Engine swap and problem with DSG after that CDGA
Orchid70
Sweden
C?ID=354348
Hi
I keep getting conflicting info and not sure if I have messed up....
So what do you guys think?
Car: 2012 Passat natural gas, CDGA engine and DSG gearbox, 7 gears, double clutch
420 000 km
Owner calls about 60000 km AFTER the oil change was due! (She drives 75000 km a year)
"Check engine light on - since some weeks"
"Have have filled up with oil couple of times in one weeks time"
"Coolant has to be topped up as well couple of times"
Coolant leak was the coolant pump.
And:
Fault code on camshaft postion sensor:
000022 - P0016
onsdag,22,April,2020,19:43:57:18201
VCDS -- Windows-baserad VAG/VAS-emulator Tändningen Windows 7 x64
VCDS version: AER 19.6.2.1  HEX-V2 CB: 0.4508.4
Dataversion: 20191020 DS308.0
www.vcds.se
Verkstads/leverantörsnamn: Firma Johannes Bruun
Verkstadskod: 000 02013 000000
VIN: WVWZZZ3CZCE089877   Reg.nr: MCC586
Mätarställning: 405320km   Rep.order:
Chassityp: 3C-VW46 (7N0)
Skanna: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4C 4F 52 53 55 56
          61 62 69 72
VIN: WVWZZZ3CZCE089877   Mätarställning: 405320km
01-Motor -- Status: Felfunktion 0010
02-Automatväxel -- Status: OK 0000
03-Bromselektronik -- Status: OK 0000
04-Styrposition -- Status: OK 0000
08-Klimatanläggning -- Status: Felfunktion 0010
09-Elektron. elcentral -- Status: Felfunktion 0010
10-park/styr-hjälp -- Status: Felfunktion 0010
15-Krockkuddar -- Status: OK 0000
16-Rattelektronik -- Status: OK 0000
17-Instrument -- Status: OK 0000
25-Startspärr -- Status: OK 0000
42-Dörrel. förare -- Status: Felfunktion 0010
44-Styrservo -- Status: OK 0000
46-Komfortcentral -- Status: OK 0000
4C-Däcktrycksk. II -- Status: OK 0000
4F-Elektr. centralenh. II -- Status: OK 0000
52-Dörrelektr. pass. -- Status: OK 0000
53-Parkeringsbroms -- Status: OK 0000
55-Helljusområde -- Status: OK 0000
56-Radio -- Status: Felfunktion 0010
61-Batteriregul. -- Status: OK 0000
62-Dörr, Vä Bak -- Status: OK 0000
69-Släpvagn -- Status: Felfunktion 0010
72-Dörr hö bak -- Status: OK 0000
Adress 01: Motor (CDG)       Labels: AER\03C-906-021-CDG.clb
   Artikelnr SW: 03C 906 021 Q    HW: 03C 907 309 D
   Komponent: 4414 CNG 14K31  G   6368
   Revision: E8H06---    Serienummer: VWZCZ000000000
   Kodning: 0000077
   Verkstad #: WSC 11064 003 1048576
   VCID: 290FFFFE05FD53DFBE8-807C
2 Funna fel:
000715 - Turbo/kompressor "B"
               P02CB - 000 - för lågt tryck
             frysta data:
                    Felstatus: 01100000
                    Felprioritet: 0
                    Felfrekvens: 1
                    Reset-räknare: 255
                    Mätarställning: 404424 km
                    Tidsindikering: 0
                    Datum: 2014.09.07
                    Tid: 17:32:56
             frysta data:
                    RPM: 1984 /min
                    Belastning: 91.3 %
                    Temperatur: 87.0°C
                    Temperatur: 21.0°C
                    Absoluttryck: 990.0 mbar
                    Spänning: 13.462 V
000022 - Rad 1
               P0016 - 000 - kamaxelläges (G40)/vevaxellägessensor (G28) Fel anpas - Fellampa(MIL) tänd
             frysta data:
                    Felstatus: 11100000
                    Felprioritet: 0
                    Felfrekvens: 1
                    Reset-räknare: 255
                    Mätarställning: 404641 km
                    Tidsindikering: 0
                    Datum: 2014.09.09
                    Tid: 09:20:42
             frysta data:
                    RPM: 2016 /min
                    Belastning: 11.8 %
                    Temperatur: 75.0°C
                    Temperatur: 10.0°C
                    Absoluttryck: 1010.0 mbar
                    Spänning: 14.859 V
Adress 02: Automatväxel        Labels: AER\0AM-927-769.clb
   Artikelnr SW: 0AM 300 058 P    HW: 0AM 927 769 D
   Komponent: GSG DSG AG7     431 4547
   Revision: 00043014    Serienummer: CU501604215411
   Kodning: 0000020
   Verkstad #: WSC 04940 001 00001
   VCID: 3E253CA2EC73C467FBA-806A
Ingen felkod funnen.
