Single Side Parking Lights on NA MK7.5 GTI with European Taillights & DAP Harness
corradokid
CA, USA
C?ID=32540
I had Single Side Parking Lights working with my stock 9/19 built NA GTI, then I upgraded to the European tail lights with DAP's wiring harness and then the rear single side parking lamp was the amber dynamic turn signal on solid. I've tried to parse out the coding in my BCM but not sure what now controls the actual "parking light" I'm trying to change the coding to (between German and channel names :confused:)
Can someone who's more familiar with the channels and which might control the parking lamp help suggest the proper adaptation channels to alter for properly working SSPL with European tails please?
I also noticed I have a fault for incorrectly coded module. DAP said this would occur on Golf R's due to them having a midline light module but not on GTIs, is this old information and my car is newer/diferent?
Below is the coding used to enable the lights, the coding DAP provided, my autoscan, and my 09 BCM adaptations as of right now.
Thank you for any insight that might be able to be offered!!
I initially followed the directions from user dmc here and worked fine stock.
https://forums.ross-tech.com/showth...ada)-Golf-R-MY16&p=47682&viewfull=1#post47682
The DAP coding changes:
                     [B]Channel                New Coding                  Old Coding[/B]
[B]Driver’s Outer[/B]
Leuchte20BR        Lichtfunktion B 20        nicht aktiv                   Blinken Links Hellphase
Leuchte20BR        Lichtfunktion C 20        nicht aktiv                   Blinken Links Dunkelphase
Leuchte23SL        Lichtfunktion A 23        Blinken Links Hellphase     Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
[B]Passenger’s Outer[/B]
Leuchte21BR        Lichtfunktion B 21        nicht aktiv                   Blinken Links Hellphase
Leuchte21BR        Lichtfunktion C 21        nicht aktiv                   Blinken Links Dunkelphase
Leuchte24SL        Lichtfunktion A 24        Blinken Rechts Hellphase   Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
[B]Driver’s Inner [/B]
Leuchte17TFL        Lichtfunktion A 17        Klemme 30g            Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
Leuchte17TFL        Lichtansteuerung HD AB 17    always                only_if_closed
Leuchte28RFL        Lichtfunktion A 28        Nebelschlusslicht wenn    Rueckfahrlicht
                                            kein Anhaenger gesteckt
[B]Passenger’s Inner[/B]
Leuchte16BLK        Lichtfunktion A 16        Klemme 30g            Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
Leuchte16BLK        Lichtansteuerung HD AB 16    always                only_if_closed
Leuchte22BR        Lasttyp 22                    43 - allgemeine LED        42 - LED dritte Bremsleuchte
Leuchte16BLK        Fehlerort mittleres Byte DTC    “00”                “36”
Leuchte17BLK        Fehlerort mittleres Byte DTC    “00”                “36”
[B]MK7.5 Golf R and 2019 GTI and Newer (but not in my 2019 GTI? See below)[/B]
Leuchte25KZL        Lichtfunktion AB 25        30                    127
Leuchte26NSL        Lichtfunktion AB 26        30                    127
Leuchte27NSL        Lichtfunktion AB 27        30                    127
[B]My 9/2019 GTI - the only Leuchte AB channels I have with numbers similar:[/B]
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 - parking light tail light brightness
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht - Enable rear fog position on switch
My auto scan:
Saturday,18,July,2020,19:52:39:41546VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.4.1.0 (x64)  HEX-NET CB: 0.4526.4
VIN: 3VW5T7AU7KM035767   License Plate:
Mileage: 1063km-660mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 29 2B 32 39 3C 42 44 47 4B
          52 5F 75 A5 A9 D6 D7
VIN: 3VW5T7AU7KM035767   Mileage: 1063km-660miles
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0005
   Revision: --H13---
   Coding: 091900322444002F1000
   Shop #: WSC 00066 790 00072
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001006
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C341CE4B7C9ED6617-8069
Readiness: 1110 1101
   Part No SW: 5Q0 614 517 FC    HW: 5Q0 614 517 BM
   Component: ESC           H45 0191
   Revision: 00000000    Serial number: 52309000000896
   Coding: 01FA6BA150230971407E020660CA6880D60A900240061636344350D1D0A94B0B0000000012121212B835351919323200
   Shop #: WSC 28436 004 1048576
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 77BEC3C8CE6F0E3E3A-8023
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0522422179
   Coding: 132C0C0623
   Shop #: WSC 00066 790 00088
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45C27900C403ACAE78-8011
   Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
   Component: Climatronic   H04 2001
   Revision: 00001K05
   Coding: 0002001420011800010400401211100C
   VCID: 48DC7034F311B1C683-801D
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
          B10CD 00 [009] - -
                    Reset counter: 24
                    Mileage: 1063 km
                    Date: 2020.07.18
                    Time: 19:47:39
                    Voltage terminal 30: 11.7 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86417091904JL
   Shop #: WSC 00066 790 00239
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7BB6DFF8F2472A5E5E-802F
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190704  043 0551
   Serial number: 97022066190711070557
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0206
   Serial number: SAY19M07D17H08M56S32
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591 A    HW: 5GD 959 591 A
   Component: J245 PS60.006  H07 0170
   Serial number: 03691616341912181602
   Coding: 181803
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300060920190C202228
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuerger‰t falsch codiert->Keine Anzeige]
                    Reset counter: 24
                    Mileage: 1063 km
                    Date: 2020.07.18
                    Time: 19:47:39
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000137089R19231
   Coding: 0271167801
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   VCID: 51EA5D50004B700ED4-8005
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 2D0040C141FFC728949C810510401600000000000000000004
   VCID: 44C46404CF3995A66F-8011
   Serial number: 02071941350541
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383C00F483F1C146F3-806D
   Serial number: 003GCR0CCGJV
   VCID: 47DE7308FE0FBEBE8A-8013
   Occupant Detection:
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000C1OCDM
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 007 19
   Serial number: 35700000000B967C6D3$
   Subsystem 3 - Part No SW: -----------    HW: 480 002 007 19
   Serial number: 35800000000AC861DD3$
   Subsystem 4 - Part No SW: -----------    HW: 480 401 907 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001C2F11B85639FC
   Subsystem 5 - Part No SW: -----------    HW: 480 402 007 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001AAF11B856C37E
   Subsystem 6 - Part No SW: -----------    HW: 480 400 908 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001C4F08AF8832ER
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 908 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001C4F08AF88381L
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2700
   Coding: 0BAD0912FD88CF0502887B0B5001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2F2E3BA876BF06FEA2-807B
   Serial number: 19091900841687
   Coding: 0101000830085900FB00023B880F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E90E6ACB1354FF6E9-803B
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29190001253840049231
   Coding: 2CFFFF
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000208919002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A3DD0608B100EB4-8065
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00021.03.19
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52E8525C054D0B16ED-8007
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0522581830
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D3211E0ACD3E46E20-8069
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0525442080
   Coding: 020111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038923401373
