How to link ecm and tcu together
TMD Auto
C?ID=413117
Customer came into shop with a blown ecu tcu. just purchased the hex-net software need to figure out how to code it to shut lights off on dash. Immobilizer light flashing ecu is chipped with a eurodyne tune and immobilizer is defeated need to get the light to stop flashing. Also tcu is in limp mode no power here is an auto scan any help would be much appreciated.
31,July,2020,12:14:23:55284
VCDS Version: 20.4.1.0 (x64)  HEX-NET2 CB: 0.4527.4
VIN: WAULC68E33A318682   License Plate:
Mileage: 230840km-143437mi   Repair Order: derek
Chassis Type: 8E (8D - Audi A4/S4/RS4 B5 (1995 > 2002))
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: WAULC68E33A318682   Mileage: 230840km-143437miles
Address 01: Engine        Labels: 06B-909-518-AMB.lbl
   Part No SW: 8E0 909 518 AK    HW: 8E0 9
   Component: 1.8L R4/5VT     G   0003
   Coding: 0016501
   Shop #: WSC 79159 665 435750
   VCID: 79A486B105C42D83145-5160
18020 - Engine Control Module Incorrectly Coded
            P1612 - 001 -
17699 - Coolant Temp Sensor at Radiator Outlet (G83)
            P1291 - 001 - Signal too Large
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8E0 927 156 P
   Component: AG5 01V 1.8l5VT USA 1213
   Coding: 0000012
   Shop #: WSC 08182 444 00375
   VCID: 3B285CB94F78DF93469-5160
18249 - Engine Control Module / Transmission Control Module Incompatible
            P1841 - 003 -
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 H
   Component: ABS/ESP allrad      2328
   Coding: 04277
   Shop #: WSC 06435
   VCID: 2D0C62E1840C4123C8D-51CE
18257 - Please check DTC Memory of Transmission Controller
            P1849 - 35-00 -
   Part No: 8E0 820 043 L
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 63351
   VCID: 2A0669FDB5E2561B2DF-5160
            41-10 - Blocked or No Voltage - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
01232 - A/C Compressor Regulator Valve (N280)
            07-00 - Signal too Low
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 C
   Component: Airbag 8.4EP        2000
   Coding: 0010607
   Shop #: WSC 63351 000 00000
   VCID: 372040897350FBF3A21-5184
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 00041
   Shop #: WSC 63351
   VCID: 3E2E55AD596ACABB617-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 L
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 03200
   Shop #: WSC 12345
   VCID: 3236719D9D321EDB95F-5160
   WAULC68E63A313847     AUZ6Z0B0398609
01177 - Engine Control Unit
            65-10 - Unauthorized - Intermittent
I am skeptical this can be fixed via coding. I suspect you have the wrong ECU part number there.
What were the original ECU and TCU part numbers, and how did both of them end up "blown"?
TMD Auto
C?ID=413117
power was supplied to a ground circuit when vehicle was running killed the car and the rest is history
TMD Auto
C?ID=413117
any ideas before i ship this thing to the dealer is it possible i can flash a new file on the cpu/tcu to make things work again any thoughts would be greatly appreciated.
TMD Auto
C?ID=413117
TMD Auto
C?ID=413117
FIXED!!!! thanks for the input guys much appreciated
TMD Auto
C?ID=413117
Please elaborate. :thanks:
Soft coding was wrong in the ecu causing the the ecu/tcu to lock out and be put into limp mode. as i re-read what i posted on my autoscan the light bulb went off i recoded the soft coding to 0016751 and all was well.
