Sound Actuator SQ5 - Engine Noise Simulators
South Molton, UK
Does this mean it doesn’t work??
A full unedited VCDS Auto-Scan would be more helpful (see my sig for a link to a How-To).
That DTC probably means the sound actuator can be reached by diagnostics but has another electrical issue, to say any more we'll need to see that Auto-Scan.
barbalatte
Sydney, Australia
Thanks again.
 Monday,06,July,2020,15:23:05:63594
VCDS Version: 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WAUZZZ8R9DA071750   License Plate:
Mileage: 85790km-53307mi   Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 0F 15 16 17 19 36 42 44 46 47 52 53 56 5F
          62 6C 6D 72 A9 C0
VIN: WAUZZZ8R9DA071750   Mileage: 85790km-53307miles
0F-Digital Radio -- Status: Cannot be reached 1100
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589     HW: 4G0 907 589
   Component: 3.0BTD EDC17  H24 0001
   Revision: 57H24---
   Coding: 2A2A4032252603020000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589 001004
   ROD: EV_ECM30BTD0118K5907589.rod
   VCID: 7EA5022DD078F357B89-802A
   Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1002
   Revision: --H16---
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 00597CD5AA8C85A7CA5-8054
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AB    HW: 8R0 907 379 AB
   Component: ESP8 quattro  H09 0050
   Coding: 245D0C01
   Shop #: WSC 06335 000 00000
   VCID: 00597CD5AA0C85A7CA5-8054
   Part No SW: 8K0 907 064 GR    HW: 8K0 907 064 FR
   Component: BCM2 2.0      H12 0633
   Coding: 05B54040000000000000
   VCID: 06556ACD8828AB97F09-8052
   Part No SW: 8K2 820 043 T    HW: 8K2 820 043 T
   Revision: D1000000    Serial number: 01180220130830
   Coding: 3625628080
   VCID: 3A2DCE3D8C501F77C41-806E
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000555658602
   Coding: 260080118134AFF0018140C300001D0D4F9DC70827090201000008004401030100000034000000
   Shop #: WSC 06335 123 12345
   VCID: 78A91435F2DCCD67F25-802C
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130124  H11 0050
   Serial number: 90243015130121190815
   Coding: 01DD13
   Serial number: 21003873
   Coding: 03005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001302131026
   Serial number: 30380296000000000001
03110 - Active Steering Control Module (J792)
                    Reset counter: 13
                    Mileage: 85360 km
                    Date: 2020.06.20
                    Time: 18:16:36
Address 0F: Digital Radio
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Serial number: 003JPD92UVBE
   Coding: 304A3431313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C9A4F5C23C7DE7425-801C
   Serial number: 6334MSME74160A68F
   Serial number: 6344MSME777301537
   Serial number: 6352QSME5328476EQ
   Serial number: 6362QSME6628377EV
   Serial number: 63732SME712B4D688
   Serial number: 63832SME582B3D7CI
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372MBD000L6
   Coding: 000037
   VCID: 43D3B3D9FB9A5EBF977-8016
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 K    HW: 8R0 920 931 K
   Component: KOMBIINSTR.   H35 0556
   Revision: 00100000    Serial number: UWY24KC2E
   Coding: A3AF220003010008010700
   VCID: 3D27C5219D7E284FE13-8068
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0055
   Revision: 1Y060027    Serial number: 2741Y132138073
   Coding: 80CD07FF00
   VCID: 4ACD9EFDDCB08FF7541-801E
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000001461041901
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 13038002403011200410
02230 - Digital Radio (DAB) (R147)
                    Reset counter: 13
                    Mileage: 85360 km
                    Date: 2020.06.20
                    Time: 18:17:35
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 53
                    Mileage: 85360 km
                    Date: 2020.06.20
                    Time: 18:42:21
                    Bin. Bits:    10111
                    Voltage: 11.70 V
                    Count: 6
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000051749369
   Coding: 01781B00000000000000
   VCID: 42DDB6DDE48057B79C1-8016
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000051960460
   Coding: 011D12205E01440004
   VCID: 4FFB8FE927D2AADF03F-801A
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0013268912
   Coding: 100000010001
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B23CB3983EA267FDF7-806E
   Revision: 00002001    Serial number: 0301338329
   Coding: 01040E2220B93095872005368004000F
   Shop #: WSC 44406 123 104857
   Component: J245EE20SKB13  H05 0220
   Component: J394EE20SKB13  H05 0220
   Revision: 00005001    Serial number: 94813011164102
   VCID: 2D07F5614D1EB8CF513-8078
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000052677644
   VCID: 4EC592ED20D8A3D7089-801A
02117 - Motor for Mirror Folding
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 29
                    Mileage: 85422 km
                    Date: 2020.06.23
                    Time: 09:52:45
                    Reset counter: 64
                    Mileage: 85553 km
                    Date: 2020.06.29
                    Time: 09:35:15
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 29
                    Mileage: 85749 km
                    Date: 2020.07.05
                    Time: 11:33:23
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001259528
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829D435B2DC0D67325-806C
   Part No SW: 4G1 035 053 G    HW: 4G1 035 053
   Component: Radio U Basic H41 0121
   Revision: AB001007    Serial number: 227B30D7696709
   Coding: 040003010000000001
   VCID: 231313591BDA7EBFF77-8076
   Part No SW: 8R2 035 754 B    HW: 8R2 035 754 C
   Component: H-BN-RW       H45 0639
   Revision: --------    Serial number: 210BP0D7509640
   Coding: 1A0A01060205E1FF4780CB4E00000403FC0000020000000000
   VCID: 3635DA0DB848FB17209-8062
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Component: DU7 High  H42 0104
   Serial number: A130BL0D2659121
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001419569
   Component: CD-Database  4949
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000052596016
   Coding: 010C12204001240004
   VCID: 46D5AACDC8A86B97B09-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J2ZA1XA
   Coding: 1020010
   VCID: 3431E005A234E9071ED-8060
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B23CB39836A267FDF7-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000052278425
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 130201200540
   VCID: 79AF1131C956D46F8DB-802C
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0002
   Serial number: 130206200331
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 71BF291191269C2F35B-8024
0006 - Actuator 1 for Engine Noise Simulation
          C113C 13 [008] - Open Circuit
                    Reset counter: 70
                    Mileage: 85360 km
                    Date: 2020.06.21
                    Time: 09:37:10
End----------(Elapsed Time: 01:52, VBatt start/end: 12.0V/12.0V)-----------
South Molton, UK
You've got several intermittent faults there, some likely caused by a low state of charge in the battery (03041 - Energy Management Active) - probably worth clearing all the fault codes and seeing which (if any) return.
BTW you really should update your VCDS (<acronym title="A registered trademark of Ross-Tech, LLC">VCDS</acronym> Version: 19.6.0.6) - the current version is 20.4.1 ;)
barbalatte
Sydney, Australia
Thanks will do. I cleared the Faluts you saw there about 2 weeks before to see what popped up and those are it! About 2 weeks worth.
So what could be the problem with Sound Actuator??
South Molton, UK
Open Circuit = wiring problem or blown fuse, so you need to get the WD for your car and do some old fashioned fault finding using a DVOM.