   Coding: 003E13200000040000000000
   Shop #: WSC 01383 790 50316
   VCID: 4FEE5B28167F66FEC2-801B
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000004066896
   Coding: 011000
   Part No SW: 5QN 909 144 B    HW: 5QN 909 144 A
   Coding: 930A0000
   ROD: EV_SteerAssisMQB_015.rod
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD05QU22
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E1026AC71B50FF6A9-807B
   Component: FCM MQB Low   002 0345
   Serial number: 23081900840006
   Coding: 000000050900210A07110F01030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 352209C094E33C2EE8-8061
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038924501558
   VCID: 4ED0462C11756FF6C9-801B
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000004071445
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027310020000000041220002001808001F0503F401200500C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 332637D89A97221EC6-8067
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  254 8130
   Serial number: VWZ6ZMW2625263
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Component: OCULowMQBUS   009 0570
   ROD: EV_OCULowMQB.rod
   VCID: 43C66718CA37929E56-8017
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 09071915P20826
   Coding: 000307000002020100221354C150490084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40CC6814DB2189864B-8015
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 190614203113
   VCID: 322832DC658D2B16CD-8067
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393A05F0B8FBD84E0C-806D
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 01:44, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
My 09 Central Electronics Adaptations:
[TABLE="width: 435"]
[TR]
[TD="width: 435, colspan: 5"];SW:5Q0-937-087-BA   HW:5Q0-937-087-BA ---  Cent. Elect. --- SA: 31347[/TD]
[/TR]
[TR]
[TD];Component:BCM PQ37BOSCH 036 0265[/TD]
[TD="colspan: 4"] Coding:000000000000000000000000000000000000000000000000000000000000[/TD]
[/TR]
[TR]
[TD];EV_BodyContrModul1UDSBosc[/TD]
[TD="align: right"]19001[/TD]
[TD="colspan: 2"]EV_BCMBOSCH_019.rod[/TD]
[TD][/TD]
[/TR]
[TR]
[TD];Saturday[/TD]
[TD="align: right"]18[/TD]
[TD]July[/TD]
[TD="align: right"]2020[/TD]
[TD]19:48:36:41546[/TD]
[/TR]
[TR]
[TD="colspan: 5"];VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0[/TD]
[/TR]
[TR]
[TD="colspan: 3"];VCID: 7BB6DFF8F2472A5E5E-802F[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG99061-Production mode-Access control[/TD]
[TD]not active[/TD]
[TD="align: right"]3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG115730-Production mode-Exterior lighting[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG112304-Production mode-Heckwischer[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG98647-Production mode-Interior lighting[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG115729-Production mode-Scheinwerferreinigung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00001-ENG115731-Production mode-Virtuel_pedal[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00002-Transport mode[/TD]
[TD]active[/TD]
[TD="align: right"]1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE00820-Activating and deactivating all development messages[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE01550-Service position[/TD]
[TD]170.494336 ∞[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02152-Characteristics in production mode[/TD]
[TD]2000 ms[/TD]
[TD="align: right"]4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking[/TD]
[TD]Decelerate[/TD]
[TD="align: right"]10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn[/TD]
[TD]short[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02332-Deactivate production mode[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen[/TD]
[TD]not active[/TD]
[TD="align: right"]8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1[/TD]
[TD]15 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2[/TD]
[TD]16 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG112304-Rear Window Wiper-Heckwischer[/TD]
[TD]logikgesteuert[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1[/TD]
[TD]5 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2[/TD]
[TD]3 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik[/TD]
[TD]7 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall[/TD]
[TD]7 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer[/TD]
[TD]Keine_Spannungsanforderung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-IDE04231-static AFS light-Steering wheel angle: offset[/TD]
[TD]0.3 ∞[/TD]
[TD="align: right"]16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit[/TD]
[TD]50.0 %/s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt[/TD]
[TD]both sides[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116675-static AFS light-Lower speed threshold[/TD]
[TD]0.0 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116682-static AFS light-Maximaltemperatur[/TD]
[TD]100.0 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116679-static AFS light-obere Grenztemperatur[/TD]
[TD]95.0 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel[/TD]
[TD]120 ∞[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116680-static AFS light-untere Grenztemperatur[/TD]
[TD]80.0 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel[/TD]
[TD]80 ∞[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116676-static AFS light-Upper speed threshold[/TD]
[TD]40.0 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG116674-static AFS light-Vorschrift[/TD]
[TD]ECE R119[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht[/TD]
[TD]15 min[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE03787-Activate left/right hand drive switch-over[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-IDE01446-Window heater-Running time of heated front window[/TD]
[TD]240 s[/TD]
[TD="align: right"]11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung[/TD]
[TD]35.0 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung[/TD]
[TD]35.0 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer[/TD]
[TD]0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt[/TD]
[TD]not installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG126845-Window heater-FSH Automatik[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert[/TD]
[TD]320 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG141955-Window heater-heizbare Heckscheibe[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv[/TD]
[TD]-2.0 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG141962-Window heater-Waschduesenheizung[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04927-ENG154810-Window heater-window heating front activation time pause[/TD]
[TD]320 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-MAS01577-Anti-theft device-Parking heater[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115864-Anti-theft device-Alarmsignal[/TD]
[TD]frequency modulated[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick[/TD]
[TD]not_active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI[/TD]
[TD]not_active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115812-Anti-theft device-DWA Camper Modus[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG142249-Anti-theft device-OBD Alarm[/TD]
[TD]not_active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm[/TD]
[TD]activ[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl[/TD]
[TD]10 Alarme[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG142008-Anti-theft device-tilt_sensor[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm[/TD]
[TD]keine verzoegerung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05143-MAS02985-Writing parameter-Value[/TD]
[TD="align: right"]130[/TD]
[TD="align: right"]5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05143-MAS04381-Writing parameter-Parameter address[/TD]
[TD]FE 00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05144-Read parameter address[/TD]
[TD]FE 00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE05145-Light configuration[/TD]
[TD]00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 05 36 00 1A 0B 10 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 10 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 38 00 22 12 00 7F 00 00 00 00 00 00 00 00 00 06 42 00 23 13 00 7F 00 00 00 00 00 00 00 00 00[/TD]
