Help! I'm relatively new to the Audi World. After pulling engine/trans for an oil leak I chose to swap in a 6 speed manual. Everything is back together and now I'm attempting to reprogram using my new Ross-Tech VCDS. The TCM is still installed and I have the tip trans on a dolly next to the left front wheel so that it can still be plugged in. After running an auto scan with no faults in ABS I attempted to code the 6 speed into the ABS but got the message "No Response from Controller". Now I have 2 faults under "engine". Although I have the Enthusiast WiFi version I'm still using the USB cord. The engine cranks but won't fire (maybe because of the engine speed sensor fault). I initially had a fault code about the Immobilizer but the dash icon with the key goes out after turning on the ignition.
My goal is to re code ABS brakes, Instruments and Engine so I can drive it over to Pure Motorsport (San Diego) and have them install an APR tune.
Monday,20,July,2020,10:09:48:25990
VCDS Version: 20.4.1.0 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: Damschen's Audi Repair
VIN: WA1YL64BX5N011410 License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
75 76 77
Address 01: Engine Labels: None
Part No SW: 4D0 907 560 DC HW: 8E0 907 560
Component: 4.2L V8/5V G 0010
Revision: 00000000 Serial number: AUZ7Z0D2643148
Coding: 0007755
Shop #: WSC 02335 785 00200
VCID: 6A98E8A7441A6FD6B5-5160
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
16706 - Engine Speed Sensor (G28)
P0322 - 004 - No Signal - Intermittent
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 AA
Component: AG5 01V 4.2l5VT USA 0404
Coding: 0001002
VCID: 0542BB1B4D44A0AE38-5160
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00110
Shop #: WSC 02335
VCID: 6A98E8A7171A6FD6B5-2580
27-00 - Implausible Signal
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 N
Component: Airbag 8.4EP 1000
Coding: 0000607
Shop #: WSC 02334 785 00200
VCID: 5AF8B867947AFF5625-5184
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02335
VCID: 2F2E39B3EC78CAFEA2-5160
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 F
Component: KOMBI+WEGFAHRS. VDO D16
Coding: 20283
Shop #: WSC 20852
VCID: 2B162DA3DB60B6DE8E-5160
WA1YL64BX5N011410 AUZ7Z0D2643148
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 D060
Coding: 25500
Shop #: WSC 22666
VCID: 48DC722F6AD67DC683-513C
01575 - Control Switched Off
35-00 - -
49-00 - No Communications
79-10 - Please Check Fault Codes - Intermittent
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 02335
VCID: 332635C30050EE1EC6-4EA6
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
VCID: 2C142EBFDD6EB1E687-4B00
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 4B0 035 192 P HW: 4B0 035 192 P
Component: RNS-E US H99 0260
Revision: 01S Serial number: AUZBZ7G9911800
Coding: 0509677
Shop #: WSC 22666 444 12345
VCID: 2A1828A7879AAFD675-5118
00856 - Radio Antenna
Reset counter: 52
Date: 2000.01.01
Time: 04:10:35
Mileage: 655350 km
Count: 101
Clock: 04:10
00857 - CD Changer Unit (R41)
Reset counter: 52
Date: 2000.01.01
Time: 04:11:12
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02335
VCID: 0444A61F157E99A62F-4AC2
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0509677
Reset counter: 52
Date: 2000.01.01
Time: 04:10:35
Mileage: 655350 km
Count: 101
Clock: 04:10
Reset counter: 52
Date: 2000.01.01
Time: 04:11:12
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 02335
VCID: 0248A0070F6A97961D-513C
End----------(Elapsed Time: 04:33, VBatt start/end: 12.3V/12.3V)-----------
