Volkswagon passat b8 2012
zeeshan
C?ID=327143
Hi all got issuse with this car is the orignal ecu went dead on it so coustmer supplied 2nd hand with same part number but it was out from touran automatic.
know i got it coded to the car but got these fault and on long codeing for ecu to make changings it wont allow me to change.Can someone help me out thanks
Tuesday,04,August,2020,18:18:35:56296
VIN: WVWZZZ3CZDE035479   License Plate: SB62
Mileage: 194830km-121061mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61 62
          72
VIN: WVWZZZ3CZDE035479   Mileage: 194830km-121061miles
15-Airbags -- Status: Not registered 0011
   Part No SW: 03L 906 023 NR    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9977
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00254034032501080000
   ASAM Dataset: EV_ECM16TDI02103L906023NR 003010
   ROD: GV_ECM16TDI021PQ36.rod
   VCID: 0352780D4B98A6934F1-8056
6013 - Brake Switch (F)
          P0571 00 [237] - Implausible Signal
                    Mileage: 194795 km
                    Date: 2020.08.04
                    Time: 01:19:05
                    Engine speed: 1104.25 /min
                    Normed load value: 8.2 %
                    Coolant temperature: 66 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 14.456 V
                    Engine speed: 1104 /min
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 14.5 V
                    Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                    Number of resets of main unit-CTR_RST_MC: 0
6088 - No Communication with Transmission Control Module
          U0101 00 [173] - -
                    Fault Frequency: 20
                    Mileage: 194795 km
                    Date: 2020.08.04
                    Time: 00:09:41
                    Engine speed: 0.00 /min
                    Coolant temperature: 79 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 11.859 V
                    Control Module temperature-TECU: 30 °C
6082 - Steering Column Control Module
          U0212 00 [045] - No Communications
                    Fault Frequency: 29
                    Mileage: 194795 km
                    Date: 2020.08.04
                    Time: 00:09:41
6342 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
          P0030 00 [237] - Malfunction / Open Circuit
                    Fault Frequency: 17
                    Mileage: 194795 km
                    Date: 2020.08.04
                    Time: 01:17:02
                    Engine speed: 784.25 /min
                    Normed load value: 45.1 %
                    Coolant temperature: 60 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 14.344 V
                    Oxygen sensor controller register-STATE_LSL_IF_SPI_RD[1]: 228
                    Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor): 0.504 Lambda / 0.000 V
                    O2 sensor 1 bank 1: duty cycle O2 heater-LSHPWM_UP[1]: 3.515625 %
                    Oxygen sensor 1 bank 1 ceramic temp-TTIP_MES_LS_UP[1]: 500.0000 °C
                    Time since engine start: 58 s
                    Battery voltage: 13.2 V
                    Exh gas press sensor 1: uncond voltage value-PRS_EX_PCAT_UP: 1003.47 hPa
6394 - Oxygen (Lambda) Sensor B1 S1: Negative Lead
          P2251 00 [101] - Open Circuit
                    Mileage: 194821 km
                    Date: 2020.08.04
                    Time: 20:55:06
                    Engine speed: 1726.25 /min
                    Normed load value: 24.7 %
                    Vehicle speed: 101 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 13.327 V
                    Oxygen sensor controller register-STATE_LSL_IF_SPI_RD[1]: 108
                    Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor): 0.502 Lambda / 0.000 V
                    Oxygen sensor enhancement adaptation factor-FAC_LSL_GAIN_AD[1]: 0.97986
                    Oxygen sensor 1 bank 1 ceramic temp-TTIP_MES_LS_UP[1]: 975.0000 °C
                    Time too low oxygen sensor voltage-T_VLS_UP_MIN_DIAG_OC_LSL_UP[1]: 0.0 s
                    Oxygen value calculated-LAMB_EXT_CLC_FIL: 2.2705
                    Exh gas press sensor 1: uncond voltage value-PRS_EX_PCAT_UP: 1048.41 hPa
Readiness: 1 2 0 0 0
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V436 0024
   Revision: --H07---    Serial number: 00000006114870
   Coding: 0002983
   Shop #: WSC 05311 000 00000
   VCID: 71BE22C56DA4A403ADD-8024
                    Reset counter: 54
                    Mileage: 194833 km
                    Date: 2014.12.26
                    Time: 22:31:47
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 54
                    Mileage: 194833 km
                    Date: 2014.12.26
                    Time: 22:31:47
   Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010004003
   Shop #: WSC 00015 115 00000
   ROD: EV_ACManueBHBVW36X_VW46.rod
   VCID: 7AAC05E93C52E75B1C7-802E
          U1111 00 [008] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2020.08.04
                    Time: 00:00:16
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 F    HW: 3AA 937 087 F
   Component: BCM PQ47 M    421 0465
   Revision: BA421001
   Coding: 0008000000000000009800801000006403010088424D81606480C7200041
   VCID: 3D26CEF56D7C1063795-8068
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 22081  26  0612
   Coding: 00B795
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:00:17
                    Voltage: 12.15 V
01800 - Light Switch (E1)
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:15:38
                        Term 15 Off
                    Voltage: 12.00 V
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:18:51
                        Term 15 Off
                    Voltage: 11.95 V
03678 - Coordinator for Start-Stop Operation
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:00:18
                    Voltage: 12.15 V
   Component: J234__108 VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PHCUCUS
   Coding: 0012344
   VCID: 7CA003F13AE6D96B0EB-8028
   Subsystem 1 - Serial number: 6332MTS633172222
   Subsystem 2 - Serial number: 6342MTS615982202
   Subsystem 3 - Serial number: 6351HTS6JD47ABKJ
   Subsystem 4 - Serial number: 6361HTS6EVSC9BKR
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                    Fault Status: 11100001
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:28:39
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:28:39
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 93
