A9 Structure borne sound retrofit: wrong vehicle type
   #41
MasterTommy
Amsterdam
C?ID=295586
SW: 3Q0 907 530 G
   #42
downtime
Finland
C?ID=280813
Ok. I think you need to upgrade it to be able to modify the datasets. If I remember correctly you need at least Q index gateway to be able to modify the dataset.
I'll check what dataset I have for Tiguan diesel. I did the upgrade and I have dataset that I modified for the DCC retrofit.
   #43
MasterTommy
Amsterdam
C?ID=295586
Allright, that would be nice! If needed ill swap out the gateway, but lets see…
   #44
MasterTommy
Amsterdam
C?ID=295586
This is a high gateway already by the way.
   #45
downtime
Finland
C?ID=280813
No need to swap, just update. Is it continental or Lear gateway?
I’ll check this evening what I have. I’ll send you PM
   #46
MasterTommy
Amsterdam
C?ID=295586
Im not sure if its Conti or Lear, autoscan is in the starting post. I haven’t had a look at the label on the gateway in the car.
Does it lose any datasets, Fecs or otherwise when flashing to Q? And while we’re at it, anything else in the autoscan that is easily flashed to a higher SW without headaches? A5 or 13 for example…
   #47
downtime
Finland
C?ID=280813
It's a continental gateway. There's a Q update 5344 available for it.
Also 13 can be updated to T and A5 is updateable to index L. BUT, A5 is not downgradeable after that. If you go L you cannot go back to H. It will brick the camera hw.
Also your ACC supports pACC and that is doable for it as well. Of course needs some special attention but doable.
And all those lose dataset after flash and A5 in some cases loses the coding as well but no FeCs or calibration values are lost.
   #48
AINils
Germany (AIB)
C?ID=56975
Index Ax is better, as Q and Ax have some small difference
