2015 Audi Q7 TDI - Can't Code New Battery
MattGreer
Colorado, USA
C?ID=411044
I'm following along, step by step, the YouTube video for coding a new battery. I have the BEM codes from the sticker off the new battery. When I click 'Test' the result is the coding for the old battery, not the new battery. I don't know what I'm doing wrong. First time user here, very new to all of this.
What am I doing wrong? Why won't the car take the new code?
Old Code (including spaces)
8K0915105F  VAO 3F6E06W
(What's interesting is the vendor is VAO, and not VA0.)
New Code:
7P0915105D  JCB 200318I07F
I'm skipping the AutoScan right now because there's several malfunctions and they may be related to the battery; I don't know. But I don't want to detract from the main reason I'm posting. Just trying to get the car to take the code.
MattGreer
Colorado, USA
C?ID=411044
For what it's worth, here's the AutoScan. Says there's a CAN Gateway malfunction, so... perhaps that's the issue?
Looking through these, just about every fault code I looked at had to do with low voltage, which would make sense as my wife tried to start the vehicle with a nearly dead battery, so it makes sense to me that nothing was getting the proper power. I figure I can probably clear most of these.
Either way, still can't code the battery which is 100% of the reason why I bought the cable. :/
Saturday,01,August,2020,21:46:13:17948
VIN: WA1LMAFE4FD032679   License Plate:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 69 6C 6D 6F 72
VIN: WA1LMAFE4FD032679   Mileage: 115070km-71501miles
4C-Tire Pressure II -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
   Component: 3.0TDI FSA    H23 0012
   Revision: 54H23---    Serial number:
   Coding: 2A2A4012253600050000
   Shop #: WSC 06221 003 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401A 001013
   ROD: EV_ECM30TDI0114L2910401A.rod
   VCID: 221DEF71144B90DB647-8076
38161 - Reductant Metering Module
          P20FE 00 [096] - Malfunction
9952 - Catalyst System; Bank 1
          P0420 00 [096] - Efficiency Below Threshold
                    Mileage: 114210 km
                    Date: 2020.07.12
                    Time: 08:57:50
                    Engine speed: 2038.00 /min
                    Normed load value: 85.1 %
                    Vehicle speed: 33 km/h
                    Coolant temperature: 62 °C
                    Intake air temperature: 31 °C
                    Ambient air pressure: 820 mbar
                    Voltage terminal 30: 13.880 V
                    Unlearning counter according OBD: 21
                    Engine torque: 321.6 Nm
                    Current operating mode_2-Bits 0-7: 64
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 2
                    Exh.gas temp.sen 3: 361.6 °C
                    Exh.gas temp.sen 4: 111.4 °C
                    Exh.gas temp.sen 1: 532.4 °C
                    Injection release status-Bits 0-7: 56
17262 - Terminal 30
          U140A 00 [032] - Open Circuit
          [Terminal 30Open circuit]
                    Engine speed: 0.00 /min
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Shut-off timer: last engine shut-off time: 0 s
                    Control module temp.: max. value: -273.1 °C
                    Mean injection quantity: 0.00 mg/stroke
                    Ambient temperature: -273.1 °C
                    Control Module temperature: -273.1 °C
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 0
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
   Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
   Component: AL1000 AISIN  002 3399
   Coding: 001378
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7BA3F215D3610113071-802E
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099441
   Shop #: WSC 31414 790 00001
   VCID: 34311929B23F0E6B86B-8060
                    Reset counter: 32
                    Mileage: 115064 km
                    Date: 2020.07.25
                    Time: 13:24:50
                    Count: 192
                    Count: 11073
                    Count: 128
                    Count: 34304
                    Reset counter: 0
                    Mileage: 115068 km
                    Count: 192
                    Count: 2885
                    Count: 297
                    Count: 32000
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10603902216261
   Coding: 0000135
   VCID: 2517F46D09E567E3015-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H05 0020
   Component: FBSAUDIC6 KSG   H03 0020
00956 - Key 2
                    Fault Status: 01110010
                    Reset counter: 0
                    Reset counter: 31
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:02
                    Reset counter: 31
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:20:37
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000030391771
   Coding: 0304A036
   VCID: 2517F46D05E567E3015-8070
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6E85CB419C9364BBB0F-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:21:00
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:00
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55931516104707
   Coding: 25011E
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 34311929BEBF0E6B86B-8060
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH46 0230
   Revision: 10H46000    Serial number: 0038QDA04DSJ
   Coding: 0014131
   VCID: 2B0302556F015193D71-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME174D3674K
   Subsystem 3 - Serial number: 6342QSME2850485CK
   Subsystem 4 - Serial number: 6352QSME7E531D5C.
