Is a Tune on an ECM a problem when asking for assistance?
GoFastVAG
Canada
C?ID=254556
I will post a full scan ASAP
Full Disclosure this is an ECM that is not the original and has a performance tune on it.
I am wanting to correct issues with an Auto to Manual Conversion correcting these two codes is proving difficult.
P1626
This is a power-train database error as I understand it I need to go to the can gateway and re coded to manual.
I don't know how....can anyone assist?
P1429
Brake booster pump diagnosis I think can be disabled in the software if the module is missing or damaged again
Jef
HQ
Auto-Scan... who did the tune and what type of tune... stage 1 or 2, or does it have that extra push to go over the cliff, stage 11? :)
South Molton, UK
Whether having a tune can be a problem depends on whether the tuner deleted some of the fault detection logic in the tune (to make readiness work) - only way to tell whether this affects you is to post a full Auto-Scan, if we can help we will.
NostraJackAss
Is the tune with an exemption on record with government such as Canada EPA for a valid conformity? :rolleyes:
Full disclosure is always best....
Did you know most conformity certificate applications, cover both manual and standard transmission under the same instrument?
So what was added or deleted in programming?
GoFastVAG
Canada
C?ID=254556
Auto Scan
Monday,27,July,2020,15:44:23:57844
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
VIN: 3VWSE29M13M153335   License Plate: 2.1 FULL SCAN 27,7,2020
Mileage: 217200km-134961mi   Repair Order:
Chassis Type: 9M (1J - VW Golf/Bora IV (1998 > 2006))
          76
VIN: 3VWSE29M13M153335   Mileage: 217200km-134961miles
Address 01: Engine        Labels: 06A-906-032-AWP.lbl
   Part No: 06A 906 032 LQ
   Component: 1.8L R4/5VT     G   0005
   Coding: 07500
   Shop #: WSC 93229
   VCID: 78FF3A215832BF86A9-5140
   3VWSE69M12M026042     VWZ7Z0A3848863
18034 - Powertrain Data Bus
            P1626 - 35-00 - Missing Message from TCU
17837 - Circuit for Brake Vacuum Pump
            P1429 - 35-00 - Open Circuit
Readiness: 0010 0000
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0018945
   Shop #: WSC 00028 000 00000
   VCID: 326BC809AECE95D657-5140
   Part No: 1C0 909 605 A
   Component: 1N AIRBAG VW51 02   0006
   Coding: 12622
   Shop #: WSC 00066
   VCID: 224B3849AE2E0556A7-5106
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2F6DC17DEDFCB83E38-5140
   Part No: 1J0 920 806 J
   Component: KOMBI+WEGFAHRSP VDO V65
   Coding: 07132
   Shop #: WSC 44615
   VCID: 2E53DC79EAF6B13633-5124
   3VWSE29M13M153335     VWZ7Z0C6704562
01039 - Coolant Temperature Sensor (G2)
01304 - Radio
            49-00 - No Communications
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70EF02013042E7C661-5106
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
   VCID: 377DF91D15AC70FE60-4AE8
   Component: 1H Tõrsteuer.FS KLO 0009
   Component: 1H Tõrsteuer.BF KLO 0009
   Component: 1H Tõrsteuer.HL KLO 0009
   Component: 1H Tõrsteuer.HR KLO 0009
Mari
C?ID=150535
Scan seems to be incomplete, missing a few modules listed in the beginning of the scan...
I'm pretty confident that the ECU in question cannot be recoded for a manual transmission. Talk to your tuner about getting ECU software that matches the current configuration of the car (manual trans, etc).
PS: Moving to Retrofits.
