Climate Control Button Lighting
jwadle
C?ID=149894
On a Mk7.5 GTI, I'm looking for coding to set the climate controls buttons to be lit at all times. Very difficult to see them during the day with sunglasses on.
Thanks for any help.
Have we got an Auto-Scan from this car somewhere here? If so, please link to it. If not, please post one.
jwadle: I'm not sure if you are aware - but MQB platform vehicles use "Dimming Characteristic" curves to modulate the illumination of some of the LED based lights inside the cabin. These curves use reference points on a virtual X/Y axis to set the lighting levels of the LEDs. Whether there is user access to individual LEDs really depends on the LED in question and the model of the car; in general, there appears to be a tendency towards giving less access on newer models.
Anyhow, pending confirmation of the information in your auto-scan and based on the stuff in my database, the functions of the individual curves in the hex08 module (if access is available) is as follows:
Dimming_characteristic_2 = Temperature display
Dimming_characteristic_3 = LED fan
Dimming_characteristic_4= LED Seat heating
Dimming_characteristic_5 = Other LEDs
Again, assuming that your particular module allows access, you can rebuild these curves to suit your own desires. As a starting point - try changing the higher "Y" values to see the effect.
jwadle
C?ID=149894
Thanks for this.
My car does have the dimming_characteristic parameters. I tried changing them from their OEM settings (10-21%) to 100% (which I assume means as bright as possible). This produced no visible result when the car is in daylight with the light switch in Auto, i.e. the LEDs appear to be very dim or off. At night, they are dimly lighted.
Any other thoughts?
Any other thoughts?
jwadle: hmm............... yes, thoughts-a-plenty!!!
This said, I must admit at being somewhat surprised (and more than a tad incredulous) at reading your observations. Like death, taxes and the basics laws of the universe -I consider the operation of Dimming Characteristic curves to be immutable (at least it's fixed in my understanding of how PWM dimming works for LEDs on MQB platform vehicles).
But, since I like to think of myself as being a not unreasonable bloke and based on your findings in the post above - I'm prepared to re-consider my (now) tentatively delusional comprehension of these curves.
However, before I abandon a basic tenet in my long-held understanding of this matter, I'd value a look at the auto-scan for the vehicle in question (as previously requested by Uwe) and a copy of the adaptation channel map for the hex08 module would also be helpful.
For the admap, please set-up the dialogue box as shown below. Of course, enter "08" into Single Controller Address box instead of "09" as shown - the picture was developed for another purpose.
jwadle
C?ID=149894
I'm attaching an Auto-Scan and the Adaptation Channel Map for module 08. As you can see, the values for Dimming_characteristic_2,3,5 parameter Y4 are set to 100%. I see no difference in lighting of the climate controls in any condition (day, night, Auto lighting, etc.).
Any additional suggestions would be appreciated.
Tuesday,04,August,2020,14:59:46:61921
VIN: 3VW6T7AU2KM013597   License Plate:
Mileage: 7929km-4926mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 29 2B 32 39 3C 42 44 47
          4B 52 5F 75 81 A5 A9 D6 D7
VIN: 3VW6T7AU2KM013597   Mileage: 7929km-4926miles
81-Gear Shift -- Status: Cannot be reached 0100
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 092500324464012F1000
   Shop #: WSC 00066 790 00174
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C2133DD66E4B9FB4EB-8068
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2404
   Revision: 00H06V08
   ROD: EV_TCMDQ381061.rod
   VCID: 2615F1B58868132B08F-8072
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 53588000000750
   Coding: 01FA6BA15021216F807C020960CA6880D60A840140061676364150D1D0A94B0B0000000012121212B835351919323200
   Shop #: WSC 00066 790 00160
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 0655913568A8332B68F-8052
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0502711070
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D348211B1AC6030F1-8016
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05