   Subsystem 5 - Serial number: 6362QSME174D3E5AZ
   Subsystem 6 - Serial number: 63734SME6C53107E6
   Subsystem 7 - Serial number: 63834SME6953044E4
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026151570190
   Coding: 0012242
   VCID: 2809FD597EF77A8B3A3-807C
   Component: E0221           H03 0040
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 985 Q    HW: 4L0 920 985 Q
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2S422J6G
   Coding: 8BD664040100CF05020205
   VCID: 42DD4FF1F48BB0DB047-8016
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB800038    Serial number: 3800M156111103
   Coding: 00C303
   VCID: 3FDB46058779DD336B9-806A
   Component: J367-BDM  H07 0125
   Serial number: 32152629384121175379
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 146
                    Reset counter: 32
                    Mileage: 109959 km
                    Date: 2020.02.27
                    Time: 17:43:00
                    Fault Frequency: 160
                    Reset counter: 32
                    Mileage: 109959 km
                    Date: 2020.02.27
                    Time: 20:43:00
                    Bin. Bits:    00000
                    Voltage: 12.40 V
                    Count: 18
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Revision: 00---012    Serial number: 00000000480036
   Coding: 0000006
   VCID: 6889BD59BE77BA8BFA3-803C
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0065
   Revision: AA000000    Serial number: 00000149612500
   Coding: 00581B00000011110000
   VCID: 323D1F31442B005B947-8066
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:02
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E050B415C1324BBF0F-807A
   Component: J0770_SWA_Slave_H03 0050
   Subsystem 3 - Serial number: 5F09.06.1500H03000AMS14750ÿ
   Subsystem 4 - Serial number: S14750ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000154647447
   Coding: 011F57205E40440004
   VCID: 48C95DD9D2B79A8BDA3-801C
01705 - Selection Switch for Mirror-Adjust (E48)
                    Fault Frequency: 101
                    Reset counter: 31
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:29:08
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:02
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 82010344530000
   Coding: 3569949
   VCID: 38292D19AE57EA0BAA3-806C
00576 - Terminal 15
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:13:49
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004001    Serial number: 00000000086199
   Coding: 030000
   VCID: 290FF85D69FD438325D-807C
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191106784
   Coding: 0758477
   VCID: 2313EA7507D199D36F1-8076
02214 - Tire Pressure Warning
                    Reset counter: 31
                    Mileage: 114938 km
                    Date: 2020.07.23
                    Time: 13:11:44
                    Hex Value: 0x0070
                    Hex Value: 0x0000
                    Hex Value: 0x0007
                    Voltage: 14.30 V
                    Temperature: 30.0°C
                    (no units): 74.0
                    Fault Status: 00101101
                    Reset counter: 32
                    Mileage: 115064 km
                    Date: 2020.07.25
                    Time: 13:24:51
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0005
                    Voltage: 10.10 V
                    Temperature: 27.0°C
                    (no units): 0.0
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:16:19
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0003
                    Voltage: 10.00 V
                    Temperature: 28.0°C
                    (no units): 255.0
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H17 0100
   Revision:             Serial number: 00000000244341
   Coding: 0012001
   VCID: 5EE59B816C33F43B00F-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000154658228
   VCID: 47CB5EE5DFA995F3D39-8012
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:29:08
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:01
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 150608-0002-006
   Coding: 1147A71010020400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42DD4FF1F40BB0DB047-8016
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156F+0F8281364
   Coding: 020007010000000000
   VCID: 2411E9690EDF9EEB16B-8070
                    Reset counter: 247
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:03
                    Voltage: 8.40 V
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:21:05
                    Voltage: 9.30 V
   Part No SW: 4L2 035 746 G    HW: 4L2 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 513F+0F7528382
   Coding: 180200060004E3EF510023456F632003140000000100000000
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130FN0F3383032
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002256269
   Component: CD-Database  5950
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000154663169
   Coding: 010E57204040230004
   VCID: 46D553E1D8A38CFB28F-8012
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:14:34
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:02
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Component: Anhaenger     H12 0100
   Revision: 2A001001    Serial number: 00000372308963
   Coding: 0200000000000000
   VCID: 313F103D412D3B43EDD-8064
00576 - Terminal 15
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:13:47
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:00
   Revision: --H09---    Serial number: 525PA8-JA541G1
   Coding: 1021201
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:29:02
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 F
   Component: ValeoHeckdeckel H61 0500
   Revision: --H61001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C149AA8F96AB9EB-8038
   Subsystem 2 - Serial number: ó
   Subsystem 3 - Serial number: RD17.06.15--H61001002F0188ÿ
   Subsystem 4 - Serial number: 2F0188ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0153620258----
   Coding: 0003595
   VCID: 2615F36174E36CFB08F-8072
   Component: J_245_EE16_SKB10H15 0220
   Component: J_394_EE16_SKB10H15 0220
   Component: J_392_EE16_SKB10H15 0220
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:00
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000154663170
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:14:34
                    Reset counter: 32
                    Mileage: 115068 km
                    Date: 2020.07.25
                    Time: 14:30:00
End----------(Elapsed Time: 02:18, VBatt start/end: 14.1V/14.2V)-----------
NEtech
Denmark
C?ID=56995
Original spare part for this model is 110 Ah, 000915105DL
Original installed is the 8K0915105F
You are trying to install 105 Ah 7P0915105D
I doubt that is accepted by the controller.
