Fault 02117/02115
barbalatte
Sydney, Australia
Hi guys. Has anyone come Across these daily codes?
They relate to the rear vision mirrors. Intermittently the passenger side window stays closed. It doesn’t open up when you start the car. After about 30 secs, the driver side opens up only.
Weird problem but I couldn’t find it in the fault list here
http://wiki.ross-tech.com/wiki/index.php?title=Category:Fault_Codes&pageuntil=17625/P1217#mw-pages
Thursday,23,July,2020,14:45:21:63594
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUZZZ8R9DA071750   License Plate:
Mileage: 86350km-53655mi   Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 36 42 44 46 47 52 53 56 5F
          62 6C 6D 72 A9 C0
VIN: WAUZZZ8R9DA071750   Mileage: 86350km-53655miles
0F-Digital Radio -- Status: Cannot be reached 1100
A9-Struct. Borne Sound -- Status: Sporadic communication error 1000
C0-Act. for Ext. Noise -- Status: Malfunction 1010
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589     HW: 4G0 907 589
   Component: 3.0BTD EDC17  H24 0001
   Revision: 57H24---
   Coding: 2A2A4032252603020000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589 001004
   ROD: EV_ECM30BTD0118K5907589.rod
   VCID: 7EA5022DD078F357B89-802A
   Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1002
   Revision: --H16---
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 00597CD5AA8C85A7CA5-8054
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AB    HW: 8R0 907 379 AB
   Component: ESP8 quattro  H09 0050
   Coding: 245D0C01
   Shop #: WSC 06335 000 00000
   VCID: 00597CD5AA0C85A7CA5-8054
   Part No SW: 8K0 907 064 GR    HW: 8K0 907 064 FR
   Component: BCM2 2.0      H12 0633
   Coding: 05B54040000000000000
   VCID: 06556ACD8828AB97F09-8052
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 55
                    Mileage: 86351 km
                    Date: 2020.07.23
                    Time: 14:37:54
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01180220130830
   Coding: 3625628080
   VCID: 3A2DCE3D8C501F77C41-806E
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000555658602
   Coding: 260080118134AFF0018140C300001D0D4F9DC70827090201000008004401030100000034000000
   Shop #: WSC 06335 123 12345
   VCID: 78A91435F2DCCD67F25-802C
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130124  H11 0050
   Serial number: 90243015130121190815
   Coding: 01DD13
   Serial number: 21003873
   Coding: 03005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001302131026
   Serial number: 30380296000000000001
03110 - Active Steering Control Module (J792)
                    Reset counter: 13
                    Mileage: 85360 km
                    Date: 2020.06.20
                    Time: 18:16:36
03124 - Terminal 30 - 3
                    Fault Status: 00101011
                    Reset counter: 73
                    Mileage: 85881 km
                    Date: 2020.07.08
                    Time: 15:13:14
03123 - Terminal 30 - 2
                    Reset counter: 73
                    Mileage: 85881 km
                    Date: 2020.07.08
                    Time: 15:13:14
Address 0F: Digital Radio
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Serial number: 003JPD92UVBE
   Coding: 304A3431313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C9A4F5C23C7DE7425-801C
   Serial number: 6334MSME74160A68F
   Serial number: 6344MSME777301537
   Serial number: 6352QSME5328476EQ
   Serial number: 6362QSME6628377EV
   Serial number: 63732SME712B4D688
   Serial number: 63832SME582B3D7CI
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372MBD000L6
   Coding: 000037
   VCID: 43D3B3D9FB9A5EBF977-8016
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 K    HW: 8R0 920 931 K
   Component: KOMBIINSTR.   H35 0556
   Revision: 00100000    Serial number: UWY24KC2E
   Coding: A3AF220003010008010700
   VCID: 3D27C5219D7E284FE13-8068
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0055
   Revision: 1Y060027    Serial number: 2741Y132138073
   Coding: 80CD07FF00
   VCID: 4ACD9EFDDCB08FF7541-801E
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000001461041901
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 13038002403011200410
02230 - Digital Radio (DAB) (R147)
                    Reset counter: 13
                    Mileage: 85360 km
                    Date: 2020.06.20
                    Time: 18:17:35
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 73
                    Mileage: 85360 km
                    Date: 2020.06.20
                    Time: 18:42:21
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 6
03619 - Control Module for Structural Accoustics
                    Reset counter: 73
                    Mileage: 85883 km
                    Date: 2020.07.08
                    Time: 15:42:52
                    Bin. Bits:    11111
