How to create a complete record of new car (fresh from factory) coding and adaptation
PanEuropean
Toronto, Canada
C?ID=11844
Hello Folks:
Yesterday, I took delivery of a new 2015 Golf Highline with multimedia (NAR spec).
Before I rev up my laptop and VCDS cable and get in there and screw things up beyond all possible recognition, I would like to create a complete record of controller coding values and adaptation channel values "fresh from the factory", in other words, a record - in the greatest possible detail - of how the car was configured the day I picked it up.
I know I have seen a post, or perhaps an article on the Ross-Tech website that explains how to do this. But, despite searching for the past half-hour, I can't find this article.
Would some kind soul point me in the correct direction? I am, of course, itching to get in and fool around with the car, but I'm sufficiently long in the tooth to know it would be prudent to records ALL the original values and settings before I do this.
Thanks in advance,
Michael
Hello Folks:
Thanks in advance,
Michael
Michael. Hi. You are a very wise man! Creating a database of your car's "Virgin" settings will be an invaluable reference source when things go pear-shaped ( which they invariably will do).
There are others here with far more expertise than me where VCDSis concerned but I did this when I first got my cable like this:
First: the easy bit was getting a record of the coding strings in all the control modules - this I did through my first autoscan. I created a simple list from the autoscan text file. See RT's video below.
Second: the more time consuming bit was making a complete set of maps for all adaptation channel settings. Your highline has over 3,500 of these and about 40% of these reside in the BCM.
I wrote a small paper on how to do this 2nd bit which is HERE but the RT video for this bit is below:
Hope this helps
golfi_vend
Tartu, Estonia
C?ID=195131
I'm guessing Pan(I hope thats ok to call?) knows how to make autoscan and adaption map, based on previous car and mod history.
Otherwise, I can't think any other value to record. Correct me if I'm wrong...Uwe, Dana Sebastian.... ?.
Yep, Auto-Scan and Adaptation Maps of every module.
Ross-Tech would be happy to keep off-site backups of those for you if you send 'em to us. :D
Zenerdiode
Newcastle, England
C?ID=24330
Watch out for the 'Security Access Required' lines in your Adaptation maps too. :p
NEtech
Denmark
C?ID=56995
I would suggest, temporary rename \Labels directory
Then write 2 in "Debug level" in "Options"
Then make an Autoscan.
Then save your Autoscan and adaption files for all Controllers some where as reference.
This will probably take about 1/2 hour, especially Controller [09].
Remember to rename Label directory back again.
GaryM
Oxford, UK
C?ID=226919
I don't have access to my car at the moment so I can't test this but out of interest, what does renaming the "\Labels" folder in conjunction with a debug level of 2 actually do?
Does the lack of a "\Labels" folder cause something special/different to happen?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
IIRC, debug level 2 makes VCDS automatically generate a controller channel map for anything that doesn't have a label file.
With the labels directory missing, nothing will have a label file, so it will create a channel map of everything.
Jason
GaryM
Oxford, UK
C?ID=226919
That's a neat trick then :) I guess you only get PLA / PLB files using this this method but probably easy enough to open them in notepad to work out what is what.
What about controllers that need a security access code? Does it try and determine the login codes for those automatically or do you need to create maps for those particular controllers manually using the Controller Channel Map screen?
NEtech
Denmark
C?ID=56995
Here we are talking about Golf 7 (AU/5G), all Controllers are UDS (I would think). So all files are saved as adpmap-xxx-xxx-xxx-x.csv, with all values for adaptation lines (channels).
If there should be any controllers that need login code, for these UDS Controllers, you then need to make those CSV files one by one.
PanEuropean
Toronto, Canada
C?ID=11844
Wow, thanks to everyone who replied, my question has been fully answered!
Uwe, I will send you a zip file that contains all the 'virgin' settings for your records.
May I suggest that the existing page on the Ross-Tech Wiki that describes how to create controller maps (http://wiki.ross-tech.com/wiki/index.php/Control_Module_Maps be updated to include a description of how to use the "Controller Channel Map" feature that is found within the "Applications" section of the current release of VCDS?
Michael
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
It is indeed.
I like using PLB channel maps to snapshot live overall ECU state when I'm tinkering, for later perusal when I'm back in the house. When using un-encrypted label files, PLBs actually have the block and field descriptions from the existing file embedded with the data. With encrypted label files it's not there, which I find really annoying, but the reason why is fairly obvious and it's just something I get to live with. I doubt that's how many people use the product anyway. I have not tried this on a UDS module so I'm not sure if the same thing applies.
Jason
The section of that page, entitled,
"Type #2: To create map files from individual control modules, please perform the following procedure: "
doesn't adequately describe that?
PanEuropean
Toronto, Canada
C?ID=11844
The section of that page, entitled, "Type #2: To create map files from individual control modules, please perform the following procedure:" doesn't adequately describe that?
Hi Uwe:
You are correct, the second procedure exactly describes the process. For some reason, I didn't comprehend the instruction to select the 'applications' menu from the main screen of VCDS, perhaps because I don't often use that Applications menu, and perhaps because I was a bit fixated on the concepts explained in the first procedure (getting the info via debug level 2 settings).
I think it would help if the Wiki contained a few screen-shots to help direct the user down the correct path. I would be happy to volunteer to enhance that Wiki page with a few screen-shots and slightly better hand-holding in the procedure description, if you would like this done.
Michael
bloggo
Birmingham UK
C?ID=198143
A question for the RT experts:
I have carried out the admap procedure for module 09 but find that several lines have been truncated. I am using Beta 15.3.0 and tried saving in csv form which amounted to 1795 lines of data.
It appears to me that the missing lines are from the subsystem modules, although I am just guessing.
Do I need to enter the debug and insert 2 then use pla files to obtain a full adaptation file or is this a bug?
Many thanks
Bill.
Truncated how? Can you send use the map please? E-mail to Support@...
bloggo
Birmingham UK
C?ID=198143
Hello Uwe,
Thanks for the reply, I will try to check what is missing before I send the map.
Bill.
Andy
Sector 7G
HC424490
I just ran an Adp channel map of 09 in my 2015 GTI and got this:
;SW:5Q0-937-087-K   HW:5Q0-937-087-K ---  Cent. Elect.
;Component:BCM PQ37BOSCH 026 0097	 Coding:00110A464041A26969E44000001407201800000000000000000000000000
;EV_BodyContrModul1UDSBosc	12003	EV_BCMBOSCH_VW37.rod
;Monday	4	May	2015	10:43:27:32002
;VCDS Version: Beta 15.3.0 (x64)  Data version: 20150314
;VCID: 43C68990CAE8DA209A-8016
(1)-Access control-Funk bei Klemme 15 ein	not active
(2)-Access control-Notschließfunktion	active
(3)-Access control-automatisches Verriegeln bei Geschwindigkeit	active
(4)-Access control-automatisches Entriegeln	active
(5)-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
(6)-Access control-ZV Tuerentriegelung	Einzeltuerentriegelung
(7)-Access control-CAN Wecken bei Softtouchbetaetigung	active
(8)-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active
(9)-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
(10)-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
(11)-Access control-Valet Parking	not active
(12)-Access control-Direkter Auswurf des Heckdeckels	active
(13)-Access control-ZV entriegelt auch Heckdeckel	active
(14)-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
(15)-Access control-Autolock Autounlock wirkt auf Heck	active
(16)-Access control-ZV Heck nur direkt auswerfen	not active
(17)-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active
(18)-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active
(19)-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active
(20)-Access control-ZV-Entriegelung nach Seitencrash	not active
(21)-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active
(22)-Access control-Elektrische Laderaumabdeckung	not active
(23)-Access control-Menuesteuerung Tuerentriegelung	active
(24)-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
(25)-Access control-Autounlock NAR	active
(26)-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
(27)-Access control-Softtouch-Betaetigung senden	Always
(28)-Access control-Servoheck Schlossansteuerung	Always
(29)-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	not active
(30)-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active
(31)-Access control-Vorrastenhaenger_Freigabe	not active
(32)-Access control-Heckfreigabe_Ohne_Verzoegerung	not active
(33)-Access control-Deaktivierung_Laderaumschliessung_extern	not active
(34)-Access control-LS_Taster_Togglefunktion	not active
(35)-Access control-Nutzfahrzeug_Schliessung	not active
(36)-Access control-Wiederverriegelung_Laderaum	Freigabe_Softtouch
(37)-Access control-Mindestbetaetigung_HDF_Innentaster	0.00 s
(1)-Access control 2-Komfortbedienung global	active
(2)-Access control 2-Comfort opening	active
(3)-Access control 2-Comfort closing	active
(4)-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
(5)-Access control 2-Nachsaven_nach_Verdecklauf	not active
(6)-Access control 2-Funk Komfort schliessen	active
(7)-Access control 2-Funk Komfort oeffnen	active
(8)-Access control 2-Schliesszylinder Komfort oeffnen	not active
(9)-Access control 2-Schliesszylinder Komfort schliessen	active
(10)-Access control 2-SAD Richtung Komfortoeffnen	Open
(11)-Access control 2-SAD Komfort schliessen	active
(12)-Access control 2-SAD Komfort oeffnen	active
(13)-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
(14)-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
(15)-Access control 2-Regenschliessen_ein_aus	active
(16)-Access control 2-Regenschliessen_art	Permanent
(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active
(18)-Access control 2-Spiegelverstellung Synchron	not active
(19)-Access control 2-Kessy Komfort oeffnen	not active
(20)-Access control 2-Kessy Komfort schliessen	active
(21)-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	not active
(22)-Access control 2-Menuesteuerung Spiegelabsenkung	active
(23)-Access control 2-Funk Spiegelanklappen	not active
(24)-Access control 2-Funk Spiegelanklappung Modus	by convenience operation via remote control key
(25)-Access control 2-Menuesteuerung synchrone Spiegelverstellung	not active
(26)-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active
(27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable
(28)-Access control 2-Menuesteuerung Regenschliessen	active
(29)-Access control 2-SAD PreCrash Konturschliessen	not active
(30)-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
(31)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
(32)-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
(33)-Access control 2-Remote_Unlock_Lock	Via ZV-Absicherung Light
(34)-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	not active
(35)-Access control 2-Signalisierung_Spiegelanklappung	not active
(36)-Access control 2-Virtuelles_Pedal	not active
(37)-Access control 2-virtuelles_pedal_HMI_einstellbar	not active
(38)-Access control 2-easycloselight_aktiv	not active
(39)-Access control 2-Spiegelanklappen_bei_Wiederverriegelung	not active
(1)-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
(2)-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active
(3)-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	kurz
(4)-Acknowledgement signals-Optical feedback during locking	Decelerate
(5)-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
(6)-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
(7)-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active
(8)-Acknowledgement signals-Akustische Rueckmeldung global	active
(9)-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active
(10)-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active
(11)-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	not active
Activating and deactivating all development messages	not active
(1)-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit
(2)-After-run for park light-Bedingungen zur Standlichtbegrenzung	not active
(3)-After-run for park light-Bedingungen zur Parklichtbegrenzung	not active
(4)-After-run for park light-Faktor fuer Verfügbarkeitstimer	Faktor fuer x1 Stunden
(5)-After-run for park light-Standlicht-Nachlaufzeit	30 min
(6)-After-run for park light-Standlicht-Verfügbarkeit	0 s
Alternating park position 1	7.49 °