[TD="align: right"]224[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler[/TD]
[TD="align: right"]30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN[/TD]
[TD]Heizmatten am BCM[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss[/TD]
[TD]1 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss[/TD]
[TD]0.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle[/TD]
[TD]22.50 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle[/TD]
[TD]21.50 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle[/TD]
[TD]22.50 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle[/TD]
[TD]21.50 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle[/TD]
[TD]38.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle[/TD]
[TD]36.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle[/TD]
[TD]38.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle[/TD]
[TD]36.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle[/TD]
[TD]56.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle[/TD]
[TD]54.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle[/TD]
[TD]56.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle[/TD]
[TD]54.00 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75[/TD]
[TD]15.7 V[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06425-Roller test bench mode: functional[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-MAS13125-Button in center console-Function of button 1[/TD]
[TD]not coded/not installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-MAS13129-Button in center console-Function of button 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-MAS13132-Button in center console-Function of button 3[/TD]
[TD]Driving program[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-MAS13135-Button in center console-Function of button 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED[/TD]
[TD]LED installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG115720-A/C heater function via remote control-Remote Start[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07356-Position during interval mode[/TD]
[TD]31.494474 ∞[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs[/TD]
[TD]abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit[/TD]
[TD="align: right"]6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit[/TD]
[TD]30 min[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen[/TD]
[TD]active[/TD]
[TD="align: right"]9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG141956-Assistance light functions-Humidity sensor[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit[/TD]
[TD]normal[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor[/TD]
[TD]LIN_REGEN_LICHT_SENSOR[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE08786-ENG124476-Assistance light functions-Sunlight Sensor[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual[/TD]
[TD="align: right"]7[/TD]
[TD="align: right"]19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit[/TD]
[TD]0.10 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach[/TD]
[TD="class: xl63, align: right"]80%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum[/TD]
[TD="class: xl63, align: right"]50%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG98648-Int. light: 2nd generation-Interior light[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG114629-Interior light: light configuration-Foot well lighting[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne[/TD]
[TD="class: xl63, align: right"]30%[/TD]
[TD="align: right"]17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz[/TD]
[TD="class: xl63, align: right"]25%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne[/TD]
[TD="class: xl63, align: right"]58%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz[/TD]
[TD="class: xl63, align: right"]53%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne[/TD]
[TD="class: xl63, align: right"]85%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10298-Alternating park position 1[/TD]
[TD]7.494498 ∞[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE10299-Alternating park position 2[/TD]
[TD]29.494476 ∞[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit[/TD]
[TD="align: right"]256[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum[/TD]
[TD="align: right"]0.2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer[/TD]
[TD="align: right"]0.6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit[/TD]
[TD="class: xl63, align: right"]100%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum[/TD]
[TD="class: xl63, align: right"]70%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren[/TD]
[TD="class: xl63, align: right"]96%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum[/TD]
[TD="class: xl63, align: right"]0%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum[/TD]
[TD="class: xl63, align: right"]127%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit[/TD]
[TD="class: xl63, align: right"]126%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum[/TD]
[TD]2.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren[/TD]
[TD]0.5 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG141948-Keyless access and start authorization-Kessy[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG246971-Keyless access and start authorization-Kessy Bewegungs¸berwachungIDGeber[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor[/TD]
[TD]Not available[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271875-Identification of sub-bus participant-Light switch[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG116830-Energy management-Energy_Management_Adaptation[/TD]
[TD]Energy management active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG142256-Energy management-Hochvoltfahrzeug[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG141950-Energy management-Hybrid vehicle[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG141978-Energy management-Recuperation[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS01490-ENG142037-Energy management-Zweitbatterie[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS05055-lower turn position[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS05056-upper turn position[/TD]
[TD]170.494336 ∞[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze[/TD]
[TD]1200 lx[/TD]
[TD="align: right"]24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze[/TD]
[TD]2200 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO[/TD]
[TD]600 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten[/TD]
[TD]1200 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten[/TD]
[TD]2200 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell[/TD]
[TD]2000 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity[/TD]
[TD]frueh[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung[/TD]
[TD]0 mV[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung[/TD]
[TD]0 mV[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC[/TD]
[TD]00 00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC[/TD]
[TD]First_dtc[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren[/TD]
[TD]active[/TD]
[TD="align: right"]4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler[/TD]
[TD]not installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11[/TD]
[TD="align: right"]60[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1[/TD]
[TD="align: right"]1[/TD]
[TD="align: right"]30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9[/TD]
[TD]door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente[/TD]
[TD]Keine_Spannungsanforderung[/TD]
[TD="align: right"]23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122212-Auflenlicht_Blinker-ABBA_Blinken[/TD]
[TD]not active[/TD]
[TD="align: right"]10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG133379-Auflenlicht_Blinker-Abbruch Komfortblinken[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG116590-Auflenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger[/TD]
[TD]separte[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG121966-Auflenlicht_Blinker-Crash flashing[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122207-Auflenlicht_Blinker-DWA_Alarm_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122206-Auflenlicht_Blinker-DWA_Schaerfungsquittung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG142194-Auflenlicht_Blinker-dynamisch_blinken_10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG142195-Auflenlicht_Blinker-Dynamische_Blink_Delay[/TD]
