I am going on with a5 2011 facelift conversion, everything is fitted and car is working, but I need to get some coding sorted out.
The DRL's are working ok, park lights are not functioning, I have swapped Bi-xenon lights to facelift Bi-xenon lights, I quess some coding is needed to get rid of the fault codes? What I have understood It is p&p hardware wise?
Friday,17,July,2020,22:50:38:43954
VCDS Version: 20.4.1.0
VIN: WAUZZZ8T7BA054499 License Plate: GJP-186
Mileage: 151030km-93845mi Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 62 72
VIN: WAUZZZ8T7BA054499 Mileage: 151030km-93845miles
Address 01: Engine (CL0MA-CDNC) Labels:* None
Part No SW: 8K2 ABT 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 A009
Revision: E1H19---
Coding: 0114000C240F0160
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TFS8K2907115P A01011
ROD: EV_ECM20AVS.rod
VCID: 73E45A31DA1E9A1E06-8026
5390 - Left Engine Mount Solenoid Valve (N144)
P1573 00 [032] - Open Circuit
Mileage: 151028 km
Engine speed: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 12.698 V
Readiness: 0010 0001
Part No SW: 8K1 927 156 G HW: 0B5 927 156 F
Component: 0B5 20TFSIRdW H05 0008
Revision: --H05--- Serial number: 0000000051
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 3978A819B8F2204E0C-806C
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 094508
VCID: 020A0FF59DA4A3961D-8056
Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Component: BCM2 2.0 H05 0435
Coding: 010400
VCID: 000E05FD93A8B1860B-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0511000000782005
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2310000088819011
Part No SW: 8T1 820 043 AN HW: 8T1 820 043 AN
Component: KLIMA 1 ZONE H08 0180
Revision: A1000000 Serial number: 01120120111652
Coding: 64000000
VCID: 7DF07C09E45ADC6E60-8028
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000908634
Coding: 2600D0914034AF010009000300005D5D001C430802010101000000
Shop #: WSC 06325 123 12345
VCID: 3C76B10DBFC0156617-8068
Subsystem 1 - Part No SW: 8T1 955 119 D HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 150111 H14 0070
Serial number: SWF11010155871
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11230220
Coding: 02532C
Component: E1 - LDS H03 0031
Serial number: 00000000001201111147
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Fault Status: 00101100
Reset counter: 100
Mileage: 151030 km
Date: 2010.01.23
Time: 12:09:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Fault Frequency: 15
Reset counter: 100
Mileage: 151030 km
Date: 2010.01.23
Time: 12:09:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0080
Revision: 11001001 Serial number: 36891101704324
Coding: 00010F
VCID: 4A9AE7D5E514BBD695-801E
Part No SW: 8K0 959 655 L HW: 8K0 959 655 L
Component: AirbagVW-AU10 H44 0610
Serial number: 003JMD08GAW.
Coding: 30513438363030303030554A304C38543053
VCID: 4682D3E5F90C5FB671-8012
Serial number: 6334MSME5A741049D
Serial number: 6344MSME5B50762FP
Serial number: 6352QSME517D371CQ
Serial number: 6362QSME367D342CS
Serial number: 63732SME0E74021C$
Serial number: 63832SME0E744B344
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H06 0156
Revision: 00000000 Serial number: 20100601000029
Coding: 000036
VCID: 4998D8D9E012B0CE9C-801C
Part No SW: 8T0 920 931 L HW: 8T0 920 931 L
Component: KOMBIINSTR. H40 0258
Revision: 00200000 Serial number: EHT737C1C
Coding: 0F07310002000008010000
VCID: 408EC5FDD32871864B-8014
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G11110828B
Coding: 00C303
VCID: 010800F998A2B88E04-8054
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 11001579060111
Part No SW: 8T0 959 793 N HW: 8T0 959 793 B
Component: TSG FA H07 1501
Coding: 011002624000450005
VCID: 54A6F9AD3750FD26FF-8000
Revision: 00002001 Serial number: 0141420778
Coding: 0100062020B900008030043280000000
Part No SW: 8T0 959 792 N HW: 8T0 959 792 B
Component: TSG BF H07 1401
Coding: 011002224000450005
VCID: 53A4FAB1325EFA1EE6-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000699537
VCID: 3466992D9790DD26DF-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Coding: 0000002
VCID: 3978A81970F2204E0C-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H07 0350
Revision: 00000011 Serial number: AUZ5Z6K1523370
Coding: 0500048004040500015B070000
VCID: 4486C9EDC7306DA66F-8010
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010002224000450005
VCID: 56A203A521ACEF3601-8002
Component: TSG HR H06 1401
End-------------------------(Elapsed Time: 03:01)--------------------------