   Coding: 0002001420011800110400401211100C
   Shop #: WSC 12345 123 61029
   VCID: 48C95F0D223CE55BDA3-801C
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C8641201190429
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7BA3F0C1236A7EC3071-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    181119  043 0551
   Serial number: 97022066181130225405
   Coding: 2E4DDD
   Component: RLHS  052 0107
   Serial number: SBY18M11D13H18M56S12
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691603832909180952
   Coding: 181803
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300250120190C200119
204546 - Remote key 2
          B147A 18 [009] - Current Too Low
                    Reset counter: 0
                    Mileage: 7875 km
                    Date: 2020.08.02
                    Time: 10:27:31
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000137089R19008
   Coding: 0271167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51FF7269D16624938DD-8004
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 350000C141FFC728949C810520401600000000000000000004
   VCID: 44D14B3D1E14C13B36B-8010
   Serial number: 17101841350905
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292FCD52DC95DBAA3-806C
   Serial number: 003GCR0AWE4W
   VCID: 47CB5C312F22EA23D39-8012
   Occupant Detection:
   Serial number: IBH00000000000AVVTY9
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 312 18
   Serial number: 35700000000170754534
   Subsystem 3 - Part No SW: -----------    HW: 480 002 611 18
   Serial number: 3580000000021A607638
   Subsystem 4 - Part No SW: -----------    HW: 480 401 409 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001BF2C06196463%
   Subsystem 5 - Part No SW: -----------    HW: 480 402 109 18
   Component: SideSensor_Pr  003 6149
   Serial number: 35200019D2E1DC43B39J
   Subsystem 6 - Part No SW: -----------    HW: 480 400 701 19
   Component: FrontSensor_D  003 6149
   Serial number: 3550001992DD6DD331DQ
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 701 19
   Component: FrontSensor_P  003 6149
   Serial number: 3560001992DD6DD3916Q
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 0BAD091AFD88CF0502886B0B50010000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2F3B1491A7925263FB9-807A
   Serial number: 25011900840053
   Coding: 030100047F085900FB00027B9C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C99560181B6BB0F-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002739790078471
   Coding: 2DFFFF
   Serial number: 2387506200
131667 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x53]
                    Reset counter: 37
                    Mileage: 7875 km
                    Date: 2020.08.01
                    Time: 13:27:27
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000378891003
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F12E9B1A64493EDD-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00007.11.18
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7D65D4605F8BB47-8006
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0501740280
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D273ED97DFEB0F3795-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0502034143
   Coding: 020111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038902301316
   Coding: 003F13205000040000000000
   VCID: 4FFB7411C75232639B9-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001589574
   Coding: 011000
   Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 931F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F9776DDA6C2D9B823-8004
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD03PL6-
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E050995A0985B6BF0F-807A
   Component: FCM MQB Low   002 0345
   Serial number: 14011900842303
   Coding: 000000050900214A07110F01030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 353726F945CE68B3B15-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038901100158
   Coding: 003F13205C00040000000000
   VCID: 4EC56915C0583B6B90F-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001588058
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027310020000000041220002001808009F0503F401200505C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 333318E14BBA76839F1-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  252 8130
