16TDI02103L997557R.rod
   VCID: 7AADF778EC5A904B1DF-802E
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 133B201209280002C81104E790210091350800
   Shop #: WSC 04941 000 00000
   VCID: 7AADF778ECDA904B1DF-802E
   Part No SW: 5P0 820 047 P    HW: 5P0 820 047 P
   Component: Climatic PQ35   014 0707
   Revision: 00014014    Serial number: 00000000000000
   VCID: 3A2D3778A05A504B5DF-806E
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Part No SW: 5K0 937 085 D    HW: 5K0 937 085 D
   Component: BCM PQ35 B+   011 0029
   Revision: BB011001
   Coding: 46180A3E9005B0904688008091000004050100A8425D81605C80C7000001
   VCID: 343119408E3EA63B873-8060
   Subsystem 1 - Part No: 1P0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 25031  22  0611
   Coding: 00DB90
   Subsystem 2 - Part No: 1P0 951 171
   Component: Innenraumuebe  010 4971
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__A0E VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P20Q3C1
   Coding: 0012357
   Shop #: WSC 06402 785 00200
   VCID: 44D14980D29E16BB373-8010
   Subsystem 1 - Serial number: 6332MTS646180470
   Subsystem 2 - Serial number: 6342MTS643450470
   Subsystem 3 - Serial number: 6351HTS6H55M69KJ
   Subsystem 4 - Serial number: 6361HTS6OH4O69KJ
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           856 0111
   Coding: 0000532
   VCID: 78A9ED70DED6825B6BB-802C
   Subsystem 1 - Part No: 1P0 959 538 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H02 0101
   Coding: 00000226
00895 - Cruise Control Switch (E45)
            014 - Defective
   Part No SW: 1P0 920 953 B    HW: 1P0 920 953 B
   Component: KOMBI         H07 0307
   Coding: 410A00
   VCID: 2F3B162C679885E3FA1-807A
   Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
   Component: J533  Gateway   H17 0233
   Revision:   H17       Serial number: 1521J1031902A6
   Coding: E9801F06000612040203
   VCID: 6B83C23C9F8039C3969-803E
   Component: IMMO          H07 0307
   VCID: 6A8DC7389CFA20CBEDF-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667937155
   Coding: 020000
   VCID: 2615F30848E2C4AB097-8072
   Part No SW: 1T0 959 701 AD    HW: 3C0 959 793
   Component: TUER-SG FT    002 0306
   Revision: 13101005    Serial number: 0000216149
   Coding: 020230
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 79AFE874E95C9B53145-802C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 65     3001
   Revision: 00H17000
   VCID: 313F10547D2C9313EC5-8064
   Part No SW: 1T0 959 702 AB    HW: 3C0 959 792
   Component: TUER-SG BT    002 0306
   Revision: 15101005    Serial number: 0000435963
   Coding: 020230
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 78A9ED70D256825B6BB-802C
   Part No SW: 1P0 035 153 B    HW: 1P0 035 153 B
   Component: Radio G3 UL   H59 0060
   Revision: 0H001001    Serial number: SEZ1Z2K6546968
   Coding: 0102040004
   VCID: 2411E9003EDE36BB173-8070
   Part No SW: 1K0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H17 0233
   Revision: --------    Serial number: 1521J1031902A6
   Coding: 030B085A
   VCID: 6889BD30827612DBFBB-803C
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790170325
00458 - Control Module for Battery Monitoring (J367)
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 169
                    Mileage: 273698 km
                    Date: 2014.12.23
                    Time: 18:04:50
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
   Component: FSE_2P8x        H40 0190
   Revision: 00000000    Serial number: 00000005235817
   Coding: 0010555
End----------(Elapsed Time: 01:17, VBatt start/end: 12.1V/12.1V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
could you have a look at the coding of the module 16; perhaps cruise control is ticked yet not installed?
Baps McGinty
Ireland
C?ID=407250
will do. wont have access to the car until tomorrow though. Thanks for the tip.
Baps McGinty
Ireland
C?ID=407250
Hi iichel
Spot on with your tip. Coding for steering wheel was looking for the Cruise Control connected to the stalk,(3), changed the coding to not installed,(0) and no more fault code.
Top man ��
Eindhoven eh? Do you know Diagnose Dan? ����
