VW EOS Cabriolet - Top Operation via Basic Settings
voxmagna
O?ID=169475
I want this vcds option to work, I've read the notes and I'm an EOS expert:
VAS offers the options with guided fault finding.
My EOS roof module data file is 1Q0-959-255-clb
My roof is fully functional with no VCDS or VAS errors
I can gain access to Basic Settings using the security access code.
If I start the test (top right button) the sunroof opens the full distance and stops.
The screen has some activity but there is no acknowledgemet of 'Done' to move to the second step.
There is nothing on the screen indicating the BS step number e.g BS 010 for open sunroof first step
Something is odd about the sequence because 1/2 second before the sunroof starts normal opening, a CAN command should lower all windows and they don't move?
Further steps in the roof cannot be executed if the windows haven't lowered! I can try repeating after manually lowering all windows?
Help please as to what I'm missing because it saves me bulding a simple box in hardware with a multiway switch for each step sequence to control the pump, its direction and solenoid valve selection.
Also, Are the Basic Settings steps excecuted strictly in order or can an individual step be executed alone e.g release roof locks or control tailgate locking?
I installed the latest software version but nothing changes on the Roof Module GUI.
https://forums.ross-tech.com/showth...Operation-via-Basic-Settings-(DO-NOT-DO-THIS)
voxmagna
O?ID=169475
Anybody using this 'engineering' function and got it working?
