Brake Disc Wiper function, (BDW): Audi A7 55 TFSIe, Q, PlugIn-Hybrid, 2020
MBe
Norway
C?ID=62044
I have experienced that brakes can be less effective in heavy rain, especially if not used for a while.
This car is hybrid and the "first braking" is electric regeneration, so I assume the mechanical brakes are less used.
Car has an BDW function in Adaptions in ABS module; IDE02631
Setting is NORMAL, 1.
Other choices except off are UP and DOWN.
Anyone familiar with this and knows what i.e UP means, if this removes water-film on discs better, and what number to use?
I think this function is implemented throughout a range of models.
Normally connected to wiperswitch position on or auto, and detection of rain on rain-sensor
Text line in adpmap-file for ABS module 03:
IDE02631-Brake disc wiper,normal ,1
Autoscan:
 Monday,03,August,2020,20:30:55:14143
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4524.4
VIN: WAUZZZF21LN026072   License Plate: DR-77022
Mileage: 11369km-7064mi   Repair Order:
Chassis Type: F2-AU58 (4N1)
Scan: 01 02 03 09 15 16 17 19 22 23 36 42 44 46 51 52 5F 6C 6D 81
          8C A5 BA BB BC C0 C5 C6 D6 D7
VIN: WAUZZZF21LN026072   Mileage: 11369km-7064miles
C5-Therm. mgt. -- Status: OK 0000
Address 01: Engine (J623-DLGA)       Labels: None
   Part No SW: 4K0 906 259 B    HW: 06L 907 425 B
   Component: R4 2.0l TFSI  H07 0002
   Coding: 1A6540320526050B340A0800000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0204K0906259B 001004
   ROD: EV_ECM20TFS0204K0906259B.rod
   VCID: 3039102D3AA0207BE23-8064
Readiness: 1110 1001
   Part No SW: 4K0 927 156 C    HW: 0HL 927 156 B
   Component: 0DK 20TFSIRdW H01 0002
   Revision: --H01---    Serial number: 0000000971
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002034
   ROD: EV_TCMDL382021_AU58.rod
   Automatic Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 80A 927 154     HW: 0DK 315 149 E
   Component: V671 ATFP-2  007 0058
   Serial number: 75307021190217000232
   Subsystem 2 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041190238000361
   Part No SW: 4N0 907 379 AN    HW: 4N0 907 379 F
   Component: ESP9 Premium  H06 0856
   Coding: 44AA41972AA40A9C119E0898207F52D3F5B9C0228254508810044ACBAF9D03
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 04518CFDDE986CDB76B-8050
   Part No SW: 4N0 907 063 FG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0690
   Coding: 07000943C13900DD0700070818AD8C68130B3310000600970101080039321C810A4509324256110800000100004918180800400044010000000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016.rod
   VCID: 78A9E80D9250383B6A3-802C
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001907050402134
   Coding: 7DC727
   Serial number: 23593883X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
   Component: E1 - LTM  H09 0086
   Serial number: 14S20.09.1900691695
   Serial number: GX1CE119061924210325
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AE    HW: 4K0 947 135 AE
   Component: Dachmodul  H42 0415
   Serial number: C00352780
   Coding: 0D0104
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H19 2720
   Serial number: 003YZM07J5NJ
   Coding: AAFCF0C00CA00000985000FFF00D40A000C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4ACD62C5BC3C7AABCC7-801E
   Belt Pretensioner left:
   Serial number: 00AI2019246088800000
   Coding: 04F001
   Belt Pretensioner right:
   Serial number: 00AI2019246379200000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 001 109 19
   Serial number: 35700000000630098042
   Subsystem 4 - Part No SW: -----------    HW: 480 001 109 19
   Serial number: 3580000000097D1C204L
   Subsystem 5 - Part No SW: -----------    HW: 480 031 309 19
   Serial number: 351001C2456919615FDC
   Subsystem 6 - Part No SW: -----------    HW: 480 031 309 19
