Hi Guys! How are you?!
I'm from Brazil and this is my first post here.. (sorry for the rusty english and for the any procedure that might be wrong inside this forum.. I looked through some topis but couldn't solve my problem..)
I have a RCD510 media center and just bought the OEM Bluetooth Module for Volkswagen (1K8 035 730 D) and did all the physical installation although I couldn't enable the bluetooth through VCDS.. I've tried to follow some tutorials over the internet (since the product doesn't come with any) but none of them worked properly.. Can anyone help me? Below is my autoscan..
Regards,
Rafael
Friday,24,July,2020,17:13:33:22766
VCDS Version: 20.4.1.0 (x64)
VIN: 3VWRE11K7AM108576 License Plate: XXXXXXX
Mileage: 162710km-101103mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 55 56 62 72 77
VIN: 3VWRE11K7AM108576 Mileage: 162710km-101103miles
Address 01: Engine (CCC) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 AA HW: 07K 906 055 AA
Component: 2,5L 125KW G 0937
Revision: G6H03--- Serial number:
Coding: 0000075
Shop #: WSC 00066 000 00000
VCID: 6DFF117874C910EED0-8038
001674 - ECM Power Relay Load Circuit
P068A - 000 - Opens Too Early - Intermittent
Date: 2047.15.31
Time: 31:63:63
Temperature: 63.0°C
Temperature: 47.0°C
Absolute Pres.: 930.0 mbar
Voltage: 10.795 V
Part No SW: 09G 927 750 HG HW: 09G 927 750 HG
Component: AQ 250 6F 1631
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 7DDF213824A9806E60-8028
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 143B400D4A220002281002EB521F0041300000
VCID: 78D1302CCB8BA54633-802C
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000000002
Shop #: WSC 00066 000 00146
VCID: 7DDF2138ECA9806E60-8028
9496597 - Sunlight Photo Sensor
B10E8 15 [008] - Open or Short to Plus
Reset counter: 38
Mileage: 162670 km
Date: 2020.07.23
Time: 08:48:37
9496613 - Sunlight Photo Sensor
Reset counter: 38
Mileage: 162670 km
Date: 2020.07.23
Time: 08:48:37
Part No SW: 5K0 937 087 D HW: 5K0 937 087 D
Component: BCM PQ35 H 011 0028
Revision: BE011001
Coding: 08000AFFF83FE3E04008008004000BE40578008871208960DCC000040000
Shop #: WSC 00066 123 12345
VCID: 364DFE14811F9336E1-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 04031 21 0512
Coding: 009795
Component: RLS 180210 05 54 0403
Coding: 0730AD
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 34
Mileage: 157718 km
Date: 2014.06.04
Time: 03:27:36
Term 15 Off
Voltage: 12.65 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 1K9 919 475 HW: 1K9 919 475
Component: PARKHILFE 8K H07 0001
Revision: -------- Serial number: 90330935310474
Coding: 100101
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 13 AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR06BNBV
Coding: 0012595
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001831
VCID: 76CD3E14019FD33621-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H06 0010
Coding: 00000131
Part No SW: 5M0 920 870 D HW: 5M0 920 870 D
Component: KOMBI H05 0305
Coding: 371F00
VCID: 3041C80C6B7BBD06BB-8064
9453074 - Fuel Level Sensor 1
B103E 1B [008] - Resistance Too High
Mileage: 162710 km
Date: 2020.07.23
Time: 20:23:13
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 200110F1001696
Coding: EDA17F06000602001002
VCID: 69F7656840210CCEBC-803C
Reset counter: 37
Mileage: 162670 km
Date: 2014.12.14
Time: 10:49:50
01304 - Radio
Fault Status: 00110100
Reset counter: 37
Mileage: 162670 km
Date: 2014.12.14
Time: 11:21:17
Mileage: 162670 km
Date: 2014.12.14
Time: 08:50:36
Component: IMMO H05 0305
VCID: 6AF51A648D2707D6B5-803E
Part No SW: 3C0 959 701 C HW: 3C0 959 793 A
Component: TUER-SG FT 002 0307
Revision: 12101005 Serial number: 0000489399
Coding: 0000B4
Shop #: WSC 01383 790 50316
ROD: EV_DCU42BroseDriveSide.rod
VCID: 2871206C53ABF5C663-807C
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AG HW: 1K0 959 795 R Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004654702
Coding: 000090
B11EC 54 [008] - Missing Calibration / Basic Setting
67074 - Motors for Central Locking
B122B 01 [009] - Electrical Failure
Reset counter: 48
Mileage: 147320 km
Date: 2019.05.31
Time: 14:55:23
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Mileage: 147320 km
Date: 2019.05.31
Time: 14:55:23
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3147CD08A871B40EB4-8064
Part No SW: 3C0 959 702 C HW: 3C0 959 792 A
Component: TUER-SG BT 002 0307
Revision: 14101005 Serial number: 0000485013
Coding: 0001B4
ROD: EV_DCU52BrosePasseSide.rod
VCID: 2977256848A1CCCE7C-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AG HW: 1K0 959 794 R Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004661837
Coding: 000090
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74C9041C17E3C1261F-8020
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
Revision: 00000001 Serial number: VWZ1Z3K3010364
Coding: 0500041004
VCID: 62E572447D175F967D-8036
03138 - Input AUX IN
Reset counter: 167
Mileage: 160764 km
Date: 2014.09.03
Time: 15:18:14
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 000 000 000 00
Component: Telefon H00 6900
Revision: 00000000 Serial number: 000000AA000000
Coding: 013420
VCID: 2A75DA6445A7C7D675-807E
01524 - Antenna for Telephone
Reset counter: 75
Mileage: 47320 km
Date: 2013.09.15
Time: 11:26:22
02791 - Telephone baseplate (R126)
Reset counter: 75
Mileage: 47320 km
Date: 2013.09.15
Time: 11:26:22
End-------------------------(Elapsed Time: 02:18)--------------------------
Rafael