Alternating park position 2	29.49 °
(1)-Ambient lighting-Defaultwert Ambienteprofil Fussraum	50%
(2)-Ambient lighting-Defaultwert Ambienteprofil Tuer	50%
(3)-Ambient lighting-Defaultwert Ambienteprofil Vorn	50%
(4)-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
(5)-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
(6)-Ambient lighting-Innenlichtinszenierung	Enabled
(1)-Anti-theft device-Alarmsignal	frequency modulated
(2)-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
(3)-Anti-theft device-DWA Alarmverzoegerung	not active
(4)-Anti-theft device-DWA Camper Modus	not active
(5)-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active
(6)-Anti-theft device-Sirenen Alarmzahl	1 Alarm
(7)-Anti-theft device-Akustischer Alarm Signalhorn	active
(1)-Assistance light functions-Notbremsanzeige NBA	not active
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
(3)-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
(4)-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	active
(5)-Assistance light functions-Fernlichtassistent Reset	not active
(6)-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
(7)-Assistance light functions-Assistenzfahrlicht bei Regen	active
(8)-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis
(9)-Assistance light functions-LS_Error_Ausgabe	not active
(10)-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active
(11)-Assistance light functions-AFL Zeitverzoegerung	2000 ms
(12)-Assistance light functions-Lichtsensorempfindlichkeit	normal
(1)-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active
(2)-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active
(3)-Auxiliary functions-Signalhorn ohne KL15	active
(4)-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active
Characteristics in production mode	0 ms
(1)-Comfort illumination-Coming Home Verbaustatus	automatic
(2)-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
(3)-Comfort illumination-Menueeinstellung Cominghome	10 s
(4)-Comfort illumination-Coming Home Leuchten	Low beam
(5)-Comfort illumination-Coming-home Einschaltereignis	Driver door
(6)-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	12 lx
(7)-Comfort illumination-Leaving-Home Verbausstatus	Enabled
(8)-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active
(9)-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 s
(10)-Comfort illumination-Helligkeitsschwelle Forward-Messung	46400 lx
(1)-Convert. top oper.-Komfortbedienung Verdeck global	active
(2)-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active
(3)-Convert. top oper.-Komfortbedienung Verdeck schließen	active
(4)-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active
(5)-Convert. top oper.-Verdeck schließen via Schließzylinder	active
(6)-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active
(7)-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active
(8)-Convert. top oper.-Verdeck oeffnen via Kessy	active
(9)-Convert. top oper.-Verdeck schließen via Kessy	active
(10)-Convert. top oper.-Doppelpuls nur Verdeck	active
(11)-Convert. top oper.-Verdeck mit Schiebedach	not active
(12)-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active
(13)-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active
(14)-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active
(15)-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active
(16)-Convert. top oper.-Remote Lock Unlock Timer s1	0 s
(17)-Convert. top oper.-Remote Lock Unlock Timer s3	0.000 ms
(1)-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
(2)-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active
(3)-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
(4)-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active
(5)-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active
(6)-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
(7)-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
(8)-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
(9)-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
Deactivate production mode	0
(1)-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
(2)-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
(3)-Driving light and parking light-Standlicht aus	active
(4)-Driving light and parking light-Parklicht ueber LSS aktiviert	not active
(5)-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	not active
(6)-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen
(7)-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
(8)-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
(9)-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
(10)-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
(11)-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
(12)-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h
(13)-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h
(14)-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
(3)-Dyn. turn signal modes-ZV_Blinken_zu	not active
(4)-Dyn. turn signal modes-ZV_Blinken_auf	not active
(5)-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
(8)-Dyn. turn signal modes-Taxi alarm flashing	not active
(9)-Dyn. turn signal modes-Panic flashing	not active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
(13)-Dyn. turn signal modes-Richtungs_blinken_links	not active
(14)-Dyn. turn signal modes-ABBA_Blinken	not active
(15)-Dyn. turn signal modes-Crash flashing	not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
(18)-Dyn. turn signal modes-Emergency_alert_blinken	not active
(1)-Energy management-Energy_Management_Adaptation	Energy management active
(2)-Energy management-Praediktives_Energiemanagement	not active
(1)-Head area heater-blower_speed	0
(2)-Head area heater-Temperature	-3
(1)-Int. light; 2nd generation-Aufloesung Dimmzeit	0.10 s
(2)-Int. light; 2nd generation-weicher Farbwechsel	not active
(3)-Int. light; 2nd generation-Tuertafelbeleuchtung mehrfarbig	active
(4)-Int. light; 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active
(5)-Int. light; 2nd generation-Cockpitbeleuchtung mehrfarbig	not active
(6)-Int. light; 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active
(7)-Int. light; 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active
(8)-Int. light; 2nd generation-Dachbeleuchtung mehrfarbig	not active
(9)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active
(10)-Int. light; 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active
(11)-Int. light; 2nd generation-BAP Farbwert Farbe 1	2
(12)-Int. light; 2nd generation-BAP Farbwert Farbe 2	3
(13)-Int. light; 2nd generation-BAP Farbwert Farbe 3	1
(14)-Int. light; 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%
(15)-Int. light; 2nd generation-Defaultwert Ambienteprofil Dach	80%
(16)-Int. light; 2nd generation-Defaultwert Ambienteprofil Farbe	2
(17)-Int. light; 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active
(18)-Int. light; 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	not active
(19)-Int. light; 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active
(20)-Int. light; 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active
(21)-Int. light; 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active
(22)-Int. light; 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active
(23)-Int. light; 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active
(24)-Int. light; 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	not active
(25)-Int. light; 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active
(26)-Int. light; 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active
(27)-Int. light; 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active
(28)-Int. light; 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active
(29)-Int. light; 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active
(30)-Int. light; 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active
(31)-Int. light; 2nd generation-Rotwert Farbe 1	0
(32)-Int. light; 2nd generation-Gruenwert Farbe 1	0
(33)-Int. light; 2nd generation-Blauwert Farbe 1	0
(34)-Int. light; 2nd generation-Rotwert Farbe 2	0
(35)-Int. light; 2nd generation-Gruenwert Farbe 2	0
(36)-Int. light; 2nd generation-Blauwert Farbe 2	0
(37)-Int. light; 2nd generation-Rotwert Farbe 3	0
(38)-Int. light; 2nd generation-Gruenwert Farbe 3	0
(39)-Int. light; 2nd generation-Blauwert Farbe 3	0
(1)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed
(2)-Interior light; light configuration-Ambiente_Lautsprecher	not installed
(3)-Interior light; light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed
(4)-Interior light; light configuration-Cockpitbeleuchtung	not installed
(5)-Interior light; light configuration-Mittelkonsolenbeleuchtung	not installed
(6)-Interior light; light configuration-Dachbeleuchtung	not installed
(7)-Interior light; light configuration-Panoramaschiebedachbeleuchtung	not installed
(8)-Interior light; light configuration-Foot well lighting	installed
(9)-Interior light; light configuration-Farbwahl ueber HMI	not installed
(10)-Interior light; light configuration-Farbwahl ueber Fahrprofil	not installed
(11)-Interior light; light configuration-LIN-Dachkonsole lokal aktivierbar	not active
(12)-Interior light; light configuration-Ambientemenue mit globalem aus	not active
(13)-Interior light; light configuration-Ambientemenue mit alle Zonen	not active
(14)-Interior light; light configuration-Ambient_Farbliste_HMI	not active
(15)-Interior light; light configuration-Frei_Farbwahl_ueber_HMI	not active
(1)-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
(2)-Interior lighting-KL30G ohne PWM	not active
(3)-Interior lighting-KL58 Einschalten mit Rampe	not active
(4)-Interior lighting-KL58 Verriegelungsausschalten	not active
(5)-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
(6)-Interior lighting-Suchbeleuchtung Festwert	100%
(1)-Light configuration-Lasttyp 0	12 - Blinkleuchten
(2)-Light configuration-BAP Bitposition 0	34
(3)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14
(4)-Light configuration-Lichtfunktion A 0	2
(5)-Light configuration-Lichtfunktion B 0	0
(6)-Light configuration-Dimmwert AB 0	100
(7)-Light configuration-Lichtansteuerung HD AB 0	Always
(8)-Light configuration-Lichtfunktion C 0	0
(9)-Light configuration-Lichtfunktion D 0	0
(10)-Light configuration-Dimmwert CD 0	0
(11)-Light configuration-Dimming Direction CD 0	maximize
(12)-Light configuration-Lichtfunktion E 0	0
(13)-Light configuration-Lichtfunktion F 0	0
(14)-Light configuration-Dimmwert EF 0	0
(15)-Light configuration-Dimming Direction EF 0	maximize
(16)-Light configuration-Lichtfunktion G 0	0
(17)-Light configuration-Lichtfunktion H 0	0
(18)-Light configuration-Dimmwert GH 0	0
(19)-Light configuration-Dimming Direction GH 0	maximize
(20)-Light configuration-Lasttyp 1	12 - Blinkleuchten
(21)-Light configuration-BAP Bitposition 1	3E
(22)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15
(23)-Light configuration-Lichtfunktion A 1	4
(24)-Light configuration-Lichtfunktion B 1	0
(25)-Light configuration-Dimmwert AB 1	100
(26)-Light configuration-Lichtansteuerung HD AB 1	Always
(27)-Light configuration-Lichtfunktion C 1	0
(28)-Light configuration-Lichtfunktion D 1	0
(29)-Light configuration-Dimmwert CD 1	0
(30)-Light configuration-Dimming Direction CD 1	maximize
(31)-Light configuration-Lichtfunktion E 1	0
(32)-Light configuration-Lichtfunktion F 1	0
(33)-Light configuration-Dimmwert EF 1	0
(34)-Light configuration-Dimming Direction EF 1	maximize
(35)-Light configuration-Lichtfunktion G 1	0
(36)-Light configuration-Lichtfunktion H 1	0
(37)-Light configuration-Dimmwert GH 1	0
(38)-Light configuration-Dimming Direction GH 1	maximize
(39)-Light configuration-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
(40)-Light configuration-BAP Bitposition 2	48
(41)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	4A
(42)-Light configuration-Lichtfunktion A 2	20
(43)-Light configuration-Lichtfunktion B 2	0
(44)-Light configuration-Dimmwert AB 2	100
(45)-Light configuration-Lichtansteuerung HD AB 2	Always
(46)-Light configuration-Lichtfunktion C 2	0
(47)-Light configuration-Lichtfunktion D 2	0
(48)-Light configuration-Dimmwert CD 2	0
(49)-Light configuration-Dimming Direction CD 2	minimize
(50)-Light configuration-Lichtfunktion E 2	8
(51)-Light configuration-Lichtfunktion F 2	9
(52)-Light configuration-Dimmwert EF 2	26
(53)-Light configuration-Dimming Direction EF 2	maximize
(54)-Light configuration-Lichtfunktion G 2	0
(55)-Light configuration-Lichtfunktion H 2	0
(56)-Light configuration-Dimmwert GH 2	0
(57)-Light configuration-Dimming Direction GH 2	maximize
(58)-Light configuration-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
(59)-Light configuration-BAP Bitposition 3	4C
(60)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	4C
(61)-Light configuration-Lichtfunktion A 3	20
(62)-Light configuration-Lichtfunktion B 3	0
(63)-Light configuration-Dimmwert AB 3	100
(64)-Light configuration-Lichtansteuerung HD AB 3	Always
(65)-Light configuration-Lichtfunktion C 3	0
(66)-Light configuration-Lichtfunktion D 3	0
(67)-Light configuration-Dimmwert CD 3	0
(68)-Light configuration-Dimming Direction CD 3	minimize
(69)-Light configuration-Lichtfunktion E 3	8
(70)-Light configuration-Lichtfunktion F3	10
(71)-Light configuration-Dimmwert EF 3	26
