Lock TC and gears on amarok
Shawa12002
Victoria, Australia
C?ID=370869
I would like to lock gears and torque convertor temporarily on a 2018/2019 Amarok V6 diesel. I just want to do Wide Open Throttle maneuvers from a creeping state to max rpm without the car changing gears or flaring up due to TC lockup.
Has anyone tried this before?
Moved to Tweaks.
I am not real hopeful that there's a way to do this, but please post an Auto-Scan so people can see exactly what transmission and TCU are in this vehicle.
Shawa12002
Victoria, Australia
C?ID=370869
I think I will close this one for now. the amarok I thought we had at work was sold last year. bugger!!
By the way Uwe, how does one end a post/thread?
OzTregger
Australia
C?ID=410945
I have a related question for a 7P Touareg.
When driving off-road at low speed in 2nd and occasionally 3rd the TC lockup clutch constantly engages and disengages.
This happens regardless of selector in D or S or manual mode.
Is there a way to adjust this through VCDS (maybe just to prevent clutch wear) but also to stop the trans sounding like a CVT?
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 34 36 42 46 52 53 55 56
          5F 62 69 6C 6D 72
VIN: WVGZZZ7PZHD009893   Mileage: 58800km-36536miles
Address 01: Engine (J623-CRCA)       Labels: None
   Part No SW: 7P1 907 401 D    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0001
   Revision: 53H41---
   Coding: 292A4012233E01020000
   Shop #: WSC 60156 002 1048576
   ASAM Dataset: EV_ECM30TDI0117P1907401D 001002
   ROD: EV_ECM30TDI0117P1907401D.rod
   VCID: 313F103201AA51A3EDD-8064
Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
   Part No SW: 0C8 927 755 M    HW: 0C8 927 755
   Component: 34O06G0Q.MOT  130 3073
   Coding: 010100011C008400000000000000000000000000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 3B23321AD3E6ABF3471-806E
Address 03: ABS Brakes
   Part No SW: 4H0 907 064 JM    HW: 4H0 907 064 JM
   Component: BCM2 2.0      H43 0582
   Coding: 05B60016000000000000
   VCID: 7DA7FC028DF265C3395-8028
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3216000105023011
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-BFS       H08 0156
   Revision: AA000000    Serial number: 00000212000249
   Coding: 0038330000004201000001010101202020202121202020
   VCID: 34311926FE38648B86B-8060
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 CR    HW: 7P6 907 040 CR
   Component: Klima 2 Zonen H23 1608
   Coding: 3626200E90
   VCID: 065593EED8A4261B68F-8052
0003 - Motor for Left Temperature Flap
          B108C 07 [008] - Mechanical Failure
                    Fault Frequency: 201
                    Reset counter: 20
                    Mileage: 55041 km
                    Date: 2020.01.28
                    Time: 08:11:10
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Component: BCM1 2.0      H20 0311
   Revision: 22020001    Serial number: 00001468049301
   Coding: 26000014D0345D010029400780005D4C431D670827010241800000000040110000000000000000
   VCID: 6A8DC75EEC7CE27BEC7-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    160821  033 0021
   Serial number: 90243401160908100255
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 80901336
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000001209160034
   Component: EVLS-SG  H08 0300
   Serial number: WA124809000024369019
   Coding: 020300
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28261623702243
   Coding: 518504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 44D149E6AE18D40B36B-8010
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
   Component: VW10Airbag00T H10 0044
   Revision: --------    Serial number: 003S80042EX6
   Coding: 000000000000000000000000000000003054
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Serial number: 3575LRB404P43GQ8AG3Q
   Serial number: 3585LRB405L45CG69P5K
   Serial number: 3517ARB405V44QG0I0CC
   Serial number: 3527ARB405V44QG0POG5
   Serial number: 3557BRB406944QG0G8J9
   Serial number: 3567BRB406944QG0FGB9
   Part No SW: 4H0 953 568 P    HW: 7P6 953 507 AL
   Component: Lenks.Modul   H06 0010
   Revision: --------    Serial number: 01374PIG00010
   Coding: 000015
   VCID: 40D945F6BA80C82B123-8014
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H05 0028
   Serial number: 0057965 TRW 20160823
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 883 L    HW: 7P6 920 883 L
   Component: Kombi         H13 0607
   Revision: 13240312    Serial number: 658030916592021
   Coding: 333733003A00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001030
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 47CB5EEA9F2EFF13D39-8012
   Part No SW: 7P6 907 530 Q    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H15 6051
   Revision: --------    Serial number: 00000002361198
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001008
