2016 VW GTI (MK7) Sunroof Switch and Control Faults
adobeeditor
Newton, MA, USA
Hi there. I have a 2016 VW GTI with sunroof issues, although they seem to be different than what I've seen online in other posts. The past two years I've had problems similar to what I've seen elsewhere that the auto-close controls get disabled. Usually I can correct the issue with the reset steps similar to what are posted here: https://golfmk7.com/forums/index.php?threads/sunroof-control-issue.327722/post-6782484
However, this time it seems like the switch is not responding to some of the controls. For example, I can tilt the sunroof but it won't open and close if I press the switch forward and backward. So I consulted my neighbor and he was able to run his VCDS on my car.
Luckily it seems like there are faults that it found with the sunroof, but I have been unable to identify how to correct them. I was nervous to do any kind of global reset because I've come across other posts where other problems came up after doing that.
Any suggestions? Below are the two faults that come up for the sunroof module:
721416 - Switch for Sunroof
B13C4 29 [008] - Signal Implausible
722437 - Control Module for Power Sunroof
B13C6 54 [009] - Missing Calibration / Basic Setting
Reset counter: 171
Mileage: 75631 km
Date: 2020.07.01
Time: 18:08:59
Thanks in advance!
South Molton, UK
Please ask your neighbor to copy the VCDS Auto-Scan of your car onto a USB stick (it will have been auto-saved into C:\Ross-Tech\VCDS\Scans) so you can post the complete unedited Scan here (how your car is configured is important) - see my sig for a link to a How-To
adobeeditor
Newton, MA, USA
Thanks @PetrolDave! See below.
Thursday,02,July,2020,13:07:42:45253
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: 3VW4T7AU7GM070263   License Plate:
Mileage: 75631km-46994mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 55 5F 75 A9
VIN: 3VW4T7AU7GM070263   Mileage: 75631km-46994miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F381AB147964023FA1-807A
21406 - EVAP Emission Control Sys
          P0441 00 [096] - Incorrect Flow
                    Mileage: 74999 km
                    Date: 2020.06.04
                    Time: 20:17:17
                    Engine speed: 1574.25 /min
                    Vehicle speed: 51 km/h
                    Coolant temperature: 98 ∞C
                    Intake air temperature: 46 ∞C
                    Voltage terminal 30: 13.769 V
                    Unlearning counter according OBD: 15
                    Engine: operating status: PUC
                    STATE_LS_SAE[1]: OL_INTR
                    T_AST_SAE: 164 s
                    MAP_MES_SAE: 24 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 3.145 V
                    FAC_TPS_1_SAE: 12.890625 %
                    FUP_H_SAE: 9690.0 kPa
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4935
   Revision: 06354004    Serial number: TFK01605181687
   ROD: EV_TCMDQ250021.rod
   VCID: 186AC16DD218A79B8BB-804C
   Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
   Component: ESC           H32 0393
   Revision: 00000000    Serial number: 51376000000489
   Coding: 01FA6BA13427096C0079020681C62980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   VCID: 4BC06E21D34E1C03F69-801E
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 178
                    Mileage: 73856 km
                    Date: 2020.03.27
                    Time: 08:35:53
   Revision: 00021000    Serial number: 0398945262
   Coding: 030C0C
   VCID: 3A2E3BE58CD4958B5DF-806E
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004200100000000000000000002
   VCID: 46D65F15C82CE16B297-8012
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 8658090616002L
   Coding: 00111A464041A26969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00291
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AAEFBE5CC54558B1DF-802E
   Component: WWS    150809  043 0581
   Serial number:         151231053711
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S3Y16M04D05H22M25S06
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03691611140201161434
   Coding: 181803
                    Reset counter: 171
                    Mileage: 75631 km
                    Date: 2020.07.01
                    Time: 18:08:59
   Serial number: 003GCR04NU0T
   VCID: 47C85211CF26F863D21-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH00000000000557SRW
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 205 16
   Serial number: 35700000000B00D07A1E
   Subsystem 3 - Part No SW: -----------    HW: 480 000 205 16
   Serial number: 3580000000078AE07A1U
   Subsystem 4 - Part No SW: -----------    HW: 480 400 205 16
   Serial number: 3510002A91FA3421616-
   Subsystem 5 - Part No SW: -----------    HW: 480 400 205 16
   Serial number: 3520002B9205728192D
   Subsystem 6 - Part No SW: -----------    HW: 480 400 404 16
   Serial number: 3550002C920414E1407U
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 404 16
   Serial number: 3560002C920414E5F2DB
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160411500259
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0452851DBE90137B773-8050
