S8 v10 no lambda trims
AndyC1976
Dorset, UK
C?ID=276161
Guys.
2006 S8 V10
I have no fuel trims at all
ZERO % on every channel
Only fault is BANK 2 SENSOR 2 heater circuit
Obviously fix this, but I have never seen a post cat cause failure of fuel trims to activate.
Wideband is still reading, you can see the voltage and calibrated value but nothing more
Any ideas
Have you checked MVB 032 in both ECUs?
AndyC1976
Dorset, UK
C?ID=276161
Yes, all zero
AndyC1976
Dorset, UK
C?ID=276161
Yes, all zero
AndyC1976
Dorset, UK
C?ID=276161
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0F 11 31 15 16 17 19 1D 1E 34 36 37
          38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76 77
VIN: WAUZZZ4E17N003524   Mileage: 133410km-82897miles
1D-Driver Ident. -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
   Part No SW: 4E0 910 552     HW: 4E0 907 552
   Component: 5.2L V10/4V FSI    0060
   Revision: 5AH11---    Serial number: AUX3Z0F5397047
   Coding: 01060003190F0160
   Shop #: WSC 00191 264 15243
   VCID: 5F9A5A966B36C8730A1-800A
005170 - Secondary Air Injection Solenoid Valve (N112)
               P1432 - 004 - Open Circuit
                    Mileage: 133331 km
                    Date: 2020.08.03
                    Time: 13:15:32
                    RPM: 167 /min
                    Load: 60.4 %
                    Temperature: 64.0C
                    Temperature: 50.0C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 10.033 V
004416 - Oxygen (Lambda) Sensor; B2 S2
               P1140 - 008 - Internal Resistance too High
                    Fault Status: 01101000
                    Mileage: 133337 km
                    Date: 2020.08.03
                    Time: 13:26:49
                    RPM: 2406 /min
                    Load: 50.6 %
                    Speed: 109.0 km/h
                    Temperature: 101.0C
                    Temperature: 30.0C
                    Voltage: 13.970 V
000352 - Oxygen (Lambda) Sensor B2 S2
               P0160 - 004 - No Activity
                    Mileage: 133337 km
                    Date: 2020.08.03
                    Time: 13:26:49
                    RPM: 2406 /min
                    Load: 51.7 %
                    Speed: 109.0 km/h
                    Temperature: 101.0C
                    Temperature: 30.0C
                    Voltage: 13.970 V
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E1 910 156 K    HW: 09E 927 156 B
   Component: AG6 09E 5,2 FSI RdW 0020
   Revision: --H01---    Serial number:        0086483
   Coding: 0000001
   Shop #: WSC 02313 785 00200
   VCID: 2B02FE466F0E64D3D69-807E
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 D    HW: 4E0 614 517 AB
   Component: ESP 5.7 allrad  H46 0500
   Coding: 0001627
   VCID: 2410157A02D0ABAB173-8070
00003 - Control Module
            014 - Defective
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 K
   Component:     FBS AUDID3  H10 0190
   Revision: 01904910    Serial number: AUX3Z0F5397047
   Coding: 0412672
   Shop #: WSC 02311 785 00200
   VCID: 58E8718A0E183F4B4BB-800C
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 D    HW: 4E0 959 760 B
   Component: Sitzmemory BFS H02  0010
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 769 Q    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 300FJ067569032
   Coding: 0020002
   Shop #: WSC 00000 000 08192
   VCID: 3A2CCB029054CD5B5DF-806E
   Subsystem 1 - Part No: 4E0 910 611
   Component: E0380 BedienteilH03 0040
   Subsystem 2 - Serial number: 00000000013249
   Subsystem 3 - Serial number: 0130.06.060000000100010003
   Subsystem 4 - Serial number: 010003
Address 08: Auto HVAC        Labels: User\4E0-910-043.lbl
   Part No SW: 4E0 910 043 B    HW: 4E0 820 043 G
   Component: KLIMAAUTOMAT    017 0450
   Revision: 00000032    Serial number: 00000000100198
   Coding: 0057705
