2010 A5 (OB5) Erase counter for start and stop processes error: request out of range
Ant_A5
Australia
C?ID=406858
Hi,
I have not long purchased a new VCDS cable to reset/recalibrate a OB5 Transmission. I'm following the Wiki guide http://wiki.ross-tech.com/wiki/inde..._Direct-Shift_Gearbox_(DSG/0B5)#Basic_Setting
but keep getting the following errors,
ERASE COUNTER FOR STAR AND STOP PROCESSES" receive "error: request out of range"
"CLUTCH VALVE CALIBRATION" and receive "aborted: safety reasons"
"DISTANCE SENSOR CALIBRATION" works and completes ok.
I followed all the Prerequisites,
Transmission fluid level correct
Transmission fluid temperature between 40°C - 100°C. (one user reports this needs to be below 60°C) "Tried above/below 60'C"
TCM fault free however it is strongly recommended to check/clear all Powertrain controllers faults also.
Key on, Engine off
Selector lever in P
Engine running for the "CLUTCH VALVE CALIBRATION"
Done multiple searches on the Ross-Tech Forum and Google. Found lots of posts with the same issue but have not found why these procedures fail or a fix other than different Scan-Tools work when tried.
Is there away to get this to work or do i need something other than VCDS do this?
Thank you,
Ant.
Monday,20,July,2020,12:09:09:15813
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8TXAA06****   License Plate:
Mileage: 132540km-82356mi   Repair Order: 2020-07-20_1
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          72
VIN: WAUZZZ8TXAA06****   Mileage: 132540km-82356miles
Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8R0 907 401 J    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H03 0008
   Revision: 15H03---
   Coding: 0114002C240F0128
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
   ROD: EV_ECM30TDI0118R0907401J.rod
   VCID: 392F286EE9DA4E93545-806C
   Part No SW: 8K1 927 156 A    HW: 0B5 927 156 E
   Component: 0B5 30 TDIRdW H03 0002
   Revision: --H03---    Serial number: 0000000056
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 33331A46CBB6B4C39E9-8066
   Part No SW: 8K0 907 379 BC    HW: 8K0 907 379 BC
   Component: ESP8 quattro  H04 0020
   Coding: 1C0500
   VCID: 7BA3F266A3E6BC83069-802E
   Part No SW: 8K0 907 064 DT    HW: 8K0 907 064 DT
   Component: BCM2 1.1      H02 0327
   Coding: 051400
   VCID: 0557949ED522FA7360D-8050
   Serial number: 0210000025016003
   Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
   Component: KLIMA 3 ZONEN H08 0171
   Revision: D0000000    Serial number: 01090320100791
   Coding: 36146000
   VCID: 76B5E35298C4E1EB797-8022
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H25 0380
   Revision: 09025001    Serial number: 00000000487120
   Coding: 260050914034AF010009000000005D5D0F1D430802010141000000
   VCID: 3A2D3762EC5C458B5DF-806E
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 090310  H12 0070
   Serial number: SWF10030090078
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10816877
   Coding: 02532C
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000503100162
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50941007208468
   Coding: 300107
   VCID: 48C95DAAA2B0271BDBB-801C
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0DGUAZ
   Coding: 30373438363030303030554A305238543053
   VCID: 44D1499A9E18037B373-8010
   Serial number: 6334MSME51436C0EI
   Serial number: 6344MSME512275073
   Serial number: 6352QSME13532204/
   Serial number: 6362QSME285715028
   Serial number: 63732SME5854571A1
   Serial number: 63832SME59544B0E9
   Revision: --------    Serial number: 90304JCF0005Z
   Coding: 000036
   VCID: 3D273C7EFD7272B378D-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8T0 920 931 D    HW: 8T0 920 931 D
   Component: KOMBIINSTR.   H37 0255
   Revision: 00000000    Serial number: CSF522A3A
   Coding: AF07310002000008010000
   VCID: 38292D6AD250579BABB-806C
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0116
   Revision: EB900055    Serial number: 5500E10228021B
   Coding: 00C303
   VCID: 03538A86DB16C4434E9-8056
   Component: J367-BDM  H07 0170
   Serial number: 1000BB08260210
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1301