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD091AA980CF0502086A001000000000000000
   VCID: 2C020DBD76803B3BDF3-8078
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 28041610801447
   Coding: 0101000830085900FB00002A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_013.rod
   VCID: 79ACE4E9C9525E93145-802C
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160000517410106123
   Coding: 31FFFF
   Revision: 00000000    Serial number: 16000077152005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 343215DDAEB063FB873-8060
   Serial number: 20051606050AAR
   Coding: 003E13200000020000000000
   VCID: 43D04601FB1ED4430E9-8016
   Serial number: 00000000000012816955
   Coding: 011000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   VCID: 392C24E989D29E93545-806C
   Component: MIB2_lite_amp H20 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA01P6MI
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6D84C0B98D1AF23388D-8038
   Serial number: 0906160605027M
   VCID: 42DE4305E404DD4B05F-8016
   Serial number: 00000000000012739643
   Coding: 091000
   Coding: 021A01010B000400
   VCID: 40DA490DEA08CF5B13B-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 027300000000000051220002001808001F0203F40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6C82CDBDB600FB3B9F3-8038
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJW00KVU
          B11CF 53 [009] - Deactivated
                    Reset counter: 169
                    Mileage: 51713 km
                    Date: 2019.02.22
                    Time: 13:49:09
                    Voltage terminal 30: 11.9 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 130 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Component: OCULowMQBUS   007 0568
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 160408202217
   VCID: 6B80CEA1B30EFC03969-803E
End----------(Elapsed Time: 01:29, VBatt start/end: 13.5V/13.6V)-----------
Looks like a problem with the switch itself, or possibly the wiring to it.
adobeeditor
Newton, MA, USA
Okay thanks @Uwe! Would this issue be something I should just take into the dealer and get their estimate? Not knowing how the fault codes work, my concern originally was that they could potentially attempt to replace more than necessary, and I'd end up shelling out more cash.
Hard to say. Depends on the dealer.
Personally, I would spend $35 to pull a set of wiring diagrams for this exact car and then see if I could determine what's wrong using a multimeter.
adobeeditor: Most certainly follow Uwe's advice (about the WD) - but if my experience with a similar problem on an early model mk7 is any help from the WD will be limited - alas! The good aspect of the WD will be that it will identify the destinations on the 5 x pin connector from the switch assembly - back to the sunroof module. This is great for continuity testing of the loom wires and the interposing connector pins !
The problem that I had was understanding how the 5 x pin connector on the actual switch operated. Alas, the WD wasn't instructive in explaining the internal arrangement within the switch housing. In the end, after I'd satisfied myself that the loom wiring was OK - I just had to take a position and buy a replacement switch. I'm not sure if the WD for your particular mk7 will be similarly limiting - but here's a very much simplified wiring arrangement for my case:
I did this project some time ago and I'm not sure whether I dismantled the old switch to confirm the internal wiring; in any event, I can't recall my finding if I did, so such considerations are academic for your project (sorry)
However, if you look at my diagram, it is possible to hypothesize- perhaps?
Clearly pin#5 is the background LED lighting for the switch and although not specifically designated, I guess that its reasonable to conclude the cathode end of the LED is the brown wire on pin#4 (brown is often the color of earth wires on mk7 WD)
So that leaves 3 x pins to explain: 3 x pin switches are invariably single-throw, double-pole meaning that a single "input" from the control module can be switched to one of two other pins on the module. In this application, I guess that the "input" pin instructs the module whether the sunroof is open, or closed at the end of the travel position
A way of testing the integrity of this switch (and of determining which pin does what) is to separately measure the resistance between pins 1&2, and 1&3, and 3&2 with the switch in one position and again with the switch in the alternative position.This gives 6 x results. For each switch position, and if the switch is OK, you should get a reading of zero ohms on only one of the pin-pair tests (ALL remaining results should be infinity ohms). And, for the pin-pairs with these 2 x zero ohm results, the common pin-number in both will be the "input" terminal for the double throw mechanism.
hope this makes sense - and I apologize if you know this stuff already!!
adobeeditor
Newton, MA, USA
Thanks so much @DV52! I haven't been able to look into this further yet this week but hoping to next week.
cilitkas
LT
Got the same issue, nothing works, same 2 faults appear, replacing the switch didnt helped, ODIS fails during calibration...
