new member wants access to forum
keiser501
Bishop's Stortford England
C?ID=196654
joined today, would like to post a vehicle problem. thanks in anticipation. jamie
Since you bought your VCDS system from one of our resellers, you're going to have to register it with Ross-Tech using this form. There's no cost to do that, but it's required prior to getting full access to the forum.
keiser501
C?ID=196654
ok will do. like the product, like the ideas and people behind the product, this is the future for independent car repairers who can give old fashioned personal (genuine) service at an affordable price (that a flashy dealer just cannot give) whilst still being able to access (near dealer level) technical info.
I've got a job coming in Friday that involves sunroof diagnostics on a VW EOS. There is a comms problem between the drivers door switch or module and the right rear window motor. Had a quick look for the owner monday as all she knew was the sun was out and the roof didn't work. It is disabled by the defect in the window circuit. Where can I get info that might help? I need to learn how to upload scans too. Thanks in anticipation Jamie
JimG
Vermont
C?ID=208775
If you haven't seen it yet, there is a sticky called "How to post an Auto-Scan" at the top of this section of the forum.
This may be helpful as well:
keiser501
C?ID=196654
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Friday,04,April,2014,13:15:03:03361
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 26 42 44 46 52 56 62 72
VIN: WVWZZZ1FZ8V048402   Mileage: 37750km/23456miles
26-Auto Roof -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1Q0 907 115 F    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H13NQ8C3
   Coding: 041C000318070160
   Shop #: WSC 00020 790 00000
   VCID: 2F6DE364BE106D6632D-807A
   Revision: 00H11001
   Coding: 0004834
   VCID: 73E52F1412B80986965-8026
   Part No SW: 1K0 820 047 HC    HW: 1K0 820 047 HC
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6CD734684F86D67E57F-8039
   Revision: 00H54000    Serial number: 00000008078264
   Coding: 058C8F0700041500470A00000F00000000085D035C000100000000000000
   VCID: 71E9251C68A43B96649-8024
   Subsystem 1 - Part No: 1Q2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 140208 022  0501
   Coding: 00038805
   Shop #: WSC 00020
                    Reset counter: 168
                    Mileage: 35736 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.05 V
Address 10: Park/Steer Assist (J446)       Labels: 1K0-919-475.clb
   Part No SW: 1K0 919 475     HW: 1K0 919 475
   Component: PARKHILFE     005 1104
   Revision: 00005000    Serial number: 0 263 004 193
   Coding: 001001
   VCID: EFEDA3643E90AD66F2D-80BA
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 6P Airbag VW8C      0180
   Revision: 92010018    Serial number: 003B3003ARCQ
   Coding: 0013904
   VCID: 3A7BC2307552B8CE953-806F
   Subsystem 1 - Serial number: 6332SRB406C0C899B
   Subsystem 2 - Serial number: 6342SRB406B64F8FL
   Subsystem 3 - Serial number: 637  RB4        8
   Subsystem 4 - Serial number: 638  RB4        9
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Coding: 0000041
   VCID: 77FD1B0406C065A6AAD-8022
   Part No SW: 1Q0 920 964     HW: 1Q0 920 964
   Revision: V0002000    Serial number: VWX7Z0H13NQ8C3
   Coding: 0019403
   Shop #: WSC 00207 067 57207
   VCID: F0EFA018E3AEB29EEB7-80A5
   Part No SW: 1K0 907 530 P    HW: 1K0 907 951
   Component: J533__Gateway   H16 0192
   Revision:   H16       Serial number: 2500K083010F3C
   Coding: E9A07F260002025001
   VCID: 3467EC0857364EBE4FF-8061
                    Reset counter: 162
                    Mileage: 37713 km
                    Time: 12:35:20
   Component: IMMO            VDD 1212
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 D    HW: 1Q0 959 255 D
   Component: Verdecksteuergeraet 0824
   Revision: 0033100M    Serial number: 080480112
   Coding: 0655366
   VCID: 3979DD3C7054B3D69C9-806C
                    Fault Frequency: 57
                    Reset counter: 167