   Coding: 011C12624001450005
   VCID: 50F975CA5AE0EFDB83B-8004
   Revision: 00002001    Serial number: 0128007476
   Coding: 01040E20203904010020043280000000
   Shop #: WSC 12345 123 61029
   Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
   Component: TSG BF        H07 1301
   Coding: 011C12224C01450005
   VCID: 4FFB76B647DEF0239A1-801A
   Revision: 00000003    Serial number: 00000000586586
   VCID: 3431195ACE38B3FB873-8060
   Part No: 8K5 907 357
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 77ABEE5693CE98E3621-8022
   Part No SW: 4F0 035 056 B    HW: 4F0 035 056
   Component: Radio U STD   H45 0020
   Revision: AB001007    Serial number: 342CU0A7775412
   Coding: 040003020100000001
   VCID: 1F1BE6F657BE00A34A1-804A
   Part No SW: 8T2 035 754 D    HW: 8T2 035 754 D
   Component: H-BN-RW       H47 0047
   Revision: --------    Serial number: 485CW0A7516071
   Coding: 010A0104000681EF01000B0E000000030000
   Subsystem 1 - Part No: 8R0 060 884 D
   Component: ROW 2009/2010  5103
   Component: DU7 High  H43 0306
   Serial number: 9356CN0A1214832
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000489682
   Component:   CD-Database  1293
   Part No SW: 8T0 959 795 J    HW: 8T0 959 795 B
   Component: TSG HL        H05 1301
   Coding: 010C12224001450005
   VCID: 52FD7FC254EC9DCBB5F-8006
   Revision: --H03---    Serial number: 525PA8-J0291IT
   Coding: 1022006
   VCID: 38292D6ADE50579BABB-806C
   Component: TSG HR        H05 1301
End----------(Elapsed Time: 01:20, VBatt start/end: 12.2V/12.2V)-----------
NEtech
Denmark
C?ID=56995
"Erase counter for start and stop processes", I don't think it is necessary.
Is parking brake activated?
Before starting basic setting, find an mark these measuring values (if available):
IDE00024
IDE000098
ENG107531
ENG107525
ENG110340
IDE04347-ENG997005
IDE04347-ENG101925
IDE04347-ENG101865
Look at values after Basic Setting is started.
Ant_A5
Australia
C?ID=406858
IDE00024
IDE000098
ENG107531
ENG107525
ENG110340
IDE04347-ENG997005
IDE04347-ENG101925
IDE04347-ENG101865
Hi NEtech,
Thank you for the quick reply.
Yes on all attempts the parking brake was activated and brake pedal NOT pressed.
I looked at the values above and did not have all of them exactly as above but similar...
IDE00024
IDE000098 Typo? IDE00098
ENG107531 Not Avi but was> ENG107531-ENG98502
ENG107525 Not Avi but was> ENG107525-ENG98502
ENG110340 Not Avi but was> ENG110340-ENG98502
IDE04347-ENG997005 Typo? IDE04347-ENG99705
IDE04347-ENG101925
IDE04347-ENG101865
See Values Before and After "ERASE COUNTER FOR START AND STOP PROCESSES" setting run.
Tuesday,21,July,2020,12:59:34:15813
Mileage: 132670km-82437mi   Repair Order: Before
                Address 02: Auto Trans  (8K1 927 156 A)
12:58:57
  IDE00024   Transmission fluid temperature 59 °C
  IDE00098   Transmission position P
  IDE04347-ENG101925   Expanded environmental conditions-A006_Svn_NEw1.Nroh 0.00 /min
  IDE04347-ENG101865   Expanded environmental conditions-A007_Svn_NEw2.Nroh 0.00 /min
  IDE04347-ENG99705   Expanded environmental conditions-E001_Svp_PKupp[K1] 0.00 bar
  ENG107525-ENG98502   M046_Grd_Zust_Sub-Data (0) GRD_SUB_AUS
  ENG107531-ENG98502   M053_Akk_FehlerPkp0_Zust-Data (0) Aus
  ENG110340-ENG98502   Z052_Akk_FehlerPkp0_Welle-Data (0) Welle1
13:00:43
  IDE00024   Transmission fluid temperature 58 °C
While running "ERASE COUNTER FOR START AND STOP PROCESSES" none of these values changed.
While running "CLUTCH VALVE CALIBRATION" the value "ENG107525-ENG98502 M046_Grd_Zust_Sub-Data" changed from
"ENG107525-ENG98502 M046_Grd_Zust_Sub-Data (0) GRD_SUB_AUS"
to
"ENG107525-ENG98502 M046_Grd_Zust_Sub-Data (75) TGR_GS_NEUTR_SCHALTEN"
to
"ENG107525-ENG98502 M046_Grd_Zust_Sub-Data (76) TGR_NLL_ANFORDERN"
And stays there untill it errors out and returns to
and get the "aborted: safety reasons" message.
Thank you,
Ant.
Ant_A5
Australia
C?ID=406858
Hi, Is there anyone on this forum who know why the above Basic Settings are not fully completing? I need to know VCDS can carry out these CALIBRATIONS, just in case I need to any transmission work, I.e Clutch Replacement or Solenoid Valve Replacment. Thanks.
