SKODA Superb 3 - Made a mistake to reset Engine Service Interval counter. Help!
Bap33
FRANCE
C?ID=175563
Hi all,
I've made the overhaul on my Skoda Superb 3 last week-end, since it had reached 45000 km.
Since I didn't have my VCDS with me, I've reset the ESI manually with the button.
Today, I've tried to do it properly with my VCDS since the km-counter seemed correctly reset, but the time counter didn't (it was still telling me there's only 6 days before next service inspection).
Remembering the garage had set my car in non Long Life service mode (@ 30000 km inspection), I've tried to put it back to LL-mode for personal reasons.
I've thus first made following settings in Control Unit # 17 - Instruments:
- IDE03349-FIX : Max. distance until next mileage-related inpsection = 30000 km
- IDE03350-FIX : Maximum time until next time-related inpsection = 730d
- IDE03351-FIX : Distance covered since last mileage-dependant inpsection = 148 km
- IDE03352-FIX : Tim since last time-dependant inpsection = 4d
- IDE-00515 : ESI oil quality : Good quality.
But surprinsingly, once I saved everything, I've got a message: "Next service in 361d", which surprised me. I thought I should not get any message sooner than 30d before next inspection (meaning after 335 days), since IDE11086-Service notification is set to 30d.
I thought I had done something inconsistent and I've set everything back to Non-LL service mode (thinking that once everything would be consistent, I could make a proper setting for LL-Service mode) :
- IDE03349-FIX : = 15000 km
- IDE03350-FIX : Maximum time until next time-related inpsection = 365d
- IDE-00515 : Poor quality.
But now it bips and says Service Time is late!... Though IDE03352 = 4d! Strange!
And I cannot change any of the parameters above. For all of them, if I try to move to 30000 km / 730d / Good oil quality, I've got an error message: "Request Out Of Range".
It looks I've "snooked myself"... :( :banghead:
Does anybody has a tip to get out of this situation?
Thanks for your assistance.
P.S.: Note, I did not try a new hard reset with the button below the tachometer. Should I?
Bap33
FRANCE
C?ID=175563
Hello @ Uwe!
Yes, this is the right car.
I'll post the requested "adaptation channel map" tomorrow.
Thanks.
Bap33
FRANCE
C?ID=175563
Hi,
Here is the requested 'Adaptation Channel Map':
Sunday,26,July,2020,23:16:38:04899
VCDS Version: 20.4.1.0 (x64)
VIN: TMBLJ9NP0Jxxxxx   License Plate:
Mileage: 45551km-28304mi   Repair Order:
VCDS Release 20.4.1:  SRI Reset-SRI3.CLB
Control Module Part Number: 3V0 920 711 B       Labels:  .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI         301 0310, Coding:07A5081AFF840008018B7B0B5001000800000000
Channel        Description                                                 	Current val.                                                	New val.
IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	no warning                                                  	---
IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	149 km                                                      	---
IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	7 d                                                         	---
IDE00515-ESI: oil quality        ESI: Oil Quality                                            	poor oil quality                                            	---
IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	200 km                                                      	---
IDE00518-ESI: thermal load        ESI: Thermal Load                                           	0 km                                                        	---
IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	15000 km                                                    	---
IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 d                                                       	---
IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	15000 km                                                    	---
IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	365 d                                                       	---
IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	100 km                                                      	---
IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	7 d                                                         	---
Sunday,26,July,2020,23:21:26:04899
VIN: TMBLJ9NP0J7533009   License Plate:
                Address 17: Instruments  (3V0 920 711 B)
23:21:15
  IDE00510   ESI: distance driven from inspection 149 km
  IDE00511   ESI: time from inspection 7 d
  IDE00512   ESI: minimum value km-driving distance/inspection 15000 km
  IDE00513   ESI: maximum value km-driving distance/inspection 30000 km
  IDE00514   ESI: maximum value of time between inspections 365 d
  IDE00515   ESI: oil quality poor oil quality
  IDE00695   ESI: service exceedance in km 0 km
  IDE00696   ESI: service exceedance in days 0 d
  IDE00697   ESI: remaining distance 14860 km
  IDE00698   ESI: remaining running time 358 d
  IDE00827   ESI: minimum value of time between inspections 365 d
23:24:20
  IDE03349   FIX: Max. distance until next mileage-related inspection 15000 km
  IDE03350   FIX: Maximum time until next time-dependent inspection 365 d
  IDE03351   FIX: Distance covered since last mileage-dependent inspection 100 km
  IDE03352   FIX: Time since last time-dependent inspection 7 d
  IDE05931   FIX: Reset value for next mileage-dependent inspection 15000 km
  IDE05932   FIX: Reset value for next time-dependent inspections 365 d
23:24:29
I don't know what's wrong... :(
Bap33
FRANCE
C?ID=175563
:confused:
I nevertheless tried to apply the process, which is explained in the link you gave in your previous message.
What is missing? What did I do wrong to get a proper Adaptation Channel Map ?
May this come from any limitation of my Micro-CAN interface?
If it helps, here is what came out from last autoscan for the same Instrument cluster:
"Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3V0 920 711 B HW: 3V0 920 711 B
Component: KOMBI 301 0310
Coding: 07A5081AFF840008018B7B0B5001000800000000
Shop #: WSC 73430 031 00140
VCID: 2F43F3B5760E6FFEA2-807A
No fault code found."