Adress 03: Bromselektronik        Labels: AER\3AA-614-109.clb
   Artikelnr SW: 3AA 614 109 AC    HW: 3AA 614 109 AC
   Komponent: J104   C2 450M VD7A 0022
   Revision: --H07---    Serienummer: 00000004836711
   Kodning: 0132465
   Verkstad #: WSC 05311 000 00000
   VCID: 6E85CCE2FC9374E72BA-803A
Adress 08: Klimatanläggning (J255)       Labels:| AER\5K0-907-044.clb
   Artikelnr SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Komponent: Climatronic   H18 1112
   Revision: 00001004
   Kodning: 0004004802
   Verkstad #: WSC 00015 115 00000
   VCID: 0059825ADA877297C96-8054
1 fel funnet:
9481988 - sensor för luftkvalitet
          B10AF 04 [008] - Internt system-fel
          Intermittent fel - Bekräftad - Testad efter att minnet rensats
             frysta data:
                    Felstatus: 00000001
                    Felprioritet: 3
                    Felfrekvens: 115
                    Reset-räknare: 140
                    Mätarställning: 393456 km
                    Datum: 2020.02.07
                    Tid: 19:32:19
Adress 09: Elektron. elcentral (J519)       Labels:. AER\3AA-937-087.clb
   Artikelnr SW: 3AA 937 087 M    HW: 3AA 937 087 E
   Komponent: BCM PQ47 H+   413 1450
   Revision: BC413001
   Kodning: 000800000000000000180280540029F423D54B88626D8D60E48046240041
   VCID: 44D14E4A8E9FAEB7ADE-8010
   Subsystem 1 - Artikelnr SW: 3AB 955 419     HW: 3AB 955 419   Labels: AER\1KX-955-119.CLB
   Komponent: Wischer 15091  10  0603
   Kodning: 00B795
   Subsystem 2 - Artikelnr: 1K0 955 559 AH  Labels: AER\1K0-955-559-AG.CLB
   Komponent: RLS 101011 05  54  0403
   Kodning: 02302A
Adress 10: park/styr-hjälp (J446)       Labels:| AER\3AE-919-475.clb
   Artikelnr SW: 3AE 919 475 C    HW: 7N0 919 475
   Komponent: PARKHILFE 8K  H06 0018
   Revision: --------    Serienummer: 28231731206977
   Kodning: 118102
   Verkstad #: WSC 60077 001 1048576
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3FDB41A6E7F9CD6FF0C-806A
1 fel funnet:
1079601 - höger givare bak för parkeringshjälpen
          B1079 31 [008] - Signal saknas
             frysta data:
                    Felstatus: 00000001
                    Felprioritet: 3
                    Felfrekvens: 22
                    Reset-räknare: 34
                    Mätarställning: 345310 km
                    Datum: 2019.05.31
                    Tid: 14:12:13
Adress 15: Krockkuddar        Labels: AER\5N0-959-655.lbl
   Artikelnr SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Komponent: J234__101 VW10 HI   1918
   Revision: 22014000    Serienummer: 003K0PLW5BF3
   Kodning: 0012337
   VCID: 4CC1666AAACF66F765E-8018
   Subsystem 1 - Serienummer: 6332MTS610562671
   Subsystem 2 - Serienummer: 6342MTS665232671
   Subsystem 3 - Serienummer: 6351HTS6K7KPEAKJ
   Subsystem 4 - Serienummer: 6361HTS6PS64FAKJ
   Subsystem 5 - Serienummer: 00000000000000000
   Subsystem 6 - Serienummer: 00000000000000000
Adress 16: Rattelektronik (J527)       Labels:| AER\5K0-953-569.clb
   Artikelnr SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
   Komponent: LENKS.MODUL   016 0180
   Revision: --X01---    Serienummer: 20151012201040