   Serial number: 352001C2456112304DDY
   Subsystem 7 - Part No SW: -----------    HW: 480 031 809 19
   Serial number: 355001C247D3A1112AF9
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 031 809 19
   Serial number: 356001C247E42EC0980H
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 030 409 19
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C246186520289S
   Subsystem 10 - Part No SW: -----------    HW: 480 001 309 19
   Serial number: I0M000000008C7D430CD
   Subsystem 11 - Part No SW: -----------    HW: 480 001 309 19
   Serial number: I0N00000000A201530CV
1069312 - Databus
          [NWD: zFAS common DTC Timeout]
                    Reset counter: 216
                    Mileage: 10680 km
                    Date: 2020.07.21
                    Time: 18:04:26
1072640 - Databus
          [NWD: 0x12DD547B FAS_ProfileMaster_01 Timeout]
                    Reset counter: 216
                    Mileage: 10680 km
                    Date: 2020.07.21
                    Time: 18:04:29
1051904 - Databus
          [NWD: 0x30B Kombi_01Timeout]
                    Reset counter: 216
                    Mileage: 10680 km
                    Date: 2020.07.21
                    Time: 18:04:18
   Part No SW: 4N0 907 129 AE    HW: 4N0 907 129 AE
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 74B1DC3D8E385C5B46B-8020
   Part No SW: 4K0 920 794 B    HW: 4K0 920 794 B
   Component: FHybRDWACC--- H12 0210
   Coding: 852450C2E88000080121E1709384C80008002800
   ROD: EV_DashBoardAU65X_VW53.rod
   Part No SW: 4N1 907 468 BB    HW: 4N1 907 468 AB
   Component: Gateway       H16 0052
   Revision: BC000001    Serial number: 018BC812219912
   Coding: 02010005000206C029810100005B0132CC78000710000000097D079E10000000
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   VCID: 79AFED09A95A213315D-802C
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4K0 915 181 B    HW: 4K0 915 181 B
   Serial number: 75801303001902080044
Address 22: AWD (J492)       Labels:* None
   Part No SW: 4K0 927 755 B    HW: 0CJ 927 749 A
   Component: C8_DLE_N_SD2  H01 0008
   Serial number: 19128A6744
   Coding: 111C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: 34311C3DCEB81C5B86B-8060
   Part No SW: 4M0 909 059 J    HW: 4M0 909 059
   Component: J539 EBKV H11 0288
   Serial number:   085460012152
   ASAM Dataset: EV_BrakeBoostBOSCHCMP 001003
   ROD: EV_BrakeBoostBOSCHCMP_AU58.rod
   VCID: 3B233701E3E6D323471-806E
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 4M0 909 057 B    HW: 4M0 909 057
   Component: VX70BrakeAssi  H04 0154
   Serial number: 05802861051218171729
   Serial number: 00000381691693
   Coding: 005812400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS002 0189
   Serial number: YE007SHS2873D
   Coding: 001CDF4252000480A001B400
   VCID: 3E253E15F0F4C60B60F-806A
   Coding: 94002101010000
   ROD: EV_EPSVWBSAU426_010.rod
   VCID: 323D1A2534AC126B947-8066
   Part No SW: 4N0 907 064 DD    HW: 4N0 907 064 D
   Component: BCM2 MLBevo H15 0183
   Coding: 01740000002000E26309A0000400080203030001804B06502F04000000040030001F0100000F11
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_AU58.rod
   Ignition key:
   Rear Light Left 1:
   Subsystem 2 - Part No SW: 4K8 945 069 B    HW: 4K8 945 069 B
   Component: Slali1AU583  H03 0404
   Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Rear Spoiler Adjustment:
   Subsystem 3 - Part No SW: 4K8 959 252     HW: 4K8 959 252
   Component: J223 HSP 0304  H02 0200
   Serial number: WA138947000074241253
   Coding: 00FF00
   Rear Light Left 2:
   Subsystem 4 - Part No SW: 4K8 945 217 B    HW: 4K8 945 217 B
   Component: Slali2AU583  H03 0404
   Rear Light Right 1:
   Subsystem 5 - Part No SW: 4K8 945 070 B    HW: 4K8 945 070 B