   VCID: 1C602D9A3AA0936BAF3-8048
00739 - Coolant Circulation Pump (V50)
                    Reset counter: 227
                    Mileage: 133174 km
                    Date: 2020.07.30
                    Time: 11:54:34
                    Temperature: 53.0C
                    Fault Status: 00100011
                    Reset counter: 9
                    Mileage: 133240 km
                    Date: 2020.07.31
                    Time: 14:20:59
                    Temperature: 29.0C
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 Q    HW: 4E0 907 279 Q
   Component: ILM Fahrer      H15 0230
   Coding: 0133121
   VCID: 3634DF32A44C293BB97-8062
   Subsystem 1 - Part No: 4E2 910 113 B
   Component: Wischer WWS D3  H50 0420
   Coding: 00000035
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0090
   Coding: 00141886
   Shop #: WSC 02313
                    Reset counter: 8
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276U8200119
   Coding: 0000001
00856 - Radio Antenna
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 228
                    Mileage: 133331 km
                    Date: 2020.08.03
                    Time: 13:15:21
                    Voltage: 11.80 V
Address 11: Engine II        Labels: Redir Fail!
Address 15: Airbags        Labels: 4E0-910-655-94.lbl
   Part No SW: 4E0 910 655 D    HW: 4E0 959 655 H
   Component:    Airbag 9.41  H13 3710
   Revision: 91H13371    Serial number: 0037P000LLH8
   Coding: 0431707
   VCID: 270A027673E640B3321-8072
   Subsystem 1 - Serial number: 63328RB40149CCB3U
   Subsystem 2 - Serial number: 63428RB40149CD2BV
   Subsystem 3 - Serial number: 63528RB40149CD58W
   Subsystem 4 - Serial number: 63628RB40149CD51Q
   Subsystem 5 - Serial number: 63729RB400D7577F.
   Subsystem 6 - Serial number: 63829RB400D757E1V
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenks䵬enmodul H14 0040
   Coding: 0112141
   VCID: 6596487E496A92A3C0D-8030
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 951 E    HW: 4E0 920 951 E
   Component: KOMBIINSTR. VDO H82 0520
   Revision: D03         Serial number: AUDID3F5000055
   Coding: 0012414
   Shop #: WSC 80093 222 69422
01704 - Terminal 58 (Dimming)
            007 - Short to Ground
                    Fault Status: 00000011
                    Reset counter: 227
                    Mileage: 133331 km
                    Date: 2020.08.03
                    Time: 13:15:09
Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B066178190
   Coding: F5D5DFFF507E1E
   VCID: 6C803D5AAA80A3EB9F3-8038
Address 1D: Driver Ident.        Labels: 4E0-910-218.lbl
   Part No SW: 4E0 910 218 A    HW: 4E2 905 218 B
   Component: FPI_1           H01 0020
   Revision: 01000102    Serial number: 28062006211639
   VCID: 1F1A1A962BB688734A1-804A
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8142506
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Coding: 0015510
   Shop #: WSC 67916 260 51396
   VCID: 2A0CFB4260F47DDB2DF-807E
   Component: Sitzmemory FS  H02  0010
   Coding: 3670126
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364FN067571042
   VCID: 3B22CE069F6EF453469-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H04 0090
   Serial number: 00000617500037
   Coding: 0036048
   VCID: 1D66209E21BA9A6358D-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 802 B
   Component: Trsteuer.FS BRM003 0100
   Coding: 0032623
   VCID: 2018196A16C8B78B73B-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 D    HW: 4E0 907 289 D
   Component: Komfortgeraet   H07 0010
   Revision: 00100007    Serial number:  W040606290053
   Coding: 0004863
   Subsystem 1 - Part No: 4E0 910 853
   Component: Heckdeckel   P27H08 0090
   Subsystem 2 - Part No: 4E0 907 719
   Component: Neigungssensor  H05 0020
                    Fault Status: 01101100
                    Reset counter: 71
                    Mileage: 122856 km