   Serial number: VWZ6ZMW0335116
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Component: OCULowMQBUS   009 0570
   ROD: EV_OCULowMQB.rod
Address 81: Gear Shift
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 15111815K21128
   Coding: 000307000002020100221354C150490084000E20012000
   Shop #: WSC 01383 790 50316
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D9472D0A0CDD1B123-8014
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 181012203246
   VCID: 323D1DE5B4A07F8B947-8066
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2AC969D68CD355D-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 01:52, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
SW:5GM-907-044-G   HW:5GM-907-044-G ---  Auto HVAC
;Component:Climatronic   H04 2001	 Coding:0002001420011800110400401211100C
;EV_ACClimaBHBVW37X	6146	EV_ACClimaBHBVW37X_006_VW37.rod
;Tuesday	4	August
;VCDS Version: Release 20.4.2 (x64)  Data version: 20200730 DS317.0
;VCID: 48C95F0D223CE55BDA3-801C
IDE00001-Production mode	Deactivating 	3
IDE01067-Retention of driver's seat heater level	active for 10 minutes 	1
IDE01478-Ignore compressor switch-off by Engine Control Module	Do not ignore 	1
IDE01479-Gear ratio of engine - A/C compressor	0	1
IDE01483-Blower voltage for voice operation	not activated 	1
IDE01488-Retrofitting of parking heater without CAN	not installed 	1
IDE01493-Air quality sensor sensitivity	Maximum 	1
IDE01503-Runtime for compressor run-in basic setting	60 s	1
IDE01536-Post-heating of parking heater	0 min	1
IDE02155-Reset all counters	not activated 	1
IDE02332-Deactivate production mode	0	3
IDE03176-Duration of compressor run in	60 s	1
IDE03251-Stop release for start-stop function	According to function requirements 	1
IDE04159-Deactivation of start-stop function	not active 	1
IDE06097-Target temperature of A/C - heater function via remote control	22.0 °C	1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed)	1500 /min	1
IDE06545-Blower voltage for production routines	12.0 V	1
IDE06546-Interior target temperature for production routines	22 °C	1
IDE06547-Air distribution for production routines	No effect 	1
IDE06593-Recirculation air for production routines	No effect 	1
IDE07108-Climate modes	Matching coding 	1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module	20 min	2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus	30 min	2
IDE07301-Remote start function: activation of seat heating	Seat heater front 	1
IDE07302-Remote start function: interior climate control status	Remote start function with fixed rated temperature active 	1
IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.	4 °C	1
IDE07304-Remote start function: activation of seat ventilation	activated 	1
IDE07305-Rem. start funct.: activat.temper. of seat heating	15 °C	1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation	20 °C	1
IDE07307-Remote start function: activation stage of seat heating	2	1
IDE07308-Remote start function: activation stage of seat ventilation	2	1
IDE07398-Blower logic for manual adjustment	Matching coding 	1
IDE07585-Hand heater function during cold start	active 	1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost	not active 	1
IDE07948-Retention of frt.pass. seat heater level	not active 	1
IDE12229-Filtering of interior air: store	Service life-dependent store 	1
IDE80006-Analysis 6	not activated 	1
IDE80007-Analysis 7	00000000 00000000  	2
IDE80008-Analysis 8	not active 	1
MAS05739-CO2 compressor on-time reduction	Matching coding 	1
MAS06564-Window condensation exterior reduction at high humidity	Matching coding 	1
MAS07251-Cut-in behavior	Matching coding 	1
MAS14860-Remote start function: windshield defogger takeover	activated 	1
MAS14861-Remote start function: windshield defogger	activated 	1
ENG122844-ENG101574-dimming_characteristic_1-X1	0	12
ENG122844-ENG99557-dimming_characteristic_1-X2	6	12
ENG122844-ENG102140-dimming_characteristic_1-X3	40	12
ENG122844-ENG102936-dimming_characteristic_1-X4	60	12
ENG122844-ENG103548-dimming_characteristic_1-X5	80	12
ENG122844-ENG113992-dimming_characteristic_1-X6	100	12
ENG122844-ENG99777-dimming_characteristic_1-Y1	0%	12
ENG122844-ENG100480-dimming_characteristic_1-Y2	6%	12