   Component: Slare1AU583  H03 0404
   Rear Light Right 2:
   Subsystem 6 - Part No SW: 4K8 945 218 B    HW: 4K8 945 218 B
   Component: Slare2AU583  H03 0404
   Part No SW: 80A 907 080 A    HW: 80A 907 080 A
   Component: 50A87696A0HO0 H08 0008
   Revision: --------    Serial number: -00105.08.19000
   Coding: 03000000000000000000
   Shop #: WSC 48165 001 1048576
   ASAM Dataset: EV_DMCMHITACAU426 003007
   ROD: EV_DMCMHITACAU426_003.rod
   VCID: 221DEA65644C82EB647-8076
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS002 0189
   Serial number: YE007SI106348
   Coding: 001CDF025E000480A001B400
   VCID: 3D273919FDF2DD13795-8068
   Part No SW: 4K0 035 063 D    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   054 2711
   Coding: 01859301FF0A000043111101C00800102F0001E403F008008E
   VCID: 2411EC7D7E588CDB16B-8070
   Subsystem 1 - Part No: V03 959 804 BL
   Component: MIB2P_EU_Q419  0411
   Subsystem 2 - Part No SW: 4K0 919 605 C    HW: 4K0 919 605 A
   Component: DU AU58x High  H42 0147
   Serial number: INX00101071900060466
   Compact Disc Database:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004419000092193014
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4K0 919 603 B    HW: 4K0 919 603
   Component: DU AU58x Bot  H41 0147
   Serial number: INX00108071900080525
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900508822003
   Component: RVC Compact   H12 0250
   Coding: 0272060102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 33331F21CBB61B639F1-8066
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 174
                    Mileage: 10617 km
                    Date: 2020.07.19
                    Time: 17:39:09
                    passive
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C744-8781-2
   Coding: 1610
   Part No SW: 4K1 713 041 H    HW: 4K1 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 19.256 40540
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 2809F84D027068BB3A3-807C
   Part No SW: 4KD 915 233     HW: 4KD 915 233
   Component: BMC_PHEV_PL58 H08 0263
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_AU58.rod
   VCID: 7AADF205AC5C2A2B1C7-802E
   Battery Junction Box:
   Subsystem 1 - Part No SW: 4K0 915 254 C    HW: 4K0 915 254 C
   Component: SX6 SFT426D0  H23 0205
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 4N0 915 115     HW: 4N0 915 115
   Component: J991 SFT426D1  H08 0105
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 4N0 915 115     HW: 4N0 915 115
   Component: J992 SFT426D2  H08 0105
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 4N0 915 115     HW: 4N0 915 115
   Component: J993 SFT426D3  H08 0105
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 4N0 915 115     HW: 4N0 915 115
   Component: J994 SFT426D4  H08 0105
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 4N0 915 115     HW: 4N0 915 115
   Component: J995 SFT426D5  H08 0105
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 4N0 915 115     HW: 4N0 915 115
   Component: J996 SFT426D6  H08 0105
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 4N0 915 115     HW: 4N0 915 115
   Component: J997 SFT426D7  H08 0105
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 4N0 915 115     HW: 4N0 915 115
   Component: J998 SFT426D8  H08 0105
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AK    HW: 4N0 907 107 F
   Component: zFAS Var A    H08 0293
   Coding: 04118600000000000000060000400C6C189D56000000000000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D00080009000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 084998CDE2B048BB1A3-805C
2114786 - Databus
          [TSK_08_TSK_Status_EA]
                    Reset counter: 216
                    Mileage: 10680 km
                    Date: 2020.07.21