   Kodning: 1982250000
   Verkstad #: WSC 45670 002 1048576
   VCID: 094F9F7EE9BD33DF9E8-805C
   Styrdon för multifunktionsratt:
   Subsystem 1 - Artikelnr SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: AER\3C8-959-537.CLB
   Komponent: E221__MFL-TK6  H06 0022
   Serienummer: 40000000000000489268
   Kodning: E20000
Adress 17: Instrument (J285)       Labels:| AER\3C8-920-xxx-17.clb-SRI1
   Artikelnr SW: 3AA 920 870 E    HW: 3AA 920 870 E
   Komponent: KOMBI         H03 0607
   Kodning: 161F01
   Verkstad #: WSC 05314 115 00000
   VCID: 34311E8ADEBF1E371DE-8060
Adress 19: CAN Gateway (J533)       Labels:. AER\7N0-907-530-V2.clb
   Artikelnr SW: 7N0 907 530 L    HW: 1K0 907 951
   Komponent: J533  Gateway H41 1620
   Revision:   H41       Serienummer: 071011F2001932
   Kodning: 462006
   Verkstad #: WSC 00000 480 652003
   VCID: 392F2FBEF95DE35FCE8-806C
Adress 25: Startspärr        Labels: AER\3C0-959-433-25.clb
   Artikelnr SW: 3AA 959 433 F    HW: 3AA 959 433 F
   Komponent:    IMMO         048 0429
   Revision: 00048000    Serienummer: VWZCZ000000000
   VCID: 3C2136AAFA6FD677D5E-8068
   Subsystem 1 - Artikelnr: 3C0 905 861 J
   Komponent:    ELV          029 0380
Adress 42: Dörrel. förare (J386)       Labels:| AER\3C0-959-70X-GEN4.clb
   Artikelnr SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Komponent: TUER-SG FT    002 0533
   Revision: 12110009    Serienummer: 0003639631
   Kodning: 0000B7
   Verkstad #: WSC 05311 115 00000
   VCID: 3537238ED5C5073F2A0-8060
   Slave Driver:
   Subsystem 1 - Artikelnr SW: 3C0 959 703     HW: 3C0 959 795   Labels: AER\1K0-959-70X-GEN4.CLB
   Komponent: J388__TSG-HL  004 0407
   Serienummer: 00000002483748
   Kodning: 000090
1 fel funnet:
66304 - knapp för fönsterhiss på förarsidan
          B11F0 29 [008] - Signafel
             frysta data:
                    Felstatus: 00000001
                    Felprioritet: 2
                    Felfrekvens: 1
                    Reset-räknare: 136
                    Mätarställning: 403812 km
                    Datum: 2020.04.12
                    Tid: 12:18:16
Adress 44: Styrservo        Labels: AER\5N1-909-144.clb
   Artikelnr SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Komponent: J500__APA-BS KL.308 1002
   Revision: 1AH03734    Serienummer: 00112730158301
   Kodning: 0000258
Adress 46: Komfortcentral        Labels:. AER\3C0-959-433-46.clb
   Komponent:    KSG PQ47 ELV 048 0714
   Kodning: 0191020052830E763404941570084FCE707801
   Subsystem 1 - Artikelnr: 1K0 951 605 C
   Komponent: LIN BACKUP HORN H05 1501
   Subsystem 2 - Artikelnr: 3C0 951 171 C
   Komponent: Neigungssensor  004 0611
   Subsystem 3 - Artikelnr: 3C0 951 171 C
   Komponent: Innenraumueberw.004 0611
Adress 4F: Elektr. centralenh. II (J520)       Labels:. AER\1K0-907-532.clb
   Artikelnr SW: 7N0 907 532     HW: 1K0 907 951
   Komponent: EZE_2         H41 1620
   Kodning: 00000008
   VCID: 6FBBD1E6F7997DEF20C-803A
   Subsystem 1 - Artikelnr SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Komponent: Analoguhr  004 0003
Adress 52: Dörrelektr. pass. (J387)       Labels:| AER\3C0-959-70X-GEN4.clb
