Saturday,18,July,2020,17:23:58:02918
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 20.4.1.0 (x64) HEX-NET : 0.4508.4
VIN: WAUZBD4G8DY001756 License Plate: AUDI 3900
Mileage: 63029km-39164mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 28 34 36 3B 42 44 46 52
53 55 5F 62 72 8F 90
VIN: WAUZBD4G8DY001756 Mileage: 63029km-39164miles
03- Brakes -- Status: Malfunction 0010
05-/Start Auth. -- Status: Malfunction 0010
Address 01: Engine (J623-CMGB) Labels: None
Part No SW: 03L 906 018 LC HW: 03L 906 018 JL
Component: R4 2.0l TDI H25 9979
Revision: 45H25---
Coding: 0A034012242400080000
Shop #: 00072 002 1048576
Dataset: EV_ECM20TDI01103L906018LC 003013
ROD: EV_ECM20TDI01103L906018LC.rod
VCID: F6A0710849CCDB36A1-80A2
Address 02: Auto Trans (J217) Labels:| 0AW-927-156.clb
Part No SW: 4G2 927 155 D HW: 0AW 927 156 K
Component: 0AW 20TDI H05 0001
Revision: --H05--- Serial number: 0000000229
Shop #: 90001 790 00000
Dataset: EV_TCMVL381 A02432
ROD: EV_TCMVL381.rod
VCID: AE109968F11CA3F629-80FA
Address 03: Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 06A147016085E280DB00
Shop #: 90001 000 00000
Dataset: EV_ESPPremiAU57X 004028
VCID: B620B108094C9B3661-80E2
0702 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[SCL_FA_Niveau_Druck_HL_Error]
Mileage: 63026 km
Date: 2020.07.17
Time: 22:39:58
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 12
Uz: B2
0706 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SCL_FA_Niveau_Druck_VL_Error]
Reset counter: 83
Mileage: 63026 km
Date: 2020.07.17
Time: 22:39:12
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 02
F-Type: 16
Uz: B1
0783 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SCL_LWR_Hoehenwert_HL_Error]
Reset counter: 83
Mileage: 63026 km
Date: 2020.07.17
Time: 22:37:14
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: DF
Uz: 9B
0785 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[SCL_LWR_Hoehenwert_VL_Error]
Reset counter: 83
Mileage: 63026 km
Date: 2020.07.17
Time: 22:37:14
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 02
Bit Info 4: 1F
F-Path: 00
F-Type: E1
Uz: 9B
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CT HW: 4H0 907 064 CT
Component: BCM2 2.0 H33 0433
Coding: 01983046000000000000
VCID: FDB26E2464FA886EE0-80A8
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 83
Mileage: 63029 km
Date: 2020.07.18
Time: 03:15:25
Part No SW: 4G0 820 043 AD HW: 4G0 820 043 AD
Component: KLIMA 4 ZONEN H13 0076
Serial number: 21111200042481
Coding: 3421607889
Dataset: EV_AirCondiComfoUDS 002036
VCID: E18A3254F0424C8EE4-80B4
0272 - No Basic Setting
B2010 00 [009] - -
[Basic settings not carried out]
Reset counter: 83
Mileage: 63026 km
Date: 2020.07.17
Time: 22:36:15
Basic setting of flap motors-Recirculation flap motor: OK
Basic setting of flap motors-Flap motor for indirect ventilation: OK
Basic setting of flap motors-Left side vent motor: OK
Basic setting of flap motors-Right side vent motor: OK
Basic setting of flap motors-Left footwell flap motor: OK
Basic setting of flap motors-Right footwell flap motor: OK
Basic setting of flap motors-Left center vent motor: OK
Basic setting of flap motors-Right center vent motor: OK
Basic setting of flap motors-Defroster flap motor: OK
Basic setting of flap motors-Left temperature flap positioning motor: OK
Basic setting of flap motors-Right temperature flap positioning motor: OK
Basic setting of flap motors-Left rear temperature door motor: OK
Basic setting of flap motors-Right rear temperature door motor: OK
Basic setting of flap motors-Fresh air door motor: OK
Basic setting of flap motors-Left rear air door motor: OK
Basic setting of flap motors-Right rear air door motor: OK
Part No SW: 4H0 907 063 CE HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0130
Revision: 19012002 Serial number: 00000001401693
Coding: 2600201040349FE08981008080001D0CCF9DC30823090201000008606101
VCID: ED925E64349A18EE50-80B8
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120607 H36 0080
Serial number: 120627094827
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20734906
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 S HW: 4G0 941 531 S
Component: E1 - H07 0044
Serial number: 12 11 2012 00001292
Serial number: 47590B56000000000001
Address 0E: Media Player 1 (R41) Labels: Redir Fail!
