2015 Q7 Blower intermittent/humming noise
PopTopTDi
C?ID=340824
First 115 degree day in AZ and the blower began making a humming (not squealing) noise, air continued to blow cold, but as if the blower was set on the lowest setting. Unplugged the unit, plugged back in, it worked for a few days. Seems to do this more during the hottest part of the day, less at night. I am leaning towards blower replacement, as the fuses all check out ok, and I am getting 11.2V to the blower. Output tests on hvac appeared normal. Could the air quality sensor (g238) be the culprit and not the blower motor?
Note the fault codes in the rear HVAC as well, though that has been operating normally.
Monday,13,July,2020,16:17:23:30156
VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: WA1LMAFE9FD029390   License Plate:
Mileage: 84310km-52387mi   Repair Order:
Chassis Type: FE-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
          55 56 5F 62 69 6C 6D 6F 72
VIN: WA1LMAFE9FD029390   Mileage: 84310km-52387miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 A    HW: 4L0 907 401 E
   Component: 3.0TDI FSA    H23 0014
   Revision: 54H23---    Serial number:
   Coding: 2A2A4012253600050000
   Shop #: WSC 61658 003 1048576
   ASAM Dataset: EV_ECM30TDI0114L2910401A 001015
   ROD: EV_ECM30TDI0114L2910401A.rod
   VCID: 221D16527448ADDB65F-8076
19186 - Fuel Injector #4 (N33)
          P0272 00 [096] - Contribution/Balance Fault
                    Mileage: 83050 km
                    Date: 2020.07.08
                    Time: 13:02:33
                    Engine speed: 2591.50 /min
                    Normed load value: 69.0 %
                    Vehicle speed: 107 km/h
                    Coolant temperature: 99 °C
                    Intake air temperature: 56 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 13.740 V
                    Unlearning counter according OBD: 33
                    selected gear-Bits 0-7: 6
                    Mean injection quantity: 46.17 mg/stroke
                    Engine oil temperature: 110.3 °C
                    Current operating mode_2-Bits 0-7: 0
                    Current operating mode_2-Bits 0-7: 16
                    O2 sensor 1 bank 1: O2 sensor actual value: 1.474
                    O2 sensor 1 bank 2: O2 sensor actual value: 6.986
38161 - Reductant Metering Module
          P20FE 00 [096] - Malfunction
   Part No SW: 0C8 927 750 AQ    HW: 0C8 927 750 AQ
   Component: AL1000 AISIN  002 3399
   Coding: 001378
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7BA30B36B3623C13069-802E
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0099441
   Shop #: WSC 31414 790 00001
   VCID: 3431E00AD23C336B873-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10603902211941
   Coding: 0000135
   Shop #: WSC 52622 001 1048576
   VCID: 25170D4E69E65AE300D-8070
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H05 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Component: FBSAUDIC6 IDG   H01 0053
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AP
   Revision: 00---031    Serial number: 00000000477492
   Coding: 0304A036
   VCID: 25170D4E65E65AE300D-8070
                    Fault Status: 00101110
                    Reset counter: 39
                    Mileage: 81352 km
                    Date: 2020.06.13
                    Time: 14:44:49
                    Temperature: 31.0°C
01273 - Fresh Air Blower (V2)
                    Fault Status: 00101010
                    Fault Frequency: 84
                    Reset counter: 64
                    Mileage: 83007 km
                    Date: 2020.07.08
                    Time: 12:17:59
                    Temperature: 46.0°C
                    (no units): 193.0
   Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
   Component: ILM Fahrer      H31 0400
   Coding: 0139123
   VCID: 6E853262FC9059BBB17-803A
   Subsystem 1 - Part No: 4L1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H18 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55961513100168
   Coding: 25011E
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 3431E00ADEBC336B873-8060
   Part No SW: 4L0 910 655 A    HW: 4L0 959 655 B
   Component: 73 AIRBAG AUDI8RH46 0230
   Revision: 10H46000    Serial number: 0038QDA01EUJ
   Coding: 0014131
   VCID: 2B03FB760F026C93D69-807E
   Subsystem 1 - Part No: 4L0 959 339 C
   Component: BF-Gewichtsens. H05 0040
   Subsystem 2 - Serial number: 6332QSME5D532156F
   Subsystem 3 - Serial number: 6342QSME0657417CI
   Subsystem 4 - Serial number: 6352QSME515445528
   Subsystem 5 - Serial number: 6362QSME5D531864N
   Subsystem 6 - Serial number: 63734SME126B3D688
   Subsystem 7 - Serial number: 63834SME156B0046Z
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 F
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026151110335
   Coding: 0012242
   VCID: 2809047A1EF4478B3BB-807C
   Component: E0221           H03 0040
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 985 Q    HW: 4L0 920 985 Q
   Component: KOMBIINSTR.   H35 0332
   Revision: 00000000    Serial number: X2S014N5G
   Coding: 8BD664040100CF05020205
   VCID: 42DDB6D294888DDB05F-8016
   Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0058
   Revision: MB800038    Serial number: 3800M15512026D
   Coding: 00C303
   VCID: 3FDBBF26E77AE0336A1-806A
   Component: J367-BDM  H07 0125
   Serial number: 32133906494121085308
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 63
                    Mileage: 84143 km
                    Date: 2020.07.12
                    Time: 14:24:00
                    Fault Status: 00101011
                    Reset counter: 63
                    Mileage: 84191 km
                    Date: 2020.07.12