(72)-Light configuration-Dimming Direction EF 3	maximize
(73)-Light configuration-Lichtfunktion G 3	0
(74)-Light configuration-Lichtfunktion H 3	0
(75)-Light configuration-Dimmwert GH 3	0
(76)-Light configuration-Dimming Direction GH 3	maximize
(77)-Light configuration-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
(78)-Light configuration-BAP Bitposition 4	3A
(79)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	49
(80)-Light configuration-Lichtfunktion A 4	20
(81)-Light configuration-Lichtfunktion B 4	0
(82)-Light configuration-Dimmwert AB 4	127
(83)-Light configuration-Lichtansteuerung HD AB 4	Always
(84)-Light configuration-Lichtfunktion C 4	0
(85)-Light configuration-Lichtfunktion D 4	0
(86)-Light configuration-Dimmwert CD 4	0
(87)-Light configuration-Dimming Direction CD 4	minimize
(88)-Light configuration-Lichtfunktion E 4	8
(89)-Light configuration-Lichtfunktion F 4	9
(90)-Light configuration-Dimmwert EF 4	127
(91)-Light configuration-Dimming Direction EF 4	maximize
(92)-Light configuration-Lichtfunktion G 4	0
(93)-Light configuration-Lichtfunktion H 4	0
(94)-Light configuration-Dimmwert GH 4	0
(95)-Light configuration-Dimming Direction GH 4	maximize
(96)-Light configuration-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
(97)-Light configuration-BAP Bitposition 5	44
(98)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	4B
(99)-Light configuration-Lichtfunktion A 5	20
(100)-Light configuration-Lichtfunktion B 5	0
(101)-Light configuration-Dimmwert AB 5	127
(102)-Light configuration-Lichtansteuerung HD AB 5	Always
(103)-Light configuration-Lichtfunktion C 5	0
(104)-Light configuration-Lichtfunktion D 5	0
(105)-Light configuration-Dimmwert CD 5	0
(106)-Light configuration-Dimming Direction CD 5	minimize
(107)-Light configuration-Lichtfunktion E 5	8
(108)-Light configuration-Lichtfunktion F5	10
(109)-Light configuration-Dimmwert EF 5	127
(110)-Light configuration-Dimming Direction EF 5	maximize
(111)-Light configuration-Lichtfunktion G 5	0
(112)-Light configuration-Lichtfunktion H 5	0
(113)-Light configuration-Dimmwert GH 5	0
(114)-Light configuration-Dimming Direction GH 5	maximize
(115)-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht
(116)-Light configuration-BAP Bitposition 6	36
(117)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A
(118)-Light configuration-Lichtfunktion A 6	11
(119)-Light configuration-Lichtfunktion B 6	15
(120)-Light configuration-Dimmwert AB 6	127
(121)-Light configuration-Lichtansteuerung HD AB 6	Always
(122)-Light configuration-Lichtfunktion C 6	0
(123)-Light configuration-Lichtfunktion D 6	0
(124)-Light configuration-Dimmwert CD 6	0
(125)-Light configuration-Dimming Direction CD 6	maximize
(126)-Light configuration-Lichtfunktion E 6	0
(127)-Light configuration-Lichtfunktion F 6	0
(128)-Light configuration-Dimmwert EF 6	0
(129)-Light configuration-Dimming Direction EF 6	maximize
(130)-Light configuration-Lichtfunktion G 6	0
(131)-Light configuration-Lichtfunktion H 6	0
(132)-Light configuration-Dimmwert GH 6	0
(133)-Light configuration-Dimming Direction GH 6	maximize
(134)-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht
(135)-Light configuration-BAP Bitposition 7	40
(136)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B
(137)-Light configuration-Lichtfunktion A 7	12
(138)-Light configuration-Lichtfunktion B 7	15
(139)-Light configuration-Dimmwert AB 7	127
(140)-Light configuration-Lichtansteuerung HD AB 7	Always
(141)-Light configuration-Lichtfunktion C 7	0
(142)-Light configuration-Lichtfunktion D 7	0
(143)-Light configuration-Dimmwert CD 7	0
(144)-Light configuration-Dimming Direction CD 7	maximize
(145)-Light configuration-Lichtfunktion E 7	0
(146)-Light configuration-Lichtfunktion F 7	0
(147)-Light configuration-Dimmwert EF 7	0
(148)-Light configuration-Dimming Direction EF 7	maximize
(149)-Light configuration-Lichtfunktion G 7	0
(150)-Light configuration-Lichtfunktion H 7	0
(151)-Light configuration-Dimmwert GH 7	0
(152)-Light configuration-Dimming Direction GH 7	maximize
(153)-Light configuration-Lasttyp 8	not active
(154)-Light configuration-BAP Bitposition 8	29
(155)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	0
(156)-Light configuration-Lichtfunktion A 8	0
(157)-Light configuration-Lichtfunktion B 8	42
(158)-Light configuration-Dimmwert AB 8	0
(159)-Light configuration-Lichtansteuerung HD AB 8	Always
(160)-Light configuration-Lichtfunktion C 8	0
(161)-Light configuration-Lichtfunktion D 8	0
(162)-Light configuration-Dimmwert CD 8	48
(163)-Light configuration-Dimming Direction CD 8	maximize
(164)-Light configuration-Lichtfunktion E 8	0
(165)-Light configuration-Lichtfunktion F 8	0
(166)-Light configuration-Dimmwert EF 8	0
(167)-Light configuration-Dimming Direction EF 8	maximize
(168)-Light configuration-Lichtfunktion G 8	71
(169)-Light configuration-Lichtfunktion H 8	0
(170)-Light configuration-Dimmwert GH 8	0
(171)-Light configuration-Dimming Direction GH 8	maximize
(172)-Light configuration-Lasttyp 9	not active
(173)-Light configuration-BAP Bitposition 9	0
(174)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	0
(175)-Light configuration-Lichtfunktion A 9	0
(176)-Light configuration-Lichtfunktion B 9	0
(177)-Light configuration-Dimmwert AB 9	0
(178)-Light configuration-Lichtansteuerung HD AB 9	Always
(179)-Light configuration-Lichtfunktion C 9	0
(180)-Light configuration-Lichtfunktion D 9	0
(181)-Light configuration-Dimmwert CD 9	0
(182)-Light configuration-Dimming Direction CD 9	maximize
(183)-Light configuration-Lichtfunktion E 9	0
(184)-Light configuration-Lichtfunktion F 9	0
(185)-Light configuration-Dimmwert EF 9	0
(186)-Light configuration-Dimming Direction EF 9	maximize
(187)-Light configuration-Lichtfunktion G 9	0
(188)-Light configuration-Lichtfunktion H 9	0
(189)-Light configuration-Dimmwert GH 9	0
(190)-Light configuration-Dimming Direction GH 9	maximize
(191)-Light configuration-Lasttyp 10	not active
(192)-Light configuration-BAP Bitposition 10	0
(193)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	0
(194)-Light configuration-Lichtfunktion A 10	0
(195)-Light configuration-Lichtfunktion B 10	0
(196)-Light configuration-Dimmwert AB 10	0
(197)-Light configuration-Lichtansteuerung HD AB 10	Always
(198)-Light configuration-Lichtfunktion C 10	0
(199)-Light configuration-Lichtfunktion D 10	0
(200)-Light configuration-Dimmwert CD 10	0
(201)-Light configuration-Dimming Direction CD 10	maximize
(202)-Light configuration-Lichtfunktion E 10	0
(203)-Light configuration-Lichtfunktion F 10	0
(204)-Light configuration-Dimmwert EF 10	0
(205)-Light configuration-Dimming Direction EF 10	maximize
(206)-Light configuration-Lichtfunktion G 10	0
(207)-Light configuration-Lichtfunktion H 10	0
(208)-Light configuration-Dimmwert GH 10	0
(209)-Light configuration-Dimming Direction GH 10	maximize
(210)-Light configuration-Lasttyp 11	not active
(211)-Light configuration-BAP Bitposition 11	0
(212)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	0
(213)-Light configuration-Lichtfunktion A 11	0
(214)-Light configuration-Lichtfunktion B 11	0
(215)-Light configuration-Dimmwert AB 11	0
(216)-Light configuration-Lichtansteuerung HD AB 11	Always
(217)-Light configuration-Lichtfunktion C 11	0
(218)-Light configuration-Lichtfunktion D 11	0
(219)-Light configuration-Dimmwert CD 11	0
(220)-Light configuration-Dimming Direction CD 11	maximize
(221)-Light configuration-Lichtfunktion E 11	0
(222)-Light configuration-Lichtfunktion F 11	0
(223)-Light configuration-Dimmwert EF 11	0
(224)-Light configuration-Dimming Direction EF 11	maximize
(225)-Light configuration-Lichtfunktion G 11	0
(226)-Light configuration-Lichtfunktion H 11	0
(227)-Light configuration-Dimmwert GH 11	0
(228)-Light configuration-Dimming Direction GH 11	maximize
(229)-Light configuration-Lasttyp 12	not active
(230)-Light configuration-BAP Bitposition 12	0
(231)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	0
(232)-Light configuration-Lichtfunktion A 12	0
(233)-Light configuration-Lichtfunktion B 12	0
(234)-Light configuration-Dimmwert AB 12	0
(235)-Light configuration-Lichtansteuerung HD AB 12	Always
(236)-Light configuration-Lichtfunktion C 12	0
(237)-Light configuration-Lichtfunktion D 12	0
(238)-Light configuration-Dimmwert CD 12	0
(239)-Light configuration-Dimming Direction CD 12	maximize
(240)-Light configuration-Lichtfunktion E 12	0
(241)-Light configuration-Lichtfunktion F 12	0
(242)-Light configuration-Dimmwert EF 12	0
(243)-Light configuration-Dimming Direction EF 12	maximize
(244)-Light configuration-Lichtfunktion G 12	0
(245)-Light configuration-Lichtfunktion H 12	0
(246)-Light configuration-Dimmwert GH 12	0
(247)-Light configuration-Dimming Direction GH 12	maximize
(248)-Light configuration-Lasttyp 13	not active
(249)-Light configuration-BAP Bitposition 13	0
(250)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	0
(251)-Light configuration-Lichtfunktion A 13	0
(252)-Light configuration-Lichtfunktion B 13	0
(253)-Light configuration-Dimmwert AB 13	0
(254)-Light configuration-Lichtansteuerung HD AB 13	Always
(255)-Light configuration-Lichtfunktion  C 13	0
(256)-Light configuration-Lichtfunktion D 13	128
(257)-Light configuration-Dimmwert CD 13	1
(258)-Light configuration-Dimming Direction CD 13	maximize
(259)-Light configuration-Lichtfunktion E 13	0
(260)-Light configuration-Lichtfunktion F 13	0
(261)-Light configuration-Dimmwert EF 13	0
(262)-Light configuration-Dimming Direction EF 13	minimize
(263)-Light configuration-Lichtfunktion G 13	1
(264)-Light configuration-Lichtfunktion H 13	0
(265)-Light configuration-Dimmwert GH 13	0
(266)-Light configuration-Dimming Direction GH 13	maximize
(268)-Light configuration-BAP Bitposition 14	0
(269)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0
(270)-Light configuration-Lichtfunktion A 14	1
(271)-Light configuration-Lichtfunktion B 14	0
(272)-Light configuration-Dimmwert AB 14	93
(273)-Light configuration-Lichtansteuerung HD AB 14	Always
(274)-Light configuration-Lichtfunktion C 14	1
(275)-Light configuration-Lichtfunktion D 14	48
(276)-Light configuration-Dimmwert CD 14	0
(277)-Light configuration-Dimming Direction CD 14	maximize
(278)-Light configuration-Lichtfunktion E 14	1
(279)-Light configuration-Lichtfunktion F 14	0
(280)-Light configuration-Dimmwert EF 14	48
(281)-Light configuration-Dimming Direction EF 14	maximize
(282)-Light configuration-Lichtfunktion G 14	0
(283)-Light configuration-Lichtfunktion H 14	168
(284)-Light configuration-Dimmwert GH 14	1
(285)-Light configuration-Dimming Direction GH 14	maximize
(286)-Light configuration-Lasttyp 15	not active
(287)-Light configuration-BAP Bitposition 15	0
(288)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	1
(289)-Light configuration-Lichtfunktion A 15	0
(290)-Light configuration-Lichtfunktion B 15	0
(291)-Light configuration-Dimmwert AB 15	0
(292)-Light configuration-Lichtansteuerung HD AB 15	Always
(293)-Light configuration-Lichtfunktion C 15	0
(294)-Light configuration-Lichtfunktion D 15	0
(295)-Light configuration-Dimmwert CD 15	0
(296)-Light configuration-Dimming Direction CD 15	maximize
(297)-Light configuration-Lichtfunktion E 15	0
(298)-Light configuration-Lichtfunktion F 15	0
(299)-Light configuration-Dimmwert EF 15	124
(300)-Light configuration-Dimming Direction EF 15	maximize
(301)-Light configuration-Lichtfunktion G 15	0
(302)-Light configuration-Lichtfunktion H 15	0
(303)-Light configuration-Dimmwert GH 15	1
(304)-Light configuration-Dimming Direction GH 15	maximize
(305)-Light configuration-Lasttyp 16	1 - LED Tagfahrlichtmodul Versorgung
(306)-Light configuration-BAP Bitposition 16	0
(307)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0
(308)-Light configuration-Lichtfunktion A 16	254
(309)-Light configuration-Lichtfunktion B 16	98
(310)-Light configuration-Dimmwert AB 16	52
(311)-Light configuration-Lichtansteuerung HD AB 16	Always
(312)-Light configuration-Lichtfunktion C 16	0
(313)-Light configuration-Lichtfunktion D 16	0
(314)-Light configuration-Dimmwert CD 16	0
(315)-Light configuration-Dimming Direction CD 16	maximize
(316)-Light configuration-Lichtfunktion E 16	62
(317)-Light configuration-Lichtfunktion F 16	0
(318)-Light configuration-Dimmwert EF 16	0
(319)-Light configuration-Dimming Direction EF 16	maximize
(320)-Light configuration-Lichtfunktion G 16	0
(321)-Light configuration-Lichtfunktion H 16	72
(322)-Light configuration-Dimmwert GH 16	0
(323)-Light configuration-Dimming Direction GH 16	maximize
(325)-Light configuration-BAP Bitposition 17	0
(326)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	0
(327)-Light configuration-Lichtfunktion A 17	128
(328)-Light configuration-Lichtfunktion  B 17	0
(329)-Light configuration-Dimmwert AB 17	58
(330)-Light configuration-Lichtansteuerung HD AB 17	Always
(331)-Light configuration-Lichtfunktion C 17	0
(332)-Light configuration-Lichtfunktion D 17	128
(333)-Light configuration-Dimmwert CD 17	0
(334)-Light configuration-Dimming Direction CD 17	maximize
(335)-Light configuration-Lichtfunktion E 17	68
(336)-Light configuration-Lichtfunktion F 17	0
(337)-Light configuration-Dimmwert EF 17	0
(338)-Light configuration-Dimming Direction EF 17	minimize
(339)-Light configuration-Lichtfunktion G 17	0
(340)-Light configuration-Lichtfunktion H 17	54