Part No SW: 8X0 035 110 C HW: 8X0 035 110
Component: CDC-MP3-Pana H41 0490
Revision: 00000008
VCID: AD129E64F41AD8EE10-80F8
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Component: PARKHILFE H01 0083
Revision: 11001001 Serial number: 61061232601523
Coding: 08C105
Dataset: EV_EPHVA18AU57X0000 004009
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: F1AA421420A2FC0E74-80A4
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00B2HM4
Coding: 30323436313230303232554A305234473053
Dataset: EV_AirbaAU10BPAAU64X 001014
Serial number: 3575HRB404V1DEDAB149
Serial number: 3585HRB40671E4S28HE9
Serial number: 3515JRB400I4UN9OJ8MH
Serial number: 3525JRB400I4UN9OP8SU
Serial number: 3554VRB40104UPLEHGNQ
Serial number: 3564VRB400U4UPLET9LG
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20121127000830
Coding: 000034
VCID: B02C8710E328B5063B-80E4
Subsystem 1 - Part No SW: 4G0 951 528 E HW: 4G0 951 528 E
Component: E221 - MFL H09 0010
Part No SW: 4G8 920 932 D HW: 4G8 920 932 D
Component: TDieRdw H79 0515
Revision: 28460208 Serial number: 658201112592024
Coding: 33A609001B410008010000
Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: B02C8710EB28B5063B-80E4
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000763177
Coding: 00C1034400
Dataset: EV_GatewPkoUDS 001018
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000001050627458
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0076
Serial number: 12111200041979
Coding: 22
Dataset: EV_ClimaContrUnitRearUDS 002018
0025 - Motor for Rear Left Upper Body Vent
B10D3 22 [009] - Signal Amplitude Too High
Reset counter: 83
Mileage: 63026 km
Date: 2020.07.17
Time: 22:36:26
Voltage terminal 30: 12.35 V
Outside air temperature: 28.0 °C
Left Rear Upper Body Vent Motor-Act.val.: 11701
Left Rear Upper Body Vent Motor-Specified value: 11701
Left Rear Upper Body Vent Motor-Stop open: 11415
Left Rear Upper Body Vent Motor-Stop closed: 10000
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [008] - Signal Amplitude Too High
Reset counter: 123
Mileage: 63026 km
Date: 2020.07.17
Time: 22:36:37
Voltage terminal 30: 12.18 V
Right Rear Upper Body Vent Motor-Act.val.: 11701
Right Rear Upper Body Vent Motor-Specified value: 11701
Right Rear Upper Body Vent Motor-Stop open: 11407
Right Rear Upper Body Vent Motor-Stop closed: 10000
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H18 0782
Coding: 008000
Dataset: EV_AirSuspe 003024
ROD: EV_AirSuspe_VW51.rod
677384 - Ride-Height System; Plausibility Error
C1046 00 [009] - -
Reset counter: 83
Mileage: 63029 km
Date: 2020.07.18
Time: 05:19:08
677385 - Ride-Height System; Plausibility Error
C1046 00 [008] - -
Reset counter: 123
Mileage: 63026 km
Date: 2020.07.17
Time: 22:39:11
367877 - Ride Height Not Learned
C1044 00 [009] - -
Reset counter: 83
Mileage: 63026 km
Date: 2020.07.17
Time: 22:36:27
115968 - Functional Limitation due to Excessive Temperature
P178E 00 [008] - -
Reset counter: 123
Mileage: 63029 km
Date: 2020.07.17
Time: 22:52:29
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000043974253
Coding: 0078130000002001000001010101102030303232203232
VCID: F7BE7C0C46C6A23EBA-80A2
Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA82020TYQ
Shop #: 00000 000 00000
Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: FA H03 0507
Coding: 011F16005E01628002080002
VCID: C7DECCCC76A612BE0A-8092
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0012048677
Coding: 101000010000
Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: B2288D18E52487164D-80E6
Revision: 00002001 Serial number: 0189234256
Coding: 011A062000B901848020080002010E0F0000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Component: BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO1920236/
Coding: 901F00
Component: BF H03 0506
VCID: C6C0C1C871AC0BB6F1-8092
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: -4 H03 0013
Revision: -------- Serial number: 00000000536882
Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: AB16907CC20ED6DE0E-80FE
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 121203-0002-036
Coding: 11215F101000A200
Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic.rod
VCID: AD129E64FC1AD8EE10-80F8
120589 - Function Restriction due to Faults in Other Modules
U1113 00 [137] - -
[Fehlerhaftes Signal in CAN-Message Fahrwerk_01_FR (0x108)]
Reset counter: 83
Mileage: 63026 km
Date: 2020.07.17
Time: 22:37:31
Part No SW: 4G0 035 182 L HW: 4G0 035 182 J
Component: RMC Cnct Plus H53 0801
Coding: 0101000001E1DB47482B060303010000000000
VCID: AA189578C5F4CFD6F5-80FE
Subsystem 1 - Part No SW: 4G0 919 603 A HW: 4G0 919 603 A
Component: DU6 Basic H43 0084
Serial number: 9464K/0C2564038
Subsystem 2 - Part No SW: 4G2 919 610 B HW: 4G2 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349LKM00081
Component: HL H03 0506
Coding: 010F14004001628002080002
VCID: C9DACAF460B2E4CE1C-809C
Component: HR H03 0506
Component: RGS-VL H13 0080
Coding: 00060000031F030000030800424CDA010000
Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: B12A8214E022BC0E34-80E4
Component: RGS-VR H13 0080
Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
End----------(Elapsed Time: 02:09, VBatt start/end: 14.0V/14.1V)-----------