   Artikelnr SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Komponent: TUER-SG BT    002 0533
   Revision: 14110009    Serienummer: 0003615133
   Kodning: 0000B6
   VCID: 36352482C8C30C2723A-8062
   Slave Passenger:
   Subsystem 1 - Artikelnr SW: 3C0 959 704     HW: 3C0 959 794   Labels: AER\1K0-959-70X-GEN4.CLB
   Komponent: J389__TSG-HR  004 0407
   Serienummer: 00000002495589
   Kodning: 000090
Adress 53: Parkeringsbroms        Labels: AER\3AA-907-801.clb
   Artikelnr SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Komponent: J540 EPB4  VW-64783 0009
   Revision:   H19       Serienummer: 00000000303288
   Kodning: 0022157
   VCID: 3537238ED945073F2A0-8060
Adress 55: Helljusområde (J745)       Labels:. AER\5M0-907-357-V3.clb
   Artikelnr SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Komponent: AFS-ECU       H04 0105
   Revision: --------    Serienummer: --------------
   Kodning: 021200000B000200
   Verkstad #: WSC 60072 001 1048576
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   Subsystem 1 - Artikelnr SW: 3D0 941 329     HW: 3D0 941 329   Labels: AER\3D0-941-329.CLB
   Komponent: LeiMo links  H04 0011
   Kodning: 230000
   Subsystem 2 - Artikelnr SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: AER\3D0-941-329.CLB
   Komponent: LeiMo rechts  H01 0002
   Kodning: 230000
Adress 56: Radio (J0503)       Labels:. AER\5M0-035-1xx-56.clb
   Artikelnr SW: 3C8 035 195 F    HW: 3C8 035 195 F
   Komponent: Radio RCD510  050 0207
   Revision: 00000001    Serienummer: VWZ1Z3L7671044
   Kodning: 05000400040011
   Verkstad #: WSC 05314 000 00000
   VCID: 2B0305F6030141CF4C4-807E
1 fel funnet:
00468 - CD-ROM-läsare (R92)
            014 - felaktig
             frysta data:
                    Felstatus: 01101110
                    Felprioritet: 5
                    Felfrekvens: 1
                    Reset-räknare: 12
                    Tidsindikering: 0
                    Datum: 2013.10.20
                    Tid: 20:22:54
Adress 61: Batteriregul. (J840)       Labels:. AER\1K0-907-534.clb
   Artikelnr SW: 7N0 907 534     HW: 1K0 907 951
   Komponent: Batt.regelung H41 1620
   Kodning: 03220864
   VCID: 71BFD79EE1AD6B1F368-8024
   Subsystem 1 - Artikelnr SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Komponent: J367-BDM  H07 0180
   Serienummer: 00000000008900751563
Adress 69: Släpvagn (J345)       Labels:. AER\7N0-907-383.clb
   Artikelnr SW: 7N0 907 383     HW: 7N0 907 383
   Komponent: Anhaenger     H09 0101
   Revision: 3I001002    Serienummer: 00000159189636
   Kodning: 4106040000000000
   VCID: 73B3DD969BB1590FC44-8026
2 Funna fel:
02562 - Lampor för bromsljus: släp
            010 - Avbrott eller kortsluten till plus - Intermittent fel - Fellampa(MIL) tänd
             frysta data:
                    Felstatus: 10101010
                    Felprioritet: 3
                    Felfrekvens: 3
                    Reset-räknare: 144
                    Tidsindikering: 0
02566 - Vänster blinklyktor: släp-
            010 - Avbrott eller kortsluten till plus - Fellampa(MIL) tänd