(341)-Light configuration-Dimmwert GH 17	15
(342)-Light configuration-Dimming Direction GH 17	maximize
(343)-Light configuration-Lasttyp 18	not active
(344)-Light configuration-BAP Bitposition 18	0
(345)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	0F
(346)-Light configuration-Lichtfunktion A 18	0
(347)-Light configuration-Lichtfunktion B 18	0
(348)-Light configuration-Dimmwert AB 18	53
(349)-Light configuration-Lichtansteuerung HD AB 18	Always
(350)-Light configuration-Lichtfunktion C 18	9
(351)-Light configuration-Lichtfunktion D 18	0
(352)-Light configuration-Dimmwert CD 18	0
(353)-Light configuration-Dimming Direction CD 18	maximize
(354)-Light configuration-Lichtfunktion E 18	63
(355)-Light configuration-Lichtfunktion F 18	10
(356)-Light configuration-Dimmwert EF 18	0
(357)-Light configuration-Dimming Direction EF 18	maximize
(358)-Light configuration-Lichtfunktion G 18	0
(359)-Light configuration-Lichtfunktion H 18	55
(360)-Light configuration-Dimmwert GH 18	15
(361)-Light configuration-Dimming Direction GH 18	maximize
(362)-Light configuration-Lasttyp 19	not active
(363)-Light configuration-BAP Bitposition 19	0
(364)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	0F
(365)-Light configuration-Lichtfunktion A 19	0
(366)-Light configuration-Lichtfunktion B 19	0
(367)-Light configuration-Dimmwert AB 19	56
(368)-Light configuration-Lichtansteuerung HD AB 19	Always
(369)-Light configuration-Lichtfunktion C 19	0
(370)-Light configuration-Lichtfunktion D 19	0
(371)-Light configuration-Dimmwert CD 19	0
(372)-Light configuration-Dimming Direction CD 19	maximize
(373)-Light configuration-Lichtfunktion E 19	66
(374)-Light configuration-Lichtfunktion F 19	0
(375)-Light configuration-Dimmwert EF 19	0
(376)-Light configuration-Dimming Direction EF 19	maximize
(377)-Light configuration-Lichtfunktion G 19	0
(378)-Light configuration-Lichtfunktion H 19	0
(379)-Light configuration-Dimmwert GH 19	0
(380)-Light configuration-Dimming Direction GH 19	maximize
(381)-Light configuration-Lasttyp 20	not active
(382)-Light configuration-BAP Bitposition 20	0
(383)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	0
(384)-Light configuration-Lichtfunktion A 20	0
(385)-Light configuration-Lichtfunktion B 20	0
(386)-Light configuration-Dimmwert AB 20	62
(387)-Light configuration-Lichtansteuerung HD AB 20	Always
(388)-Light configuration-Lichtfunktion C 20	0
(389)-Light configuration-Lichtfunktion D 20	0
(390)-Light configuration-Dimmwert CD 20	1
(391)-Light configuration-Dimming Direction CD 20	maximize
(392)-Light configuration-Lichtfunktion E 20	0
(393)-Light configuration-Lichtfunktion F 20	0
(394)-Light configuration-Dimmwert EF 20	0
(395)-Light configuration-Dimming Direction EF 20	maximize
(396)-Light configuration-Lichtfunktion G 20	0
(397)-Light configuration-Lichtfunktion H 20	0
(398)-Light configuration-Dimmwert GH 20	0
(399)-Light configuration-Dimming Direction GH 20	maximize
(400)-Light configuration-Lasttyp 21	not active
(401)-Light configuration-BAP Bitposition 21	0
(402)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	0
(403)-Light configuration-Lichtfunktion A 21	0
(404)-Light configuration-Lichtfunktion B 21	0
(405)-Light configuration-Dimmwert AB 21	19
(406)-Light configuration-Lichtansteuerung HD AB 21	Always
(407)-Light configuration-Lichtfunktion C 21	2
(408)-Light configuration-Lichtfunktion D 21	128
(409)-Light configuration-Dimmwert CD 21	0
(410)-Light configuration-Dimming Direction CD 21	maximize
(411)-Light configuration-Lichtfunktion E 21	35
(412)-Light configuration-Lichtfunktion F 21	4
(413)-Light configuration-Dimmwert EF 21	0
(414)-Light configuration-Dimming Direction EF 21	minimize
(415)-Light configuration-Lichtfunktion G 21	0
(416)-Light configuration-Lichtfunktion H 21	41
(417)-Light configuration-Dimmwert GH 21	0
(418)-Light configuration-Dimming Direction GH 21	maximize
(419)-Light configuration-Lasttyp 22	not active
(420)-Light configuration-BAP Bitposition 22	0
(421)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	0
(422)-Light configuration-Lichtfunktion A 22	0
(423)-Light configuration-Lichtfunktion B 22	0
(424)-Light configuration-Dimmwert AB 22	26
(425)-Light configuration-Lichtansteuerung HD AB 22	Always
(426)-Light configuration-Lichtfunktion C 22	0
(427)-Light configuration-Lichtfunktion D 22	0
(428)-Light configuration-Dimmwert CD 22	0
(429)-Light configuration-Dimming Direction CD 22	maximize
(430)-Light configuration-Lichtfunktion E 22	40
(431)-Light configuration-Lichtfunktion F 22	0
(432)-Light configuration-Dimmwert EF 22	0
(433)-Light configuration-Dimming Direction EF 22	maximize
(434)-Light configuration-Lichtfunktion G 22	0
(435)-Light configuration-Lichtfunktion H 22	0
(436)-Light configuration-Dimmwert GH 22	0
(437)-Light configuration-Dimming Direction GH 22	maximize
(438)-Light configuration-Lasttyp 23	not active
(439)-Light configuration-BAP Bitposition 23	0
(440)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	0
(441)-Light configuration-Lichtfunktion A 23	0
(442)-Light configuration-Lichtfunktion B 23	0
(443)-Light configuration-Dimmwert AB 23	0
(444)-Light configuration-Lichtansteuerung HD AB 23	Always
(445)-Light configuration-Lichtfunktion C 23	0
(446)-Light configuration-Lichtfunktion D 23	0
(447)-Light configuration-Dimmwert CD 23	0
(448)-Light configuration-Dimming Direction CD 23	maximize
(449)-Light configuration-Lichtfunktion E 23	0
(450)-Light configuration-Lichtfunktion F 23	0
(451)-Light configuration-Dimmwert EF 23	16
(452)-Light configuration-Dimming Direction EF 23	maximize
(453)-Light configuration-Lichtfunktion G 23	0
(454)-Light configuration-Lichtfunktion H 23	0
(455)-Light configuration-Dimmwert GH 23	0
(456)-Light configuration-Dimming Direction GH 23	maximize
(457)-Light configuration-Lasttyp 24	not active
(458)-Light configuration-BAP Bitposition 24	0
(459)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	0
(460)-Light configuration-Lichtfunktion A 24	0
(461)-Light configuration-Lichtfunktion B 24	0
(462)-Light configuration-Dimmwert AB 24	1
(463)-Light configuration-Lichtansteuerung HD AB 24	Always
(464)-Light configuration-Lichtfunktion C 24	0
(465)-Light configuration-Lichtfunktion D 24	16
(466)-Light configuration-Dimmwert CD 24	0
(467)-Light configuration-Dimming Direction CD 24	maximize
(468)-Light configuration-Lichtfunktion E 24	145
(469)-Light configuration-Lichtfunktion F 24	0
(470)-Light configuration-Dimmwert EF 24	112
(471)-Light configuration-Dimming Direction EF 24	maximize
(472)-Light configuration-Lichtfunktion G 24	1
(473)-Light configuration-Lichtfunktion H 24	16
(474)-Light configuration-Dimmwert GH 24	0
(475)-Light configuration-Dimming Direction GH 24	maximize
(477)-Light configuration-BAP Bitposition 25	0
(478)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	0
(479)-Light configuration-Lichtfunktion A 25	58
(480)-Light configuration-Lichtfunktion B 25	0
(481)-Light configuration-Dimmwert AB 25	66
(482)-Light configuration-Lichtansteuerung HD AB 25	Always
(483)-Light configuration-Lichtfunktion C 25	1
(484)-Light configuration-Lichtfunktion D 25	112
(485)-Light configuration-Dimmwert CD 25	1
(486)-Light configuration-Dimming Direction CD 25	maximize
(487)-Light configuration-Lichtfunktion E 25	80
(488)-Light configuration-Lichtfunktion F 25	0
(489)-Light configuration-Dimmwert EF 25	1
(490)-Light configuration-Dimming Direction EF 25	maximize
(491)-Light configuration-Lichtfunktion G 25	0
(492)-Light configuration-Lichtfunktion H 25	0
(493)-Light configuration-Dimmwert GH 25	0
(494)-Light configuration-Dimming Direction GH 25	maximize
(495)-Light configuration-Lasttyp 26	not active
(496)-Light configuration-BAP Bitposition 26	0
(497)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	0
(498)-Light configuration-Lichtfunktion A 26	0
(499)-Light configuration-Lichtfunktion B 26	0
(500)-Light configuration-Dimmwert AB 26	78
(501)-Light configuration-Lichtansteuerung HD AB 26	Always
(502)-Light configuration-Lichtfunktion C 26	0
(503)-Light configuration-Lichtfunktion D 26	0
(504)-Light configuration-Dimmwert CD 26	0
(505)-Light configuration-Dimming Direction CD 26	maximize
(506)-Light configuration-Lichtfunktion E 26	1
(507)-Light configuration-Lichtfunktion F 26	0
(508)-Light configuration-Dimmwert EF 26	78
(509)-Light configuration-Dimming Direction EF 26	maximize
(510)-Light configuration-Lichtfunktion G 26	0
(511)-Light configuration-Lichtfunktion H 26	1
(512)-Light configuration-Dimmwert GH 26	0
(513)-Light configuration-Dimming Direction GH 26	maximize
(515)-Light configuration-BAP Bitposition 27	FE
(516)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	0
(517)-Light configuration-Lichtfunktion A 27	254
(518)-Light configuration-Lichtfunktion B 27	255
(519)-Light configuration-Dimmwert AB 27	1
(520)-Light configuration-Lichtansteuerung HD AB 27	Always
(521)-Light configuration-Lichtfunktion C 27	0
(522)-Light configuration-Lichtfunktion D 27	0
(523)-Light configuration-Dimmwert CD 27	0
(524)-Light configuration-Dimming Direction CD 27	maximize
(525)-Light configuration-Lichtfunktion E 27	0
(526)-Light configuration-Lichtfunktion F 27	0
(527)-Light configuration-Dimmwert EF 27	54
(528)-Light configuration-Dimming Direction EF 27	maximize
(529)-Light configuration-Lichtfunktion G 27	0
(530)-Light configuration-Lichtfunktion H 27	148
(531)-Light configuration-Dimmwert GH 27	0
(532)-Light configuration-Dimming Direction GH 27	maximize
(533)-Light configuration-Lasttyp 28	1 - LED Tagfahrlichtmodul Versorgung
(534)-Light configuration-BAP Bitposition 28	0
(535)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	0
(536)-Light configuration-Lichtfunktion A 28	0
(537)-Light configuration-Lichtfunktion B 28	0
(538)-Light configuration-Dimmwert AB 28	75
(539)-Light configuration-Lichtansteuerung HD AB 28	only_if_closed
(540)-Light configuration-Lichtfunktion C 28	1
(541)-Light configuration-Lichtfunktion D 28	72
(542)-Light configuration-Dimmwert CD 28	0
(543)-Light configuration-Dimming Direction CD 28	maximize
(544)-Light configuration-Lichtfunktion E 28	1
(545)-Light configuration-Lichtfunktion F 28	0
(546)-Light configuration-Dimmwert EF 28	0
(547)-Light configuration-Dimming Direction EF 28	maximize
(548)-Light configuration-Lichtfunktion G 28	0
(549)-Light configuration-Lichtfunktion H 28	0
(550)-Light configuration-Dimmwert GH 28	0
(551)-Light configuration-Dimming Direction GH 28	maximize
(553)-Light configuration-BAP Bitposition 29	0
(554)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	FF
(555)-Light configuration-Lichtfunktion A 29	255
(556)-Light configuration-Lichtfunktion B 29	255
(557)-Light configuration-Dimmwert AB 29	67
(558)-Light configuration-Lichtansteuerung HD AB 29	Always
(559)-Light configuration-Lichtfunktion C 29	0
(560)-Light configuration-Lichtfunktion D 29	239
(561)-Light configuration-Dimmwert CD 29	0
(562)-Light configuration-Dimming Direction CD 29	maximize
(563)-Light configuration-Lichtfunktion E 29	142
(564)-Light configuration-Lichtfunktion F 29	0
(565)-Light configuration-Dimmwert EF 29	16
(566)-Light configuration-Dimming Direction EF 29	minimize
(567)-Light configuration-Lichtfunktion G 29	0
(568)-Light configuration-Lichtfunktion H 29	16
(569)-Light configuration-Dimmwert GH 29	0
(570)-Light configuration-Dimming Direction GH 29	maximize
(571)-Light configuration-Lasttyp 30	not active
(572)-Light configuration-BAP Bitposition 30	0
(573)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	0
(574)-Light configuration-Lichtfunktion A 30	18
(575)-Light configuration-Lichtfunktion B 30	0
(576)-Light configuration-Dimmwert AB 30	80
(577)-Light configuration-Lichtansteuerung HD AB 30	only_if_closed
(578)-Light configuration-Lichtfunktion C 30	254
(579)-Light configuration-Lichtfunktion D 30	78
(580)-Light configuration-Dimmwert CD 30	0
(581)-Light configuration-Dimming Direction CD 30	maximize
(582)-Light configuration-Lichtfunktion E 30	78
(583)-Light configuration-Lichtfunktion F 30	0
(584)-Light configuration-Dimmwert EF 30	35
(585)-Light configuration-Dimming Direction EF 30	minimize
(586)-Light configuration-Lichtfunktion G 30	0
(587)-Light configuration-Lichtfunktion H 30	0
(588)-Light configuration-Dimmwert GH 30	0
(589)-Light configuration-Dimming Direction GH 30	maximize
(590)-Light configuration-Lasttyp 31	not active
(591)-Light configuration-BAP Bitposition 31	0
(592)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	0
(593)-Light configuration-Lichtfunktion A 31	0
(594)-Light configuration-Lichtfunktion B 31	0
(595)-Light configuration-Dimmwert AB 31	123
(596)-Light configuration-Lichtansteuerung HD AB 31	only_if_closed
(597)-Light configuration-Lichtfunktion C 31	0
(598)-Light configuration-Lichtfunktion D 31	0
(599)-Light configuration-Dimmwert CD 31	0
(600)-Light configuration-Dimming Direction CD 31	maximize
(601)-Light configuration-Lichtfunktion E 31	78
(602)-Light configuration-Lichtfunktion F 31	0
(603)-Light configuration-Dimmwert EF 31	54
(604)-Light configuration-Dimming Direction EF 31	minimize
(605)-Light configuration-Lichtfunktion G 31	0
(606)-Light configuration-Lichtfunktion H 31	118
(607)-Light configuration-Dimmwert GH 31	0
(608)-Light configuration-Dimming Direction GH 31	maximize
(609)-Light configuration-Lasttyp 32	not active