[TD]50 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG126819-Auflenlicht_Blinker-Emergency_alert_blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG154601-Auflenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen[/TD]
[TD]Warnblinke_zulaessig[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG115774-Auflenlicht_Blinker-Komfortblinken[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG116587-Auflenlicht_Blinker-Komfortblinken Blinkzyklen[/TD]
[TD="align: right"]3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122208-Auflenlicht_Blinker-Multi_kollisions_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122209-Auflenlicht_Blinker-Notwarn_blinken_NBA_Phase_2[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG121967-Auflenlicht_Blinker-Panic flashing[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG154711-Auflenlicht_Blinker-PreCrash_RECAS[/TD]
[TD]PreCrash_passiv[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122211-Auflenlicht_Blinker-Richtungs_blinken_links[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122210-Auflenlicht_Blinker-Richtungs_blinken_rechts[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122201-Auflenlicht_Blinker-Schluessel_Anlern_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG121968-Auflenlicht_Blinker-Taxi alarm flashing[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG126629-Auflenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122202-Auflenlicht_Blinker-UGDO_ Anlern_Blinken[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG142029-Auflenlicht_Blinker-Warnblinken_durch_Fahrerassistenz[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG246997-Auflenlicht_Blinker-Warnblinken_TP_max[/TD]
[TD]120 min[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122214-Auflenlicht_Blinker-Warnblinken_Zuendung_AUS[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122213-Auflenlicht_Blinker-Warnblinken_Zuendung_EIN[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122204-Auflenlicht_Blinker-ZV_Blinken_auf[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141649-ENG122203-Auflenlicht_Blinker-ZV_Blinken_zu[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG141986-Auflenlicht_Front-Abblendlicht_Leuchtentyp[/TD]
[TD]H7[/TD]
[TD="align: right"]9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG246962-Auflenlicht_Front-ABL Redundanz Check sperren[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG116705-Auflenlicht_Front-Allwetterlicht Ausschaltgrenze[/TD]
[TD]350 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG116704-Auflenlicht_Front-Allwetterlicht Einschaltgrenze[/TD]
[TD]350 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG115833-Auflenlicht_Front-Fahrlicht bei Tag[/TD]
[TD]Daytime running lights[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG142193-Auflenlicht_Front-Geschwindigkeitsabhaengiges TFL[/TD]
[TD]5 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG115861-Auflenlicht_Front-Lichthupe bei Zuendung aus moeglich[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG115832-Auflenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG142191-Auflenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG142190-Auflenlicht_Front-Signaturlicht_verbaut[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG116592-Auflenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG116594-Auflenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG122184-Auflenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG115734-Auflenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG116593-Auflenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG115733-Auflenlicht_Front-Tagfahrlichtkontrollleuchte[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG142192-Auflenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG116591-Auflenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141647-ENG115860-Auflenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren[/TD]
[TD]limitieren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht[/TD]
[TD]Yes[/TD]
[TD="align: right"]5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit[/TD]
[TD]0 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG142020-Auflenlicht_uebergreifend-All-weather lights[/TD]
[TD="align: right"]18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG133381-Auflenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung[/TD]
[TD]abschaltbar ¸ber Energiemanagement[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG133380-Auflenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG142188-Auflenlicht_uebergreifend-bewusstes Standlicht[/TD]
[TD]Aktive Begrenzung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG246968-Auflenlicht_uebergreifend-CHo_LHo_Nachlauf[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG115656-Auflenlicht_uebergreifend-Coming Home Leuchten[/TD]
[TD]Low beam[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG116601-Auflenlicht_uebergreifend-Coming Home Verbaustatus[/TD]
[TD]automatic[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG116604-Auflenlicht_uebergreifend-Coming-home Einschaltereignis[/TD]
[TD]Driver door[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG130581-Auflenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG126818-Auflenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig[/TD]
[TD]kein_Hinweis[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG137034-Auflenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer[/TD]
[TD]Faktor fuer x5 Minuten[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG154619-Auflenlicht_uebergreifend-Fernlicht_LH[/TD]
[TD]Sollspannungsanforderung 13.5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG154177-Auflenlicht_uebergreifend-Fog light[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG116608-Auflenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung[/TD]
[TD]46400 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG116605-Auflenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung[/TD]
[TD]12 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG142189-Auflenlicht_uebergreifend-HVLM_Ladezustandsanzeige[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG115858-Auflenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht[/TD]
[TD]integriert in Suchbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG142185-Auflenlicht_uebergreifend-LCM_blinker[/TD]
[TD]false[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG141992-Auflenlicht_uebergreifend-LDS_mit_AFL[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG141991-Auflenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG141990-Auflenlicht_uebergreifend-LDS_mit_Nebellicht[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG141993-Auflenlicht_uebergreifend-LDS_mit_Standlichtstellung[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG115657-Auflenlicht_uebergreifend-Leaving-Home Verbausstatus[/TD]
[TD]Enabled[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG141989-Auflenlicht_uebergreifend-Lichtdrehschalter (LDS)[/TD]
[TD]discrete[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG115862-Auflenlicht_uebergreifend-Lichtwarnungsverhalten[/TD]
[TD]klemmenabhaengig[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG142034-Auflenlicht_uebergreifend-Light_Control_Module[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG98354-Auflenlicht_uebergreifend-Low beam[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG115863-Auflenlicht_uebergreifend-Menueeinstellung CHO LHO[/TD]
[TD]Menuesteuerung Zeit aktivieren[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG116603-Auflenlicht_uebergreifend-Menueeinstellung Cominghome[/TD]
[TD]10 seconds[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG116607-Auflenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP[/TD]
[TD]10 seconds[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG116602-Auflenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG116606-Auflenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG115859-Auflenlicht_uebergreifend-Parklicht ueber LSS aktiviert[/TD]
[TD]One-sided[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG126816-Auflenlicht_uebergreifend-Standlicht aus[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG115829-Auflenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG133383-Auflenlicht_uebergreifend-Standlicht-Verf¸gbarkeit[/TD]
