RS6 Faults / Active Cruise Problems
sammi_s
United Arab Emirates
C?ID=223403
Hey everyone,
I recently purchased a 2014 C7 RS6, got the car for good value. Had the car compression tested and leak down and that was perfect so I bought the car as it was mechanically excellent but have some fault codes with one MAJOR MAJOR problem, my Adaptive cruise control and Brake guard fault comes on the dash and does not work and I have tried the following:
- Connected a new cable from the image processor to the camera and nothing, the code still comes up.
- Replaced the camera with another used camera, still nothing the code still comes up (a new camera is 15 days order and super expensive in UAE)
- Checked all the wiring seems ok and cant seem to figure out the problem. any help would be amazing because I really want the cruise control to work.
Also the trunk issue is confusing me, I recalibrated everything code went away and now back again.
Sunday,26,July,2020,18:15:49:02798
VCDS Version: 20.4.1.0 (x64)
VIN: WUA82DFC2EN901082   License Plate: RS
Mileage: 128246km-79688mi   Repair Order: Rs
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B 3C
          42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 85 8B 8E 8F 90 BA
VIN: WUA82DFC2EN901082   Mileage: 128246km-79688miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560     HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0012
   Revision: NCH62---
   Coding: 122A003265460B0A1000
   Shop #: WSC 23688 002 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906560 001013
   ROD: EV_ECM40TFS0114G0906560.rod
   VCID: 65C1DB64646B28AE98-8030
Readiness: 1110 1101
   Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H16 1007
   Revision: --H16---
   VCID: 71E9BF34A0A3F40EF4-8024
   Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
   Component: ESP PREMIUM   H09 0100
   Coding: 64BF890126FD9180CB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004036
   VCID: 3E735408A17D5B7639-806A
   Part No SW: 4H0 907 064 DT    HW: 4H0 907 064 DT
   Component: BCM2 2.0      H35 0510
   Coding: 05A92F06000000000000
   VCID: 7EF39408E9FD9B7679-802A
   Part No SW: 4G0 820 043 AD    HW: 4G0 820 043 AD
   Component: KLIMA 4 ZONEN H13 0088
   Serial number: 23081300040090
   Coding: 680220780D
   ASAM Dataset: EV_AirCondiComfoUDS 002043
   VCID: 61C9CF747043448E64-8034
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001619772
   Coding: 0907201009749FF2B98100C4A0001800CF9CC7082E080201800108546F01
   VCID: 6FEDB94CBE97E2FEE2-803A
   Component: WWS57X 130715  H36 0080
   Serial number:         130821080637
   Coding: 0045F7
   Serial number: 21666342
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 29 08 2013  00000977
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000020081300010247
   Coding: 110000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000030071300010701
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA106232000004383150
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: B6F843C6000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4H0 919 475 AB    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0060
   Revision: --------    Serial number: 56231323901502
   Coding: B80B1B
   ASAM Dataset: EV_EPHVA2CAU57X0000 002012
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 72EBB038A5A5CF160D-8026
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H19 0410
   Coding: 7E04010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 285F925053F9F5C663-807C
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
                    Reset counter: 164
                    Mileage: 128246 km
                    Date: 2020.07.26
                    Time: 17:35:02
                    Control Module temperature: 62 °C
                    Voltage terminal 15: 12.489 V
Address 14: Susp. Elect.        Labels: None
   Part No SW: 4G0 907 376     HW: 4G0 907 376 A
   Component: J250 DRC FahrwerH01 0040
   Revision: 00000000    Serial number: 00894015097400
   Coding: 0000000
   VCID: 6BD5AD5C4A8F1EDECE-803E
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00EK51Z
   Coding: 3032343631334E303438554A304C34473053
   VCID: 36634C28894D9336E1-8062
   Serial number: 3575HRB400U50JEC897B
   Serial number: 3585HRB400450J5SCHEC
   Serial number: 3515JRB401C50LKOF8LU
   Serial number: 3525JRB401I50LKOFABT
   Serial number: 3554VRB405322HCSJO9$
   Serial number: 3564VRB405722HCSNOTP
   Revision: --------    Serial number: 90372MHU000DZ
   Coding: 00003D
   Shop #: WSC 00469 128 08858
   VCID: 377D412C86476A3EFA-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 19 07 2013  D0272836
   Part No SW: 4G0 920 931 B    HW: 4G0 920 931 B
   Component: TBenRdwAccNv  H80 0618
   Revision: 30460232    Serial number: 658300813596048
   Coding: 538F110BAFC10008010400
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 25419B6424EBE8AE58-8070
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000001071112
   Coding: 00E5074800
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 8984701103
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 13061000000000000379
   Part No SW: 8K0 907 144 L    HW: 8K0 907 144 L
   Component: DYNAMIKLENK.  H06 0720
   Revision: 52001005    Serial number: --------------
   Coding: 010100
   VCID: 387F42108B596546F3-806C
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   VCID: 7CF79E00FFE1896657-8028
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0200
   Serial number: 002108130001211
   Part No SW: 4G0 919 158 J    HW: 4G0 919 158 J
   Component: KLIMA FOND    H07 0088
   Serial number: 29081300041757
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002021
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000071533404
   VCID: 77FD812CC6C7AA3E3A-8022
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E00LX4U
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 377D412C8E476A3EFA-8062