(610)-Light configuration-BAP Bitposition 32	0
(611)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	0
(612)-Light configuration-Lichtfunktion A 32	172
(613)-Light configuration-Lichtfunktion B 32	0
(614)-Light configuration-Dimmwert AB 32	36
(615)-Light configuration-Lichtansteuerung HD AB 32	Always
(616)-Light configuration-Lichtfunktion C 32	1
(617)-Light configuration-Lichtfunktion D 32	184
(618)-Light configuration-Dimmwert CD 32	1
(619)-Light configuration-Dimming Direction CD 32	maximize
(620)-Light configuration-Lichtfunktion E 32	56
(621)-Light configuration-Lichtfunktion F 32	1
(622)-Light configuration-Dimmwert EF 32	96
(623)-Light configuration-Dimming Direction EF 32	minimize
(624)-Light configuration-Lichtfunktion G 32	0
(625)-Light configuration-Lichtfunktion H 32	56
(626)-Light configuration-Dimmwert GH 32	1
(627)-Light configuration-Dimming Direction GH 32	maximize
(628)-Light configuration-Lasttyp 33	not active
(629)-Light configuration-BAP Bitposition 33	0
(630)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	0
(631)-Light configuration-Lichtfunktion A 33	0
(632)-Light configuration-Lichtfunktion B 33	0
(633)-Light configuration-Dimmwert AB 33	12
(634)-Light configuration-Lichtansteuerung HD AB 33	only_if_closed
(635)-Light configuration-Lichtfunktion C 33	1
(636)-Light configuration-Lichtfunktion D 33	0
(637)-Light configuration-Dimmwert CD 33	0
(638)-Light configuration-Dimming Direction CD 33	maximize
(639)-Light configuration-Lichtfunktion E 33	78
(640)-Light configuration-Lichtfunktion F 33	0
(641)-Light configuration-Dimmwert EF 33	92
(642)-Light configuration-Dimming Direction EF 33	minimize
(643)-Light configuration-Lichtfunktion G 33	0
(644)-Light configuration-Lichtfunktion H 33	0
(645)-Light configuration-Dimmwert GH 33	0
(646)-Light configuration-Dimming Direction GH 33	maximize
(648)-Light configuration-BAP Bitposition 34	0
(649)-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	0
(650)-Light configuration-Lichtfunktion A 34	0
(651)-Light configuration-Lichtfunktion B 34	0
(652)-Light configuration-Dimmwert AB 34	66
(653)-Light configuration-Lichtansteuerung HD AB 34	Always
(654)-Light configuration-Lichtfunktion C 34	1
(655)-Light configuration-Lichtfunktion D 34	0
(656)-Light configuration-Dimmwert CD 34	0
(657)-Light configuration-Dimming Direction CD 34	maximize
(658)-Light configuration-Lichtfunktion E 34	0
(659)-Light configuration-Lichtfunktion F 34	0
(660)-Light configuration-Dimmwert EF 34	111
(661)-Light configuration-Dimming Direction EF 34	minimize
(662)-Light configuration-Lichtfunktion G 34	0
(663)-Light configuration-Lichtfunktion H 34	224
(664)-Light configuration-Dimmwert GH 34	0
(665)-Light configuration-Dimming Direction GH 34	maximize
lower turn position	31.49 °
Position during interval mode	31.49 °
(1)-Production mode-Scheinwerferreinigung	not active
(2)-Production mode-Frontwischer deaktivieren	not active
(3)-Production mode-Heckwischer	not active
(4)-Production mode-Interior lighting	not active
(5)-Production mode-Aussenbeleuchtung	not active
(6)-Production mode-Access control	not active
(7)-Production mode-Virtuel_pedal	not active
Read parameter address	FE 00 00
(1)-Rear Window Wiper-Komfortwischen Heck	active
(2)-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
(3)-Rear Window Wiper-Automatisches Heckwischen	not active
(4)-Rear Window Wiper-Traenenwischen Heck	active
(5)-Rear Window Wiper-Heckwischer Weiterlauf	not active
(6)-Rear Window Wiper-Kein automatisches Abparken	not active
(7)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
(8)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
(9)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
(10)-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
(11)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	0 s
(12)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	0.0 s
(13)-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active
Roller test bench mode; functional	not active
(1)-Seat fan charac. curve-Level_1_Sitz	25%
(2)-Seat fan charac. curve-Level_1_Lehne	30%
(3)-Seat fan charac. curve-Level_2_Sitz	25%
(4)-Seat fan charac. curve-Level_2_Lehne	30%
(5)-Seat fan charac. curve-Level_3_Sitz	53%
(6)-Seat fan charac. curve-Level_3_Lehne	58%
(7)-Seat fan charac. curve-Level_4_Sitz	53%
(8)-Seat fan charac. curve-Level_4_Lehne	58%
(9)-Seat fan charac. curve-Level_5_Sitz	80%
(10)-Seat fan charac. curve-Level_5_Lehne	85%
(11)-Seat fan charac. curve-Level_6_Sitz	80%
(12)-Seat fan charac. curve-Level_6_Lehne	85%
(1)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	16.00 °C
(2)-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	18.00 °C
(3)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	16.00 °C
(4)-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	18.00 °C
(5)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	36.00 °C
(6)-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	38.00 °C
(7)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	36.00 °C
(8)-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	38.00 °C
(9)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	52.00 °C
(10)-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	54.00 °C
(11)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	52.00 °C
(12)-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	54.00 °C
(13)-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s
(14)-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C
Service position	170.49 °
(1)-static AFS light-bei Rueckwaertsfahrt	both sides
(2)-static AFS light-Vorschrift	ECE R119
(3)-static AFS light-Lower speed threshold	0.00 km/h
(4)-static AFS light-Upper speed threshold	40.00 km/h
(5)-static AFS light-Steering wheel angle; offset	-63.75 °
(6)-static AFS light-Unterer Lenkradwinkel	180 °
(7)-static AFS light-Oberer Lenkradwinkel	120 °
(8)-static AFS light-Abdimmgeschwindigkeit	50.00 %/s
(9)-static AFS light-Maximaltemperatur	100.00 °C
(10)-static AFS light-obere Grenztemperatur	95.00 °C
(11)-static AFS light-untere Grenztemperatur	80.00 °C
Transport mode	active
(1)-Turn signal control-Warnblinken bei Verdeckentriegelung	not active
(2)-Turn signal control-Komfortblinken Blinkzyklen	4
(3)-Turn signal control-Sonderfunktionen	not enabled
(4)-Turn signal control-Signalprioritaet fuer Blinker	MFG
(5)-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte
(6)-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active
(7)-Turn signal control-Komfortblinken	active
(8)-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00%
(9)-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.1
(10)-Turn signal control-Abbruch Komfortblinken	not active
upper turn position	170.49 °
(1)-Window heater-Temperaturabhaengige Einschaltzeit HSH	not active
(2)-Window heater-Temperaturabhaengige Einschaltzeit FSH	active
(3)-Window heater-FSH Automatik	not active
(4)-Window heater-Heckscheibenheizung Zeitwert	600 s
(5)-Window heater-Running time of heated front window	240 s
(6)-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C
(7)-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C
(1)-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	0
(2)-Windshield wiper-SRA Verzoegerungszeit	0 ms
(3)-Windshield wiper-SRA Waschzeit	0 ms
(4)-Windshield wiper-SRA Einweichpausenzeit	0 ms
(5)-Windshield wiper-SRA Nachwaschzeit	0 ms
(6)-Windshield wiper-SRA Pausenzeit	0 ms
(7)-Windshield wiper-SRA bei Waschwassermangel	not active
(8)-Windshield wiper-Frontwischer Referenzlauf	active
(9)-Windshield wiper-Variable Regensensoraktivierung	not active
(10)-Windshield wiper-Wischer stop bei KL15 aus	not active
(11)-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
(12)-Windshield wiper-Regensensor aktivieren	Deactivating
(13)-Windshield wiper-Menuesteuerung Frontwischer	not active
(14)-Windshield wiper-Frontwischer Notlaufprogramm	active
(15)-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active
(16)-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
(17)-Windshield wiper-Traenenwischen Front Status	not active
(18)-Windshield wiper-Washer_Tipwiping_Variant	0
(19)-Windshield wiper-Adaptives Nachwischen bei SRA	not active
(20)-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active
(21)-Windshield wiper-Tippendes_Frontwaschen	not active
(22)-Windshield wiper-Frontwischer_Abtauposition	not active
(1)-Writing parameter-Parameter address	FE 00 00
(2)-Writing parameter-Value	130
erase_error_table	55 00 00
error_mask	0 bit
Frontwaschfunktion	10
(1)-Innenbeleuchtung Abdimmen-x0	0 ms
(2)-Innenbeleuchtung Abdimmen-X1	200 ms
(3)-Innenbeleuchtung Abdimmen-X2	400 ms
(4)-Innenbeleuchtung Abdimmen-X3	600 ms
(5)-Innenbeleuchtung Abdimmen-X4	800 ms
(6)-Innenbeleuchtung Abdimmen-X5	1000 ms
(7)-Innenbeleuchtung Abdimmen-X6	1200 ms
(8)-Innenbeleuchtung Abdimmen-x7	1400 ms
(9)-Innenbeleuchtung Abdimmen-x8	1600 ms
(10)-Innenbeleuchtung Abdimmen-x9	1800 ms
(11)-Innenbeleuchtung Abdimmen-x10	2000 ms
(12)-Innenbeleuchtung Abdimmen-y0	100.00%
(13)-Innenbeleuchtung Abdimmen-Y1	72.00%
(14)-Innenbeleuchtung Abdimmen-Y2	48.00%
(15)-Innenbeleuchtung Abdimmen-Y3	33.00%
(16)-Innenbeleuchtung Abdimmen-Y4	18.00%
(17)-Innenbeleuchtung Abdimmen-Y5	12.00%
(18)-Innenbeleuchtung Abdimmen-Y6	8.00%
(19)-Innenbeleuchtung Abdimmen-y7	6.00%
(20)-Innenbeleuchtung Abdimmen-y8	4.00%
(21)-Innenbeleuchtung Abdimmen-y9	2.00%
(22)-Innenbeleuchtung Abdimmen-y10	0.00%
(1)-Innenbeleuchtung Fotosensor-x0	0
(2)-Innenbeleuchtung Fotosensor-X1	50
(3)-Innenbeleuchtung Fotosensor-X2	100
(4)-Innenbeleuchtung Fotosensor-X3	200
(5)-Innenbeleuchtung Fotosensor-X4	253
(6)-Innenbeleuchtung Fotosensor-X5	0
(7)-Innenbeleuchtung Fotosensor-X6	0
(8)-Innenbeleuchtung Fotosensor-x7	0
(9)-Innenbeleuchtung Fotosensor-x8	0
(10)-Innenbeleuchtung Fotosensor-x9	0
(11)-Innenbeleuchtung Fotosensor-x10	0
(12)-Innenbeleuchtung Fotosensor-y0	0 lx
(13)-Innenbeleuchtung Fotosensor-Y1	50 lx
(14)-Innenbeleuchtung Fotosensor-Y2	100 lx
(15)-Innenbeleuchtung Fotosensor-Y3	200
(16)-Innenbeleuchtung Fotosensor-Y4	500
(17)-Innenbeleuchtung Fotosensor-Y5	0
(18)-Innenbeleuchtung Fotosensor-Y6	0 lx
(19)-Innenbeleuchtung Fotosensor-y7	0 lx
(20)-Innenbeleuchtung Fotosensor-y8	0 lx
(21)-Innenbeleuchtung Fotosensor-y9	0 lx
(22)-Innenbeleuchtung Fotosensor-y10	0 lx
(1)-Innenbeleuchtung Hochdimmen-x0	0 ms
(2)-Innenbeleuchtung Hochdimmen-X1	200 ms
(3)-Innenbeleuchtung Hochdimmen-X2	400 ms
(4)-Innenbeleuchtung Hochdimmen-X3	600 ms
(5)-Innenbeleuchtung Hochdimmen-X4	800 ms
(6)-Innenbeleuchtung Hochdimmen-X5	1000 ms
(7)-Innenbeleuchtung Hochdimmen-X6	1200 ms
(8)-Innenbeleuchtung Hochdimmen-x7	1400 ms
(9)-Innenbeleuchtung Hochdimmen-x8	1600 ms
(10)-Innenbeleuchtung Hochdimmen-x9	1800 ms
(11)-Innenbeleuchtung Hochdimmen-x10	2000 ms
(12)-Innenbeleuchtung Hochdimmen-y0	0.00%
(13)-Innenbeleuchtung Hochdimmen-Y1	1.00%
(14)-Innenbeleuchtung Hochdimmen-Y2	3.00%
(15)-Innenbeleuchtung Hochdimmen-Y3	5.00%
(16)-Innenbeleuchtung Hochdimmen-Y4	11.00%
(17)-Innenbeleuchtung Hochdimmen-Y5	22.00%
(18)-Innenbeleuchtung Hochdimmen-Y6	40.00%
(19)-Innenbeleuchtung Hochdimmen-y7	80.00%
(20)-Innenbeleuchtung Hochdimmen-y8	95.00%
(21)-Innenbeleuchtung Hochdimmen-y9	100.00%
(22)-Innenbeleuchtung Hochdimmen-y10	100.00%
(1)-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
(2)-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
(3)-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
(4)-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
(5)-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
(6)-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
(7)-Innenbeleuchtung KL 58xd log Bus-y0	10
(8)-Innenbeleuchtung KL 58xd log Bus-Y1	10
(9)-Innenbeleuchtung KL 58xd log Bus-Y2	100
(10)-Innenbeleuchtung KL 58xd log Bus-Y3	150
(11)-Innenbeleuchtung KL 58xd log Bus-Y4	220
(12)-Innenbeleuchtung KL 58xd log Bus-Y5	253
(1)-Innenbeleuchtung KL 58xd max-x0	0 lx
(2)-Innenbeleuchtung KL 58xd max-X1	8 lx
(3)-Innenbeleuchtung KL 58xd max-X2	200 lx
(4)-Innenbeleuchtung KL 58xd max-X3	300 lx
(5)-Innenbeleuchtung KL 58xd max-X4	500 lx
(6)-Innenbeleuchtung KL 58xd max-y0	16
(7)-Innenbeleuchtung KL 58xd max-Y1	16
(8)-Innenbeleuchtung KL 58xd max-Y2	100
(9)-Innenbeleuchtung KL 58xd max-Y3	100
(10)-Innenbeleuchtung KL 58xd max-Y4	100
(1)-Innenbeleuchtung KL 58xd min-x0	0 lx
(2)-Innenbeleuchtung KL 58xd min-X1	8 lx
(3)-Innenbeleuchtung KL 58xd min-X2	220 lx
(4)-Innenbeleuchtung KL 58xd min-X3	300 lx
(5)-Innenbeleuchtung KL 58xd min-X4	500 lx
(6)-Innenbeleuchtung KL 58xd min-y0	6
(7)-Innenbeleuchtung KL 58xd min-Y1	6
(8)-Innenbeleuchtung KL 58xd min-Y2	100
(9)-Innenbeleuchtung KL 58xd min-Y3	100
(10)-Innenbeleuchtung KL 58xd min-Y4	100
(1)-Innenbeleuchtung KL 58xd PWM-x0	0
(2)-Innenbeleuchtung KL 58xd PWM-X1	10
(3)-Innenbeleuchtung KL 58xd PWM-X2	50
(4)-Innenbeleuchtung KL 58xd PWM-X3	100
(5)-Innenbeleuchtung KL 58xd PWM-X4	220
(6)-Innenbeleuchtung KL 58xd PWM-X5	253
(7)-Innenbeleuchtung KL 58xd PWM-y0	2.00%
(8)-Innenbeleuchtung KL 58xd PWM-Y1	2.00%
(9)-Innenbeleuchtung KL 58xd PWM-Y2	6.00%
(10)-Innenbeleuchtung KL 58xd PWM-Y3	10.00%
(11)-Innenbeleuchtung KL 58xd PWM-Y4	80.00%
(12)-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
(1)-Innenbeleuchtung KL 58xs max-x0	0 lx
(2)-Innenbeleuchtung KL 58xs max-X1	8 lx
(3)-Innenbeleuchtung KL 58xs max-X2	50 lx