             frysta data:
                    Felstatus: 11101010
                    Felprioritet: 3
                    Felfrekvens: 22
                    Reset-räknare: 104
                    Tidsindikering: 0
Slut--------(Förfluten tid: 01:44, Vbatt start/stopp: 12.2V/12.2V)---------
We changed oil and told her that this most likely wont last long and the chain and coolant pump would need to be changed ASAP.
The day after, she called and told the car had died on her and didnt start after that - and she had to top up engine oil already after 50 km drive.
Fault codes this time:
000022 - P0016
008851 - P2293 - Fuel pressure control valve (N276) - intermittent
000136 - P0088 - Fuel rail / system pressure - too high
måndag,27,April,2020,18:56:38:18201
www.vcds.se
VIN: WVWZZZ3CZCE089877   Reg.nr: MCC568
                Adress 01: Motor       Labels: AER\03C-906-021-CDG.clb
Styrenhet artikelnr: 03C 906 021 Q    HW: 03C 907 309 D
  Komponent och/eller version: 4414 CNG 14K31  G   6368
           SW-kodning: 0000077
            Verkstadskod: WSC 11064 003 1048576
3 Funna fel:
000022 - Rad 1
             frysta data:
                    Felstatus: 11100000
                    Felprioritet: 0
                    Felfrekvens: 1
                    Reset-räknare: 255
                    Mätarställning: 405325 km
                    Tidsindikering: 0
                    Datum: 2032.14.25
                    Tid: 11:37:43
             frysta data:
                    RPM: 687 /min
                    Belastning: 19.6 %
                    Temperatur: 45.0°C
                    Temperatur: 13.0°C
                    Spänning: 14.859 V
008851 - Regleringsventil för bränsletryck (N276)
               P2293 - 000 - mekaniskt fel - Intermittent fel - Fellampa(MIL) tänd
             frysta data:
                    Felstatus: 10100000
                    Felprioritet: 0
                    Felfrekvens: 24
                    Reset-räknare: 255
                    Mätarställning: 405395 km
                    Tidsindikering: 0
                    Datum: 2032.14.27
                    Tid: 19:49:35
             frysta data:
                    RPM: 652 /min
                    Belastning: 26.3 %
                    Temperatur: 62.0°C
                    Temperatur: 24.0°C
                    Absoluttryck: 1000.0 mbar
                    Spänning: 14.478 V
000136 - Bränsle rail-/systemtryck
               P0088 - 000 - för högt - Fellampa(MIL) tänd
             frysta data:
                    Felstatus: 11100000
                    Felprioritet: 0
                    Felfrekvens: 24
                    Reset-räknare: 255
                    Tidsindikering: 0
                    Datum: 2032.14.27
                    Tid: 19:49:39
             frysta data:
                    RPM: 775 /min
                    Belastning: 28.2 %
                    Temperatur: 60.0°C
                    Temperatur: 24.0°C
                    Spänning: 14.478 V
I thought I had found i perfect engine to swap with.
130000 km.
But I dont today know, if it came from a manual or DSG AND the engine is from 2010.