[TD]6 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG154174-Auflenlicht_uebergreifend-Turn signal[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141656-ENG126817-Auflenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG98399-debug_light_function-Activation[/TD]
[TD="align: right"]11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG101417-debug_light_function-Adresse[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG126820-debug_light_function-Bitmask[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG126821-debug_light_function-Divisor[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG98827-debug_light_function-Offset[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126647-ENG126822-debug_light_function-Polaritaet[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246955-ENG246967-digital_key-central_locking_digital_key_general[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0[/TD]
[TD="class: xl64, align: right"]0.00%[/TD]
[TD="align: right"]6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1[/TD]
[TD="class: xl64, align: right"]50.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2[/TD]
[TD="class: xl64, align: right"]100.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP[/TD]
[TD]present[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung[/TD]
[TD]AFS: FLA: Fernlicht ueber AFS[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent[/TD]
[TD]Not Present[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung[/TD]
[TD]present[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung[/TD]
[TD]800 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG141966-Front_wiper-Frontwischertyp[/TD]
[TD]LIN[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG115771-Front_wiper-Regensensor aktivieren[/TD]
[TD]Deactivating[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay[/TD]
[TD]300 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG99457-ENG117394-Head area heater-blower_speed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG99457-ENG98971-Head area heater-Temperature[/TD]
[TD="align: right"]-2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid[/TD]
[TD]installed[/TD]
[TD="align: right"]8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-MAS00213-HW_Verbau-Insufficient coolant[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-MAS00214-HW_Verbau-Brake pad wear[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG142026-HW_Verbau-Druckklappe[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG142036-HW_Verbau-PTC Zuheizer[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4[/TD]
[TD="class: xl64, align: right"]83.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5[/TD]
[TD="class: xl64, align: right"]67.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7[/TD]
[TD="align: right"]33[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8[/TD]
[TD="class: xl64, align: right"]17.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0[/TD]
[TD="class: xl64, align: right"]58.50%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4[/TD]
[TD="class: xl64, align: right"]54.50%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5[/TD]
[TD="class: xl64, align: right"]49.50%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6[/TD]
[TD="class: xl64, align: right"]46.50%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7[/TD]
[TD="class: xl64, align: right"]35.50%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8[/TD]
[TD="class: xl64, align: right"]31.50%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9[/TD]
[TD="class: xl64, align: right"]20.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0[/TD]
[TD]maximize[/TD]
[TD="align: right"]16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15[/TD]
[TD="align: right"]100[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15[/TD]
[TD="align: right"]63[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15[/TD]
[TD]41 - LED Kleinleistung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15[/TD]
[TD]Warnblinktaster_Suchbeleuchtung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12[/TD]
[TD="align: right"]127[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12[/TD]
[TD="align: right"]22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12[/TD]
[TD="align: right"]38[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12[/TD]
[TD]6 - LED Lichtmodul[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12[/TD]
[TD]Nebellicht links[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13[/TD]
[TD="align: right"]42[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13[/TD]
[TD]Nebellicht rechts[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16[/TD]
[TD]43 - allgemeine LED[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16[/TD]
[TD]Klemme 30G[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17[/TD]
[TD]Klemme 30G[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20[/TD]
[TD]minimize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20[/TD]
[TD]3D[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20[/TD]
[TD="align: right"]13[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20[/TD]
[TD]35 - kombinierte LED Blink-Bremsleuchten[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20[/TD]
[TD]Brake light[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21[/TD]
[TD]minimize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21[/TD]
[TD]3E[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22[/TD]
[TD]2C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22[/TD]
[TD="align: right"]29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22[/TD]
[TD]Quittierungsfunktion 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23[/TD]
[TD]0A[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23[/TD]
[TD]Blinken links Hellphase[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24[/TD]
[TD]2A[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24[/TD]
[TD]1A[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24[/TD]
[TD]Blinken rechts Hellphase[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24[/TD]
[TD]Parking light right[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25[/TD]
[TD="align: right"]30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25[/TD]
[TD="align: right"]28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25[/TD]
[TD]Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26[/TD]
[TD="align: right"]54[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27[/TD]
[TD="align: right"]53[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28[/TD]
[TD="align: right"]31[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28[/TD]
[TD]0B[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28[/TD]
[TD]only_if_closed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28[/TD]
[TD]Nebelschlusslicht wenn kein Anhaenger gesteckt[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29[/TD]
[TD="align: right"]32[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29[/TD]
[TD]1B[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29[/TD]
[TD]Rueckfahrlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2[/TD]
[TD]Parklicht links (beidseitiges Parklicht aktiviert li & re)[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30[/TD]
[TD="align: right"]89[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30[/TD]
[TD]36 - LED Kleinleistung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30[/TD]
[TD]Footwell light[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3[/TD]
[TD]not active[/TD]
[TD="align: right"]16[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6[/TD]
[TD="align: right"]0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6[/TD]
[TD]1A[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6[/TD]
[TD="align: right"]36[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6[/TD]
[TD]5 - LED Abblendlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6[/TD]
[TD]Abblendlicht links[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6[/TD]
[TD]Lichthupe bei bereits aktivem Abblendlicht oder bereits aktivem Dauerfahrlicht[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7[/TD]
[TD]1B[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7[/TD]
