2010 VW Golf Mk6 1.6 TDI No starter when turned to Ign position3
dulux72
C?ID=336242
Hi
I have an issue with a Golf Mk6 1.6 Tdi
Dash is lit up like a Christmas Tree and when key is turn to position 3 nothing
I can hear the fuel pump start but the starter doesnt engage
The car needed a ECU swap but the complete set up was removed from donor vehicle (ECU, BCM, Ignition barrel and key) Unfortunately I was stung whilst buying at auction and am now trying to just get it started.
My autoscan is below
Monday,03,August,2020,12:09:33:41688
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ1KZAW330134   License Plate:
Mileage: 72350km-44956mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZAW330134   Mileage: 72350km-44956miles
62-Door, Rear Left -- Status: Not registered 0001
72-Door, Rear Right -- Status: Not registered 0001
   Part No SW: 03L 906 023 HM    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 9628
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00114014030501080000
   ASAM Dataset: EV_ECM16TDI02103L906023HM 003010
   ROD: EV_ECM16TDI02103L997557R.rod
   VCID: 78FFB88CC37193462B-802C
8 Faults Found:
7461 - EGR Valve (N18)
          P0403 00 [096] - Malfunction
                    Mileage: 72262 km
                    Date: 2020.05.18
                    Time: 05:25:53
                    Engine speed: 1293.00 /min
                    Vehicle speed: 35 km/h
                    Coolant temperature: 67 °C
                    Intake air temperature: 13 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 14.795 V
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 12.210 %
                    EGR Solen.val.: actual value-ANG_EGRV[0]: 14.471 %
                    Air mass: actual value (mg/stroke)-MAF_MES: 435.532 mg/stroke
                    Sensor for engine block temperature: raw value-Coolant temperature: 67 °C
6141 - Coolant Fan Control Circuit 1
          P0480 00 [044] - Electrical Malfunction
                    Mileage: 72357 km
                    Date: 2020.07.27
                    Time: 01:04:00
                    Engine speed: 0.00 /min
                    Coolant temperature: 5 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 10.278 V
                    Engine speed: 0 /min
                    Sensor for temp after charge air cooler: raw value-TBA_MES: 11 °C
                    Sensor for engine block temperature: raw value-Coolant temperature: 21 °C
                    Outside air temperature-Ambient temperature: 7.50 °C
                    Coolant fan 1: activation-Radiator fan 1: activation: 9.8 %
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Mileage: 72357 km
                    Date: 2020.08.03
                    Time: 00:01:02
                    Coolant temperature: 15 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 11.633 V
                    Battery voltage: 11.6 V
10453 - Output for Starter Relay
          P0615 00 [037] - Open Circuit
                    Status of starter activation-FRF_ST_RL: 1
                    Sensor for engine block temperature: raw value-Coolant temperature: 15 °C
                    Number of resets of main unit-CTR_RST_MC: 0
10457 - Control Circuit for Starter Relay 2
          P3049 00 [037] - Open Circuit
10446 - Neutral Gear Sensor
          P15A0 00 [037] - Electrical Malfunction
                    Voltage terminal 30: 11.746 V
                    Battery voltage: 11.7 V
                    Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: 20.358 °
                    Neutral position sensor: adapted transmission angle-ANG_NEUT_GEAR_AD_NEUT: 0.247 °
                    Engaged gear: calculated-DRI_MT_BAS: 0
                    Clutch Position Sensor-Starter control: clutch switch: 00000000
                    Starter control: clutch switch-Starter control: interlock switch: 00000000
10436 - Neutral Gear Sensor
          P15A1 00 [109] - Implausible Signal
                    Mileage: 62805 km
                    Date: 2019.01.27
                    Time: 00:02:52
                    Engine speed: 782.00 /min
                    Normed load value: 24.3 %
                    Coolant temperature: 55 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 12.875 V
                    Battery voltage: 14.3 V
                    Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: -14.002 °
10440 - Neutral Gear Sensor
                    Mileage: 62805 km
                    Date: 2019.01.27
                    Time: 00:02:37
                    Engine speed: 780.50 /min
                    Coolant temperature: 54 °C
                    Voltage terminal 30: 12.762 V
                    Battery voltage: 14.5 V
                    Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: 18.144 °
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   VCID: 78FFB88CCB7193462B-802C
                    Reset counter: 81
                    Date: 2014.12.25
                    Time: 11:54:37
                    Count: 3
                    Count: 20992
                    Count: 195
                    Count: 43776
                    Fault Status: 01100101
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 11:53:55
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 279
                    Count: 43776
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 11:53:55
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 295
                    Count: 43776
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 11:53:55
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 270
                    Count: 43776
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6DD199D8BC3326EEC8-8038
          B10AB F0 [009] - Too Low
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2020.08.03
                    Time: 11:55:05
   Part No SW: 1K0 937 085 D    HW: 1K0 937 085 D
   Component: BCM PQ35  B+  103 0575
   Revision: 00103 AG
   Coding: 40180A3A9025189044080080000000E443010088424D8160648087200001
   VCID: 306F40AC63818B06A3-8064
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 09011  21  0512
   Coding: 009795
                    Fault Status: 01101100
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 12:03:40
                    Voltage: 11.60 V
                        Term 50 Off
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 12:03:41
                    Voltage: 12.00 V
                        Term 50 Off
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRA2LB0N
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B756780B2C7785E06-806E
   Serial number: 3572MSME2743144DZZZV
   Serial number: 3582MSME414B314FZZZ.