I have since that learned that these cars have a habit of beeing near impossible to marry used parts between cars =(
The problem after the swap is following:
The mechatronic doesnt know sometimes what gear to but in - or wether to but an other gear in...
It kind of kicks in the gears. Right from the 1:st to the 2:nd gear.
Ive tried to beform basic settings - without luck.
When I told the owner of this - she told me that the Mechatronics was changed, when the car had hardly 170 000 km on the clock. From the invoice I can read, that it was updated and 2 liters gearbod oil (G052512A2) was used. But at tha time the fault code was different, it was "The clutch opens unintentionally" - no fault codes have been saved on the invoice.
Today:
Fault codes for both clutch 1 and 2, are set almost instantly:
006011 - P177B - 007 - Clutch 1 - Tolerance limit reached - Intermittent fault
Readiness: 1000 0000
måndag,20,Juli,2020,18:40:48:18201
VCDS version: AER 20.4.1.1  HEX-V2 CB: 0.4508.4
Dataversion: 20200630 DS317.0
www.vcds.se
Styrenhet artikelnr: 0AM 300 058 P    HW: 0AM 927 769 D
  Komponent och/eller version: GSG DSG AG7     431 4547
           SW-kodning: 0000020
            Verkstadskod: WSC 04940 001 00001
                      VCID: 3E253CA2EC73C46B616-806A
1 fel funnet:
006011 - koppling 1
               P177B - 007 - Toleransgräns uppnådd - Intermittent fel
             frysta data:
                    Felstatus: 00100111
                    Felprioritet: 0
                    Felfrekvens: 1
                    Reset-räknare: 10
                    Mätarställning: 405434 km
                    Tidsindikering: 0
                    Datum: 2034.14.27
                    Tid: 07:01:34
I never saved the clutch 2 fault code.
And I have been using the Swedish version.
The car is at our friends who made the swap - who use to work for VAG in the past. His friend, who still works there, is on a holiday for a month and not reachable. So dont know who to ask anymore.
What am I to do next?? Or try?
Orchid70
Sweden
C?ID=354348
After some thinking.
Could it be the Mechatronic (that is, already by this time, almost double the age of what it was last time it started to mess up and was changed) - that didnt like beeing zeroed during the engine swap. When the battery was off.
In retrospect, should the Motronic have been supplied with power during the swap?
Orchid70
Sweden
C?ID=354348
What about the selector cable adjustment?
The engine and gearbox was removed and the new engine was mounted - then everything was installed in the car.
I am afraid the guys did not read on, before they went on, to do the change....
siLc
Tallinn, Estonia
C?ID=330192
Lot of things to address, lets get going...
First, please post all autoscan data using the English language version of VCDS. You can install it besides your Swedish version. Most people able to help don't speak Swedish ;)
Thanks for the heads up - now I know how many times I can skip oil changes in order for the engine to seize :D From the factory parts catalogue, the engine block of a CDGA engine from a B6 (2010) and B7 (2011-2015) is the same, regardless of transmission type.
Have you considered the mileage of the current DSG clutch pack? Judging from the DSG SW version, the last clutch change (at least at a dealership) was sometime in 2013. The clutches are a wear item and don't last forever. Have a good look at THIS and then the clutch measurement blocks in the TCM.
If all the selector positions work and are correctly indicated in the MFA, then its not the selector cable.
Orchid70
Sweden
C?ID=354348
Thank you siLc (Im from Finland =) ).
I do have the English version and do use it when I know I need to post something here =)
Unfortunatelly I never did an English autoscan, before or after, the engine change. At the moment the car is not here.
Very happy to hear that the engine is the same. We have a friend whos son works at VAG - and that Junior (his name) said for a long time that the engines are different....
There was no problems with the clutches before the engine change. It came immediately after the change.
The fault code on clutch 1, came first.
I did the basic setting and after that both clutch 1 and 2 gave fault codes.