Please advise.
Thanks a lot!
[Applications]
[Controller Channel Map]
Single Controller Address = 17
Login or security code: Leave blank.
Function = Adaptations
Output = CSV File
[Go]
The map will be located in your Logs sub-folder.
Bap33
FRANCE
C?ID=175563
Hi,
Now, it should be OK. I don't know what I done wrong last time...
	SW:3V0-920-711-B   HW:3V0-920-711-B ---  Instruments
	EV_DashBoardVDDMQBAB,009060,EV_DashBoardVDDMQBAB_009_VW37.rod
	Monday,27,July,2020,23:04:09:04899
	VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
IDE00295-Oil temperature display,On ,1
IDE00301-Distance,45595 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,French ,1
IDE00500-Hour,23 H,1
IDE00501-Minute,4 min,1
IDE00502-Year,2020 yr,2
IDE00503-Month,7 mon,1
IDE00504-Day,27 d,1
IDE00510-ESI: distance driven from inspection,193 km,3
IDE00511-ESI: time from inspection,8 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,365 d,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00517-ESI: soot entry,300 km,2
IDE00518-ESI: thermal load,100 km,2
IDE00819-Day counter,1033 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE02489-Display depiction,Version 1 ,1
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
IDE03329-Driving profiled for range remaining,6.8 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
IDE03346-MAS02201-Units adjusted-Temperature,Degrees Celsius ,3
IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
IDE03348-MAS01456-Speed warning-Speed,200 ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,15000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,365 d,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,100 km,2
IDE03352-FIX: Time since last time-dependent inspection,8 d,2
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE05931-FIX: Reset value for next mileage-dependent inspection,15000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
IDE06588-Ignition active message: actuator,Driver door ,1
IDE06922-No-voltage display,Unknown (2),1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
MAS03685-Digital speedometer,Display ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,15 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,0A ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,46 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,03 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,03 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,11 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1F ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5A ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,46 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,11 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,5A ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8 ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 3C ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 B4 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 DC ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,46 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0C ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46 ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Note, I can send the .csv file if necessary. I didn't see how to attach it to the post. :(
Thanks for your assistance. :)
EDIT : When reading the settings carefully, I have 2 questions:
1) A vocabulary issue: What is the difference between 'Service' and 'Inspection'? Which one is 15000km interval and which one is 30000 km? May be I've mixed both.
2) "IDE00827-ESI: minimum value of time between inspections,365 d,2 ": Should it be set to "0" instead of "365"? It may be the reason why it bips, since time from last inspection is currently 8 days (thus < 365).
Sadly, VAG doesn't always use terminology in a consistent way. When on flexible intervals, an oil change 'service' is what you should be reminded of sometime between the minimum and maximum distance and time called for in the ESI parameters. An 'inspection' always happens on a fixed interval basis specified in the FIX parameters.
2) "IDE00827-ESI: minimum value of time between inspections,365 d,2 ": Should it be set to "0" instead of "365"? It may be the reason why it bips, since time from last inspection is currently 8 days (thus < 365).[/I]
No, I don't think so.
But I don't see anything obviously incorrect either. :confused:
Bap33
FRANCE
C?ID=175563
What about making a "hard reset" with the odometer button and then changing "IDE00511-ESI: time from inspection,8 d,2" back to 8 or 9 actually today?
Same thing with "IDE00510-ESI: distance driven from inspection,193 km,3": put it back to 193 (I didn't use the car today).
Would that make sense?
I don't think there's any harm in trying that.
Bap33
FRANCE
C?ID=175563
Hi,
Sorry for the response time. I did not see the thread had continued on a 2nd page.
Well. I've just been trying my "trick" and... it works! No bip anymore! Hurrah!!!!
Just after the odometer button reset, I've changed:
"IDE00510-ESI: distance driven from inspection,0 km,3" to 236 km
"IDE00511-ESI: time from inspection,0 d,2" to 12d
And I also changed other parameters to consistent values:
"IDE03349-FIX: Max. distance until next mileage-related inspection,15000 km,2" to 14800 (had set the exact value, but it automatically rounds to the closest hundred)
"IDE03351-FIX: Distance covered since last mileage-dependent inspection,00 km,2" to 200 (idem)
"IDE03352-FIX: Time since last time-dependent inspection,0 d,2" to 12
Also went back to LL-mode:
"IDE00515-ESI: oil quality,poor oil quality ,1" to good oil quality
Here is the adaptation channel amp modifications.
	Friday,31,July,2020,00:59:10:04899
IDE00301-Distance,45638 km,3
IDE00342-ESI: Resetting ESI,Reset ,1
IDE00500-Hour,0 H,1
IDE00501-Minute,59 min,1
IDE00504-Day,31 d,1
IDE00510-ESI: distance driven from inspection,236 km,3
IDE00511-ESI: time from inspection,12 d,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00518-ESI: thermal load,0 km,2
IDE00819-Day counter,1036 d,2
IDE03349-FIX: Max. distance until next mileage-related inspection,14800 km,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,200 km,2
IDE03352-FIX: Time since last time-dependent inspection,12 d,2
Lessons learnt from this mistake:
- Never use odometer button again to reset the ESI counter. Rather use VCDS
- Make "Adaptation channel map" before changing parameters, to be able to restore last operating parameters
- Never go too fast when changing parameters.
Really happy to get a fix! ;)
Thanks you @ UWE!
