2012 Audi A6
Farivar
C?ID=413168
Hi. i bought this car 2 weeks ago. in couple days after purchase , some issue show up.
First , when i turn on the engine in morning ,i feel strange smells (like gas).
second , some times driver side blind spot didnt work corectly (without message) but most of the time it work corectly , and 3rd , acc and braking assist didnt work and message says acc and audi braking guard: unavailable! but some times it work randomly.
after i recieved my Hex-V2 , i scan it and vcds showed me that:
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 20.4.2(x64) Data version: 20200730 DS317.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Tuesday,04,August,2020,22:11:35:17634
VIN: WAUHGAFC3CN151926 License Plate: Mileage: 170231km-105776mi Repair Order:
Chassis Type: FC-AU57 (4G0) Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90
VIN: WAUHGAFC3CN151926 Mileage: 170231km-105776miles
01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 3B-Sensor Elect. -- Status: Malfunction 0010 3C-Lane Change -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 6C-Back-up Cam. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 85-On Board Cam. -- Status: OK 0000 8B-Adaptive Cruise 2 -- Status: Malfunction 0010 8E-Image Processing -- Status: Malfunction 0010 8F-Pretens. Frt Left -- Status: Malfunction 0010 90-Pretens. Frt Right -- Status: Malfunction 0010 ------------------------------------------------------------------------------
after that , i cleared the codes and in new scan , just 3 fault show up:
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb Part No SW: 4G0 907 561 A HW: 4G0 907 561 Component: ACC3 H17 0400 Serial number: 00000000000000 Coding: 3601010202 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_AdaptCruisContrAU57X 002010 ROD: EV_AdaptCruisContrAU57X_002.rod VCID: 2809FC8A1277556B3A3-807C
1 Fault Found: 93440 - Function Restriction due to Faults in Other Modules U1113 00 [009] - [FAULT_CIS_VIDEO_FAIL] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 60 Mileage: 170231 km Date: 2020.08.03 Time: 22:16:37
Control Module temperature: 25 °C Voltage terminal 15: 14.295 V Velocity_vehicle_reference: -0.01 m/s Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 4G0 035 746 C HW: 4G0 035 746 Component: H-BNT-NA H48 0423 Revision: -------- Serial number: 031CH0C7533112 Coding: 050200000003E9EF75128B3E00000003100001000000000000 Shop #: WSC 02391 785 00200 VCID: 270BFFB61FE95A13339-8072
Subsystem 1 - Part No: 8R0 060 884 AD Component: NAR 2011 0505
Subsystem 2 - Part No SW: 4G0 919 605 D HW: 4G0 919 605 D Component: DU8 C7 SV H63 0060 Serial number: AUZ8ZDEAL002Q6
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 C Component: E380 BDT C7 H11 0204 Serial number: 90349LCG000RQ
Subsystem 4 - Part No: 8R0 060 961 B Component: CD-Database 3371
1 Fault Found: 03276 - Please Check Software Version Management 000 - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 60 Mileage: 170231 km Time Indication: 0 Date: 2020.08.03 Time: 22:16:39
Freeze Frame: Text: DUA009,Front,A,3c,15,1
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb Part No SW: 4G0 907 107 D HW: 4H0 907 107 Component: BV-SG H30 0038 Serial number: 005000051403127 Coding: 048198180111 Shop #: WSC 02391 785 00200 ASAM Dataset: EV_BC7 001001 ROD: EV_BC7.rod VCID: 270BFFB61F695A13339-8072
1 Fault Found: 0080 - Video Cable for Image Processing C1107 02 [009] - Signal Failure [No_connection_to_camera] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 60 Mileage: 170231 km Date: 2020.08.03 Time: 22:16:37
Outside air temperature: 19.5 °C Voltage terminal 15: 14.3 V Control Module temperature: 27.0 °C
what can i do?
sorry about my bad english. im new in US.
Hi and welcome.
Please post a complete Auto-Scan.
Please copy it directly from VCDS or from Notepad. I'm not sure what software you passed the above through, but it removed most of the line breaks and made an unreadable mess.
Farivar
C?ID=413168
oh ok sorry for my mistake and thanks for your respond. nice to meet you.