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:28:37
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BF    HW: 5K0 953 569 S
   Revision: FF010041    Serial number: 20120614300562
   Coding: 1182050000
   Shop #: WSC 00015 115 12345
   VCID: 6A8C35A94CF257DBEC7-803E
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
1140738 - Steering angle sensor
                    Reset counter: 52
                    Mileage: 194795 km
                    Date: 2020.08.04
                    Time: 00:28:38
                    UBat: 12.60 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
   Part No SW: 3AA 920 970 J    HW: 3AA 920 970 J
   Component: KOMBI         H05 0705
   Coding: 461F00
   Shop #: WSC 05314 115 00000
   VCID: 3A2CC5E97CD2275B5C7-806E
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2020.08.04
                    Time: 00:00:15
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 270512F1000694
   Coding: 462007
   Shop #: WSC 05314 123 12345
   VCID: 41DEB205118474831DD-8014
                    Fault Frequency: 13
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:00:17
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         045 0400
   Revision: 00045000    Serial number: VWZCZ000000000
   Shop #: WSC 06402 785 00200
   VCID: 76B411D904CA833B78F-8022
01176 - Key
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:58:48
   Revision: A1001003    Serial number: 7663315537
   Coding: 020100
   Shop #: WSC 05314 000 00000
   VCID: 2A0CF5A98CF297DB2C7-807E
                    Reset counter: 91
   Part No SW: 3C0 035 279 M    HW: 3C0 035 279 M
   Component: RNS315-EU   H52 0319
   Serial number: VWZAZ2M5989503
   Coding: 040004010400110000019002
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 2D06FEB5BD9C80E3C95-8078
   Component: EUR_W_0038  0038
   Part No SW: 3AA 959 701     HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0534
   Revision: 13110009    Serial number: 0005268567
   Coding: 0202B5
   Shop #: WSC 05311 115 00000
   VCID: 74B02BD11E36912B46B-8020
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003096403
   Coding: 010290
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 51
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 194    3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 372ADCDD43403A33A39-8062
                    Fault Status: 11100101
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:28:37
                    Battery Volts: 12.5 V
                        DU
                    Temperature: 29.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:00:16
                    Voltage: 12.25 V
                        DU
                    Temperature: 28.0°C
                    RPM: 1498 /min
   Component:    KSG PQ47 ELV 045 0634
   Coding: 0191020052830E76340494157C085FCE105C01
   Shop #: WSC 19310 607 00002
   Component: Neigungssensor  004 0611
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 00000008
   VCID: 6FBA24BD7790B2F3BB9-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0004
   Part No SW: 3AA 959 702     HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0534
   Revision: 15110009    Serial number: 0005264912
   Coding: 0202B4
   VCID: 75B616D5154C8823715-8020
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003093730
   Coding: 010290
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [008] - Electrical Failure
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2020.08.04
                    Time: 01:06:46
   Revision:   H19       Serial number: 00000000406531
   Coding: 0010000
   VCID: 3634D1D9444AC33BB8F-8062
                    Fault Status: 01110000
                    Reset counter: 54
                    Mileage: 116273 km
                    Date: 2013.09.06
                    Time: 00:26:42
                    Voltage: 12.00 V
                    Count: 98
                    Hex Value: 0x1243
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 54
                    Mileage: 116273 km
                    Date: 2013.09.06
                    Time: 00:26:42
                    Voltage: 12.00 V
                    Count: 41
                    Hex Value: 0x1243
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Status: 01110101
                    Reset counter: 54
                    Mileage: 116273 km
                    Date: 2013.09.06
                    Time: 00:26:42
                    Voltage: 12.00 V
                    Count: 99
                    Hex Value: 0x1243
                    Hex Value: 0x0001
                    Hex Value: 0x1010
03182 - Clutch Position Sensor (G476)
            010 - Open or Short to Plus
                    Fault Status: 01111010
                    Reset counter: 52
                    Voltage: 12.20 V
                    Count: 55
                    Hex Value: 0x1243
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 91
                    Mileage: 194795 km
                    Date: 2014.12.26
                    Time: 00:00:14
                    Voltage: 12.20 V
                    Count: 71
                    Hex Value: 0x1243
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Frequency: 23
                    Reset counter: 54
                    Mileage: 194791 km
                    Date: 2014.12.26
                    Time: 00:02:07
                    Voltage: 12.60 V
                    Count: 73
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 7N0 907 534     HW: 7N0 907 530 K
   Component: Batt.regelung H40 1632
   Coding: 030F1859
   VCID: 71BE22C561A4A403ADD-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900062051
End----------(Elapsed Time: 01:29, VBatt start/end: 12.5V/12.3V)-----------
When/where was the Touareg sold with a 1.6 TDI? :confused:
Many modern ECUs have software in them that is specific to the transmission and gear ratios and cannot just be coded for a different one, despite the fact that such codings are defined. I'm certain this is the case here, but it wouldn't surprise me either.
zeeshan
C?ID=327143
my mistake from touran fixed
What was the original ECU part number?
Have you checked a parts catalog to see if the current ECU 03L-906-023-NR has ever been used in a car with manual transmission? Because if not, you can be pretty confident that it cannot be coded for such.
zeeshan
C?ID=327143
Orignal ecu number 03L 907 425C
Replaced with same part number
That sounds like the hardware part number. But the software in the ECU is equally (or more) important.