(4)-Innenbeleuchtung KL 58xs max-X3	500 lx
(5)-Innenbeleuchtung KL 58xs max-y0	100
(6)-Innenbeleuchtung KL 58xs max-Y1	100
(7)-Innenbeleuchtung KL 58xs max-Y2	100
(8)-Innenbeleuchtung KL 58xs max-Y3	100
(1)-Innenbeleuchtung KL 58xs min-x0	0 lx
(2)-Innenbeleuchtung KL 58xs min-X1	8 lx
(3)-Innenbeleuchtung KL 58xs min-X2	50 lx
(4)-Innenbeleuchtung KL 58xs min-X3	500 lx
(5)-Innenbeleuchtung KL 58xs min-y0	6
(6)-Innenbeleuchtung KL 58xs min-Y1	6
(7)-Innenbeleuchtung KL 58xs min-Y2	100
(8)-Innenbeleuchtung KL 58xs min-Y3	100
(1)-Innenbeleuchtung KL 58xs PWM-x0	0.00%
(2)-Innenbeleuchtung KL 58xs PWM-X1	50.00%
(3)-Innenbeleuchtung KL 58xs PWM-X2	100.00%
(4)-Innenbeleuchtung KL 58xs PWM-y0	0.00%
(5)-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
(6)-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
(1)-Innenbeleuchtung KL 58xt max-x0	0 lx
(2)-Innenbeleuchtung KL 58xt max-X1	8 lx
(3)-Innenbeleuchtung KL 58xt max-X2	50 lx
(4)-Innenbeleuchtung KL 58xt max-X3	500 lx
(5)-Innenbeleuchtung KL 58xt max-y0	100
(6)-Innenbeleuchtung KL 58xt max-Y1	100
(7)-Innenbeleuchtung KL 58xt max-Y2	100
(8)-Innenbeleuchtung KL 58xt max-Y3	100
(1)-Innenbeleuchtung KL 58xt min-x0	0 lx
(2)-Innenbeleuchtung KL 58xt min-X1	8 lx
(3)-Innenbeleuchtung KL 58xt min-X2	50 lx
(4)-Innenbeleuchtung KL 58xt min-X3	500 lx
(5)-Innenbeleuchtung KL 58xt min-y0	6
(6)-Innenbeleuchtung KL 58xt min-Y1	6
(7)-Innenbeleuchtung KL 58xt min-Y2	100
(8)-Innenbeleuchtung KL 58xt min-Y3	100
(1)-Innenbeleuchtung KL 58xt PWM-x0	0.00%
(2)-Innenbeleuchtung KL 58xt PWM-X1	50.00%
(3)-Innenbeleuchtung KL 58xt PWM-X2	100.00%
(4)-Innenbeleuchtung KL 58xt PWM-y0	0.00%
(5)-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
(6)-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
(1)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
(2)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	100 ms
(3)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	160 ms
(4)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	200 ms
(5)-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	260 ms
(6)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
(7)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
(8)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
(9)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	10
(10)-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
(1)-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten
(2)-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34
(3)-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0	100
(7)-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0	0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
(1)-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
(3)-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
(4)-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Left high beam
(5)-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
(6)-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
(7)-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
(8)-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active
(9)-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active
(10)-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
(11)-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
(12)-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active
(13)-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active
(14)-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
(15)-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
(16)-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active
(17)-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active
(18)-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
(19)-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
(1)-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter; Diagnosesensierung für 'LED low'
(2)-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
(3)-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
(4)-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Right high beam
(5)-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
(6)-Leuchte11SHUTTER RB22-Dimmwert AB 11	127
(7)-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
(8)-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active
(9)-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active
(10)-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
(11)-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
(12)-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active
(13)-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active
(14)-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
(15)-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
(16)-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active
(17)-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active
(18)-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
(19)-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
(1)-Leuchte12NL LB45-Lasttyp 12	6 - LED Lichtmodul
(2)-Leuchte12NL LB45-Lampendefektbitposition 12	38
(3)-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
(4)-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links
(5)-Leuchte12NL LB45-Lichtfunktion B 12	not active
(6)-Leuchte12NL LB45-Dimmwert AB 12	127
(7)-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
(8)-Leuchte12NL LB45-Lichtfunktion C 12	not active
(9)-Leuchte12NL LB45-Lichtfunktion D 12	not active
(10)-Leuchte12NL LB45-Dimmwert CD 12	0
(11)-Leuchte12NL LB45-Dimming Direction CD 12	maximize
(12)-Leuchte12NL LB45-Lichtfunktion E 12	not active
(13)-Leuchte12NL LB45-Lichtfunktion F 12	not active
(14)-Leuchte12NL LB45-Dimmwert EF 12	0
(15)-Leuchte12NL LB45-Dimming Direction EF 12	maximize
(16)-Leuchte12NL LB45-Lichtfunktion G 12	not active
(17)-Leuchte12NL LB45-Lichtfunktion H 12	not active
(18)-Leuchte12NL LB45-Dimmwert GH 12	0
(19)-Leuchte12NL LB45-Dimming Direction GH 12	maximize
(1)-Leuchte13NL RB5-Lasttyp 13	6 - LED Lichtmodul
(2)-Leuchte13NL RB5-Lampendefektbitposition 13	42
(3)-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
(4)-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts
(5)-Leuchte13NL RB5-Lichtfunktion B 13	not active
(6)-Leuchte13NL RB5-Dimmwert AB 13	127
(7)-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
(8)-Leuchte13NL RB5-Lichtfunktion C 13	not active
(9)-Leuchte13NL RB5-Lichtfunktion D 13	not active
(10)-Leuchte13NL RB5-Dimmwert CD 13	0
(11)-Leuchte13NL RB5-Dimming Direction CD 13	maximize
(12)-Leuchte13NL RB5-Lichtfunktion E 13	not active
(13)-Leuchte13NL RB5-Lichtfunktion F 13	not active
(14)-Leuchte13NL RB5-Dimmwert EF 13	0
(15)-Leuchte13NL RB5-Dimming Direction EF 13	maximize
(16)-Leuchte13NL RB5-Lichtfunktion G 13	not active
(17)-Leuchte13NL RB5-Lichtfunktion H 13	not active
(18)-Leuchte13NL RB5-Dimmwert GH 13	0
(19)-Leuchte13NL RB5-Dimming Direction GH 13	maximize
(1)-Leuchte15AL RB44-Lasttyp 15	not active
(2)-Leuchte15AL RB44-Lampendefektbitposition 15	0
(3)-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0
(4)-Leuchte15AL RB44-Lichtfunktion A 15	not active
(5)-Leuchte15AL RB44-Lichtfunktion B 15	not active
(6)-Leuchte15AL RB44-Dimmwert AB 15	0
(7)-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always
(8)-Leuchte15AL RB44-Lichtfunktion C 15	not active
(9)-Leuchte15AL RB44-Lichtfunktion D 15	not active
(10)-Leuchte15AL RB44-Dimmwert CD 15	0
(11)-Leuchte15AL RB44-Dimming Direction CD 15	maximize
(12)-Leuchte15AL RB44-Lichtfunktion E 15	not active
(13)-Leuchte15AL RB44-Lichtfunktion F 15	not active
(14)-Leuchte15AL RB44-Dimmwert EF 15	0
(15)-Leuchte15AL RB44-Dimming Direction EF 15	maximize
(16)-Leuchte15AL RB44-Lichtfunktion G 15	not active
(17)-Leuchte15AL RB44-Lichtfunktion H 15	not active
(18)-Leuchte15AL RB44-Dimmwert GH 15	0
(19)-Leuchte15AL RB44-Dimming Direction GH 15	maximize
(1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active
(2)-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0
(3)-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0
(4)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active
(5)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0
(7)-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
(8)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active
(9)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active
(10)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
(11)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize
(12)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active
(13)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active
(14)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
(15)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize
(16)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active
(17)-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active
(18)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
(19)-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
(1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active
(2)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0
(3)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0
(4)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active
(5)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active
(6)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0
(7)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
(8)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active
(9)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active
(10)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
(11)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize
(12)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active
(13)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active
(14)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
(15)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize
(16)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active
(17)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active
(18)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
(19)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
(1)-Leuchte18BLK HLA60-Lasttyp 18	not active
(2)-Leuchte18BLK HLA60-Lampendefektbitposition 18	0
(3)-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	0
(4)-Leuchte18BLK HLA60-Lichtfunktion A 18	not active
(5)-Leuchte18BLK HLA60-Lichtfunktion B 18	not active
(6)-Leuchte18BLK HLA60-Dimmwert AB 18	0
(7)-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
(8)-Leuchte18BLK HLA60-Lichtfunktion C 18	not active
(9)-Leuchte18BLK HLA60-Lichtfunktion D 18	not active
(10)-Leuchte18BLK HLA60-Dimmwert CD 18	0
(11)-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize
(12)-Leuchte18BLK HLA60-Lichtfunktion E 18	not active
(13)-Leuchte18BLK HLA60-Lichtfunktion F 18	not active
(14)-Leuchte18BLK HLA60-Dimmwert EF 18	0
(15)-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
(16)-Leuchte18BLK HLA60-Lichtfunktion G 18	not active
(17)-Leuchte18BLK HLA60-Lichtfunktion H 18	not active
(18)-Leuchte18BLK HLA60-Dimmwert GH 18	0
(19)-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
(1)-Leuchte19BLK HRC31-Lasttyp 19	not active
(2)-Leuchte19BLK HRC31-Lampendefektbitposition 19	0
(3)-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	0
(4)-Leuchte19BLK HRC31-Lichtfunktion A 19	not active
(5)-Leuchte19BLK HRC31-Lichtfunktion B 19	not active
(6)-Leuchte19BLK HRC31-Dimmwert AB 19	0
(7)-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
(8)-Leuchte19BLK HRC31-Lichtfunktion C 19	not active
(9)-Leuchte19BLK HRC31-Lichtfunktion D 19	not active
(10)-Leuchte19BLK HRC31-Dimmwert CD 19	0
(11)-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize
(12)-Leuchte19BLK HRC31-Lichtfunktion E 19	not active
(13)-Leuchte19BLK HRC31-Lichtfunktion F 19	not active
(14)-Leuchte19BLK HRC31-Dimmwert EF 19	0
(15)-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
(16)-Leuchte19BLK HRC31-Lichtfunktion G 19	not active
(17)-Leuchte19BLK HRC31-Lichtfunktion H 19	not active
(18)-Leuchte19BLK HRC31-Dimmwert GH 19	0
(19)-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
(1)-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten
(2)-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E
(3)-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15
(4)-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase
(5)-Leuchte1BLK VRB20-Lichtfunktion B 1	not active
(6)-Leuchte1BLK VRB20-Dimmwert AB 1	100
(7)-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
(8)-Leuchte1BLK VRB20-Lichtfunktion C 1	not active
(9)-Leuchte1BLK VRB20-Lichtfunktion D 1	not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 1	0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 1	not active
(13)-Leuchte1BLK VRB20-Lichtfunktion F 1	not active
(14)-Leuchte1BLK VRB20-Dimmwert EF 1	0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 1	not active
(17)-Leuchte1BLK VRB20-Lichtfunktion H 1	not active
(18)-Leuchte1BLK VRB20-Dimmwert GH 1	0
(19)-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
(1)-Leuchte20BR LA71-Lasttyp 20	14 - kombinierte Blink- Bremsleuchten
(2)-Leuchte20BR LA71-Lampendefektbitposition 20	13
(3)-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	3D
(4)-Leuchte20BR LA71-Lichtfunktion A 20	Brake light
(5)-Leuchte20BR LA71-Lichtfunktion B 20	Blinken links Hellphase
(6)-Leuchte20BR LA71-Dimmwert AB 20	100