i dont have first one before clear codes now but the new one is:
Thursday,06,August,2020,15:58:44:17634
VIN: WAUHGAFC3CN151926   Mileage: 170414km-105890miles
Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSI  H07 0006
   Revision: --H07---
   Coding: 0A2A0034056600060000
   ASAM Dataset: EV_ECM30TFS0214G0907551A 002007
   ROD: EV_ECM30TFS0214G0907551A_002.rod
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 AJ
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 3B2333C6F3E1EEF3471-806E
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 44A70F0122E5F0804B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 38292CCAC2D7C5EBAA3-806C
   Part No SW: 4H0 907 064 BR    HW: 4H0 907 064 BR
   Component: BCM2 2.0      H31 0333
   Coding: 0D882006000000000000
   VCID: 7AADF6C2BCDB17FB1C7-802E
   Serial number: 2312000049758003
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H12 0064
   Serial number: 18031200040230
   Coding: 6601207A4C
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0111
   Revision: 11012002    Serial number: 00000001435517
   Coding: 09072091073C9FE281000884A0003800CF9CD208A20801258001085C3B00
   VCID: 77ABEFF68FC90A93639-8022
   Component: WWS57X 120217  H35 0080
   Serial number:         120308112854
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20105294
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 12 03 2012  00001896
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R18WW02
   Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
   Component: SLR-B8  H06 0007
   Serial number:           0025429053
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000019031200010853
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000012031200010955
   Coding: 110000
   Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103085000001108146
   Coding: 020300
   Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 05184C16000000000001
   Part No SW: 4H0 919 475 N    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0050
   Revision: 11001001    Serial number: 55901206902417
   Coding: 280906
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3D273DDEEDF5E0C3795-8068
   Coding: 3601010202
          U1113 00 [009] - -
                    Fault Frequency: 15
                    Reset counter: 64
                    Mileage: 170231 km
                    Date: 2020.08.03
                    Time: 22:26:47
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 14.206 V
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D8001Y0P+
   Coding: 303234373131303030324A55304C34473053
   VCID: 33331BE6DBB126B39F1-8066
   Serial number: 6940000Y150001FF0U0Y
   Serial number: 3575HRB405B1775489HO
   Serial number: 3585HRB405B1775479JQ
   Serial number: 3515JRB40184UHGC6HIW
   Serial number: 3525JRB400C4UHL8CHD
   Serial number: 3554VRB405P18E5GI9H-
   Serial number: 3564VRB405P18E5GFO9+
   Revision: --------    Serial number: 90372LC90023G
   Coding: 00003C
   VCID: 372B2FF6CF49CA93A39-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
   Serial number: 13 02 2012  11205944
   Part No SW: 4G8 920 982 T    HW: 4G8 920 982 T
   Component: TBenUsaAcc    H79 0416
   Revision: 28460177    Serial number: 658060312596027
   Coding: 0BC609040F01D705020000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K_AU57.rod
   VCID: 45D7553E8525A803215-8010
   Part No SW: 4G0 907 468 G    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000439160
   Coding: 00C1033000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 343118FADEBF218B86B-8060
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790525608
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0064
   Serial number: 19031200040084
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 2F3B179637990253FB9-807A
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000025318268
   Coding: C0581B008F002001000001010101102030303232203232
   VCID: 38292CCAC257C5EBAA3-806C
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0009
   Revision: --------    Serial number: EJ1BPA42046WGF0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 2D070D9E3D957043C95-8078
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 303914EA26271DABE23-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F15.03.1200H020003CF24853ÿ
   Subsystem 4 - Serial number: F24853ÿ
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F17205E00628002000013
   VCID: 41DF412E918D84231DD-8014
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0028407020
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1EE224AB2FBB947-8066
   Revision: 00002001    Serial number: 0172525773
   Coding: 0106023A00FA448580B00880020500000000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000076432
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO1552404
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00001025316
   Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0130
   Revision: CJ007000    Serial number: 00000000040672
   Coding: 030000
   VCID: 1C61D05A56AF89CBAEB-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F17205E00628002000002
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000281988
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D06820C7B677B2C7-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120316-0004-036
   Coding: 1221A6601002A400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C01009A068F794BDEB-8078
   Part No SW: 4G0 035 082 C    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0101
   Revision: AB001007    Serial number: 236C 0C7519581
   Coding: 020007010000000001
   VCID: 2019E4AA7AC7AD2B723-8074
                    Reset counter: 61
                    Mileage: 170231 km
                    Date: 2020.08.03
                    Time: 22:26:48
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F17204000628002000002
   VCID: 44D1483A8E9F910B36B-8010
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 C    HW: 4H0 907 441 B
   Component: SG Rueckfahrkamera  0161
   Revision: --H05---    Serial number: 525 PA8J22G633
   Coding: 1080004
   VCID: 270BFFB613E95A13339-8072
   Component: TSG HR        H04 0212
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H25 0036
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B5BE25E58803C15-8030
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 3601010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   VCID: 2615F2B21863431B08F-8072
   ROD: EV_BC7.rod
          C1107 02 [024] - Signal Failure
                    Reset counter: 61
                    Mileage: 170231 km
                    Date: 2020.08.03
                    Time: 22:26:49
                    Outside air temperature: 20.0 °C
                    Control Module temperature: 30.0 °C
0161 - Video Cable for Image Processing
          [No_camera_found_on_startup]
                    Reset counter: 64
                    Mileage: 170231 km
                    Date: 2020.08.03
                    Time: 22:27:26
                    Voltage terminal 15: 13.2 V
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 313F11EE21AD14A3EDD-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
End----(Elapsed Time: 02:37, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
Gas smell: There are some recalls on these cars pertaining to fuel lines. Check with a dealer to see if any of them are still open on this particular car.
ACC and Braking Guard: This is due to the C1107 Video Cable failure. Inspect ends of the cable, repair as needed, or replace cable. This is a fairly common fault.
Blind Spot monitoring: I see no obvious reason for it. Wait until the problem occurs again and then make another scan.
Farivar
C?ID=413168
thanks a lot. i appreciate it.
Farivar
C?ID=413168
just last question: where can i find that cable? where is it?
sorry i had 2003 0pel omega before so i dont familliar with audi before.
