Skoda Octavia 1Z MY2012 light coding question
MartinsX
Riga, Latvia
C?ID=268515
Hello!
I have some questions, mainly addressed to light coding experts here :)
This Skoda is equipped with separate DRL bulbs (inside front fog lights), RLS, light switch with AUTO position and BCM PQ35 H 110 0651, Part No SW: 1K0 937 087 Q HW: 1K0 937 087 Q.
DRL's were disabled in coding (Byte 15 Bit 6 OFF)
Customer wants to have his DRL's working.
When I enable DRL's in coding (Byte 15 Bit 6 ON),
40000AB8E80508C04008008011008124437000AE526D85605C8540000040   Original Coding
40000AB8E80508C04008008011008164437000AE526D85605C8540000040   DRL via separate lights set to ACTIVE
in light switch AUTO position everything works as expected - with ignition on DRL's or low beam+side/marker lights+number plate lights are switched on and changes automatically depending on ambient light intensity signal from RLS.
But DRL's are on with ignition on, when light switch is in 0 position, too...
Main question: is it possible to code/adapt something (without touching Byte 18) to make DRL's stay off, when light switch is in position 0?
Additional (more theoretical) questions:
- is it possible for this BCM to make that in AUTO position, if it is dark outside according signal from RLS, low beam switches on only after engine is started (for battery saving), but stays on until ignition is switched off if engine stalls accidentally (for safety)?
- is it possible to adjust ambient light intensity level for switching from DRL to low beam and vice versa?
- what does Bit 5 in Byte 26 (DRL indicator lamp) mean and how does it work?
Autoscan and BCM admap below.
Saturday,18,July,2020,12:34:11:32442
VCDS Version: 20.4.1.0 (x64)
VIN: TMBGE61Z1C8018674   License Plate:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 56 62 72
VIN: TMBGE61Z1C8018674   Mileage: 290140km-180284miles
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 CT    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H24 7101
   Revision: 42H24---    Serial number:
   Coding: 001D0012042400080000
   Shop #: WSC 73430 031 00126
   ASAM Dataset: EV_ECM20TDI01103L906018CT 003004
   ROD: EV_ECM20TDI01103L906018CJ.rod
   VCID: 7EF394C7E189CF7679-802A
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 3103
   Revision: 05351113    Serial number: 00001110210984
   Shop #: WSC 73430 790 00126
   VCID: 26439CA79199B7B651-8072
   Revision: 00H31001
   Coding: 113B401C09230002881102EB901D0042350000
   VCID: 7BF59DD3FA9BDA5E5E-802E
02214 - Tire Pressure Warning
                    Reset counter: 240
                    Mileage: 288495 km
                    Date: 2014.11.11
                    Time: 18:53:49
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 49921
                    Count: 763
   Part No SW: 3T0 907 044 BL    HW: 3T0 907 044 BL
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7DF193CBEC8FD46E60-8028
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 40000AB8E80508C04008008011008124437000AE526D85605C8540000040
   VCID: 3F8D29C3AE03067E32-806A
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 07111  26  0601
   Coding: 00D7B7
   Component: RLS 271011 05  54  0403
   Coding: 0730ED
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32901129400805
   Coding: 10810E
   Shop #: WSC 13765 790 00126
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 336575F39A4BD21EC6-8066
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC28CPW+
   Coding: 0020790
   VCID: 3D7153CB640F146E20-8068
   Subsystem 1 - Serial number: 6332MSME6506154A8
   Subsystem 2 - Serial number: 6342MSME6562247BF
   Subsystem 3 - Serial number: 6351HSME29460541+
   Subsystem 4 - Serial number: 6361HSME29501365%
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20111107800198
   Coding: 188A140000
   ROD: EV_SMLSNGVOLWS.rod
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
147462 - Terminal 15
          B1148 12 [008] - Short to Plus
                    Reset counter: 243
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 17:55:35