(7)-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
(8)-Leuchte20BR LA71-Lichtfunktion C 20	Blinken links Dunkelphase
(9)-Leuchte20BR LA71-Lichtfunktion D 20	not active
(10)-Leuchte20BR LA71-Dimmwert CD 20	0
(11)-Leuchte20BR LA71-Dimming Direction CD 20	minimize
(12)-Leuchte20BR LA71-Lichtfunktion E 20	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte20BR LA71-Lichtfunktion F 20	not active
(14)-Leuchte20BR LA71-Dimmwert EF 20	28
(15)-Leuchte20BR LA71-Dimming Direction EF 20	maximize
(16)-Leuchte20BR LA71-Lichtfunktion G 20	not active
(17)-Leuchte20BR LA71-Lichtfunktion H 20	not active
(18)-Leuchte20BR LA71-Dimmwert GH 20	0
(19)-Leuchte20BR LA71-Dimming Direction GH 20	maximize
(1)-Leuchte21BR RC8-Lasttyp 21	14 - kombinierte Blink- Bremsleuchten
(2)-Leuchte21BR RC8-Lampendefektbitposition 21	23
(3)-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3E
(4)-Leuchte21BR RC8-Lichtfunktion A 21	Brake light
(5)-Leuchte21BR RC8-Lichtfunktion B 21	Blinken rechts Hellphase
(6)-Leuchte21BR RC8-Dimmwert AB 21	100
(7)-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
(8)-Leuchte21BR RC8-Lichtfunktion C 21	Blinken rechts Dunkelphase
(9)-Leuchte21BR RC8-Lichtfunktion D 21	not active
(10)-Leuchte21BR RC8-Dimmwert CD 21	0
(11)-Leuchte21BR RC8-Dimming Direction CD 21	minimize
(12)-Leuchte21BR RC8-Lichtfunktion E 21	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte21BR RC8-Lichtfunktion F 21	not active
(14)-Leuchte21BR RC8-Dimmwert EF 21	28
(15)-Leuchte21BR RC8-Dimming Direction EF 21	maximize
(16)-Leuchte21BR RC8-Lichtfunktion G 21	not active
(17)-Leuchte21BR RC8-Lichtfunktion H 21	not active
(18)-Leuchte21BR RC8-Dimmwert GH 21	0
(19)-Leuchte21BR RC8-Dimming Direction GH 21	maximize
(1)-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte
(2)-Leuchte22BR MA57-Lampendefektbitposition 22	29
(3)-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
(4)-Leuchte22BR MA57-Lichtfunktion A 22	Brake light
(5)-Leuchte22BR MA57-Lichtfunktion B 22	not active
(6)-Leuchte22BR MA57-Dimmwert AB 22	100
(7)-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always
(8)-Leuchte22BR MA57-Lichtfunktion C 22	not active
(9)-Leuchte22BR MA57-Lichtfunktion D 22	not active
(10)-Leuchte22BR MA57-Dimmwert CD 22	0
(11)-Leuchte22BR MA57-Dimming Direction CD 22	maximize
(12)-Leuchte22BR MA57-Lichtfunktion E 22	not active
(13)-Leuchte22BR MA57-Lichtfunktion F 22	not active
(14)-Leuchte22BR MA57-Dimmwert EF 22	0
(15)-Leuchte22BR MA57-Dimming Direction EF 22	maximize
(16)-Leuchte22BR MA57-Lichtfunktion G 22	not active
(17)-Leuchte22BR MA57-Lichtfunktion H 22	not active
(18)-Leuchte22BR MA57-Dimmwert GH 22	0
(19)-Leuchte22BR MA57-Dimming Direction GH 22	maximize
(1)-Leuchte23SL HLC10-Lasttyp 23	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
(3)-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29
(4)-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte23SL HLC10-Lichtfunktion B 23	not active
(6)-Leuchte23SL HLC10-Dimmwert AB 23	28
(7)-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	Always
(8)-Leuchte23SL HLC10-Lichtfunktion C 23	not active
(9)-Leuchte23SL HLC10-Lichtfunktion D 23	not active
(10)-Leuchte23SL HLC10-Dimmwert CD 23	0
(11)-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
(12)-Leuchte23SL HLC10-Lichtfunktion E 23	not active
(13)-Leuchte23SL HLC10-Lichtfunktion F 23	not active
(14)-Leuchte23SL HLC10-Dimmwert EF 23	0
(15)-Leuchte23SL HLC10-Dimming Direction EF 23	maximize
(16)-Leuchte23SL HLC10-Lichtfunktion G 23	not active
(17)-Leuchte23SL HLC10-Lichtfunktion H 23	not active
(18)-Leuchte23SL HLC10-Dimmwert GH 23	0
(19)-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
(1)-Leuchte24SL HRA65-Lasttyp 24	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
(3)-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A
(4)-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte24SL HRA65-Lichtfunktion B 24	not active
(6)-Leuchte24SL HRA65-Dimmwert AB 24	28
(7)-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	Always
(8)-Leuchte24SL HRA65-Lichtfunktion C 24	not active
(9)-Leuchte24SL HRA65-Lichtfunktion D 24	not active
(10)-Leuchte24SL HRA65-Dimmwert CD 24	0
(11)-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
(12)-Leuchte24SL HRA65-Lichtfunktion E 24	not active
(13)-Leuchte24SL HRA65-Lichtfunktion F 24	not active
(14)-Leuchte24SL HRA65-Dimmwert EF 24	0
(15)-Leuchte24SL HRA65-Dimming Direction EF 24	maximize
(16)-Leuchte24SL HRA65-Lichtfunktion G 24	not active
(17)-Leuchte24SL HRA65-Lichtfunktion H 24	not active
(18)-Leuchte24SL HRA65-Dimmwert GH 24	0
(19)-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
(1)-Leuchte25KZL HA59-Lasttyp 25	18 - 2* 5W
(2)-Leuchte25KZL HA59-Lampendefektbitposition 25	28
(3)-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
(4)-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte25KZL HA59-Lichtfunktion B 25	not active
(6)-Leuchte25KZL HA59-Dimmwert AB 25	100
(7)-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always
(8)-Leuchte25KZL HA59-Lichtfunktion C 25	not active
(9)-Leuchte25KZL HA59-Lichtfunktion D 25	not active
(10)-Leuchte25KZL HA59-Dimmwert CD 25	0
(11)-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
(12)-Leuchte25KZL HA59-Lichtfunktion E 25	not active
(13)-Leuchte25KZL HA59-Lichtfunktion F 25	not active
(14)-Leuchte25KZL HA59-Dimmwert EF 25	0
(15)-Leuchte25KZL HA59-Dimming Direction EF 25	maximize
(16)-Leuchte25KZL HA59-Lichtfunktion G 25	not active
(17)-Leuchte25KZL HA59-Lichtfunktion H 25	not active
(18)-Leuchte25KZL HA59-Dimmwert GH 25	0
(19)-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
(1)-Leuchte26NSL LA72-Lasttyp 26	1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte26NSL LA72-Lampendefektbitposition 26	0
(3)-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	47
(4)-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte26NSL LA72-Lichtfunktion B 26	not active
(6)-Leuchte26NSL LA72-Dimmwert AB 26	127
(7)-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always
(8)-Leuchte26NSL LA72-Lichtfunktion C 26	not active
(9)-Leuchte26NSL LA72-Lichtfunktion D 26	not active
(10)-Leuchte26NSL LA72-Dimmwert CD 26	0
(11)-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
(12)-Leuchte26NSL LA72-Lichtfunktion E 26	not active
(13)-Leuchte26NSL LA72-Lichtfunktion F 26	not active
(14)-Leuchte26NSL LA72-Dimmwert EF 26	0
(15)-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
(16)-Leuchte26NSL LA72-Lichtfunktion G 26	not active
(17)-Leuchte26NSL LA72-Lichtfunktion H 26	not active
(18)-Leuchte26NSL LA72-Dimmwert GH 26	0
(19)-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
(1)-Leuchte27NSL RC6-Lasttyp 27	not active
(2)-Leuchte27NSL RC6-Lampendefektbitposition 27	0
(3)-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	0
(4)-Leuchte27NSL RC6-Lichtfunktion A 27	not active
(5)-Leuchte27NSL RC6-Lichtfunktion B 27	not active
(6)-Leuchte27NSL RC6-Dimmwert AB 27	0
(7)-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always
(8)-Leuchte27NSL RC6-Lichtfunktion C 27	not active
(9)-Leuchte27NSL RC6-Lichtfunktion D 27	not active
(10)-Leuchte27NSL RC6-Dimmwert CD 27	0
(11)-Leuchte27NSL RC6-Dimming Direction CD 27	maximize
(12)-Leuchte27NSL RC6-Lichtfunktion E 27	not active
(13)-Leuchte27NSL RC6-Lichtfunktion F 27	not active
(14)-Leuchte27NSL RC6-Dimmwert EF 27	0
(15)-Leuchte27NSL RC6-Dimming Direction EF 27	maximize
(16)-Leuchte27NSL RC6-Lichtfunktion G 27	not active
(17)-Leuchte27NSL RC6-Lichtfunktion H 27	not active
(18)-Leuchte27NSL RC6-Dimmwert GH 27	0
(19)-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
(1)-Leuchte28RFL LC11-Lasttyp 28	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
(3)-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
(4)-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
(5)-Leuchte28RFL LC11-Lichtfunktion B 28	not active
(6)-Leuchte28RFL LC11-Dimmwert AB 28	100
(7)-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	Always
(8)-Leuchte28RFL LC11-Lichtfunktion C 28	not active
(9)-Leuchte28RFL LC11-Lichtfunktion D 28	not active
(10)-Leuchte28RFL LC11-Dimmwert CD 28	0
(11)-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
(12)-Leuchte28RFL LC11-Lichtfunktion E 28	not active
(13)-Leuchte28RFL LC11-Lichtfunktion F 28	not active
(14)-Leuchte28RFL LC11-Dimmwert EF 28	0
(15)-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
(16)-Leuchte28RFL LC11-Lichtfunktion G 28	not active
(17)-Leuchte28RFL LC11-Lichtfunktion H 28	not active
(18)-Leuchte28RFL LC11-Dimmwert GH 28	0
(19)-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
(1)-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W; auch H15
(2)-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
(3)-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
(4)-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
(5)-Leuchte29RFL RA64-Lichtfunktion B 29	not active
(6)-Leuchte29RFL RA64-Dimmwert AB 29	100
(7)-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	Always
(8)-Leuchte29RFL RA64-Lichtfunktion C 29	not active
(9)-Leuchte29RFL RA64-Lichtfunktion D 29	not active
(10)-Leuchte29RFL RA64-Dimmwert CD 29	0
(11)-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
(12)-Leuchte29RFL RA64-Lichtfunktion E 29	not active
(13)-Leuchte29RFL RA64-Lichtfunktion F 29	not active
(14)-Leuchte29RFL RA64-Dimmwert EF 29	0
(15)-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
(16)-Leuchte29RFL RA64-Lichtfunktion G 29	not active
(17)-Leuchte29RFL RA64-Lichtfunktion H 29	not active
(18)-Leuchte29RFL RA64-Dimmwert GH 29	0
(19)-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
(1)-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte2SL VLB10-Lampendefektbitposition 2	48
(3)-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A
(4)-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights
(5)-Leuchte2SL VLB10-Lichtfunktion B 2	not active
(6)-Leuchte2SL VLB10-Dimmwert AB 2	100
(7)-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
(8)-Leuchte2SL VLB10-Lichtfunktion C 2	not active
(9)-Leuchte2SL VLB10-Lichtfunktion D 2	not active
(10)-Leuchte2SL VLB10-Dimmwert CD 2	0
(11)-Leuchte2SL VLB10-Dimming Direction CD 2	minimize
(12)-Leuchte2SL VLB10-Lichtfunktion E 2	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte2SL VLB10-Lichtfunktion F 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)
(14)-Leuchte2SL VLB10-Dimmwert EF 2	26
(15)-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
(16)-Leuchte2SL VLB10-Lichtfunktion G 2	not active
(17)-Leuchte2SL VLB10-Lichtfunktion H 2	not active
(18)-Leuchte2SL VLB10-Dimmwert GH 2	0
(19)-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
(1)-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung
(2)-Leuchte30FR LC72-Lampendefektbitposition 30	0
(3)-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
(4)-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
(5)-Leuchte30FR LC72-Lichtfunktion B 30	not active
(6)-Leuchte30FR LC72-Dimmwert AB 30	89
(7)-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
(8)-Leuchte30FR LC72-Lichtfunktion C 30	not active
(9)-Leuchte30FR LC72-Lichtfunktion D 30	not active
(10)-Leuchte30FR LC72-Dimmwert CD 30	0
(11)-Leuchte30FR LC72-Dimming Direction CD 30	maximize
(12)-Leuchte30FR LC72-Lichtfunktion E 30	not active
(13)-Leuchte30FR LC72-Lichtfunktion F 30	not active
(14)-Leuchte30FR LC72-Dimmwert EF 30	0
(15)-Leuchte30FR LC72-Dimming Direction EF 30	maximize
(16)-Leuchte30FR LC72-Lichtfunktion G 30	not active
(17)-Leuchte30FR LC72-Lichtfunktion H 30	not active
(18)-Leuchte30FR LC72-Dimmwert GH 30	0
(19)-Leuchte30FR LC72-Dimming Direction GH 30	maximize
(1)-Leuchte31AMBL 1C61-Lasttyp 31	not active
(2)-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0
(3)-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0
(4)-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active
(5)-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active
(6)-Leuchte31AMBL 1C61-Dimmwert AB 31	0
(7)-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
(8)-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active
(9)-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active
(10)-Leuchte31AMBL 1C61-Dimmwert CD 31	0
(11)-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
(12)-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active
(13)-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active
(14)-Leuchte31AMBL 1C61-Dimmwert EF 31	0
(15)-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
(16)-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active
(17)-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active
(18)-Leuchte31AMBL 1C61-Dimmwert GH 31	0
(19)-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
(1)-Leuchte32AMBL 2C35-Lasttyp 32	not active
(2)-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0
(3)-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0
(4)-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active
(5)-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active
(6)-Leuchte32AMBL 2C35-Dimmwert AB 32	0
(7)-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
(8)-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active
(9)-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active
(10)-Leuchte32AMBL 2C35-Dimmwert CD 32	0
(11)-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