                    Mileage: 37713 km
                    Time: 12:34:33
                    Voltage: 11.70 V
                    Voltage: 11.70 V
                    Voltage: 4.90 V
                    Error Code: 0
   Part No SW: 1Q0 959 701 E    HW: 1Q0 959 701 E
   Component: Tuer-SG         006 1212
   Coding: 0000693
   VCID: 3663D600414A5CAE71B-8063
02071 - Local Databus
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 81908A000186285B080484057008DEC690FCA0
   VCID: 8305FFD4C218B906065-80D6
   Component: LIN BACKUP HORN H08 9001
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 1Q0 951 177 A
   Component: Innenraumueberw.158 0502
   Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
   Coding: 0000948
   VCID: 377DDB044640A5A66AD-8062
   Part No: 1K0 035 186 AE
   Component: Radio GR0       034 0033
   Revision: 0003404S    Serial number: VWZ2Z2H3103844
   Coding: 0040400
   VCID: 69D94D7C4074C3562C9-803C
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Component: Tuer-SG         006 1301
   Coding: 0000128
   Shop #: WSC 00020 790 1012544
keiser501
C?ID=196654
Friday,04,April,2014,13:27:52:03361
Control Module Part Number: 1K0 907 530 P
Component and/or Version: J533__Gateway H16 0192
Software Coding: E9A07F260002025001
Work Shop Code: WSC 00020
Advanced Identification
Identification: TFJ-ING
Revision: H16
Date: 01.03.08
Test stand number: 0K02
Manufacturer number: 0F3C
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00000 000 00000
Flash Date: --.--.--
Software
K3.4.9
D3.4.9a
I3.4.9
A5.1.6a
XPQ35_V26.2
XBL_X02A
XBR_PQ35light_V1.8
Misc.
Hardware number: 1K0 907 951
VCDS Info:
Yup, it would not surprise me at all if the lack of communications to the right rear door control module (which a number of control modules are upset about) is the cause of the roof not working. Of course there aren't really any rear doors, but the modules are used to actuate the rear windows, and those windows must get out of the way of things, otherwise the roof can't work.
The first thing I would do is check that the rear door control module that's out to lunch is getting power.
keiser501
C?ID=196654
FOLLOW UP: eos booked in for new window motor 038 028 156c comes in kit 1qo 998 792 with new connector and small premade wire, with instructions saying it is a modified part (assume therefore they are a common problem, had to come from germany as uk sold out.....there must have been a rush for them the one day the sun came out in good ol blighty!. J389 is the module number, it's part of the motor assy. let you know then. Have filled out thr form to get full forum access. Jamie
Next diagnostic job VW CADDY 2008, No powers and earths to the DLC? would like to fix a couple of simple things on this little van to get it through the MOT test. 1. No rear fog (or fog warning tell-tale) and the sidelights (all 4) only come on when light switch is turned to headlight position. I.e if you take the key out you could not leave it's sidelights on? I've checked the fuses....all appear ok. No eobd comms because socket is dead of all activity (except for a tiny glimmer from my DLC breakout box led on pin 16? No wiring diagrams to go on? SSP website I sometimes use doesn't give me much to go on....... Surely I can fix it and not have to send my customer to Main Stealer? any ideas? Thanks in anticipation . Jamie
Keithuk
Stoke on Trent, England
C?ID=122432
The only thing missing from Ross Tech Wiki is:
VAG Error Code: 01334
Fault Location:
Door Control Module Rear Right (J389) - No Signal/Communication - Intermittent
Possible Cause:
Fuse(s).
Wiring/Connector(s) from/to Door Control Module Rear Right (J389) faulty.
Data BUS defective.
Possible Solutions:
Check/Replace Fuse(s).
Check Wiring/Connector(s) from/to Door Control Module Rear Right (J389).
Check/Replace Door Control Module Rear Right (J389).
Read Measuring Value Blocks (MVB).
Check Data BUS.
As taken from my EOBD II Fault Codes Software.
Rescue11
C?ID=213141
Good evening! I hope we will be able to communicate properly and correct some situation.