[TD="align: right"]40[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7[/TD]
[TD]Abblendlicht rechts[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8[/TD]
[TD="align: right"]127[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8[/TD]
[TD]4B[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8[/TD]
[TD="align: right"]44[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8[/TD]
[TD]Versorgungsbedarf der LCM Module[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9[/TD]
[TD]maximize[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9[/TD]
[TD="align: right"]49[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9[/TD]
[TD]3A[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141661-Leuchtenkonfiguration_Aussenlich_Heck[/TD]
[TD]00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 00 7F 00 00 80 00 00 00 00 00 00 23 23 00 3E 18 00 7F 00 00 80 00 00 00 00 00 00 2B 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 02 00 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 04 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 53 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 1A 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00[/TD]
[TD="align: right"]192[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141662-Leuchtenkonfiguration_Sonstiges[/TD]
[TD]2B 00 00 00 25 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 00 25 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00[/TD]
[TD="align: right"]128[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR[/TD]
[TD]1-Sensor_LWR[/TD]
[TD="align: right"]62[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze[/TD]
[TD="class: xl64, align: right"]90.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze[/TD]
[TD="class: xl64, align: right"]10.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung[/TD]
[TD]-114.3 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz[/TD]
[TD="class: xl63, align: right"]15%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe[/TD]
[TD]10.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1[/TD]
[TD]-8.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2[/TD]
[TD]-8.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3[/TD]
[TD]-8.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1[/TD]
[TD]-8.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2[/TD]
[TD]-8.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3[/TD]
[TD]-8.00 mm/%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante[/TD]
[TD]Variante_1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR[/TD]
[TD="class: xl64, align: right"]0.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf[/TD]
[TD]0.00 Hz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung[/TD]
[TD]normal[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal[/TD]
[TD]Negative[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe[/TD]
[TD]0 mm[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle[/TD]
[TD="class: xl64, align: right"]95.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle[/TD]
[TD="class: xl64, align: right"]2.50%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr[/TD]
[TD]0 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr[/TD]
[TD]100 Hz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung[/TD]
[TD]0.00 Hz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte[/TD]
[TD]CAN_Daempferregelung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed[/TD]
[TD]not installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese[/TD]
[TD="class: xl64, align: right"]20.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad[/TD]
[TD]0.0 %/s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht[/TD]
[TD="class: xl64, align: right"]-100.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1[/TD]
[TD]2.0 s[/TD]
[TD="align: right"]7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang[/TD]
[TD]10 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS[/TD]
[TD]Nicht_verbaut[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze[/TD]
[TD]100 m[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246981-Lichttaster-Lichttastermodul[/TD]
[TD]lds[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config[/TD]
[TD="align: right"]1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle[/TD]
[TD]30 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabh‰ngig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabh‰ngig_Parameter[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabh‰ngig[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabh‰ngig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabh‰ngig_Parameter[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabh‰ngig[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Z¸ndungsabh‰ngig[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen[/TD]
[TD]40 ms[/TD]
[TD="align: right"]27[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit[/TD]
[TD]100 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt[/TD]
[TD]10 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v[/TD]
[TD]1 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen[/TD]
[TD]500 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i[/TD]
[TD="align: right"]0.5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset[/TD]
[TD]5 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p[/TD]
[TD="class: xl64, align: right"]13.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh[/TD]
[TD]110 W[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh[/TD]
[TD]25 Hz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0[/TD]
[TD]39 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1[/TD]
[TD]43 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2[/TD]
[TD]47 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus[/TD]
[TD]50 ∞C[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung[/TD]
[TD]60 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh[/TD]
[TD]30 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0[/TD]
[TD="align: right"]12[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1[/TD]
[TD="class: xl64, align: right"]5.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2[/TD]
[TD="class: xl64, align: right"]50.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3[/TD]
[TD="class: xl64, align: right"]75.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4[/TD]
[TD="align: right"]110[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5[/TD]
[TD="align: right"]126.5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1[/TD]
[TD="class: xl64, align: right"]6.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2[/TD]
[TD="class: xl64, align: right"]16.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3[/TD]
[TD="class: xl64, align: right"]30.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4[/TD]
[TD="class: xl64, align: right"]60.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5[/TD]
[TD="class: xl64, align: right"]100.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0[/TD]
[TD="class: xl64, align: right"]-5.00%[/TD]
[TD="align: right"]20[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0[/TD]
[TD="align: right"]-5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG141954-Networking-A/C electronics[/TD]
[TD]installed[/TD]
[TD="align: right"]8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG141974-Networking-Bremsen_Steuergeraet[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG141953-Networking-Getriebesteuergeraet[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG99457-Networking-Head area heater[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG122979-ENG141969-Networking-UGDO[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG142044-OCU-DWA_push[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG246970-OCU-IAA -Nutzer_management[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-OCU-[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG142261-OCU-Remote HuF Abbruch[/TD]
[TD]20 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz[/TD]
[TD]3 Hz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1[/TD]
[TD]80 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG124714-ENG125657-OCU-Remote_Unlock_Lock[/TD]
[TD]Via ZV-Absicherung Light[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten[/TD]
[TD="align: right"]4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG126848-Personalization-Personalisierung_aktiv[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion[/TD]
