I need some help to activate the rear lights on Golf.
I want to enable taillights with the front led drl's when the light
switch is sett to auto.
New eu rules do not require taillights , but it is safer to have them on
all the time.
all the time.
> Chassis Type: 1K (7N0)
> Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 25 2B 42 44 46 52 55
> 56 62 72 77
> VIN: WVWZZZ1KZCW162412
> 01-Engine -- Status: OK 0000
> 02-Auto Trans -- Status: OK 0000
> 03-ABS Brakes -- Status: OK 0000
> 04-Steering Angle -- Status: OK 0000
> 05-Acc/Start Auth. -- Status: OK 0000
> 08-Auto HVAC -- Status: OK 0000
> 09-Cent. Elect. -- Status: OK 0000
> 10-Park/Steer Assist -- Status: OK 0000
> 15-Airbags -- Status: OK 0000
> 16-Steering wheel -- Status: OK 0000
> 17-Instruments -- Status: OK 0000
> 18-Aux. Heat -- Status: OK 0000
> 19-CAN Gateway -- Status: OK 0000
> 20-High Beam Assist. -- Status: OK 0000
> 25-Immobilizer -- Status: OK 0000
> 2B-Steer. Col. Lock -- Status: OK 0000
> 42-Door Elect, Driver -- Status: OK 0000
> 44-Steering Assist -- Status: OK 0000
> 46-Central Conv. -- Status: OK 0000
> 52-Door Elect, Pass. -- Status: OK 0000
> 55-Xenon Range -- Status: OK 0000
> 56-Radio -- Status: OK 0000
> 62-Door, Rear Left -- Status: OK 0000
> 72-Door, Rear Right -- Status: OK 0000
> 77-Telephone -- Status: OK 0000
> Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
> Part No SW: 03F 906 070 GB HW: 03F 907 309
> Component: SIMOS10.12AH10 2677
> Revision: --H10--- Serial number: 00000000000000
> Coding: 002500D6232400081000
> Shop #: WSC 99999 1023 2097151
> ASAM Dataset: EV_ECM12TFS02103F906070GB 004004
> ROD: EV_ECM12TFS02103F906070FS.rod
> VCID: 68D547A493F0005E337-803D
> No fault code found.
> Readiness: 0000 0000
> Address 02: Auto Trans Labels: 0AM-300-04x.lbl
> Part No SW: 0AM 300 052 D HW: 0AM 927 769 D
> Component: GSG DSG AG7 431 2717
> Revision: 00043014 Serial number: CU501110155386
> Coding: 0000020
> Shop #: WSC 01357 011 00200
> VCID: 2C5DFBB48F88EC7E17F-8079
> Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
> Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
> Component: ESP MK60EC1 H31 0121
> Revision: 00H31001
> Coding: 113B200D212800FC880F04E5841B0040350000
> VCID: 7BFF08E8FA66BBC6CE5-802E
> Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
> Part No SW: 5K0 959 434 A HW: 5K0 959 434 A
> Component: VWKESSYPQ35GP 085 0802
> Revision: 00085000 Serial number: 0156598223
> Coding: 030C0C
> ASAM Dataset: EV_KESSY_PQ35GP A01018
> ROD: EV_KESSY_PQ35GP.rod
> VCID: 336FE0C89AB6B386565-8066
> Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
> Part No SW: 5K0 907 044 FA HW: 5K0 907 044 FA
> Component: Climatronic H18 1112
> Revision: 00001004
> Coding: 0000004002
> ASAM Dataset: EV_Climatronic A01010
> ROD: EV_ClimaAutoBasis_SE36.rod
> VCID: 6FE72CB8B61ED76672D-803A
> Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
> Part No SW: 1K0 937 086 M HW: 1K0 937 086 M
> Component: BCM PQ35 M 110 0651
> Revision: 00110 AC
> Coding: 40180A3A88251AC0500800C8740089E44B554088776DADB0E4840024A040
> VCID: 3A71CDECB5DC42CE953-806F
> Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
> Component: Wischer 11101 26 0512
> Coding: 009795
> Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
> Component: RLS 171011 05 54 0403
> Coding: 0230AD
> Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
> Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
> Component: PARKHILFE PLA H08 0116
> Revision: -------- Serial number: 13991119400745
> Coding: 30810A
> VCID: 4895A724FB30205E137-801D
> Address 15: Airbags (J234) Labels: 5K0-959-655.clb
> Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
> Component: AirbagVW10 013 0613
> Serial number: 003G5RABLZHG
> Coding: 00004431
> ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
> ROD: EV_AirbaVW10SMEVW360.rod
> VCID: 3163EAC060AA8196249-8064
> Crash sensor for side airbag; driver side:
> Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
> Component: S.Sens.Fahr.V H01 ----
> Serial number: 3572MSME18314463ZZZN
> Crash sensor for side airbag; passenger side:
> Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
> Component: S.Sens.Beif.V H01 ----
> Serial number: 3582MSME50554063ZZZM
> Crash sensor for side airbag; rear driver side:
> Component: S.Sens.Fahr.H --- ----
> Serial number: 3512QSME62416032ZZZF
> Crash sensor for side airbag; rear passenger side:
> Component: S.Sens.Beif.H --- ----
> Serial number: 3522QSME48126314ZZZL
> Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
> Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