ENG122844-ENG100773-dimming_characteristic_1-Y3	40%	12
ENG122844-ENG100631-dimming_characteristic_1-Y4	60%	12
ENG122844-ENG102174-dimming_characteristic_1-Y5	80%	12
ENG122844-ENG113993-dimming_characteristic_1-Y6	100%	12
ENG122845-ENG101574-dimming_characteristic_2-X1	0	12
ENG122845-ENG99557-dimming_characteristic_2-X2	10	12
ENG122845-ENG102140-dimming_characteristic_2-X3	50	12
ENG122845-ENG102936-dimming_characteristic_2-X4	100	12
ENG122845-ENG103548-dimming_characteristic_2-X5	220	12
ENG122845-ENG113992-dimming_characteristic_2-X6	253	12
ENG122845-ENG99777-dimming_characteristic_2-Y1	2%	12
ENG122845-ENG100480-dimming_characteristic_2-Y2	2%	12
ENG122845-ENG100773-dimming_characteristic_2-Y3	10%	12
ENG122845-ENG100631-dimming_characteristic_2-Y4	100%	12
ENG122845-ENG102174-dimming_characteristic_2-Y5	85%	12
ENG122845-ENG113993-dimming_characteristic_2-Y6	100%	12
ENG122846-ENG101574-dimming_characteristic_3-X1	0	12
ENG122846-ENG99557-dimming_characteristic_3-X2	10	12
ENG122846-ENG102140-dimming_characteristic_3-X3	50	12
ENG122846-ENG102936-dimming_characteristic_3-X4	100	12
ENG122846-ENG103548-dimming_characteristic_3-X5	220	12
ENG122846-ENG113992-dimming_characteristic_3-X6	253	12
ENG122846-ENG99777-dimming_characteristic_3-Y1	3%	12
ENG122846-ENG100480-dimming_characteristic_3-Y2	3%	12
ENG122846-ENG100773-dimming_characteristic_3-Y3	6%	12
ENG122846-ENG100631-dimming_characteristic_3-Y4	100%	12
ENG122846-ENG102174-dimming_characteristic_3-Y5	100%	12
ENG122846-ENG113993-dimming_characteristic_3-Y6	100%	12
ENG122847-ENG101574-dimming_characteristic_4-X1	0	12
ENG122847-ENG99557-dimming_characteristic_4-X2	10	12
ENG122847-ENG102140-dimming_characteristic_4-X3	50	12
ENG122847-ENG102936-dimming_characteristic_4-X4	100	12
ENG122847-ENG103548-dimming_characteristic_4-X5	220	12
ENG122847-ENG113992-dimming_characteristic_4-X6	253	12
ENG122847-ENG99777-dimming_characteristic_4-Y1	2%	12
ENG122847-ENG100480-dimming_characteristic_4-Y2	2%	12
ENG122847-ENG100773-dimming_characteristic_4-Y3	5%	12
ENG122847-ENG100631-dimming_characteristic_4-Y4	10%	12
ENG122847-ENG102174-dimming_characteristic_4-Y5	85%	12
ENG122847-ENG113993-dimming_characteristic_4-Y6	100%	12
ENG122848-ENG101574-dimming_characteristic_5-X1	0	12
ENG122848-ENG99557-dimming_characteristic_5-X2	10	12
ENG122848-ENG102140-dimming_characteristic_5-X3	50	12
ENG122848-ENG102936-dimming_characteristic_5-X4	100	12
ENG122848-ENG103548-dimming_characteristic_5-X5	220	12
ENG122848-ENG113992-dimming_characteristic_5-X6	253	12
ENG122848-ENG99777-dimming_characteristic_5-Y1	2%	12
ENG122848-ENG100480-dimming_characteristic_5-Y2	2%	12
ENG122848-ENG100773-dimming_characteristic_5-Y3	5%	12
ENG122848-ENG100631-dimming_characteristic_5-Y4	100%	12
ENG122848-ENG102174-dimming_characteristic_5-Y5	85%	12
ENG122848-ENG113993-dimming_characteristic_5-Y6	100%	12
ENG130577-Knockout_timer_activation	not activated 	1
jwadle: hmm........ the admap ain't quite a .CSV format. Not sure why my suggestions keep not working for you - perhaps it's my heavy Australian accent :)? But never mind - where there is a will, there is normally a way of dealing with idiosyncratic stuff like this - that occasionally happens.
However, before we consider the hex08 matter - there seems to be a more interesting issue happening in the Gateway installation list on your auto-scan report. Apparently the hex19 module is bitterly disappointed that it can't find an "undefined" module that has been programmed as being installed. The curious question about the identity of the mysterious "undefined" module might be answered further down the auto-scan report by the "cannot be reached" DTC for the hex81 module. I've never seen a MQB platform vehicle with a separate Gear Shift module; normally control of the shift mechanism in a DSG gearbox happens in the hex02 module. Can you advise how this nebulous module became registered in the Gateway installation list-please?
So, to the hex08 (non-.CSV) admap -it seems that the entire structure of the dimming_characteristic channels is (almost) identical to the myriad of other vehicles in my MQB database. I say "almost" because there are a few odd channel settings that may be remnants of your attempts to implement my previous suggestions - these changes should be reverted to their original factory settings.