   Part No SW: 1Z0 920 843 S    HW: 1Z0 920 843 S
   Component: KOMBI         H05 0607
   Coding: 110A01
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
   VCID: 489F321FF3CD41C683-801C
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 021111F1001228
   Coding: 352302
   VCID: 3A7B58D7B521235605-806E
                    Reset counter: 242
                    Mileage: 288482 km
                    Date: 2014.11.09
                    Time: 18:16:40
   Component: IMMO          H05 0607
   VCID: 6ADBA8978D0153D6B5-803E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1102
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F6D7983BE63F6FEA2-807A
   Part No SW: 3T0 035 192 F    HW: 3T0 035 192 F
   Component: RNS315-EU   H35 0263
   Serial number: SKZAZ2L9225926
   Coding: 000004110401000000000003
   Shop #: WSC 43476 004 1048576
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 31697FFB6057E00EB4-8064
9 Faults Found:
1048587 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
                    Reset counter: 242
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
1048593 - Front Left Bass Speaker
          B105F 13 [008] - Open Circuit
                    Reset counter: 216
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
1048594 - Front Right Bass Speaker
          B1062 13 [008] - Open Circuit
                    Reset counter: 216
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
1048595 - Rear Left Bass Speaker
          B1065 13 [008] - Open Circuit
                    Reset counter: 216
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
1048596 - Rear Right Bass Speaker
          B1067 13 [008] - Open Circuit
                    Reset counter: 216
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
1048632 - Antenna 1 for Radio
          B1119 13 [008] - Open Circuit
                    Reset counter: 216
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
1048634 - Antenna 2 for radio
          B111A 13 [008] - Open Circuit
                    Reset counter: 216
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
1048582 - GPS Antenna
          B1054 13 [008] - Open Circuit
                    Reset counter: 242
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
1048652 - Telephone Microphone
          B1048 13 [008] - Open Circuit
                    Reset counter: 242
                    Mileage: 288482 km
                    Date: 2020.06.18
                    Time: 18:02:48
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2119
   Coding: 0004598
   VCID: 76E38CE701B9873621-8022
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 346776EF5745D526DF-8060
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0004598
   VCID: 489F321F3BCD41C683-801C
00121 - Outside Warning Light/Door exit Light Passenger Side
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012574
   VCID: 326B70F7AD51DB16CD-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 336575F3524BD21EC6-8066
End-------------------------(Elapsed Time: 02:44)--------------------------
;SW:1K0-937-087-Q   HW:1K0-937-087-Q ---  Cent. Elect.
;Component:BCM PQ35  H   110 0651, Coding:40000AB8E80508C04008008011008164437000AE526D85605C8560000040
;Saturday,18,July,2020,13:12:16:32442
;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
;VCID: 3F8D29C3AE03067E32-806A
Channel,,Field 1,Field 2,Field 3,Field 4,
01,5,Key,learn (adapt),5,-,
02,,ERROR:,Channel 02,Not,Available,
03,0,OPEN,Single Door,0,-,
04,0,Auto Lock /, ,OFF,-,
05,0,Auto Unlock, ,OFF,-,
06,1,Comfort,Remote Ctrl.,ON,-,
07,0,Comfort,Conv. Top 0,OFF,-,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,,ERROR:,Channel 10,Not,Available,
11,,ERROR:,Channel 11,Not,Available,
12,1,safe,Blink,Delay,-,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,0,Comfort,CLOSE,OFF,-,
18,,ERROR:,Channel 18,Not,Available,
19,0,Locked,Inactive,OFF,-,
20,,ERROR:,Channel 20,Not,Available,
21,,ERROR:,Channel 21,Not,Available,
22,0,Adapt Value,Erase, ,-,
23,10,Coming Home, ,10.00 s,-,