To change both clutches is not a sheap thing - so Id like to be VERY sure before proceeding on that.
Is there a way to find out that the Mechatronic is intact?
What about the gear selector lever cable? If that is not correctly adjusted - would that give this fault codes?
siLc
Tallinn, Estonia
C?ID=330192
Well, there were some improvements to the CDGA engine on the B7 but if the swapped B6 engine itself is running fine, why bother for now? I hope you at least changed the timing chain on the replaced engine...
According to a dealership master tech I know, the performing of basic settings brings out all the clutch wear related symptoms. If the mechatronic was adapted to the worn clutches, performing basic settings wipes this adaptation away and you are left with jerky gearshifts.
Read what I said about the selector cable and the linked article about the clutch parameters and report back ;)
NostraJackAss
Did you know adding Engine oil and thicker ATF viscosity by means of experiments in the DSG's & that were once allegedly condemned bad, have been very promising to stop jerky jerky shift routines & while bringing back additional useful life of exceeding an additional 100K now?
siLc
Tallinn, Estonia
C?ID=330192
Is this info for the 6-speed DQ250 DSG? Don't think this applies to the 7-speed DQ200...
Orchid70
Sweden
C?ID=354348
I missed the link you provided, siLc- will be reading tonight!!
And will be off to the car hopefully tomorrow and check out alla the measuring block results.
BIG kiss on your cheek dearest!!! <3 <3
Yes - OF COURSE the chain, tensioners, seals (forgotton everything I bought for it =) but it was the lots - except the VVT pulley ) has been done before mounting to the car!!!!! Oil has been canged!
I tried the basic settings only after the problems started, when I picked up the car - and I guess - Mectatronic beeing without power during the work, it perhaps already there, lost all its learnings.
And the new engine was running fine according to the scrapper - a one we trust as well.
And the car has been used as horse trailer puller, as well as been driven 270 000 km, the last 4 years.
Let you guys know, when I know more.
siLc
Tallinn, Estonia
C?ID=330192
No problem!
A horse trailer puller? I've only pulled light trailers (750kg fully laden) with my 2011 Passat B7 CNG and it felt like torturing the DSG clutches while maneuvering :) My ex-Swedish car is "a bit" less used with 82000km driven in the last 4 years (total 158000km). DSG clutches were changed at 40000km and have lasted 118000km so far.
Orchid70
Sweden
C?ID=354348
I have no idea how it has been behaving with horse trailer - and the owner is not trusted with any car really... When she came to us 1½ years ago - we told her that her car was over due by far! We told her to get rid of it right away. And we didnt even know it was that cursed DSG gearsbox on it!! Only the "unfortunate" chain.... We could see it had been changed once - but too long ago. So we told her she H-A-D TO change oils every 1000 km! She did once and then - she forgot or what ever happened. My chin dropped when I found out how far she had driven.... and then: driving around with Check engine light on, for at least couple of weeks (I dont know if she told the truth) - filling on oil and coolant God knows how often!!
Its good to know though - how yours is behaving! It sounds more and more like she is up for a clutch change as well.... We will have to see.
Orchid70
Sweden
C?ID=354348
Im at loss - but my gut feeling is clucthes.
This is what I saved from our test drive.
I managed to make a basic setting in Measuring Block 060 - then after that, basic setting in 069: where the adaptation/setting turned into "ON" for a brief second and back to "OFF"; briefly to "ON" and then "OFF" - so dont think anyting was adapted. Tried several times.
After the Basic setting of 060 measuring block adaptation - there will always be sett an intermittent fault code on something with "too short travel" (unfortunatelly I did not save it).
Anyhow - after this procedure - for a short time, I thought we had succeeded =) For at least 5 km the shifting went perfectly!! No fault codes.
Earlier, doing the basic setting, made no difference, the fault code (006011 - P177B - 003 - Clutch 1 - Tolerance limit reached) was sett directly after first meters of driving.