   ROD: EV_GatewUDS_VW52.rod
   VCID: 46D553EE9824E61B28F-8012
   Subsystem 1 - Part No SW: 7P0 915 181 C    HW: 7P0 915 181 C
   Component: Batt_Sensor  H07 0270
   Serial number: 43244K42565811554456
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 16254000456011200181
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschraenkung Pausenempfehlung]
                    Reset counter: 17
                    Mileage: 58529 km
                    Date: 2020.09.19
                    Time: 16:06:29
                    Voltage terminal 30: 13.3 V
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 35 °C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AG    HW: 7P0 907 553 AG
   Component: PASM          H05 0950
   Revision: 00000000    Serial number: 00000161610669
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001005
   ROD: EV_PASMConti.rod
   VCID: 7CA1F10696686CCB0EB-8028
   Component: MEM-FS        H08 0156
   Revision: AA000000    Serial number: 00000212000365
   Coding: 00383B0000004201000001010101202020202121202020
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H03 0306
   Revision: --------    Serial number: 0000217804179
   Coding: 011D1620DE01451205080002
   VCID: 7AADF71E9CDC52FB1C7-802E
   Revision: 00002001    Serial number: 0416620761
   Coding: 019B1E20A8B9108183200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 172
   Component: Sensor, DWA  005 0502
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H03 0306
   Revision: --------    Serial number: 0000217541272
   Coding: 011D1620DE01451205080000
   VCID: 48C95DD692B0F06BDA3-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 G    HW: 7P0 907 801 G
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1673100046
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 372B2E2AEFCE8F93A39-8062
   Slave 3:
   Component: AFS-ECU       H01 0120
   Coding: 01A602000B000200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FDB460AC7FEB7D36B9-806A
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B00000
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227I-0G2554071
   Coding: 040005020100000003
   VCID: 2615F36E38E4061B08F-8072
   Part No SW: 7P6 035 764 M    HW: 7P6 035 764 A
   Component: H-BNT-RW      H42 1023
   Revision: --------    Serial number: 605I+0G7510655
   Coding: 010A01050040C1EF41002B0E00000003F00001030000000000
   VCID: 43D34AFAAB96D3330F1-8016
   Subsystem 1 - Part No: 8R0 060 884 DJ
   Component: ROW 2016  0806
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9SGF00ZY4
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: CD-Database  6890
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H04 0306
   Revision: --------    Serial number: 0000217327327
   Coding: 011814200001251005080000
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H20 0160
   Revision: 7C001003    Serial number: 0401535730
   Coding: 0300000202000000
   ROD: EV_TrailFunctGener2Hella_VW52.rod
Address 6C: Back-up Cam. (J928)       Labels:| 7P6-907-441-V1.clb
   Part No SW: 7P6 907 441 G    HW: 7P6 907 441 G
   Component: TopView       H09 0115
   Revision: 11001001    Serial number: 82330JG0192431
   Coding: 0100000001000000010102000000
   ASAM Dataset: EV_CamerSysteTopViewVW 001014
   ROD: EV_CamerSysteTopViewVW.rod
   VCID: 3D273C02CDF2A5C3795-8068
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 245600345
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H04 0306
   Revision: --------    Serial number: 0000217317364
End----------(Elapsed Time: 01:59, VBatt start/end: 13.4V/13.4V)-----------
Shawa12002
Victoria, Australia
C?ID=370869
          5F 62 69 6C 6D 72
   Revision: 53H41---
   Coding: 3626200E90
                    Reset counter: 20
                    Mileage: 55041 km
                    Date: 2020.01.28
                    Time: 08:11:10
   Coding: 004DBD
   Coding: 025223
   Coding: 020300
   Coding: 518504
   Coding: 000015
   Coding: 000D07AD00
   Voltage stabilizer:
          B130E 00 [008] - -
                    Reset counter: 17
                    Mileage: 58529 km
                    Date: 2020.09.19
                    Time: 16:06:29
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Coding: 14210000
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   Slave 3:
   Coding: B00000
   Coding: B00000
   Coding: 0533314003
Sorry for the late response I hope you found a solution.
There are two ways which I know are definitely possible. 1: Find a hacker who can get into the calibration files and change the TC lock-up parameters.
2: Get a TC lockup kit. a mob in Melbourne Australia make these for various 4X4s and what it is is basically a breakout box which puts whatever % duty cycle you want on the TC while simultaneously emulating the TC solenoid to avoid the PCM throwing a DTC and going into limp mode.
Option 2 is easier and safer.