[TD]profiles_active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG142030-Personalization-Profil_Variante[/TD]
[TD]Konto (v. 1.x)[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-MAS01065-Querschnitts_funktionen-Brand[/TD]
[TD]VW[/TD]
[TD="align: right"]5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus[/TD]
[TD]Pin A31[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG154685-Querschnitts_funktionen-Hupe[/TD]
[TD]Sollspannungsanforderung 13.5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme[/TD]
[TD]not_installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment[/TD]
[TD]Left[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141646-ENG141965-Querschnitts_funktionen-Traffic side[/TD]
[TD]Right[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung[/TD]
[TD="align: right"]10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG115729-ENG154424-Scheinwerferreinigung-Waschen[/TD]
[TD]Keine_Spannungsanforderung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss[/TD]
[TD]200 ms[/TD]
[TD="align: right"]48[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung[/TD]
[TD]1000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus[/TD]
[TD]5000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein[/TD]
[TD]300 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus[/TD]
[TD]5000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein[/TD]
[TD]300 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus[/TD]
[TD]5000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein[/TD]
[TD]300 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung[/TD]
[TD]90000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung[/TD]
[TD]90000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung[/TD]
[TD]1000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus[/TD]
[TD]5000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein[/TD]
[TD]300 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus[/TD]
[TD]5000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein[/TD]
[TD]60 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen[/TD]
[TD]20 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle[/TD]
[TD]16.5 V[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr[/TD]
[TD]15.5 V[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle[/TD]
[TD]8.5 V[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr[/TD]
[TD]8.5 V[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein[/TD]
[TD]0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung[/TD]
[TD]1000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein[/TD]
[TD]0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus[/TD]
[TD]5000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein[/TD]
[TD]300 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus[/TD]
[TD]5000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein[/TD]
[TD]300 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus[/TD]
[TD]5000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein[/TD]
[TD]300 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker[/TD]
[TD]MFG[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116588-Sonderfunktionen-[/TD]
[TD]not enabled[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus[/TD]
[TD]by convenience operation via remote control key[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt[/TD]
[TD="align: right"]250[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel[/TD]
[TD]10 km/h[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter[/TD]
[TD]LIN[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_f¸r_P_plausibel[/TD]
[TD]1000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen[/TD]
[TD]40 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0[/TD]
[TD]0.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1[/TD]
[TD]8.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2[/TD]
[TD]50.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3[/TD]
[TD]80.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4[/TD]
[TD]100.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0[/TD]
[TD="align: right"]6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3[/TD]
[TD="align: right"]50[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4[/TD]
[TD="align: right"]100[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0[/TD]
[TD]0.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1[/TD]
[TD]8.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2[/TD]
[TD]50.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3[/TD]
[TD]80.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4[/TD]
[TD]100.0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0[/TD]
[TD]0 ms[/TD]
[TD="align: right"]22[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2[/TD]
[TD]400 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3[/TD]
[TD]600 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4[/TD]
[TD]800 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5[/TD]
[TD]1000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6[/TD]
[TD]1200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7[/TD]
[TD]1400 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8[/TD]
[TD]1600 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9[/TD]
[TD]1800 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3[/TD]
[TD="class: xl64, align: right"]80.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4[/TD]
[TD="class: xl64, align: right"]40.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8[/TD]
[TD="class: xl64, align: right"]3.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9[/TD]
[TD="class: xl64, align: right"]1.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM[/TD]
[TD]0.00 s[/TD]
[TD="align: right"]21[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung[/TD]
[TD]Potentiometer[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen[/TD]
[TD]20.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen[/TD]
[TD]3.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten[/TD]
[TD]not_active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS[/TD]
[TD="align: right"]2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM[/TD]
[TD]0.00 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert[/TD]
[TD="class: xl63, align: right"]100%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl[/TD]
[TD]Fotosensor_Kombi[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung[/TD]
[TD]Always active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor[/TD]
[TD="align: right"]0.1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3[/TD]
[TD="align: right"]200[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4[/TD]
[TD="align: right"]253[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2[/TD]
[TD]100 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4[/TD]
[TD="align: right"]500[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1[/TD]
[TD]200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2[/TD]
[TD]400 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3[/TD]
[TD]600 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4[/TD]
[TD]800 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5[/TD]
[TD]1000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6[/TD]
[TD]1200 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7[/TD]
[TD]1400 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8[/TD]
[TD]1600 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9[/TD]
[TD]1800 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4[/TD]
[TD="class: xl64, align: right"]11.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5[/TD]
[TD="class: xl64, align: right"]22.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3[/TD]
[TD="align: right"]150[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4[/TD]
[TD="align: right"]220[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2[/TD]
[TD]200 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3[/TD]
[TD]300 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2[/TD]
[TD]220 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3[/TD]
[TD]300 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0[/TD]
[TD="class: xl64, align: right"]2.00%[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1[/TD]
[TD]8 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2[/TD]
