Key adaptation not working
Limalex
London
C?ID=260940
Hello Members.
I replaced my BCM on a Vw T5,1 Caravelle to a 7E0 937 090 D BCM PQ25 Max4 H82 0762
I cleared the stored data from the BCM and when attempting to code my keys VCDS says Chanel not available.
Are my only option is the dealer coding?
Saturday,01,August,2020,11:52:12:36108
VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WV2ZZZ7HZCH133237   License Plate: AJ62
Mileage: 135260km-84046mi   Repair Order: New BCM adaptation issue
Adaptation Channel 001:
Stored value
  ERROR:
  Channel 01
  Not
  Available
Latest scan
Saturday,01,August,2020,11:47:49:36108
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 56 69 78 0B
VIN: WV2ZZZ7HZCH133237   Mileage: 135260km-84046miles
0D-Slide Door, Left -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JD    HW: 03L 907 309 H
   Component: R4 v002 EDC   X36 8749
   Revision: 22X36---    Serial number: 00000000000000
   Coding: 0125401A232400080000
   Shop #: WSC 79883 336 16496
   ASAM Dataset: EV_ECM20BTD01103L906022JD 002011
   ROD: EV_ECM20BTD01103L906022JB.rod
   VCID: 70ACD288AB2E1F06FB-8024
   Part No SW: 0BT 300 045 M    HW: 0BH 927 711 C
   Component: DSG DQ500-7F  H05 1795
   Revision: 00H05V01
   VCID: 3FCE41B4A6F0B07E32-806A
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 J    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0109
   Revision: 00H43001
   Coding: 108764AD09A7089826A49074AA6510
   Shop #: WSC 02756 790 49152
   VCID: 393A2FACB0D49E4E0C-806C
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 AC    HW: 7E5 907 040 AC
   Component: ClimatronicT5 H19 0407
   Revision: 00001003
   Coding: 0004000102
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 699ABFEC88F4EECEBC-803C
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0012304120015096
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 3
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 8601 312180165
   Coding: A0B279382E612413932888106C2B8EDD0080410F60844000300003000000
   Shop #: WSC 35110 377 08192
   VCID: 2C1406F84F863BE687-8078
   Component: RLS 180412 05  54  0403
   Coding: 02302E
   Subsystem 2 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 3 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 4 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 171
   Subsystem 7 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Serial number: 70000000000000149465
   Coding: E30000
                    Fault Status: 00101011
                    Reset counter: 43
01516 - Terminal 30; Left
                    Reset counter: 3
00927 - Terminal 30 (Right)
                    Reset counter: 3
04194 - Vehicle Status with Under-Voltage
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 3
Address 0D: Slide Door, Left        Labels: Redir Fail!
   Part No: 7E0 959 243 D
   Component: Schiebetuer-SG  407 0328
   Shop #: WSC 02756 790 00000
   VCID: 302C1288A3AE5F06BB-8064
   Part No SW: 7E0 919 475 E    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H11 0013
   Revision: --------    Serial number: 47461208500166
   Coding: 108102
   ASAM Dataset: EV_VW75XParkAssis8K A01005
   ROD: EV_VW75XParkAssis8K_A01_VN75.rod
   VCID: 34241E989FB66326DF-8060
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H07 0013
   Revision: --------    Serial number: 003HM002866L
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3620249089CA7136E1-8062
   Serial number: 3495ZRB405B0P7HOEHCF
   Serial number: 3505ZRB40510P7AOGGM1
   Part No SW: 7E0 920 980 E    HW: 7E0 920 980 E
   Component: KOMBI         H04 0306
   Coding: 460F01
   VCID: 2D120BFC7C9C32EE90-8078
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                    Reset counter: 3
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 B
   Component: J737__Standheizung  0605
   Revision: 00085000    Serial number: 09019275F00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 2404EED8E756F3A64F-8070
                    Temperature: 28.0°C
                    Voltage: 11.56 V
                    Temperature: 77.5°C
00625 - Vehicle Speed Signal
                    Temperature: 28.0°C
                    Voltage: 11.49 V
                    Temperature: 77.5°C
00667 - Ambient Temperature Signal
                    Temperature: 28.0°C
                    Voltage: 11.49 V
                    Temperature: 77.5°C
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 042300
   VCID: 689CBAE89BFED7C6A3-803C
01304 - Radio
                    Reset counter: 3
                    Reset counter: 3
   Component: IMMO          H04 0306
   VCID: 6A98C0E08DF2E5D6B5-803E
Address 56: Radio
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000509112665
   Coding: 0100000101000000
   VCID: 322818806DA26D16CD-8066
                    Reset counter: 3
Address 78: Slide Door, Right        Labels: Redir Fail!
End----(Elapsed Time: 02:04, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
NEtech
Denmark
C?ID=56995
Check BCM, Channel 099, Factory mode is probably active, must be inactive.
Limalex
London
C?ID=260940
Thank you NEtech. I checked and it is not . I bought a second hand BCM
Limalex
London
C?ID=260940
Ok Local Vw dealer not willing to help unless I buy a brand new BCM from them.
Anyone any idea I should try???
siLc
Tallinn, Estonia
C?ID=330192
Dealers usually insist on installing a component which is appropriate to the particular vehicle as per VIN and which the factory diagnostic tool will adapt to the vehicle without fuss.
What BCM did the car have originally?
Limalex
London
C?ID=260940
They said they not going to code the keys for a second hand BCD because they cannot give warranty for that work.
My original BCM T5GP H+4 H47 0254 7H0 937 087 H
I just do not understand why VCDS cannot do it. Others upgraded the BCD without any issue. What could be the difference with this particular BCD?
RyMar
South Africa
C?ID=133909
Part numbers not the same. BCM are fitted & coded to Vin no (equipment fitted).
I would recommend getting a BCM with the same part no and try coding again.
siLc
Tallinn, Estonia
C?ID=330192
I vaguely remember the retrofit from anything else to a 090 BCM needed wiring work - running additional battery powers to the BCM, which it appears to be currently missing.
There should be threads about the very same thing on this forum.
Limalex
London
C?ID=260940
They are not. It meant to be an upgrade 090D is a T6 BCM
Limalex
London
C?ID=260940
Yes there are some wiring work needed, but that should be a next stage. According to my research everyone who done the BCM upgrade done it without any issue with key coding. However, no-one done it on a Caravelle. Could this might be an issue?
I am trying to get some BCM part numbers and pictures of a T73A/B connectors from a T6 Caravelle on an other forum, but no luck yet. My BCM is from a Transporter
I find out that there are some differences on the BCM's pin layout according to the latest connector pin apssigmrnt list on the wiring diagram, but it nothing to do with key coding either.
Spacewalker
Poland
C?ID=159607
if your BCM is from car after 2019 you not allow to adapt key over BCM
after 2019 all cars use Remote Learn durring key learn ....something like MQB cars
even ODIS mention that , and when you look into IMMo coding - you will see that this function is enable
