Wednesday,15,July,2020,21:19:20:35129
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 20.4.1.0 (x64) HEX-NET : 0.4508.4
VIN: WVWGR2AU2HW033267 License Plate: PLA SCAN
Mileage: 49526km-30774mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 3C 42 44 47 52 55
5F 65 A9
VIN: WVWGR2AU2HW033267 Mileage: 49526km-30774miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: Malfunction 0010
Address 01: Engine (J623-CJXB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00322426050B3004
Shop #: 01357 011 00200
Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259F.rod
VCID: 312AFB8A60A0630EB4-8064
Readiness: 1010 0001
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A H54 4934
Revision: 06354004 Serial number: TFK01605092874
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 53E691023A7C711EE6-8006
P1734 00 [002] - -
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BJ HW: 5Q0 614 517 AG
Component: ESC H62 0636
Revision: 00000000 Serial number: 61696000000969
Coding: 01FA6BA15423196F4779070641CA6980D62A98E2E08296770042508A428803
Shop #: 04033 002 104857
Dataset: EV_Brake1UDSContiMK100IPB 035019
VCID: 7AB81CA6FD56605645-802E
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0487186097
Coding: 1F20000723
Shop #: 28455 002 104857
Dataset: EV_KessyHellaMQBAB 004041
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E30D0B6A1FE8C7639-806A
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to temp low voltage]
Reset counter: 109
Mileage: 49526 km
Date: 2020.07.15
Time: 21:04:16
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition met
Control Module Voltage: 8.161 V
Vehicle speed: 0.0 km/h
Engine speed: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Coding information: coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID sensor 1 authentication: status: No response
ID sensor 2 authentication: status: No response
ID sensor 3 authentication: status: No response
ID sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Part No SW: 5G0 907 044 BL HW: 5G0 907 044 BL
Component: Climatronic H04 1601
Revision: 00001K08
Coding: 0002001420010000100500401210142A
Shop #: 12345 123 61029
Dataset: EV_ACClimaBHBVW37X 006142
VCID: 72A83486A52618160D-8026
Geber für Kنltemitteldruck/Kنltemitteltemperatur:
Air quality sensor:
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: MQBAB H H24 0175
Serial number: 01061617100204
Coding: 00111A46C24122F30FA44090B10C07281800000000000000000000000000
Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 0444625E8F9226A62F-8050
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160604 043 0551
Serial number: 160613064939
Component: 037 0059
Serial number: S4Y16M06D25H01M38S35
Coding: 90A8DD
Serial number: 000000000ZY1615123DN
Serial number: 00000000000066231573
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST0010PXH400000
Coding: 181801
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417618062
Coding: 0371665051
Shop #: 00046 123 12345
Dataset: EV_EPHVA2CAU3700000 009037
VCID: 50EC9E0E0B6A0A06DB-8004
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 30051641350349
Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 383CC6AE83DAB246F3-806C
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1W6ZPL
Dataset: EV_AirbaVW20SMEVW37X 002130
VCID: 41CAAB4AD000F38E44-8014
Subsystem 1 - Part No SW: ----------- HW: 480 002 306 16
Serial number: 35767000000FC2846C12
Subsystem 2 - Part No SW: ----------- HW: 480 002 306 16
Serial number: 35867000000B87F46C17
Subsystem 3 - Part No SW: ----------- HW: 480 401 806 16
Serial number: 35165029F21160C4C2BB
Subsystem 4 - Part No SW: ----------- HW: 480 401 806 16
Serial number: 3526502C521160C0C2B1
Subsystem 5 - Part No SW: ----------- HW: 480 401 806 16
Serial number: 35565029920EDB6092BQ
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 18061604221605
Coding: 0410
Dataset: EV_SMLSKLOMQB 020002
VCID: 075E7552BEA40DBE4A-8052
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 408 3196
Coding: 47AD30983A88000801087B0C1401000000000000
Dataset: EV_DashBoardVDDMQBAB 009058
VCID: 2A18ECE64D7610D675-807E
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW High 128 1265
Revision: -------- Serial number: 0005050239
Coding: 030100043F085900FB00026A9C0F00010001050000000000000000000000
Shop #: 30586 002 1048576
Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 7CB41ABEF7625E6657-8028
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29160001143840096243
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6226310304
Serial number: HA1-00012.05.16
Coding: 0001
Dataset: EV_AllWheelContrHA1VW37X 004013
VCID: 4AD88C66ED3630D695-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000108135004
Coding: 5D00000000000000
Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 3424F29E9FB25626DF-8060
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0391756389
Coding: 02031103
Shop #: 12345 123 12345
Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
VCID: 3C34DABEB7E29E6617-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0390808420
Coding: 020311
Component: FS 020 0041
Serial number: 080616EF802086
Coding: 003E1220D000040000001000
Dataset: EV_DCUDriveSideEWMAXKLO 006003
VCID: 43C6A142CA1CE19E56-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000010546876
Coding: 110000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8307
Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A38DCA6BDD6A05605-806E
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0150
Revision: 00000001 Serial number: VWZ8Z1GBA01ZJ0J
Coding: 12000000008AAA8A000000000000
Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 6D9227FABC18C7EED0-8038
Component: BFS 020 0041
Serial number: 120616EFC04057
Coding: 003E1020DC00040000801000
Dataset: EV_DCUPasseSideEWMAXKLO 006003
VCID: 42C8A446D506E8965D-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000010454152
Coding: 090000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: - H07 0090
Coding: 02A202000B010200
Dataset: EV_HeadlRegulVWAFSMQB 001120
VCID: 40CCAE4EDB0AFA864B-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 5NA 035 045 HW: 5NA 035 045
Component: MU-H-N-RW H51 0981
Serial number: A849L0HB001908
Coding: 0273000C0000000051110002000928211F0207F401200000DF
Shop #: 35332 001 104857
Dataset: EV_MUHig4CGen2AW7 001081
ROD: EV_MUHig4CGen2AW7_VW37.rod
VCID: 75A20F9AD4480F2E28-8020
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H35 9074
Serial number: VWZ6ZFS2960131
Subsystem 2 - Part No SW: V03 959 806 FQ HW: -----------
Component: 2019/2020 --- 0079
Compact Disc Database:
Component: Gracenote2 --- 4011
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000343204
Dataset: EV_RDKBERU30 006001
ROD: EV_RDKBERU30_006_VW37.rod
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160506200106
Dataset: EV_SoundActuaGen2AU64X 003010
VCID: 2F2EFDF2769475FEA2-807A
End----------(Elapsed Time: 01:48, VBatt start/end: 12.3V/12.2V)-----------