Again, without intending any offense to your previous observations, my confirmation of the normalcy of the LED dimming control channels in your car strengthens my resolve in how the characteristic curve process operates. If you are prepared to try again, I suggest the following to demonstrate my hypothesis:
Let's experiment with LED for heated seats on the AC panel (I assume that your car has heated front seats because of the long-code setting in your auto-scan for this option in the BCM).
Change the setting for the channels below to 100%
dimming_characteristic_4-Y1 (2%)
dimming_characteristic_4-Y2 (2%)
dimming_characteristic_4-Y3 (5%)
dimming_characteristic_4-Y4 (10%)
dimming_characteristic_4-Y5 (85%)
dimming_characteristic_4-Y6 (100%)
If my understanding is correct, this should set the LED to maximum illumination under ALL cabin lighting conditions and for ALL LDS positions. Does this happen?
PS: The bracketed values in the list above are your current settings for these channels -please return these values after the experiment
jwadle
C?ID=149894
I have attached the .csv version of the hex08 admap below.
;SW:5GM-907-044-G   HW:5GM-907-044-G ---  Auto HVAC
;Component:Climatronic   H04 2001, Coding:0002001420011800110400401211100C
;EV_ACClimaBHBVW37X,006146,EV_ACClimaBHBVW37X_006_VW37.rod
;Tuesday,04,August,2020,15:04:22:61921
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01479-Gear ratio of engine - A/C compressor,0.00 ,1
IDE01483-Blower voltage for voice operation,not activated ,1
IDE01488-Retrofitting of parking heater without CAN,not installed ,1
IDE01493-Air quality sensor sensitivity,Maximum ,1
IDE01503-Runtime for compressor run-in basic setting,60 s,1
IDE01536-Post-heating of parking heater,0 min,1
IDE03176-Duration of compressor run in,60 s,1
IDE03251-Stop release for start-stop function,According to function requirements ,1
IDE04159-Deactivation of start-stop function,not active ,1
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min,1
IDE06545-Blower voltage for production routines,12.0 V,1
IDE06546-Interior target temperature for production routines,22 °C,1
IDE06593-Recirculation air for production routines,No effect ,1
IDE07108-Climate modes,Matching coding ,1
IDE07301-Remote start function: activation of seat heating,Seat heater front ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.,4 °C,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,15 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20 °C,1
IDE07307-Remote start function: activation stage of seat heating,2 ,1
IDE07308-Remote start function: activation stage of seat ventilation,2 ,1
IDE07398-Blower logic for manual adjustment,Matching coding ,1
IDE07585-Hand heater function during cold start,active ,1
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,not active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE80006-Analysis 6,not activated ,1
IDE80007-Analysis 7,00000000 00000000  ,2
IDE80008-Analysis 8,not active ,1
MAS05739-CO2 compressor on-time reduction,Matching coding ,1
MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
MAS07251-Cut-in behavior,Matching coding ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,100 %,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
ENG122846-ENG99777-dimming_characteristic_3-Y1,3 %,12
ENG122846-ENG100480-dimming_characteristic_3-Y2,3 %,12
ENG122846-ENG100773-dimming_characteristic_3-Y3,6 %,12
ENG122846-ENG100631-dimming_characteristic_3-Y4,100 %,12
ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %,12
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
ENG122848-ENG100631-dimming_characteristic_5-Y4,100 %,12
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
ENG130577-Knockout_timer_activation,not activated ,1
I will try the dimming settings you suggested for the seat heating controls.
In response to your other observations:
  • I am not aware of any changes to my OEM hex08 settings other than the three Y4 dimming parameters I set to 100% as I described in my earlier message. I would like to know which other parameters seem unusual to you.
  • Regarding your observations on the DSG settings: My car has APR Stage 1 software for both the ECU and TCU (DSG) which may explain what you noticed.
Thanks again for your assistance.
- Jack
jwadle
C?ID=149894
- Jack
I have made the changes you suggested on all dimming_characteristic_4 Y parameters. With these set to 100% I see no difference between the seat heating controls and all other climate controls.
- Jack
Jack: Thanks for the feedback. Hmm....... OK - then I must apologize for my insistence!!
