Im trying to delete/ coding it out from the gateway moduel and ecm. the air suspension was converted to coil over struts .
I need help , where else should i delete it from and what exactly should i do , need help , cant get the long coding helper tag in vcds too.
Any body??
attached all the details , autoscan + label+ screen shots.
AUDI S8-4H 2012 AIR SUSPENSION TO COIL OVER CONERSION, NEED HELP CODING IT OUT
Any body??
Tuesday,21,July,2020,20:53:46:49727
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUA2BFD9DN004378 License Plate:
Mileage: 123310km-76621mi Repair Order: 126
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 1B 20 22 28 34 36
3B 42 46 47 52 53 56 5F 62 6C 6D 6F 72 81 85 88 89 8B 8E 8F
90 A9 BA
VIN: WAUA2BFD9DN004378 Mileage: 123310km-76621miles
34-Level Control -- Status: Not registered 0011
3B-Sensor Elect. -- Status: Not registered 0001
85-On Board Cam. -- Status: Malfunction 0010
88-Multicont. Seat Driver -- Status: Malfunction 0010
89-Multicont. Seat Pass. -- Status: Malfunction 0010
8B-Adaptive Cruise 2 -- Status: Cannot be reached 0100
8F-Pretens. Frt Left -- Status: Cannot be reached 0100
90-Pretens. Frt Right -- Status: Cannot be reached 0100
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CGTA) Labels: Redir Fail!
Part No SW: 4H0 907 557 HW: 4H0 906 014
Component: 4.0l V8TFSI / H56 0008
Revision: NCH56---
Coding: 022A00326546010A1000
Shop #: WSC 49493 123 104857
ASAM Dataset: EV_ECM40TFS0114H0907557 001010
ROD: EV_ECM40TFS0114H0907557.rod
VCID: 6D9201A0BC53C1EED0-8038
Readiness: 1110 1101
Part No SW: 4H1 927 158 EG HW: 0BK 927 156 AG
Component: 0BK 40TFSIUSA H16 1002
Revision: --H16---
VCID: 79BA25F0F81B6D4E4C-802C
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 E HW: 4H0 907 379 E
Component: ESP PREMIUM H10 0352
Coding: C2FDA30043BFC500E300
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 3424D4C49FF95026DF-8060
0675 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_HL_Error]
Reset counter: 216
Mileage: 123139 km
Date: 2020.07.17
Time: 21:40:45
VzRef: 00
Bit Info 1: C0
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 39
F-Type: 24
Uz: AB
0677 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_VL_Error]
Fault Frequency: 13
Reset counter: 221
Mileage: 123136 km
Date: 2020.07.13
Time: 17:54:37
VzRef: 00
Bit Info 1: 40
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 02
F-Path: 39
F-Type: 1A
Uz: AB
0776 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_HL_Invalid]
Fault Frequency: 19
Reset counter: 219
Mileage: 123154 km
Date: 2020.07.17
Time: 22:49:33
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 39
F-Type: 23
Uz: A6
0778 - Function Restriction due to Implausible Message(s)
U1112 00 [009] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_VL_Invalid]
Fault Frequency: 9
Reset counter: 180
Mileage: 123136 km
Date: 2020.07.16
Time: 19:57:53
VzRef: 00
Bit Info 1: C0
Bit Info 2: 40
Bit Info 3: 82
Bit Info 4: 00
F-Path: 39
F-Type: 19
Uz: AB
Part No SW: 4H0 907 064 DF HW: 4H0 907 064 CF
Component: BCM2 2.0 H32 0510
Coding: 05A72F46000000000000
Shop #: WSC 72400 819 29397
VCID: 70AC18D4A3612C06FB-8024
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000030228656
Coding: C018320085047201000001010101112131313333283333
Shop #: WSC 02313 785 00200
VCID: 3522E9C09C83492EE8-8060
03725 - Control Module for Seat Belt Tensioner; Left Front
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:21:48
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 H HW: 4H0 820 043 H
Component: Klima 4 Zonen H20 0120
Coding: 680120783C
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 25023980242339AE58-8070
0137 - Motor for Right Side Window Defrost Flap
B10D8 22 [009] - Signal Amplitude Too High
Fault Frequency: 47
Reset counter: 181
Mileage: 123136 km
Date: 2020.07.09
Time: 20:21:51
0386 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Reset counter: 214
Mileage: 123136 km
Date: 2020.07.09
Time: 20:53:16
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001517872
Coding: 0907201009749FF3BB810044A0001800009CC3080E000101800108546F01
VCID: 6FAE1BA8BE5F33FEE2-803A
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120225 H35 0080
Serial number: 120518163837
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10262746
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 11 01 2011 00000173
Subsystem 4 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A31 LED Mod1L H03 0006
Serial number: 00000021051200010938
Coding: 100000
Subsystem 5 - Part No SW: 4H0 907 472 B HW: 4H0 907 472 B
Component: A27 LED Mod1R H03 0006
Serial number: 00000004061200010142