                    Time: 18:57:53
                    Bin. Bits:    11111
                    Voltage: 13.50 V
                    Count: 7
                    Bin. Bits:    11001
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
   Revision: 00---012    Serial number: 00000030388272
   Coding: 0000006
   VCID: 6889447ADE74878BFBB-803C
00003 - Control Module
                    Fault Status: 00100011
                    Fault Frequency: 14
                    Mileage: 75238 km
                    Date: 2020.02.11
                    Time: 15:11:22
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 249
                    Mileage: 81352 km
                    Date: 2020.06.13
                    Time: 14:44:54
   Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
   Component: MEM-FS        H08 0065
   Revision: AA000000    Serial number: 00000147832797
   Coding: 00581B00000011110000
   VCID: 323DE61224283D5B95F-8066
   Part No SW: 4L0 910 566 C    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 009 014-10
   Coding: 0010001
   VCID: 2E05F2623C1019BBF17-807A
   Component: J0770_SWA_Slave_H03 0050
   Subsystem 3 - Serial number: 5F11.05.1500H03000AMS15056ÿ
   Subsystem 4 - Serial number: S15056ÿ
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000151763712
   Coding: 011F57205E40440004
   VCID: 48C9A4FAB2B4A78BDBB-801C
01705 - Selection Switch for Mirror-Adjust (E48)
                    Fault Frequency: 16
                    Reset counter: 56
                    Mileage: 82481 km
                    Date: 2020.06.21
                    Time: 09:15:30
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 82010168090000
   Coding: 3569949
   VCID: 3829D43ACE54D70BABB-806C
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004001    Serial number: 00000000086653
   Coding: 030000
   VCID: 290F017E09FE7E83245-807C
00871 - Bass Speaker Front Right (R23)
                    Fault Status: 00111011
                    Fault Frequency: 13
                    Reset counter: 25
Address 4C: Tire Pressure II        Labels: 4F0-910-274.clb
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H04 0110
   Revision: 00000519    Serial number: 00005191103716
   Coding: 0758477
   VCID: 2313135667D2A4D36E9-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 D
   Component: ILM Beifahrer   H17 0100
   Revision:             Serial number: 00000000237545
   Coding: 0012001
   VCID: 5EE562A20C30C93B017-800A
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000151782716
   VCID: 47CBA7C6BFAAA8F3D21-8012
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 150527-0002-040
   Coding: 1147A71010020400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 42DDB6D294088DDB05F-8016
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156E00F8268308
   Coding: 020007010000000000
   VCID: 2411104A6EDCA3EB173-8070
02983 - Connection between Impedance Converter 1 and Window Antenna
                    Reset counter: 61
                    Mileage: 83776 km
                    Date: 2020.07.11
                    Time: 17:00:50
                    Voltage: 12.50 V
   Part No SW: 4L2 035 746 G    HW: 4L2 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 513F.0F7524625
   Coding: 180200060004E3EF510023456F632003140000000100000000
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130E-0F3362886
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002252451
   Component: CD-Database  5950
                    Reset counter: 63
                    Mileage: 84239 km
                    Date: 2020.07.13
                    Time: 11:14:27
                    Bin. Bits: 00000000 00000010
                    Bin. Bits: 00000000 00000000
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000151795724
   Coding: 010E57204040230004
   VCID: 46D5AAC2B8A0B1FB297-8012
Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
   Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
   Component: Anhaenger     H12 0100
   Revision: 2A001001    Serial number: 00000370210946
   Coding: 0200000000000000
   VCID: 313FE91E212E0643EC5-8064
02539 - Terminal 30 from Control Module
                    Reset counter: 63
                    Mileage: 83135 km
                    Date: 2020.07.08
                    Time: 14:12:37
   Revision: --H09---    Serial number: 525PA8-JA4433O
   Coding: 1021201
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 F
   Component: ValeoHeckdeckel H61 0500
   Revision: --H61001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81386ACA8CABAB9F3-8038
,ó
   Subsystem 3 - Serial number: RD25.05.15--H61001002E0216ÿ
   Subsystem 4 - Serial number: 2E0216ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0151680225----
   Coding: 0003595
   VCID: 26150A4214E051FB097-8072
   Component: J_245_EE16_SKB10H15 0220
   Component: J_394_EE16_SKB10H15 0220
   Component: J_392_EE16_SKB10H15 0220
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000151795723
End----------(Elapsed Time: 02:17, VBatt start/end: 12.1V/12.1V)-----------
NostraJackAss
Is pollen filter or air scoop restricted in box with FOD?
Are you going to fix air quality sensor and change blower motor?
PopTopTDi
C?ID=340824
Yes I was considering changing blower and/or air quality sensor but wasn’t sure to try one before the other.
New cabin air filter, forgive me what is FOD?
PopTopTDi
C?ID=340824
No FOD noted, thanks for that!
Video link to noise :
NostraJackAss
Is blower motor out of balance due to something FOD ingress too it in squirl cage or faulty lubricant in bearing run out?
PopTopTDi
C?ID=340824
Don’t see any signs of FOD, no signs of damage to blades. Took motor out and tested it, blows without noise or issues, if it is out of balance it is undetectable to me.
