VW T-ROC full scan
Daniel Guerra
Portugal
C?ID=230512
Hi all,
I purchased a new car a VW T-ROC and for curiosity, I did a full scan. It does the scan but now I have a message that I never had before: "Unsupported vehicle.Please upgrade to a current Ross-Tech interface."
Does this mean I can't continue to use my interface?
Here is a full scan:
Thursday,06,August,2020,19:07:27:09177
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.2.0 (x64)
VIN: WVGZZZA1ZLV161940   License Plate:
Chassis Type  A1 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 3C 42 44 4B 52 5F A5 BB BC
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DGTE)       Labels: None
   Part No SW: 04L 906 056 TH    HW: 04L 907 445 G
   Component: R4 1.6l TDI   H01 6987
   Revision: 22102001
   Coding: 0119403243441D092000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM16TDI03004L906056TH 004001
   ROD: N/A
   VCID: 0603B84EB904F4B629-8053
No ASAM data for: "EV_ECM16TDI03004L906056TH" ()
Readiness: N/A
   Part No SW: 5Q0 614 517 DK    HW: 5Q0 614 517 BN
   Component: ESC           H35 0113
   Revision: 00000000    Serial number: 61720000003469
   Coding: 46FA6A7D90260C6D4780060462C32562560930E26046A4733440F078D0A24B0B00000523525212121035351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
   ROD: N/A
   VCID: 7DF1D7A2ECD2B76E78-8029
No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
Address 08: Auto HVAC (J255)       Labels:. 5G0-907-044.clb
   Part No SW: 5G0 907 044 FP    HW: 5G0 907 044 FP
   Component: Climatronic   H04 2401
   Revision: 00001K10
   Coding: 060201042001100D1105000000101032
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   ROD: N/A
   VCID: 7AFBDCBEFDFC80565D-802F
No ASAM data for: "EV_ACClimaBHBVW37X" ()
   Part No SW: 5Q0 937 084 DL    HW: 5Q0 937 084 DK
   Component: BCM MQBAB MxL H42 0312
   Serial number: 01102017001846
   ASAM Dataset: EV_BCMMQB 020001
   ROD: N/A
   VCID: 0501BF428402FFAE20-8051
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054  0206
   Serial number: SBY20M06D10H11M53S40
   Coding: 0018DD
   Subsystem 2 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY200752QQP
   Subsystem 3 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004  0007
   Serial number: 00000000000001083259
   Subsystem 4 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0100010320200C106877
No ASAM data for: "EV_BCMMQB" ()
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058320077
   Coding: 0471055801
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: N/A
   VCID: 50AF5E160BC0EA06C3-8005
No ASAM data for: "EV_EPHVA18AU3700000" ()
Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 2A04604250FF8748949C810560408700000000000000000004
   ROD: N/A
   VCID: 4385615ACAB6019E4E-8017
No ASAM data for: "EV_ACCMRRCONTIVW376" ()
Address 15: Airbags (J234)       Labels:. 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CS    HW: 3Q0 959 655 CS
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z7P9H60P+
   Coding: 88CCC0C0000000005C5400CF000800000065
   Shop #: WSC 00020 043 00000
   ROD: N/A
   VCID: 11299B12C04AA30E8C-8045
   Component: BeltPretRevFL  106 1040
   Serial number: 2GA857705B0169U00106
   Coding: 80000D
   Component: BeltPretRevFR  106 1040
   Serial number: 2GA857706B0170U00437
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 005 20
   Serial number: 3570000000076D65E74Y
   Subsystem 4 - Part No SW: -----------    HW: 454 001 805 20
   Serial number: 35800000000C8245874N
   Subsystem 5 - Part No SW: -----------    HW: 454 800 803 20
   Serial number: 351004F88D21A000000R
   Subsystem 6 - Part No SW: -----------    HW: 454 800 903 20
   Serial number: 35200FB993B1B000000.
   Subsystem 7 - Part No SW: -----------    HW: 454 800 903 20
   Serial number: 35500186E451B000000K
No ASAM data for: "EV_AirbaVW21TS6VW48X" ()
Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
   Part No SW: 2GA 920 741 B    HW: 2GA 920 741 B
   Component: KOMBI         204 6700
   Coding: 05A402066F8C00080188630B5001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: N/A
   VCID: 3365319A9A16B11EDE-8067
No ASAM data for: "EV_DashBoardVDDMQBAB" ()
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4388
   Revision: --------    Serial number: 0000952405
   Coding: 030100044F0873002200025C080F00010001070000000000000000000000
   ROD: N/A
   VCID: 70EFFE96AB80CA06E3-8025
   Component: 4-01-13-01-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 1632009141000304FJ2B
   Coding: 2C0000
   Component: J367-BDMHella  H11 9070
   Serial number: 9759914705
No ASAM data for: "EV_GatewNF" ()
Address 3C: Lane Change (J1086)       Labels: None
   Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
   Component: HRE3_Kl15_Mst H05 0052
   Serial number: 14520002652879
   Coding: 50014500
   ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
   ROD: N/A
   VCID: 387F06B683705246EB-806D
No ASAM data for: "EV_HREntryHellaGen3Kl15" ()
Address 42: Door Elect, Driver (J386)       Labels: Redir Fail!
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000412208976
   Coding: 00310220D000028000001000
   ROD: N/A
   VCID: 4D9147621CF2C7EEA8-8019
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000041106338
No ASAM data for: "EV_DCU2DriveSideMAXHCONT" ()
Address 44: Steering Assist (J500)       Labels:. 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 151F0000
   ROD: N/A
   VCID: 74E7F286DF98F62607-8021
No ASAM data for: "EV_SteerAssisMQB" ()
Address 4B: Multifunc. Module
Interface not compatible.
Address 52: Door Elect, Pass. (J387)       Labels: Redir Fail!
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000412419774
   Coding: 00310020DC00028000001000
   ROD: N/A
   VCID: 4C974A66E7E8CEE6BF-8019
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000041250910
   Coding: 190000
No ASAM data for: "EV_DCU2PasseSideMAXHCONT" ()
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 846 B    HW: 3Q0 035 846 B
   Component: MU-S-N-ER     854 0876
   Coding: 02720601BE0000004111000100080A001F0500C4012001008F
   ROD: N/A
   VCID: 306F3E966B008A06A3-8065
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  361 8214
   Serial number: VWZ6ZHX1770788
   Subsystem 2 - Part No SW: 5NA 919 866 S    HW: -----------
   Component: ECE1 2020  --- 1310
No ASAM data for: "EV_MUStd4CDELP" ()
Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H13 0610
   Serial number: 10062015K11977
   Coding: 0002070600000401002213548150A90094000E20002000
   ROD: N/A
   VCID: 408F6E56DBA01A8653-8015
No ASAM data for: "EV_MFKBoschMQBB" ()
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End-------------------------(Elapsed Time: 05:43)--------------------------
Yes, that's a model year 2020 car. You will need one of our current interfaces.
Discounted, trade-in upgrades are available here, or contact your distributor.
PS: Car doesn't appear to be broken. Moving to a more appropriate section.