> Component: LENKS.MODUL 014 0140
> Revision: FF010040 Serial number: 20111019200774
> Coding: 101A140000
> ASAM Dataset: EV_SMLSNGVOLWSXS A01004
> ROD: EV_SMLSNGVOLWS.rod
> VCID: 7DFB06F0EC72B5F6F01-8028
> Multi Function Steering Wheel Control Module:
> Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
> Component: E221__MFL-TK6 H06 0022
> Coding: E30000
> Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
> Part No SW: 5K0 920 882 HW: 5K0 920 882
> Component: KOMBI H03 0407
> Coding: 170F01
> ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
> ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
> VCID: EDDBB6B03C12A576C01-80B8
> Address 18: Aux. Heat Labels: 1K0-815-007.clb
> Part No: 5K0 963 272 B
> Component: Standheizer 022 3907
> Revision: 00022000 Serial number: 09020188000000
> Coding: 0031012
> VCID: 2F67ECB8BE9E976632D-807A
> Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
> Part No SW: 7N0 907 530 H HW: 1K0 907 951
> Component: J533 Gateway H42 1620
> Revision: H42 Serial number: 161011F1001970
> Coding: 350002
> VCID: 356BDED09CC2ADB6781-8060
> Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
> Part No SW: 5K0 857 511 B HW: 8P0 857 511 C
> Component: FLA H04 0006
> Revision: AA001002
> Coding: 02018B6B74745D545420363E00
> VCID: 2D5BF6B07492E576001-8078
> Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
> Part No SW: 5K0 953 234 HW: 5K0 953 234
> Component: IMMO H03 0407
> Coding: 000007
> ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
> ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
> VCID: EAD1BDAC0DFCB24EA53-80BF
> Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
> Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
> Component: ELV-PQ35 H20 0230
> Revision: 00000000 Serial number: 11000227761003
> Coding: 4900000000000000
> ASAM Dataset: EV_ELVMarquMPVW36X A01001
> ROD: EV_ELVMarquMPVW36X.rod
> VCID: 2E59F1BC71949E6E39B-807B
> Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
> Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
> Component: Tuer-SG 009 2119
> Coding: 0004278
> VCID: 3261E5CCADACBA8E5D3-8067
> Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
> Part No: 1K0 909 144 M
> Component: EPS_ZFLS Kl. 69 3201
> Revision: 00H20000
> VCID: 346DE3D457B8B4BE4FF-8061
> Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
> Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
> Coding: 0004534
> VCID: 336FE0C852B6B386565-8066
> Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
> Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
> Component: AFS-Steuergeraet 0148
> Revision: 00H04000 Serial number:
> Coding: 1442908
> Subsystem 1 - Part No: 7L6 941 329 B
> Component: AFS-Lst.-Modul l 0005
> Coding: 00000022
> Subsystem 2 - Part No: 7L6 941 329 B
> Component: AFS-Lst.-Modul r 0005
> Coding: 00000022
> Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
> Part No SW: 3C8 035 190 C HW: 3C8 035 190 C
> Component: Radio RCD510 050 0207
> Revision: 00000001 Serial number: VWZ1Z3L1569156
> Coding: 05000440040005
> VCID: 234F108822562306A65-8076
> Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
> Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
> Component: Tuer-SG 007 2101
> Coding: 0000144
> Shop #: WSC 01357 011 1012552
> VCID: 356BDED05CC2ADB6781-8060
> Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
> Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
> Coding: 0000144
> VCID: 3669D9DC41C4A6AE71B-8063
> Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
> Part No SW: 3C8 035 730 B HW: 3C8 035 730 B
> Component: Telefon 011 0723
> Revision: -------- Serial number: 35909603252885
> Coding: 020000000100000000000000
> ASAM Dataset: EV_UHVPremi A02003
> ROD: EV_UHVPremi_SE36.rod
> VCID: 2241158C354C2A0EAD3-8077
> End ---------------------------------------------------------------------
> Wednesday,23,April,2014,13:06:30:33755
> VCDS -- Windows Based VAG/VAS Emulator
> VCDS Version: 12.12.2.0
> Data version: 20140212
> Workshop Code: 940 00213 000025
> VIN: WVWZZZ1KZCW162412 License Plate: UF57291
> Mileage: 19709 Repair Order: Ernst
> 56 62 72 77
> Coding: 0000020
> Revision: 00H31001
> Coding: 030C0C
> Revision: 00001004
> Coding: 0000004002
> Revision: 00110 AC
> Coding: 009795
> Coding: 0230AD
> Coding: 30810A
> Coding: 00004431
> Coding: 101A140000
> Coding: E30000
> Coding: 170F01
> Coding: 0031012
> Coding: 350002
> Revision: AA001002
> Coding: 000007
> Coding: 0004278
> Revision: 00H20000
> Coding: 0004534
> Coding: 1442908
> Coding: 00000022
> Coding: 00000022
> Coding: 0000144
> Coding: 0000144