   Serial number: 3512QSME36444615ZZZO
   Serial number: 3522QSME0402470DZZZM
          B1000 1B [137] - Resistance Too High
                    Mileage: 72357 km
                    Date: 2020.08.03
                    Time: 11:56:12
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 0305DF6042B7C09E0E-8056
   Part No SW: 5K0 920 970 N    HW: 5K0 920 970 N
   Component: KOMBI         H03 0305
   Coding: 470B00
   VCID: 39797D88B8FB4A4E14-806C
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 250212F6000528
   Coding: 350003
   VCID: 3B756780BAC7785E06-806E
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 12:00:02
03406 - Control Module for Battery Monitoring
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 12:01:02
   Component: IMMO          H03 0305
   VCID: 6ADB92C48DDD31D6AD-803E
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Revision: A1001003    Serial number: 7667748725
   VCID: 2643A6F45145D5B649-8072
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2140
   Coding: 0000692
   VCID: 33654FA05297B01EDE-8066
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: 316945A8A88B820EAC-8064
                    Fault Status: 11100101
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 12:01:09
                    Battery Volts: 12.3 V
                        DD
                    Temperature: 22.0°C
                    Count: 3
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Component: Tuer-SG         009 2114
   Coding: 0000692
   VCID: 326B4AA4AD8DB916D5-8066
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  040 0166
   Revision: 00000001    Serial number: VWZ1Z3I5459503
   Coding: 0100040004
   VCID: 65C1E1F86CC31EAE80-8030
   Component: Batt.regelung H43 1623
   Coding: 030F1859
   VCID: 71E985A8A80BC20EEC-8024
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 12:04:40
02252 - Generator
                    Reset counter: 81
                    Mileage: 72357 km
                    Date: 2014.12.25
                    Time: 12:04:40
   Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 34674CBC5799B726C7-8060
   Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
   Coding: 0000144
   VCID: 356171B85CE3AE2EF0-8060
End-------------------------(Elapsed Time: 02:23)--------------------------
I guess I would start with looking at wiring diagrams and trying to figure out what might cause the "Open Circuit" faults for the starter relay.
Shawa12002
Victoria, Australia
C?ID=370869
There's an earth point or two in the engine bay just behind the left headlight(assuming your is a RHD). Take the nuts completly off and clean these points. Then i wold sugest posting scans before ECU swap, tha way it's easier to identify pre-existing faults to new ones. ECU are pretey robust from my point of view and most of them are condemned yet they have no faults.
dulux72
C?ID=336242
Unfortunately I can’t post pre Ecu swap autoscan as this was done prior to my knowledge and purchase at auction.
Update I noticed that the coding was for a car with stop start and once this was updated the engine now turns over. However it still doesn’t fire. I’ve noticed that there is a fault with the MAF sensor would this be enough to stop it starting ?
I really doubt that a MAF fault would prevent the starter from engaging. But starter relay faults would, and potentially Neutral Gear Sensor faults as well.
dulux72
C?ID=336242
Sorry but I think you misread my update
The starter now engages and using Vcds I can see that the engine is rotating at 280rpm but it doesn’t fire
Indeed, I did.
I still doubt that a MAF fault would prevent it from firing at all. What happens if you disconnect the MAF?
Shawa12002
Victoria, Australia
C?ID=370869
Is the engine code on engine the same as the one in the new ECU. You might need to soucre wirinig diagrams for both the vehicle with the new ECU and your one. Coding alone will not cut it unless every pin is in its designated position. From experience during on going product development, changes can happen to the same vehicle just a week apart in the production line.
Otherwise check your fuel relay then check if you can get cam sensor signal, engine rpm means the crank sensors is probably ok. If cam sensor is showing up during crank then check for power to the coils. If you have all of these and still no firing, then its either wiring pinout issue or immo. Just a out of interest how long was the engine down for? do you have oil pressure in you top end?
dulux72
C?ID=336242
I am alot further forward then I was a week ago. The engine runs Woohoo
However I think I've discovered the reason for the faults codes in the engine ECU
I have the original spec for the car from erWin and the car was never originally fitted for start stop and the codes displayed are the replacement ECU 'looking' for the components for start stop
Please remember that I didn't swap the ECU, BCM, Cluster or ignition this was done without my knowledge prior to my purchase.
My question is can the replacement ECU be recoded to the correct spec and therefore not search for elements that don't exist.
Theoretically, it's Byte 6, Bit 0 of the ECU's coding, and it is indeed set in this ECU. The question is whether this ECU's software will accept a change to that bit.
dulux72
C?ID=336242
OK thanks
I'll give it a try and report back
I'm guessing that if it doesn't work the only permanent fix would be a swap of the ECU and associated bits to the correct version for this vehicle ?
OK thanks
It's possible ECU hardware is correct, but software isn't. In that case, it could be flashed with correct software. But do try the coding first.
NostraJackAss
Component: 1,6l R4 CR td H23 9628 <<<<<<<<<<<<<<<<<< FIRMWARE UPDATE NEEDED?
Coding: 00114014032401080000 Try this yet?
Volkswagen
PartVersion
FL_03L906023HM6304
8848
9418
9628
9970
9971
9978
dulux72
C?ID=336242
Thanks for both suggestions but neither were successful
Both add an additional code saying that the engine control module is incorrectly coded as well as the 4 around the stop start function.
I've managed to locate a replacement ECU set that is the same as the car's original so it may be that another swap will finally sort the issues. I've managed to sort all the other faults that were hidden on this vehicle so on the home straight
Thanks for the suggestions
