speed cruise
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
I have got skoda octavia with the ability of spped cruise control ( by the left signals arm )
one of the Electicion tried to adjust the day light by the wiper arm..then the speed cruise control dosent work any time
any help
Regards
Thursday,19,February,2015,13:43:18:25282
VCDS Version: 14.10.0.0
Data version: 20141022
Dealer/Shop Name: Ferwana Workshop Bros.
Workshop Code: 123 12345 023456
VIN: TMBCS61Z4AC021036   License Plate:
Mileage: 194890km-121099mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56
VIN: TMBCS61Z4AC021036   Mileage: 194890km-121099miles
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 021 TB    HW: 03G 906 021 AN
   Component: R4 1,9l EDC G000SG  2047
   Revision: --H11---    Serial number:
   Coding: 0000071
   Shop #: WSC 31414 790 00001
   VCID: 72E1BE8A6DCDE3B169F-8027
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 113B201C092400FB880B04E7901F0041300000
   VCID: 78F58CA2CBB189E157B-802D
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 M    HW: 3T0 820 047 M
   Component: Climatic      150 0303
   Revision: 00006001
   Coding: 0000000002
   ROD: EV_ClimaBasis_SK35.rod
   VCID: 397349A6B83B50E9685-806C
9477489 - Motor for Air Distribution Flap
          B109D 71 [008] - Actuator stuck
                    Fault Frequency: 78
                    Reset counter: 108
                    Mileage: 190580 km
                    Date: 2015.01.20
                    Time: 04:09:14
   Part No SW: 1K0 937 087 E    HW: 1K0 937 087 E
   Component: BCM PQ35  H+  103 0575
   Revision: 00103 AG
   Coding: 40180AB8B005089040080080010001E4430000AE420081605C0440000000
   VCID: 336F7B8E9257AAB9A29-8066
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 09041  22  0601
   Coding: 00D7B7
                    Fault Status: 00101010
                    Fault Frequency: 19
                    Reset counter: 88
                    Mileage: 191940 km
                    Date: 2015.01.30
                    Time: 23:42:39
                    Voltage: 14.00 V
                        Term 50 Off
                    Fault Frequency: 63
                    Reset counter: 85
                    Mileage: 191027 km
                    Date: 2015.01.25
                    Time: 03:29:28
                    Voltage: 13.65 V
                        Term 50 Off
                    Reset counter: 94
                    Mileage: 192083 km
                    Date: 2015.02.05
                    Time: 00:16:00
                    Voltage: 8.70 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 94
                    Mileage: 192083 km
                    Date: 2015.02.05
                    Time: 00:16:01
                    Voltage: 8.70 V
                        Term 50 Off
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 94
                    Mileage: 192083 km
                    Date: 2015.02.05
                    Time: 00:16:01
                    Voltage: 8.70 V
                        Term 50 Off
                    Reset counter: 111
                    Mileage: 194236 km
                    Date: 2015.02.16
                    Time: 06:36:00
                    Voltage: 10.95 V
                        Term 50 Off
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2L5L3F
   Coding: 0020790
   VCID: 3D7B5DB664136CC944D-8068
   Subsystem 1 - Serial number: 6332MSME52241118
   Subsystem 2 - Serial number: 6342MSME5270337DC
   Subsystem 3 - Serial number: 6351HSME21377057%
   Subsystem 4 - Serial number: 6361HSME21374C142
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0000033
   VCID: 0201EE4A5D6DD33179F-8057
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1Z0 920 843 G    HW: 1Z0 920 843 G
   Component: KOMBI         H05 0305
   Coding: 110B00
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 3C7D50B2B70965C1733-8069
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K1040600F0
   Coding: E9801F06400202001302
   VCID: 69D3D9E6401B2069D85-803C
   Component: IMMO          H05 0305
   VCID: 6AD1A6EA8D1D2B71D1F-803F
Address 37: Navigation
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2113
   Coding: 0000116
   VCID: 48953C623BD13961E7B-801D
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 68     3001
   Revision: 00H17000
   VCID: 31637186A84B98A9D05-8064
                    Fault Status: 00110010
                    Reset counter: 94
                    Mileage: 192083 km
                    Date: 2015.02.05
                    Time: 00:16:00
                    Battery Volts: 9.0 V
                        DU
                    Temperature: 15.0°C
                    Torque: 0.000 Nm
                    Torque: -2.1 Nm
                    RPM: -1 /min
                    Drive Current: 0.0 A
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000116
   VCID: 47973F5E36CF3619EE1-8012
Address 56: Radio
End-------------------------(Elapsed Time: 01:44)--------------------------
Spacewalker
Poland
C?ID=159607
I see is not enable in ECU, because is
but should be
Component: R4 1,9l EDC GA00SG 2047
Go to Steering controler (16th)
measure Block 004 and check if is all response from CCS buttons
after go to ECU (01)
Measure block and look into 006 (switch monitoring)
You should see different status when you press CCS buttons
NEtech
Denmark
C?ID=56995
but should be
Spacewalker, why should there be an A ?
Normally G is cruise control activated, and A (without G) is ACC.:)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
...and before you bother with Cruise Control, start with replacing the faulty Ignition Switch. :)
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
Thank you all...
but what should I do now as resolving the problem?
Note : everything was OK ( Cruise control ) till someboday try to deactivate the daytime light by using the function in the windshield arm
NEtech
Denmark
C?ID=56995
Delete all fault codes. Ign. OFF. Check what is fault codes is back.
Then do as Sebastian and Spacewalker wrote.
If no relevant fault codes you could maybe try and deactivate CCS > Ign OFF (1 min.) > Activate CCS.