If you want to install that battery, I suggest you try:
000915105CF JCB 200318I07F
           ^ Only 1 space!
But first delete all error codes.
:cool:
MattGreer
Colorado, USA
C?ID=411044
So here's the original battery BEM codes. I guess I don't understand how the coding differs, and why, between the two batteries and what needs to get entered.
Why was the "8K" accepted for the part number for the OEM battery, but the "7P" needs to get replaced by zeros?
Also I noticed that the OEM coding had three blank spaces after the serial number. The serial number, as coded, got truncated for some reason on the OEM battery. I thought it would have been 350614E06W, but what was coded in the car was just "3F6E06W" followed by three spaces.
I'm so confused. I'll go try your suggestion now.
MattGreer
Colorado, USA
C?ID=411044
OK, couldn't go to bed until I'd tried this. And... your code worked. Thank you! I mashed the "clear all DTC"... hope that wasn't a mistake...
Two questions:
1. How did you know what to change?
2. I was hoping to be able to do this on my own, but I couldn't. I had to have someone give me a modified code. And I took that doggone battery out to find the hidden sticker that I wasn't aware of and at the end of the day that code didn't work. So in the future, if I get a different battery someday, how will I know what code to use?
NEtech
Denmark
C?ID=56995
More than 20 year VW diagnostics.
7P0 is VW Touareg part number not Audi.
Part numbers can be found on for example Partlinks24.
Also import Battery history file into VCDSToolbox and see Record 4 hoover.
Part number for your VIN, is 000 915 105 DL (110Ah).
MattGreer
Colorado, USA
C?ID=411044
I do appreciate your help; I couldn't have done this without you!
I was misled to believe that coding a new battery was a simple process. All that's required is the BEM codes but there's more to it than that.
The replacement battery is a Diehard, made in Germany. I realize it's not a 1:1 replacement. But that's what I thought the BEM codes were for, to let the electrical system know the capacity for proper management. 105 Ah vs 110 Ah and so forth.
So part numbers are specific to the car make/model I guess? Touareg/7P0915105D = Q7/000915105CF
It'll be another four years or more before I have to replace the battery, I hope. But I guess I'm going to have to come back here for help. Frustrating.
BEM codes should work fine when one installs the correct battery. ;)
But you didn't really think that Audi would want you to install a Volkswagen battery, did you? :D
MattGreer
Colorado, USA
C?ID=411044
It goes without saying that I'm quite the n00b here and behind the times. :) This is (obviously) the first time I've had to replace the battery on the Q7. I never would have guessed that this Diehard battery is a *VW* battery. A battery is a battery, or so I thought. Either you have enough CCA or you don't. BUT, no so anymore. :) I'm just one of those regular folks that enjoys wrenching on my car now and again, plus saving $400 on a battery replacement is nothing to sneeze at either. I think the price of this Diehard vs the Audi replacement is probably pretty comparable but at the time, you have a dead battery, gotta get it replaced, just run over to your local auto parts store and get the replacement that they say fits. Never had an issue before.
Sorry for all the posts on this but I'm the curious sort and I really enjoy learning. I contacted Clarios about the trouble I was having so I'll see if I can figure out how to translate from one battery part number to another. I'm going to keep poking at this until I feel like I really understand everything or I've exhausted these support forums. :banghead:
Indeed, a battery is pretty much a battery, but the BEM code you tried to use is based on a VW part number, not an Audi part number. ;)
Next time you change the battery, worst case, just change one digit of the serial number and leave everything else the same (assuming of course that you're installing a battery with the same specs as the current one).
MattGreer
Colorado, USA
C?ID=411044
That's what I figured, hopefully battery specs will be the same on the next one!
MattGreer
Colorado, USA
C?ID=411044
OK, I think I have a final solution, albeit not a great one, but it's what I have for the moment.
I simply searched on the BEM part number for the Diehard battery and I happened to come upon this website: https://oemwolf.com/oem-parts/7p0915105d.html
So, in the future, should I run into an issue coding a new battery, searching for the part number may provide some clue as to what part number must be used in its place.