   Part No SW: 4G0 907 566 K    HW: 4G0 907 566
   Component: J769  SWA MasterH04 0010
   Revision: 00H04000    Serial number: 6PZ 010 287-09
   Coding: 0000005
   VCID: 377D412C46476A3EFA-8062
   Subsystem 1 - Part No: 4G0 907 568 K
   Component: J770  SWA Slave H04 0020
   Subsystem 2 - Serial number: 6PZ 010 287-29
   Subsystem 3 - Serial number: 5F24.07.1300H04000AMS14086ÿ
   Subsystem 4 - Serial number: S14086ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011F1E005E00628002080013
   VCID: 45813BE4CCAB08AE78-8010
   Component: RCEPS         H38 0010
   Revision: 00001000    Serial number: 0017775118
   Coding: 011100010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326B703865258F16CD-8066
   Revision: 00002001    Serial number: 0312359906
   Coding: 013A0E20A0B93095833009840E0312470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.008  H02 0007
   Serial number:     WOO2327218%
   Coding: 901F00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00004297376
   Subsystem 5 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.008  H02 0007
   Serial number:     WOO2327225/
   Coding: 801F00
   Subsystem 6 - Part No SW: 3AA 962 243 B    HW: 3AA 962 243 B
   Component: GEB.F.Heckoef  H16 0810
   Serial number: 93002408
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 164
                    Mileage: 128246 km
                    Date: 2020.07.26
                    Time: 17:35:05
   Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
   Component: BO G3 C7      H09 0160
   Revision: 11000000    Serial number: 0017594
   VCID: 25419B642CEBE8AE58-8070
   Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
   Component: BO C7 SLAVE  H51 0100
   Serial number: 00207130024410
   Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
   Component: TSG BF        H04 0507
   Coding: 011F1E005E00628002080002
   VCID: 448726E0C79131A66F-8010
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000800168
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C576E404701D9E687-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 130824-0002-036
   Coding: 1122A6601002B300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2D5163447C1BD0EE90-8078
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227H+0D7847250
   Coding: 070003010000000001
   VCID: 26439C6851EDE3B651-8072
   Part No SW: 4G0 035 764 K    HW: 4G0 035 764 H
   Component: H-BNT-RW      H51 0732
   Revision: --------    Serial number: 192H-0D7504137
   Coding: 070D00010303E9EF75908B2E00000003740001020000000000
   VCID: 2F6D794C7E17A2FEA2-807A
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD0023Y8W
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349PGL00055
   Component: CD-Database  5298
                    Reset counter: 164
                    Mileage: 128246 km
                    Date: 2020.07.26
                    Time: 17:35:05
                    Text: KBD_FC7,KBD,A,fa,cc,1
   Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
   Component: TSG HL        H03 0507
   Coding: 010F1C004000628002080002
   VCID: 479D31ECF6A71ABE8A-8012
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273     HW: 4H0 907 273
   Component: RDKBERU25     H09 0700
   Serial number: 10000000003585
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 68DFD250937935C6A3-803C
   Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
   Component: TopView       H05 0220
   Revision: 11001001    Serial number: 82330JF0103840
   Coding: 0203000101010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
   ROD: EV_CamerSysteTopViewAUDI_007.rod
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 235301198
   Coding: 097205C010
   ROD: EV_HDSGAu571.rod
   VCID: 35614B24944B982EE8-8060
0114 - Load Space Cover
          B12EF 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 164
                    Mileage: 128246 km
                    Date: 2020.07.26
                    Time: 17:35:01
                    Voltage terminal 30: 12.40 V
   Component: TSG HR        H03 0507
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 26439C6859EDE3B651-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H19 0400
   Coding: 7E04010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   Part No SW: 4G0 907 107 E    HW: 4H0 907 107
   Component: BV-SG         H32 0041
   Serial number: 005000121608137
   Coding: 04809A1B0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
                    Reset counter: 164
                    Mileage: 128246 km
                    Date: 2020.07.26
                    Time: 17:35:11
                    Outside air temperature: 39.5 °C
                    Voltage terminal 15: 12.5 V
                    Control Module temperature: 51.0 °C
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 31697F346023B40EB4-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H07 0006
   Revision: 00001001    Serial number: 97809002397000
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X.rod
   VCID: 66C3DC68996D23B691-8032
1294 - Actuator 1 for Drivetrain Mounts
          C1131 07 [009] - Mechanical Failure
                    Reset counter: 164
                    Mileage: 128246 km
                    Date: 2020.07.26
                    Time: 17:35:03
End-------------------------(Elapsed Time: 07:32)--------------------------
now since the scan I have fixed the following:
5F
03276 - Please Check Software Version Management .FIXED and GONE
Address BA:
1294 - Actuator 1 for Drivetrain Mounts .ordered new mounts for this code
01134 - Alarm Horn (H12) .ordered new alarm (wiper cover area I believe)
Please guys any help would be greatly appreciated.
ACC and Brake Guard not working is a side-effect of the video fail.
Since you've already replaced the camera and the cable, I'm not sure what to tell you about the Video Cable fault.