[TD]50 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0[/TD]
[TD]0 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1[/TD]
[TD]10 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2[/TD]
[TD]100 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3[/TD]
[TD]500 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4[/TD]
[TD]800 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5[/TD]
[TD]1020 lx[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2[/TD]
[TD="align: right"]80[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3[/TD]
[TD="align: right"]180[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4[/TD]
[TD="align: right"]300[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0[/TD]
[TD]0 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1[/TD]
[TD]2000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2[/TD]
[TD]3000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3[/TD]
[TD]4000 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4[/TD]
[TD]5100 ms[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2[/TD]
[TD="align: right"]15[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141632-ENG116646-Sunroof-SAD Komfort schliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen[/TD]
[TD]tilting[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule[/TD]
[TD]LIN[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck[/TD]
[TD="align: right"]9[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schlieflen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden[/TD]
[TD]Always[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schlieflen via Funkfernbedienung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schlieflen via Kessy[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schlieflen via Schlieflzylinder[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version[/TD]
[TD]Version_1_2[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6[/TD]
[TD]00 00[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG115755-ZV allgemein-Notschlieflfunktion[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG141957-ZV allgemein-Radio freq.[/TD]
[TD]315MHz[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG141958-ZV allgemein-Tankschloss[/TD]
[TD]Bidirectional[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum[/TD]
[TD]Freigabe_Softtouch[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung[/TD]
[TD]Einzeltuerentriegelung[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion[/TD]
[TD]installed[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck[/TD]
[TD]active[/TD]
[TD="align: right"]3[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141654-ENG116706-ZV Autolock-Autounlock NAR[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock[/TD]
[TD]adjustable[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung[/TD]
[TD]Contact control[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster[/TD]
[TD]0.0 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp[/TD]
[TD]1 or 2 notch rear actuator[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-IDE02021-ZV Komfort-Comfort closing[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-IDE02022-ZV Komfort-Comfort opening[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit[/TD]
[TD]600 s[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG115670-ZV Komfort-Komfortbedienung global[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar[/TD]
[TD]adjustable[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG246991-ZV Komfort-pa_Two_Keys[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG125656-ZV Komfort-Regenschliessen_art[/TD]
[TD]Permanent[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus[/TD]
[TD]active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG141999-ZV T¸rkonfiguration-Fond_Schloss[/TD]
[TD]2-Motorenschloesser[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG142043-ZV T¸rkonfiguration-HFT_Invertierung_Drehfallensignal[/TD]
[TD]nicht invertiert[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG142039-ZV T¸rkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG142038-ZV T¸rkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG142001-ZV T¸rkonfiguration-Schiebetuer_links[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG142002-ZV T¸rkonfiguration-Schiebetuer_rechts[/TD]
[TD]No[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG142041-ZV T¸rkonfiguration-Schiebetueren_Crafter[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG142244-ZV T¸rkonfiguration-Schiebetuerschloss_direkt_BCM[/TD]
[TD]Driver side[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG116631-ZV T¸rkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe[/TD]
[TD]not active[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG142000-ZV T¸rkonfiguration-Schlosstyp_NAR[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]ENG141652-ENG141959-ZV T¸rkonfiguration-Viertuerer[/TD]
[TD]Yes[/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD="colspan: 2"]Elapsed Time: 01:59[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
^^^ ^^^ corradokid: Hi
I'm not sure that I really understand your DAP harness changes, but as currently coded in your BCM admap, the ONLY tail-light lamp that operates as SSPL is Leuchte24SL HRA65 - which is on the RHS of the car. Oddly, the equivalent lamp on the LHS is missing the twin Leuchte-command for SSPL.
So, does SSPL work on the RHS tails (it should illuminate the right-side turn-signal light )?
If so, try this to enable SSPL on the LHS:
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 > Parklicht links (beidseitiges Parklicht aktiviert li & re)
And...... just as a favor, please try changing the following channels from their current setting 43 - allgemeine LED to 32 - allgemeine LED bis 12W
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17
then try clearing the BCM DTC - if the error remains, revert the values back
corradokid
CA, USA
C?ID=32540
Hi Don,
Thank you for the suggestions, when I went out to check the SSPL and you are correct - I must have not clicked "Do it" on the last change I intended to make. :facepalm:
Both rear SSPL sides work now, as the full turn signal LED—is this how the SSPL work in Europe with the MK7.5 tail lights or is it the parking light? Maybe this was my confusion thinking it was not working correctly!
This did not change anything for my car. Taillights still worked, error still remained in the BCM, but doesn't seem to be harming anything?
Thank you for helping me with this confusion on my part!
My SSPL working (on solid):
How I thought it should work which made me question the coding :facepalm::
corradokid: Good to read that all is well now!!
As for your question above - I don't know how SSPL works in Europe; we Antipodeans like to think of ourselves as being separate from our kindred folk way up there in the North!! :)
Truth is that the 35 x Leuchte-sets in your BCM can be made to do almost anything (within reason of course and subject to to the limitations of what are fairly rudimentary programming functions). So, with the caveat that your DoT road rules should be a consideration in any decision to change lighting on a NAR model car, you should be able to apply the SSPL functions to whatever light that you choose.
Unfortunately however, the primary impact of installing a cross-wiring harness is to reassign the way that the wiring in the car connects to individual lights. This has the effect of assigning different pins in the BCM to different lights and the consequential result is that the factory allocation of Leutche-set to particular lamp positions changes.
So my database of factory assignment for Leuchte-sets to lamp position is useless in your case!! But, if you are so motivated to experiment and if you tell me what light functions the additional lamps that you want to use for SSPL currently perform, I can make further suggestions
corradokid
CA, USA
C?ID=32540
Don - thank you again for the help! Interesting to learn more about how the BCM works in MK7(.5) cars coming from a MK5 where things are..... simpler.
Thank you for the explanation as well to what the 35 x Leuchte-sets have the potential to do. So for this case, as things are working fine for me now I'll ignore the error in the BCM and enjoy the car =)
I'll also make a backup of coding if VW dealer ever recodes. All those possible BCM adaptations :eek:
