Touareg - Air Suspension - Running Gear Fault
aj2thec
Australia
HC804925 (2nd hand?)
Hey guys,
It looks like I am now part of the Touareg 'Running Gear Fault' club......
I have a good look around the net and have found that this issue comes up a lot, but there are not to many solutions out there (without taking it to a dealer and $2k later anyways....).
Here's where I'm at:
Car: Aussie RHD 08' V6 TDI with air suspension.
I've got the red 'Running Gear Fault' warning on my MFD. The car is sitting at normal ride height but won't raise or lower.
Here's what I've done so far:
Checked the fuse next to batt under the seat - all good.
Checked the fuse in fuse cluster on the right hand end of the dash (as per Manual) - no fuse present.
Inspected the Level Control Module (AKA: Adaptive suspension
control unit J197 ??) in rear hatch - noticed no power along the two power wires (red w/yellow trace).
Inspected compressor - Visual only, appeared ok. Probed main power wires - no power.
Inspected Level Control Module relay located at the e-box under the dash (see pic below - '373' location: D3) - removed relay - tested ok. Removed relay and hard-wired the switch - compressor functioned as per normal but fault remained and car would not re-level. Probed relay wires and noticed that the coil terminals (85 and 86) both had a 12 V reading - explains why relay tested ok but when fitted would not function the comp - strange??
Note: For anyone else trying to access this relay - the grey relay housing will drop down from the harness once you unclip both ends.
The auto scan is below. It is my first time using VCDS am I'm not exactly sure how to use this information to continue fault finding.
If anyone can point me in the right direction from here it would be very much appreciated!!
Thanks,
AJC
VCDS Version: Release 14.10.1
Data version: 20150130
Saturday,21,February,2015,23:18:01:23511
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 34 37 46 55 56 68 6D 76
VIN: WVGZZZ7LZ8D052230   Mileage: 146870km-91260miles
34-Level Control -- Status: Malfunction 1010
68-Wiper Electr. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 1010
Address 01: Engine (CAS)       Labels: 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 N    HW: 7L0 907 401 H
   Component: 3.0TDI EDC17G100AG  0060
   Revision: --H02---    Serial number: VWX3Z0G1698559
   Coding: 04210023590F0568
   Shop #: WSC 10500 959 71994
   VCID: 3663EDE6421CAA9184C-5106
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 FT    HW: 09D 927 750 FT
   Component: AL 750 6A           1168
   Revision: 00H75000    Serial number:
   Coding: 0004456
   Shop #: WSC 31414 790 00001
   VCID: 05015A2A4F7AF1095D6-5140
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 L    HW: 7L0 907 379 L
   Component: ESP ALLRAD MK25E1   0303
   Revision: 00H53001
   Coding: 0004482
   VCID: 428B813619D40631384-8017
   Part No SW: 3D0 909 139 B    HW: 5WK 485 04
   Component:    Kessy            6840
   Revision: 68406620    Serial number: VWX3Z0G1698559
   Coding: 0000232
   VCID: 285F339E9FA8CC61060-807D
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AF
   Component: CLIMAtronic R/L     4331
   Coding: 0020520
   VCID: 74E717EE13E0F8817A8-8021
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2000
   Revision: -0004---    Serial number: --------------
   Coding: 600004002B221C000000000000000000
   VCID: 000F4B3E5758D4216E0-8055
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234  39 VW8T       0250
   Revision: 92011025    Serial number: 0039P003PJGE
   Coding: 0013113
   VCID: 7AFB39D631848EF1204-802F
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0010011
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 885 R    HW: 7L6 920 885 R
   Component: J285 KOMBI-INST.    7520
   Revision: KHH06V02
   Coding: 0007101
   Shop #: WSC 00581 210 64475
   VCID: 4B95AC122A9EC779CB2-801E
                    Reset counter: 196
                    Mileage: 146851 km
                    Date: 2015.02.20
                    Time: 18:27:02
01310 - Level Control System Control Module (J197)
                    Reset counter: 236
                    Mileage: 146851 km
                    Date: 2015.02.20