(12)-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active
(13)-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active
(14)-Leuchte32AMBL 2C35-Dimmwert EF 32	0
(15)-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
(16)-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active
(17)-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active
(18)-Leuchte32AMBL 2C35-Dimmwert GH 32	0
(19)-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
(1)-Leuchte33AMBL 3C36-Lasttyp 33	not active
(2)-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0
(3)-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0
(4)-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active
(5)-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active
(6)-Leuchte33AMBL 3C36-Dimmwert AB 33	0
(7)-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
(8)-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active
(9)-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active
(10)-Leuchte33AMBL 3C36-Dimmwert CD 33	0
(11)-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
(12)-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active
(13)-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active
(14)-Leuchte33AMBL 3C36-Dimmwert EF 33	0
(15)-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
(16)-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active
(17)-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active
(18)-Leuchte33AMBL 3C36-Dimmwert GH 33	0
(19)-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
(1)-Leuchte34AMBL 4C37-Lasttyp 34	not active
(2)-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0
(3)-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0
(4)-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active
(5)-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active
(6)-Leuchte34AMBL 4C37-Dimmwert AB 34	0
(7)-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
(8)-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active
(9)-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active
(10)-Leuchte34AMBL 4C37-Dimmwert CD 34	0
(11)-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
(12)-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active
(13)-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active
(14)-Leuchte34AMBL 4C37-Dimmwert EF 34	0
(15)-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
(16)-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active
(17)-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active
(18)-Leuchte34AMBL 4C37-Dimmwert GH 34	0
(19)-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
(1)-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
(2)-Leuchte3SL VRB21-Lampendefektbitposition 3	4C
(3)-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C
(4)-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights
(5)-Leuchte3SL VRB21-Lichtfunktion B 3	not active
(6)-Leuchte3SL VRB21-Dimmwert AB 3	100
(7)-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
(8)-Leuchte3SL VRB21-Lichtfunktion C 3	not active
(9)-Leuchte3SL VRB21-Lichtfunktion D 3	not active
(10)-Leuchte3SL VRB21-Dimmwert CD 3	0
(11)-Leuchte3SL VRB21-Dimming Direction CD 3	minimize
(12)-Leuchte3SL VRB21-Lichtfunktion E 3	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte3SL VRB21-Lichtfunktion F 3	Parking light right
(14)-Leuchte3SL VRB21-Dimmwert EF 3	26
(15)-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
(16)-Leuchte3SL VRB21-Lichtfunktion G 3	not active
(17)-Leuchte3SL VRB21-Lichtfunktion H 3	not active
(18)-Leuchte3SL VRB21-Dimmwert GH 3	0
(19)-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
(1)-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte4TFL LB4-Lampendefektbitposition 4	3A
(3)-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49
(4)-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights
(5)-Leuchte4TFL LB4-Lichtfunktion B 4	not active
(6)-Leuchte4TFL LB4-Dimmwert AB 4	127
(7)-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
(8)-Leuchte4TFL LB4-Lichtfunktion C 4	not active
(9)-Leuchte4TFL LB4-Lichtfunktion D 4	not active
(10)-Leuchte4TFL LB4-Dimmwert CD 4	0
(11)-Leuchte4TFL LB4-Dimming Direction CD 4	minimize
(12)-Leuchte4TFL LB4-Lichtfunktion E 4	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte4TFL LB4-Lichtfunktion F 4	Parklicht links (beidseitiges Parklicht aktiviert li & re)
(14)-Leuchte4TFL LB4-Dimmwert EF 4	127
(15)-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
(16)-Leuchte4TFL LB4-Lichtfunktion G 4	not active
(17)-Leuchte4TFL LB4-Lichtfunktion H 4	not active
(18)-Leuchte4TFL LB4-Dimmwert GH 4	0
(19)-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
(1)-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
(2)-Leuchte5 TFL RB32-Lampendefektbitposition 5	44
(3)-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B
(4)-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights
(5)-Leuchte5 TFL RB32-Lichtfunktion B 5	not active
(6)-Leuchte5 TFL RB32-Dimmwert AB 5	127
(7)-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5	not active
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5	not active
(10)-Leuchte5 TFL RB32-Dimmwert CD 5	0
(11)-Leuchte5 TFL RB32-Dimming Direction CD 5	minimize
(12)-Leuchte5 TFL RB32-Lichtfunktion E 5	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(13)-Leuchte5 TFL RB32-Lichtfunktion F 5	Parking light right
(14)-Leuchte5 TFL RB32-Dimmwert EF 5	127
(15)-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
(16)-Leuchte5 TFL RB32-Lichtfunktion G 5	not active
(17)-Leuchte5 TFL RB32-Lichtfunktion H 5	not active
(18)-Leuchte5 TFL RB32-Dimmwert GH 5	0
(19)-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
(1)-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
(2)-Leuchte6ABL LC5-Lampendefektbitposition 6	36
(3)-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
(4)-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
(5)-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6	127
(7)-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
(8)-Leuchte6ABL LC5-Lichtfunktion C 6	not active
(9)-Leuchte6ABL LC5-Lichtfunktion D 6	not active
(10)-Leuchte6ABL LC5-Dimmwert CD 6	0
(11)-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
(12)-Leuchte6ABL LC5-Lichtfunktion E 6	not active
(13)-Leuchte6ABL LC5-Lichtfunktion F 6	not active
(14)-Leuchte6ABL LC5-Dimmwert EF 6	0
(15)-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
(16)-Leuchte6ABL LC5-Lichtfunktion G 6	not active
(17)-Leuchte6ABL LC5-Lichtfunktion H 6	not active
(18)-Leuchte6ABL LC5-Dimmwert GH 6	0
(19)-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
(1)-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
(2)-Leuchte7ABL RB1-Lampendefektbitposition 7	40
(3)-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
(4)-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
(5)-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7	127
(7)-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
(8)-Leuchte7ABL RB1-Lichtfunktion C 7	not active
(9)-Leuchte7ABL RB1-Lichtfunktion D 7	not active
(10)-Leuchte7ABL RB1-Dimmwert CD 7	0
(11)-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
(12)-Leuchte7ABL RB1-Lichtfunktion E 7	not active
(13)-Leuchte7ABL RB1-Lichtfunktion F 7	not active
(14)-Leuchte7ABL RB1-Dimmwert EF 7	0
(15)-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
(16)-Leuchte7ABL RB1-Lichtfunktion G 7	not active
(17)-Leuchte7ABL RB1-Lichtfunktion H 7	not active
(18)-Leuchte7ABL RB1-Dimmwert GH 7	0
(19)-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
(1)-Leuchte8FL LB39-Lasttyp 8	36 - LED Kleinleistung
(2)-Leuchte8FL LB39-Lampendefektbitposition 8	35
(3)-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	26
(4)-Leuchte8FL LB39-Lichtfunktion A 8	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte8FL LB39-Lichtfunktion B 8	Parklicht links (beidseitiges Parklicht aktiviert li & re)
(6)-Leuchte8FL LB39-Dimmwert AB 8	127
(7)-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
(8)-Leuchte8FL LB39-Lichtfunktion C 8	not active
(9)-Leuchte8FL LB39-Lichtfunktion D 8	not active
(10)-Leuchte8FL LB39-Dimmwert CD 8	0
(11)-Leuchte8FL LB39-Dimming Direction CD 8	maximize
(12)-Leuchte8FL LB39-Lichtfunktion E 8	not active
(13)-Leuchte8FL LB39-Lichtfunktion F 8	not active
(14)-Leuchte8FL LB39-Dimmwert EF 8	0
(15)-Leuchte8FL LB39-Dimming Direction EF 8	maximize
(16)-Leuchte8FL LB39-Lichtfunktion G 8	not active
(17)-Leuchte8FL LB39-Lichtfunktion H 8	not active
(18)-Leuchte8FL LB39-Dimmwert GH 8	0
(19)-Leuchte8FL LB39-Dimming Direction GH 8	maximize
(1)-Leuchte9FL RB2-Lasttyp 9	36 - LED Kleinleistung
(2)-Leuchte9FL RB2-Lampendefektbitposition 9	3F
(3)-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	27
(4)-Leuchte9FL RB2-Lichtfunktion A 9	Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht)
(5)-Leuchte9FL RB2-Lichtfunktion B 9	Parking light right
(6)-Leuchte9FL RB2-Dimmwert AB 9	127
(7)-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
(8)-Leuchte9FL RB2-Lichtfunktion C 9	not active
(9)-Leuchte9FL RB2-Lichtfunktion D 9	not active
(10)-Leuchte9FL RB2-Dimmwert CD 9	0
(11)-Leuchte9FL RB2-Dimming Direction CD 9	maximize
(12)-Leuchte9FL RB2-Lichtfunktion E 9	not active
(13)-Leuchte9FL RB2-Lichtfunktion F 9	not active
(14)-Leuchte9FL RB2-Dimmwert EF 9	0
(15)-Leuchte9FL RB2-Dimming Direction EF 9	maximize
(16)-Leuchte9FL RB2-Lichtfunktion G 9	not active
(17)-Leuchte9FL RB2-Lichtfunktion H 9	not active
(18)-Leuchte9FL RB2-Dimmwert GH 9	0
(19)-Leuchte9FL RB2-Dimming Direction GH 9	maximize
(1)-Leuchten14AL LB6-Lasttyp 14	not active
(2)-Leuchten14AL LB6-Lampendefektbitposition 14	0
(3)-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0
(4)-Leuchten14AL LB6-Lichtfunktion A 14	not active
(5)-Leuchten14AL LB6-Lichtfunktion B 14	not active
(6)-Leuchten14AL LB6-Dimmwert AB 14	0
(7)-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always
(8)-Leuchten14AL LB6-Lichtfunktion C 14	not active
(9)-Leuchten14AL LB6-Lichtfunktion D 14	not active
(10)-Leuchten14AL LB6-Dimmwert CD 14	0
(11)-Leuchten14AL LB6-Dimming Direction CD 14	maximize
(12)-Leuchten14AL LB6-Lichtfunktion E 14	not active
(13)-Leuchten14AL LB6-Lichtfunktion F 14	not active
(14)-Leuchten14AL LB6-Dimmwert EF 14	0
(15)-Leuchten14AL LB6-Dimming Direction EF 14	maximize
(16)-Leuchten14AL LB6-Lichtfunktion G 14	not active
(17)-Leuchten14AL LB6-Lichtfunktion H 14	not active
(18)-Leuchten14AL LB6-Dimmwert GH 14	0
(19)-Leuchten14AL LB6-Dimming Direction GH 14	maximize
(1)-LuB Lichtrouter Kennlinie 1-x0	0.00%
(2)-LuB Lichtrouter Kennlinie 1-X1	5.00%
(3)-LuB Lichtrouter Kennlinie 1-X2	50.00%
(4)-LuB Lichtrouter Kennlinie 1-X3	75.00%
(5)-LuB Lichtrouter Kennlinie 1-X4	110
(6)-LuB Lichtrouter Kennlinie 1-X5	126.5
(7)-LuB Lichtrouter Kennlinie 1-y0	0.00%
(8)-LuB Lichtrouter Kennlinie 1-Y1	6.00%
(9)-LuB Lichtrouter Kennlinie 1-Y2	16.00%
(10)-LuB Lichtrouter Kennlinie 1-Y3	30.00%
(11)-LuB Lichtrouter Kennlinie 1-Y4	60.00%
(12)-LuB Lichtrouter Kennlinie 1-Y5	100.00%
(1)-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung	not active
(2)-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active
RLS_close_glazing	2.00 s
(1)-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h
(2)-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h
(3)-RLS_lights_for_autobahn-p_t_autobahn_delay_on	10 s
(4)-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s
(1)-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12
(2)-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6
(3)-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx
(4)-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s
RLS_LIN_Communication	4 s
(1)-RLS_Night_Sensitivity-p_lx_rs_day	500 lx
(2)-RLS_Night_Sensitivity-p_lx_rs_dawn	200 lx
RLS_tunel_gateway_recognize	5 s
RLS_Washer_Front	15 s
RLS_wiper_position_parking	15 s
(1)-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
(2)-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
(3)-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
(4)-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
(5)-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
(6)-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
(7)-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
(8)-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
(9)-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
(10)-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
(1)-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute	40
(2)-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute	60
(3)-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30
Looks like 1897 lines. No Security Access needed. There were several Adp Channels for stuff like "Passenger Massage" and whatnot that gave an error not available on the screen and therefore no data was saved to the map. Is that what you mean?
bloggo
Birmingham UK
C?ID=198143
Hello Andy
yes, this is what I found and I have sent photos to Uwe at support, although I only had 1795 lines.
Bill
Andy
Sector 7G
HC424490
That doesn't seem like anything was truncated but rather it just doesn't save a line when that adaptation channel is not available. Also different versions of control modules can have different numbers of lines. Is there something that exists in your car that is showing a plausible value that is not shown in Adaptation maps?