Then - all of the sudden, in shifting to higher gears - the hard shifiting started again. First came the clutch 1 fault code (NO LONGER INTERMITTENT)- and after 3 km the clutch 2 fault code. It happens in all gears - but is hardest in shifiting from 1 to 2 and in reverse.
I tried to measure as much I could while hubby drove. That Russian home page is HUGE!!! I saved 19 pdf documents about Mechatronics, clutches and DSG boxes =)
Here is what I have - if anyone could help me understand it (sorry - noticed first at home I had taken the Swedish version again.....):
Following was driven in second, perhaps third gear:
Standing still:
Orchid70
Sweden
C?ID=354348
Next wonders.
1:
Our car is manufactured in october 2011.
The clutch is different between <juny/>july 2011. I guess I need to take a look at the manufacturing date on the gearbox??
2:
Is there something extra thats good to know, chaning the clutch? Our friend has done it once at a workshop, at work, some time ago.
3:
Special tools are needed. We dont think our friend has the opportunity to borrow the tools from his work.
The kit I have been looking at online, dont have any listing on exactly, what parts is included.
Any tip on that?
4:
In case we would need to desmantle the Mechatronic - there is a special tool needed for that. T10407 Correct? Where to get one? Everything online has 4-5 weeks delevery.
We are planning on changning the oil when the clutch is beeing changed. In case we cannot desmantle it - we are going to try to poor it out without removing the unit from gearbox....
siLc
Tallinn, Estonia
C?ID=330192
According to the drive2 article, those clutch parameters aren't good.
Where are you seeing this clutch date info? My vehicle is manufactured september 2011 and gearbox code is NAU. Yours is most probably the same. The HW and SW part numbers in the scan are the same.
This might help -> https://www.partsinmotion.co.uk/xlist/35/602_VAG_BR_VERB_EN.pdf
Orchid70
Sweden
C?ID=354348
I could see the info about change in clutch kits, on the home page that sells LUK clutches.
I called VAG and they told me it shoudl be the kit that has original number 0AM198140L (so, this one from LUK: 602000600, 2:nd generation clutch kit).
Thanks a lot! It feels better knowing instead of guessing.
The special tools kits are EXPENSIVE though =(
siLc
Tallinn, Estonia
C?ID=330192
0AM198140L is the clutch kit which has currently lasted me close to 120000km. By now it has been superseded to 0AM198142AA, though the LUK and Sachs part numbers will still be the same. When changing the clutch pack, its advised to update the TCU SW to the latest version. For this box, its SW version number is 6248.
Orchid70
Sweden
C?ID=354348
I havent checked the SW yet, I only know they chnaged the Mechatronic unit 2016 and updated the software.
But I will be checking the software numbers.
We are going to order the clutch kit through my friens work and hopefully be able to borrow the tools in the same time. Its a LUK kit. The guy who can make the order is on holiday =) They all are at the moment.
Thank you for remebering me!!! It will be couple of weeks before the car is running again. I will leet you know how it went!
Orchid70
Sweden
C?ID=354348
So the clutch has been changed and the verdict is:
The transmission is behaving the same as before =(
I will be gettng the software version next.
Orchid70
Sweden
C?ID=354348
I have been to to the car and triied to do all the adaptations mentioned in the Russian site.
MB 060 - no problem.
MB 069 how ever stops like this (it did do it even before the clutch change):
In the above picture, there is also seen a worn but functioning clutch (from the Russian site). On our clutch, the spring was somewhat more out, and the pins inside where cracked. But I think clutch still worked.
Link to the Russian site with pictures of new clutch and used one compared (scroll all the way down):
Orchid70
Sweden
C?ID=354348
Of course I forgot to check the software number when I was at the car.
But I notised one thing.
When the car is cold - there is no problems with changing the gears.
When the oil gets warm - the problems start.