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103086000001307353
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: DB788D26000000000001
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:00
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 230627982217C79E36-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061215301947
Coding: 280B01
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77BE23C8CE0F7B3E3A-8022
Part No SW: 4H0 907 561 B HW: 4H0 907 561
Component: ACC3 H17 0400
Coding: 7C04010101
ASAM Dataset: EV_AdaptCruisContrAU64X 002021
ROD: EV_AdaptCruisContrAU64X_002.rod
VCID: 2A18CABC4D3D16D675-807E
10 Faults Found:
88064 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_SLOW_MISALIGNMENT]
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:02
Control Module temperature: 47 °C
Voltage terminal 15: 11.965 V
88320 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MAR_FAST_MISALIGNMENT]
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:02
31488 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_LRRS_INFO]
Reset counter: 181
Mileage: 123310 km
Date: 2020.07.21
Time: 00:34:31
Control Module temperature: 43 °C
Voltage terminal 15: 13.668 V
90880 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_LRRS_CONDITION]
Reset counter: 181
Mileage: 123310 km
Date: 2020.07.21
Time: 02:40:05
Control Module temperature: 38 °C
Voltage terminal 15: 12.084 V
32000 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_LRRS_STATUS]
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:03
Voltage terminal 15: 11.966 V
77824 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_LRRS_DEJU]
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:03
91392 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_LRRS_POSITION]
Reset counter: 181
Mileage: 123310 km
Date: 2020.07.21
Time: 00:34:32
Voltage terminal 15: 13.748 V
78592 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_CIM_TIMEOUT_LRRS_FOV_03]
Reset counter: 181
Mileage: 123310 km
Date: 2020.07.21
Time: 00:34:31
102912 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[FAULT_CIS_EC_CONFIG]
Reset counter: 221
Mileage: 123310 km
Date: 2020.07.21
Time: 00:33:50
84224 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[FAULT_DAI_LRRS_TIMEOUT]
Reset counter: 181
Mileage: 123310 km
Date: 2020.07.21
Time: 00:37:08
Control Module temperature: 44 °C
Voltage terminal 15: 13.778 V
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG008TXCY
Coding: 30314246323430303033554A304C34483053
VCID: 3620EECC89854236E1-8062
Serial number: 3575HRB405H1D5MS30MN
Serial number: 3585HRB405R1D5MKD0R+
Serial number: 3515JRB406119KD2AHP7
Serial number: 3525JRB406319KD2N0H+
Serial number: 3554VRB40124UEIMG0K2
Serial number: 3564VRB40184UEIMN9AF
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LEP0002A
Coding: 00003C
VCID: 373EE3C8868FBB3EFA-8062
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Component: E221 - MFL H08 0009
Serial number: 03 05 2012 D0066096
Part No SW: 4H0 920 830 N HW: 4H0 920 830 N
Component: TBenRDWACCNV- H72 0515
Revision: 35081077 Serial number: 658060612592054
Coding: 53870802A7400008010100
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod
VCID: 302CD8D46BE16C06BB-8064
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 K HW: 4H0 919 204 K
Component: Analoguhr D4 H05 0224
Serial number: 1120523001191
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung / Adaption]
Reset counter: 178
Mileage: 123175 km
Date: 2020.07.18
Time: 18:31:39
9437185 - Fuel Tank Level Sensor 3
B1179 1B [008] - Resistance Too High
Reset counter: 218
Mileage: 123175 km
Date: 2020.07.18
Time: 18:31:39
9453074 - Fuel Level Sensor 1
B103E 1B [008] - Resistance Too High
Reset counter: 218
Mileage: 123175 km
Date: 2020.07.18
Time: 18:31:39
9459739 - Fuel Level Sensor 2
B1058 1B [008] - Resistance Too High
Reset counter: 218
Mileage: 123172 km
Date: 2020.07.19
U1014 00 [009] - -
Reset counter: 178
Mileage: 123175 km
Date: 2020.07.18
Time: 18:31:39
Part No SW: 4H0 907 468 AB HW: 4H0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000538706
Coding: 00ED074800
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: 71AA1DD0A06B250EF4-8024
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 00000000004970349313
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 12136001639011200410
5080 - Front Left belt tensioner control module
U107C 00 [009] - No communication
[Steuergerät für RGS Links Keine Kommunikation]
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:12
Voltage terminal 30: 11.9 V
Voltage terminal 15: 11.9 V
Control Module temperature: 59 °C
