Unable to access engine control module in crafter 2.5 2016 model
fenderjazz
C?ID=400400
Tuesday,04,August,2020,14:52:31:46540
VIN: WV1ZZZ2FZA7007031   License Plate:
Mileage:    Repair Order: 4AUG
Chassis Type: 2F (2F - VW Crafter Chassis Cab (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 91: LT3 Engine        Labels: Redir Fail!
   Part No SW: 076 906 022 P    HW: 076 906 022 G
   Component: R5 2,5L EDC A020SG  9022
   Coding: 0003032
   Shop #: WSC 60259 001 1048576
   VCID: 2019E65FE6C8BFCB723-8074
No Faults Found
  or D[B]TCs not supported by controller
[/B]
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
   Component: IMMO          0805  0815
   Revision: 00805000    Serial number: VWXDZ0J1011348
   VCID: 6D87CF6B619AA2A3895-8038
Address 94: LT3 Airbag
   Part No HW: 9064461442
   Shop #: WSC 00118 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F7878BE58A0A63515-8000
Address 95: LT3 ESP
   Part No SW: 9069022800    HW: 0004460153
   ASAM Dataset: 3 4101
   ROD: CRFT_ESP_3_36946.rod (*)
   VCID: 04518ACF5E9043EB76B-8050
Address 96: LT3 Instruments
   Part No SW: 9069026400    HW: 9069012000
   ASAM Dataset: 32 787
   ROD: CRFT_KOMBI_32_787.rod
Address 99: LT3 Ign. Switch
   Part No HW: 9065455808
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  0815
   Revision: 00805000    Serial number: 12345678901234
   Shop #: WSC 53558 001 1048576
Address 9B: LT3 Driver Door
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
Address B0: LT3 Roof Display
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BA3F133236E3C13071-802E
9090 - Interior monitoring: Data wire short circuit
            Test Complete - Active/Stored
Address B1: LT3 Upper Console
   Part No HW: 9065453907
   ASAM Dataset: 67 3
   ROD: CRFT1_OBF_67_3.rod (*)
Address B4: LT3 Central Elec.
   Part No SW: 9064420700    HW: 9065453601
   ASAM Dataset: 33 260
   ROD: CRFT_EZE_33_260.rod (*)
9039 - Back-up lights: Short to GND
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 065590C768AC71FB68F-8052
End----------(Elapsed Time: 01:25, VBatt start/end: 13.3V/13.1V)-----------
fenderjazz
C?ID=400400
Chassis Type: 2F (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Address 01: Engine (CEC)       Labels: Redir Fail!
   Revision: 24H34---    Serial number: VWXDZ0J1011348
   Coding: 0003032
   VCID: 2019E65FE6D8BFCB723-5160
               P0299 - 000 - Control Range Not Reached - Intermittent
                    RPM: 3066 /min
                    Speed: 90.0 km/h
                    Load: 74.5 %
                    Absolute Pres.: 2325.6 mbar
                    Absolute Pres.: 1764.6 mbar
                    Lambda: 72.6 %
                    Lambda: 5.5 %
Readiness: 0 3 0 0 1
   Coding: 0003032
                    RPM: 3066 /min
                    Speed: 90.0 km/h
                    Load: 74.5 %
                    Lambda: 72.6 %
                    Lambda: 5.5 %
Address 95: LT3 ESP
   ASAM Dataset: 21 3
   ASAM Dataset: 67 3
End----------(Elapsed Time: 01:11, VBatt start/end: 12.4V/12.3V)-----------
OK, there was a glitch during the first scan, but in the second scan, it clearly is accessible.
fenderjazz
C?ID=400400
thanks but when i tried to access engine block it wont access it ? ?
fenderjazz
C?ID=400400
Uwe:
selecting 01-Engine - gave a 'no response from controller despite trying many times closed application disconnected cable restarted same issue ?
Have you tried 91 (under the LT3 tab) instead of 01?
fenderjazz
C?ID=400400
thanks i did try both panel and the chassis
is there another way protocol etc