                    Voltage: 12.00 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
04014 - Control Module for Engine Noise Simulation
                    Reset counter: 73
                    Mileage: 85883 km
                    Date: 2020.07.08
                    Time: 15:42:52
                    Bin. Bits:    11111
                    Voltage: 12.00 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 0.40 s
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000051749369
   Coding: 01781B00000000000000
   VCID: 42DDB6DDE48057B79C1-8016
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000051960460
   Coding: 011D12205E01440004
   VCID: 4FFB8FE927D2AADF03F-801A
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0013268912
   Coding: 100000010001
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B23CB3983EA267FDF7-806E
   Revision: 00002001    Serial number: 0301338329
   Coding: 01040E2220B93095872005368004000F
   Shop #: WSC 44406 123 104857
   Component: J245EE20SKB13  H05 0220
   Component: J394EE20SKB13  H05 0220
   Revision: 00005001    Serial number: 94813011164102
   VCID: 2D07F5614D1EB8CF513-8078
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000052677644
   VCID: 4EC592ED20D8A3D7089-801A
02117 - Motor for Mirror Folding
            006 - Short to Plus
                    Fault Status: 01100110
                    Fault Frequency: 14
                    Reset counter: 55
                    Mileage: 85422 km
                    Date: 2020.06.23
                    Time: 09:52:45
                    Reset counter: 64
                    Mileage: 85553 km
                    Date: 2020.06.29
                    Time: 09:35:15
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 8
                    Reset counter: 55
                    Mileage: 85749 km
                    Date: 2020.07.05
                    Time: 11:33:23
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001259528
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829D435B2DC0D67325-806C
   Part No SW: 4G1 035 053 G    HW: 4G1 035 053
   Component: Radio U Basic H41 0121
   Revision: AB001007    Serial number: 227B30D7696709
   Coding: 040003010000000001
   VCID: 231313591BDA7EBFF77-8076
   Part No SW: 8R2 035 754 B    HW: 8R2 035 754 C
   Component: H-BN-RW       H45 0639
   Revision: --------    Serial number: 210BP0D7509640
   Coding: 1A0A01060205E1FF4780CF4E00000403FC0000020000000000
   VCID: 3635DA0DB848FB17209-8062
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Component: DU7 High  H42 0104
   Serial number: A130BL0D2659121
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001419569
   Component: CD-Database  4949
                    Reset counter: 70
                    Mileage: 85793 km
                    Date: 2020.07.06
                    Time: 15:40:37
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
                    Reset counter: 70
                    Mileage: 85793 km
                    Date: 2020.07.06
                    Time: 15:40:40
                    Bin. Bits: 00001000 00000000
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000052596016
   Coding: 010C12204001240004
   VCID: 46D5AACDC8A86B97B09-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J2ZA1XA
   Coding: 1020010
   VCID: 3431E005A234E9071ED-8060
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 70
                    Mileage: 85793 km
                    Date: 2020.07.06
                    Time: 15:39:44
                        Reverse OFF
                    Count: 3
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B23CB39836A267FDF7-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000052278425
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 130201200540
   VCID: 79AF1131C956D46F8DB-802C
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0002
   Serial number: 130206200331
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 71BF291191269C2F35B-8024
0006 - Actuator 1 for Engine Noise Simulation
          C113C 13 [008] - Open Circuit
                    Mileage: 85360 km
                    Date: 2020.06.21
                    Time: 09:37:10
End----(Elapsed Time: 01:55, VBatt start/end: 12.0V/11.7V. VIgn 11.8V)-----
Yeah, it's a bit strange that you have both "Short to Plus" and "Short to GND" for the same motor, but... I wonder if it's a DC motor that the door module reverses polarity to when it runs in one direction compared to the other?
barbalatte
Sydney, Australia
Could it be the battery? My initial thought was the battery considering both Ground and Plus came up.
Gona bring to my mechanic on Saturday and scan with his tool. See what comes up. Very strange though. Have you come across Error 02117 or 02115?
barbalatte
Sydney, Australia
My mechanic mate recons it’s the switch in the door. Either that or the control module.
Will report back.
