I have a 2003 New Beetle Turbo S. I found out, after I bought it, that it was in a crash and was repaired. Not repaired very well. The airbag module had 11 fault codes including crash data. I noticed the airbag light never comes on. I put in new seats and a new airbag control module part number 1C0 909 605 T/025. I coded the module using VCDS with a coding of 12853 which VCDS calculated using the index.
I used a workshop code of 00000. The module seemed to take that without any errors. There are now no faults, but the airbag light still doesn't come on at all when the engine is started and it goes through its self test. I now don't know if the airbag system is working or not. What can I do to get the airbag light to come on like it should during startup? I tried to change the workshop code, but it seems to be 'read only.' How to I change the workshop code from 'read only?'
I have pulled the instrument cluster, and it appears to never have been taken apart and tampered with as there are factory stickers across the seam where the halves go together. I know the seat airbags are good but don't know if the steering wheel, passenger side airbags or either of the seat belt igniters are good. There were fault codes that the both seat belt igniters fired in the crash. Both seat belts do lock when you pull on them quickly.
Here is the most recent full scan of the car, performed after the new airbag module was installed and coded.
Thursday,23,July,2020,11:31:03:56773
VCDS Version: 20.4.1.0 HEX-V2 CB: 0.4508.4
VIN: 3VWFE21C13M434233 License Plate: AOJ1670
Mileage: 151510km-94143mi Repair Order:
Chassis Type: 1C (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWFE21C13M434233 Mileage: 151510km-94143miles
Address 01: Engine Labels: 06A-906-032-AWP.lbl
Part No: 06A 906 032 LS
Component: 1.8l 5VT NB MT G 4745
Coding: 00002
Shop #: WSC 00066
VCID: 7AAEFB93D5C2858B1DF-513C
3VWFE21C13M434233 VWZ5Z0C0301056
17608 - Boost Pressure Control Valve (N249)
P1200 - 35-10 - Mechanical Malfunction - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Coding: 0019970
Shop #: WSC 00066 000 00000
VCID: 343215ABB226B3FB873-5160
Part No: 1C0 909 605 T
Component: 25 AIRBAG VW51 0E 0015
Coding: 12853
VCID: 353428AFBC5CAAF3B0D-4B3C
Address 17: Instruments Labels: 1C0-920-x4x.lbl
Part No: 1C0 920 951 JX
Component: KOMBI+WEGFAHRS. M73 V02
Coding: 07234
Shop #: WSC 03999
VCID: 005A897BB31EDF5B53B-4B1E
Part No: 6N0 909 901
Component: Gateway K<->CAN V022
Coding: 00006
Shop #: WSC 19410
VCID: 70BAD9BB83BECFDBA3B-4B00
Part No: 1C0 959 799 G
Component: 2K Komfortgerát HLO 0004
Coding: 00064
Shop #: WSC 23071
VCID: 3B203E979A787C83469-4B00
Subsystem 1 - Part No: 1C2959802A
Component: 2K Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C2959801A
Component: 2K Tõrsteuer.BF KLO 0009
Address 54: Rear Spoiler Labels: 1C0-959-733.lbl
Part No: 1C0 959 733 E
Component: Heckspoiler 0002
VCID: 2D0400CF540CE233C8D-51A8
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 196 CL
Component: RADIO DE2 0006
Coding: 06033
Shop #: WSC 23320
VCID: 6B80CED7AA982C03969-51CE
00855 - Connection to CD changer
49-00 - No Communications
End----------(Elapsed Time: 03:43, VBatt start/end: 12.3V/12.2V)-----------
Log-AOJ1670-3VWFE21C13M434233-151510km-94143mi.txt
Displaying Log-AOJ1670-3VWFE21C13M434233-151510km-94143mi.txt.