                    Time: 18:04:37
2117638 - invalid data record
          B2005 00 [008] - -
          [Data_Set_Invalid]
                    Reset counter: 216
                    Mileage: 10680 km
                    State_DSDL_Hosts-APH: OK
                    State_DSDL_Hosts-DSDL_Flag: not_active
                    State_DSDL_Hosts-MVH: NOK
                    State_DSDL_Hosts-SRH: NOK
                    State_DSDL_Hosts-SSH: NOK
2117696 - Parameterization
          B170A F1 [008] - Step 2 Not Performed
                    Reset counter: 216
                    Mileage: 10680 km
Address BA: Motor Mounts (J931)       Labels: None
   Part No SW: 4M0 907 145 E    HW: 4M0 907 145 B
   Component: AEMevo        H10 0132
   ASAM Dataset: EV_AEMZFAU736 006014
   ROD: EV_AEMZFAU736_006.rod
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS004 0189
   Serial number: YE007SHC04489
   Coding: 000CDD0200000480A000B000
   VCID: 40D940ED8A00B0FB123-8014
   Component: TSG HBFS004 0189
   Serial number: YE007SHU2768D
Address C0: Act. for Ext. Noise (J943)       Labels:* None
   Part No SW: 4K0 035 335     HW: 3F0 035 335
   Component: E_SOUND_SGH05 0113
   Serial number: EN193504540000
   Coding: 04
   ASAM Dataset: EV_ESoundMLBEvoS1NN 003008
   ROD: EV_ESoundMLBEvoS1NN.rod
   VCID: 629DAA6524CCC2EB247-8036
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4M0 965 429 N    HW: 4M0 965 429 F
   Component: TME-Max       H08 0303
   Serial number: 0062813
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002033
   ROD: EV_ThermContrVISAU49X_AU58.rod
   VCID: 42DD4AE5840CA2EB047-8016
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00103.8W.2A20370246
   Air Conditioning Compressor Sub:
   Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
   Component: J842 EKK es33  H03 0015
   Serial number: 00000000019051401231
   Geber für Kältemitteldruck/Kältemitteltemperatur 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Refrigerant Expansion Valve 2:
   Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000151041509
   Refrigerant Shut Off Valve 2:
   Subsystem 6 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130922466
   Refrigerant Shut Off Valve 3:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130922426
   Refrigerant Shut Off Valve 4:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130922418
   Refrigerant Shut Off Valve 5:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130922250
Address C6: Batt. Chrg. (AX4)       Labels:* 5QE-915-681.clb
   Part No SW: 5QE 915 681 S    HW: 5QE 915 681 S
   Component: OBC Delta-ES  H74 2831
   Coding: 11508B607000
   Shop #: WSC 00150 218 00000
   ASAM Dataset: EV_OBCTwoPhaseDT2MLBev14P 001002
   ROD: EV_OBCTwoPhaseDT2MLBev14P.rod
   VCID: 5CE1949D06A8F41B6EB-8008
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0031
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 72BDDA25F42C526B547-8026
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
End----------(Elapsed Time: 02:20, VBatt start/end: 13.0V/13.0V)-----------
Address 15: DTCs cleared
Address A5: DTCs cleared
I show the choices for IDE02631 in your ABS being:
OFF, low, normal, and up.
I think if you want more, you should try 'up'.
Reactions: MBe
MBe
Norway
C?ID=62044
Will try it this evening after work, and see what number UP gives.
Hopefully this function is not capable of "frying discs" if increased.
Do I maybe need to use Security Access, prior to doing changes in Adaption?
If so, can it be the same code, 38561, as used when programming automatic parking brake IDE08134?
Morten
MBe
Norway
C?ID=62044
Quick update.
i have tried both UP and LOW.
Cannot say I feel much of a difference.
Anyone else experience the same issue with brakes on hybrid or fully electric cars?
Morten