System status: Terminal 15 on
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
5081 - Front Right belt tensioner control module
U107D 00 [009] - No communication
[Steuergerät für RGS Rechts Keine Kommunikation]
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:12
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
6654 - Automatic distance regulation 2
U1071 00 [009] - No communication
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:12
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
0023 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert (Flexray)]
Fault Frequency: 58
Reset counter: 181
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:13
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
U140B 00 [008] - -
[Powermanagement active]
Reset counter: 214
Mileage: 123136 km
Date: 2020.07.09
Time: 20:53:16
Voltage terminal 30: 11.7 V
Voltage terminal 15: 11.7 V
Control Module temperature: 65 °C
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 1
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4H0 907 144 C HW: 4H0 907 144 C
Component: DYNAMIKLENK. H06 0100
Revision: 51001005 Serial number: --------------
Coding: 090100
VCID: 281C30B45B3124C663-807C
Part No SW: 8K0 857 511 F HW: 8K0 857 511 A
Component: FLA H04 0020
Revision: AA001002
Coding: 04018B6B74745D545420363E00
VCID: 3424D4C497F95026DF-8060
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H15 0013
Serial number: 002805120001003
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 271E33885E2F2BBE6A-8072
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 C HW: 4H0 919 158 C
Component: Klima Fond H16 0120
Coding: 2000000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiHeck.rod
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Coding: 008006
ASAM Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
VCID: 2E10C6AC71D57AF6A9-807A
12 Faults Found:
677384 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Fault Frequency: 17
Reset counter: 221
Mileage: 123172 km
Date: 2020.07.18
Time: 10:36:46
677385 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Fault Frequency: 16
Reset counter: 221
Mileage: 123172 km
Date: 2020.07.18
Time: 10:36:46
455691 - Sensor for Ride-Height
C1048 07 [008] - Mechanical Failure
Reset counter: 220
Mileage: 123208 km
Date: 2020.07.19
Time: 20:47:56
36363 - Valve for Damping Adjustment Front Left
C1040 13 [009] - Open Circuit
Fault Frequency: 49
Reset counter: 181
Mileage: 123172 km
Date: 2020.07.18
Time: 00:28:53
36619 - Valve for Damping Adjustment Front Right
C1041 13 [009] - Open Circuit
Reset counter: 181
Mileage: 123172 km
Date: 2020.07.18
Time: 00:28:53
36875 - Valve for Damping Adjustment Rear Left
C1042 13 [009] - Open Circuit
Reset counter: 180
Mileage: 123172 km
Date: 2020.07.18
Time: 00:28:53
37131 - Valve for Damping Adjustment Rear Right
C1043 13 [009] - Open Circuit
Reset counter: 178
Mileage: 123172 km
Date: 2020.07.18
Time: 00:28:53
C10C8 00 [008] - -
Reset counter: 220
Mileage: 123175 km
Date: 2020.07.19
Time: 10:57:04
37147 - Valve for Damping Adjustment Rear Right
C1043 13 [008] - Open Circuit
Reset counter: 218
Mileage: 123175 km
Date: 2020.07.18
Time: 20:56:08
36635 - Valve for Damping Adjustment Front Right
C1041 13 [008] - Open Circuit
Reset counter: 218
Mileage: 123175 km
Date: 2020.07.18
Time: 20:56:08
36379 - Valve for Damping Adjustment Front Left
C1040 13 [008] - Open Circuit
Reset counter: 218
Mileage: 123175 km
Date: 2020.07.18
Time: 20:56:08
115968 - Functional Limitation due to Excessive Temperature
P178E 00 [008] - -
Reset counter: 220
Mileage: 123172 km
Date: 2020.07.18
Time: 00:28:53
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000030226329
Coding: C0183B0085057201000001010101112131313333203333
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:26
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 L HW: 4H0 907 637 G
Component: SARA 6D red H02 0053
Revision: -------- Serial number: EJ1BPA71000FDU
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
VCID: 383CE0F48391B446F3-806C
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0263
Revision: -------- Serial number: 0000128188871
Coding: 011F1E005E0062C202083007
VCID: 48DC9034FB71C4C683-801C
Fault Frequency: 61
Reset counter: 181
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:31
Revision: 00002001 Serial number: 0176405234
Coding: 011A0E2000B93585B330C7C40E03010F0000000000000000000000000000
Shop #: WSC 02311 785 00200
Subsystem 1 - Part No: 4H0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H07 0006
Serial number: WOO16259030
Coding: 901F00
Subsystem 4 - Part No SW: 4H0 947 135 G HW: 4H0 947 135 G