                    Time: 18:55:54
   Revision: KHH06V02
   Coding: 0007101
Address 19: CAN Gateway        Labels: 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 885 R
   Component: J533  GW-K-CAN TP20 7520
   Coding: 7FE2E79948046003
   VCID: 70EF1BFE63F8C4A19E0-8025
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 01094E3A5B52DD2961E-5122
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 J
   Component: LUFTFDR.-CDC- 3C3P1 3125
   Coding: 0015521
   VCID: 3A7BF9D671044EF1604-806F
            009 - Open or Short to Ground
   Part No SW: 7L6 035 680 C    HW: 7L6 035 680 BX
   Component: RNS-MID       H03 3810
   Revision: AB001001    Serial number: VWZ6Z7H7240028
   Coding: 020004000400002200
   VCID: 326BD1F66D74B6B1A84-8067
00857 - CD Changer Unit (R41)
                    Reset counter: 196
                    Mileage: 146872 km
                    Date: 2015.02.21
                    Time: 23:15:46
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L6 959 933 A
   Component: 1A HSG              0600
   Coding: 0000085
   Shop #: WSC 10500 959 100544
   VCID: 408F8B3E10D814212E0-4B06
   Subsystem 1 - Part No: 7L0 959 701 R
   Component: Tuersteuergeraet FS 6302
   Subsystem 2 - Part No: 7L0 959 702 R
   Component: Tuersteuergeraet BF 6302
   Subsystem 3 - Part No: 7L6 959 703
   Component: Tuersteuergeraet HL 0202
   Subsystem 4 - Part No: 7L6 959 704
   Component: Tuersteuergeraet HR 0202
   Subsystem 5 - Part No: 7L0 907 719 A
   Subsystem 6 - Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    0001
   Revision:   H02       Serial number:
   Coding: 1288579
   VCID: 3979E6DA740245E969E-806C
   Subsystem 1 - Part No: 7L6 941 329 B
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    X008
   Coding: 00000019
                    Reset counter: 196
                    Mileage: 146872 km
                    Date: 2015.02.21
                    Time: 23:16:31
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 C
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 3A7BF9D675044EF1604-806F
   Component: RLS     181207 046  0204
   Coding: 00208933
   Shop #: WSC 31414
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 7L6 959 107 A    HW: 7L6 959 107 A
   Component: J605  HECKKLAPPE    1210
   Revision: --H05---    Serial number: --------026415
   Coding: 0122110
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
01543 - Parking Aid Warning Chime (H15)
            002 - Lower Limit Exceeded
End-------------------------(Elapsed Time: 04:27)--------------------------
LN-TAL
Norway
C?ID=13729
What the fault code says is that the power supply (terminal 30, which is the "always powered bus") is missing power. I would start checking the power line as per WD.
aj2thec
Australia
Update:
Fixed! The fault at address 34 said there was a fault with terminal 30 - one of the main power runs in the car's elec system. I tracked down a wiring diagram and checked it from batt to module. Turned out to be a simple fuse. I would have found this early on but the workshop manual I had did not match my car.
Thanks everyone for your help.
BrucTDI
Israel
Update:
Hi, I'm facing very similar issue with my 2009 3.0 TDI touareg...
can you please point me to the fuse that failed for you and it's location?
steijntr
Brazil
C?ID=277363
My car's compressor stopped working - the compressor does not receive 12V. When I jump with 12V cables to the compressor directly it works fine. I checked fuse position 44 on the right side 5A (OK) and also the 40A fuse under the driver seat - all fine. I checked the relay which is working fine, replaced it for a new one , but nothing different. The relay receives 12V and when I "jump the relay" the compressor still does not work . What is there between the relay and the compressor? That is where is my problem - please help
dlysnes
Norway
Same here
I have a 2011 v6. Where can I find this fuse?
Thanx for any help :)
/D
pbas
Sweden
C?ID=137414
/D
Not quite sure where that particular fuse is located but I found one that stopped the compressor on my 2011.
Open the fuse box on the left (driver) side of the instrument panel.
Check the 40 amp fuse at the very top (there are only two of them so they're easy to locate).