                    Date: 2015.05.30
                    Time: 20:50:08
                    Reset counter: 71
                    Mileage: 122856 km
                    Date: 2015.05.30
                    Time: 20:50:08
Address 47: Sound System        Labels: None
   Part No SW: 4E0 910 466 D    HW: 4E0 035 466
   Component: BO_D3           H06 0320
   Revision: 12S00002    Serial number: 02006060003597
   Coding: 0000027
   Subsystem 1 - Part No: 4E0 910 465 B
   Component: BO_D3_SLAVE     H31 0310
   Subsystem 2 - Serial number: 00806060001447
   Subsystem 3 - Serial number: 0208.06.060000000100030003
   Subsystem 4 - Serial number: 030003
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 B
   Component: ILM Beifahrer   H11 0070
   Revision:             Serial number: 00000000000515
   Coding: 0010101
   VCID: 1E6427922CBC817B417-804A
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E2 959 801 B
   Component: Trsteuer.BF BRM003 0100
   Coding: 0032623
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0000731
   Shop #: WSC 00505 067 57207
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000018
   VCID: 290E044E65F276C3245-807C
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 396FW067541274
   Coding: 0000001
   VCID: 313EEC2E4D220E03EC5-8064
                    Fault Frequency: 17
                    Reset counter: 227
                    Mileage: 128310 km
                    Date: 2020.02.15
                    Time: 18:12:11
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R0078 TVhybridT     0470
   Revision: R0H05000    Serial number: 76300700396401
   Coding: 0000003
   VCID: 2516087E09EA52A300D-8070
00866 - Antenna 4 for TV (R58)
                    Reset counter: 228
                    Mileage: 133334 km
                    Date: 2020.08.03
                    Time: 13:24:22
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H12 0550
   Revision: 00000000    Serial number: 00000000011253
   Shop #: WSC 00000 128 00289
   Subsystem 1 - Part No: 4E0 915 105 DL
   Component: von VA0  3802046OB5
   Coding: 344530393135313035444C564130333830323034364F4235
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Trsteuer.HL BRM003 0100
   Coding: 0032623
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05
   Revision: 00050340    Serial number: 00000900046087
   Coding: 0212333
   Shop #: WSC 12345 000 00000
                    Fault Status: 00101101
                    Reset counter: 6
                    Mileage: 133174 km
                    Date: 2020.07.30
                    Time: 11:20:31
                    (no units): 0.0
                    Voltage: 0.00 V
                    (no units): 27.0
                    Temperature: 23.0C
                    Temperature: 24.0C
                    Temperature: 21.0C
                    Temperature: 26.0C
   Part No SW: 4E0 910 754 S    HW: 4E0 035 753 A
   Component: SDS 3502 UK     H45 0630
   Revision: 00000000    Serial number: 00000606230360
   Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam.        Labels: 4E0-910-441.clb
   Part No SW: 4E0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6610AZ
   Coding: 1021302
   VCID: 5CE06D9A7A20D36B6F3-8008
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: Trsteuer.HR BRM003 0100
   Coding: 0032623
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 C    HW: 4E0 919 283 C
   Component: Parkhilfe 8-Kan H12 0040
   Revision: 00H12000    Serial number: 08720617900066
   Coding: 0321008
   VCID: 2312166607DEAC936E9-8076
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H13 1130
   Revision: 00000000    Serial number: 00000007539963
   Coding: 0010900
   Shop #: WSC 00164 210 89663
   VCID: 2C00FD5A6A0063EBDF3-8078
End----------(Elapsed Time: 02:17, VBatt start/end: 12.2V/12.2V)--
AndyC1976
Dorset, UK
C?ID=276161
Anyone got any ideas