Component: Dachelektroni H11 0080
Serial number: A2012000000000638292
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS010 H05 0005
Serial number: WOO1000PN3Q
Subsystem 6 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84256176
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:36
Part No SW: 4H1 035 465 HW: 4H1 035 465
Component: BO G3 D4 ANC H03 0130
Revision: 09S00000 Serial number: 0010497
Coding: 020101
VCID: 64846484679980A68F-8030
Subsystem 1 - Part No SW: 4H0 035 466 HW: 4H0 035 466
Component: BO D4 SLAVE H51 0180
Serial number: 02003120020059
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000127936457
VCID: 3C34FCE4BFA9986617-8068
Fault Frequency: 61
Reset counter: 181
Mileage: 123136 km
Date: 2020.07.09
Time: 20:22:42
Fault Frequency: 33
Reset counter: 221
Mileage: 123136 km
Date: 2020.07.15
Time: 10:52:47
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000365602
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B16CFB842C70FDE8E-807E
Part No SW: 4H0 035 053 G HW: 4H0 035 053
Component: Radio U Basic H60 0121
Revision: AB001007 Serial number: 228FV0C7511506
Coding: 070003010000000001
Part No SW: 4H0 035 764 L HW: 4H0 035 764 N
Component: H-BNT-RW H44 0637
Revision: -------- Serial number: 181FP0C7501026
Coding: 030D00000201F9EF65908B0E00000003740031020000000000
VCID: 312ADDD068EB650EB4-8064
Subsystem 1 - Part No: 8R0 060 884 AJ
Component: ROW 2012 0403
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDC9300KQB/
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000083631
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Reset counter: 181
Mileage: 123310 km
Date: 2020.07.21
Time: 02:40:09
Bin. Bits: 00000000 00100000
Bin. Bits: 00001000 00000000
Bin. Bits: 00000000 00000000
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000128182444
Coding: 010F1E00400062C202083007
Part No SW: 4H0 907 428 A HW: 7P6 907 441 D
Component: TopView H05 0120
Revision: 11001001 Serial number: 82330JF0045010
Coding: 0209000101010000000102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 005023
ROD: EV_CamerSysteTopViewAUDI_005.rod
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 144201057
Coding: 0210044000
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3D32F1E0ACB3916E20-8068
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000076138
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 638667986A97879E76-8036
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000128182455
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5013 Serial number: SN120503 0225
ROD: EV_GSM2x3Mono_AU64.rod
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Coding: E8040000
ROD: EV_OnBoardCamerDPC.rod
VCID: 26003E8C592532B651-8072
0708 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[EGD_Fahrwerk_01_Signal_Error]
Fault Frequency: 23
Reset counter: 221
Mileage: 123136 km
Date: 2020.07.13
Time: 17:54:35
Outside air temperature: -30.5 °C
Voltage terminal 15: 13.1 V
Control Module temperature: 44.0 °C
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00006386178802
Coding: 662FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F2EDBA876DF73FEA2-807A
0018 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Funktionseinschränkung wegen fehlender CAN-Botschaft]
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:23:22
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00006386273802
Coding: 262FF2
U1111 00 [009] - -
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:23:26
0031 - Solenoid for Inflation of Lumbar Support 3
B11B6 13 [008] - Open Circuit
Reset counter: 219
Address 8B: Adaptive Cruise 2
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H30 0038
Serial number: 005000050106127
Coding: 01A08A030111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
0091 - Function Limitation due to Missing Video Data
C1108 00 [008] - -
[DPC_SystemError]
Fault Frequency: 23
Reset counter: 221
Mileage: 123136 km
Date: 2020.07.13
Time: 17:54:36
Outside air temperature: 38.5 °C
Voltage terminal 15: 13.5 V
Control Module temperature: 42.0 °C
Address 8F: Pretens. Frt Left
Address 90: Pretens. Frt Right
Part No SW: 4H0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0003
Serial number: 120508200046
VCID: 2C14CCA447C908E687-8078
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804000287404
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X.rod
VCID: 66807E8C99A5F2B691-8032
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Reset counter: 174
Mileage: 123136 km
Date: 2020.07.09
Time: 20:23:35
End----------(Elapsed Time: 03:07, VBatt start/end: 12.1V/12.1V)-----------