24,10,Leaving Home, ,10.00 s,-,
25,15,Timer Rear,Window Htr.,600,-,
26,,ERROR:,Channel 26,Not,Available,
27,,ERROR:,Channel 27,Not,Available,
28,,ERROR:,Channel 28,Not,Available,
29,0, ,Status,Erase,-,
30,6,AFL,Delay,0.06 s,-,
31,3,Comfort,Blink,3,-,
32,0,Start,Function,0,-,
33,,ERROR:,Channel 33,Not,Available,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
181,,ERROR:,Channel 181,Not,Available,
182,,ERROR:,Channel 182,Not,Available,
183,,ERROR:,Channel 183,Not,Available,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Channel 191,Not,Available,
192,,ERROR:,Channel 192,Not,Available,
193,,ERROR:,Channel 193,Not,Available,
194,,ERROR:,Channel 194,Not,Available,
195,,ERROR:,Channel 195,Not,Available,
196,,ERROR:,Channel 196,Not,Available,
197,,ERROR:,Channel 197,Not,Available,
198,,ERROR:,Channel 198,Not,Available,
199,,ERROR:,Channel 199,Not,Available,
200,,ERROR:,Channel 200,Not,Available,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Channel 202,Not,Available,
203,,ERROR:,Channel 203,Not,Available,
204,,ERROR:,Channel 204,Not,Available,
205,,ERROR:,Channel 205,Not,Available,
206,,ERROR:,Channel 206,Not,Available,
207,,ERROR:,Channel 207,Not,Available,
208,,ERROR:,Channel 208,Not,Available,
209,,ERROR:,Channel 209,Not,Available,
210,,ERROR:,Channel 210,Not,Available,
211,,ERROR:,Channel 211,Not,Available,
212,,ERROR:,Channel 212,Not,Available,
213,,ERROR:,Channel 213,Not,Available,
214,,ERROR:,Channel 214,Not,Available,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,,ERROR:,Channel 221,Not,Available,
222,,ERROR:,Channel 222,Not,Available,
223,,ERROR:,Channel 223,Not,Available,
224,,ERROR:,Channel 224,Not,Available,
225,,ERROR:,Channel 225,Not,Available,
226,,ERROR:,Channel 226,Not,Available,
227,,ERROR:,Channel 227,Not,Available,
228,,ERROR:,Channel 228,Not,Available,
229,,ERROR:,Channel 229,Not,Available,
230,,ERROR:,Channel 230,Not,Available,
231,,ERROR:,Channel 231,Not,Available,
232,,ERROR:,Channel 232,Not,Available,
233,,ERROR:,Channel 233,Not,Available,
234,,ERROR:,Channel 234,Not,Available,
235,,ERROR:,Channel 235,Not,Available,
236,,ERROR:,Channel 236,Not,Available,
237,,ERROR:,Channel 237,Not,Available,
238,,ERROR:,Channel 238,Not,Available,
239,,ERROR:,Channel 239,Not,Available,
240,,ERROR:,Channel 240,Not,Available,
241,,ERROR:,Channel 241,Not,Available,
242,,ERROR:,Channel 242,Not,Available,
243,,ERROR:,Channel 243,Not,Available,
244,,ERROR:,Channel 244,Not,Available,
245,,ERROR:,Channel 245,Not,Available,
246,,ERROR:,Channel 246,Not,Available,
247,,ERROR:,Channel 247,Not,Available,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
I doubt it. These BCM PQ35 modules were not very flexible in terms of such configuration unless you edit the EEPROM.
hadez16
C?ID=289891
Is that secret lighting configuration EEPROM hexdump download/upload cheat code for PQ35 BCMs, that I saw in my dreams last night, already in a beta phase?
downtime
Finland
C?ID=280813
I think in PQ35 it was possible to have an option in mfd menu light & vision where you could tick drl on / off and if off, they would be off when the light switch is in 0 position. Other positions work normally.
Now not sure if the option was there by default or did you have to code something. It’s been a while since I’ve done any coding to PQ35 car.
langers2k
C?ID=224085
Try byte 26, bit 3 - I'm sure I've tried that before and it gave the behaviour you want.
On a side note, you probably want to enable byte 15, bit 7 as that should also give the DRL on/off option in the maxidot.
Not that I'm aware of.
Probably in the RLS (rain/light sensor) which is a submodule of the BCM. It's not something I've looked at but I'm sure others have tweaked the tint levels etc to alter the on/off brightness.
I think it's enable the "DRL on" warning lamp for clusters that have it fitted although it's missing from the Octavia cluster so is unlikely to do much ;)
MartinsX
Riga, Latvia
C?ID=268515
Thank You all for answers! Will try when car will come to me next time :thumbs:
