VW PASSAT CC IMMOBILIZER ACTIVE ERROR
Shift Performance
Trinidad
C?ID=96348
I have attached the autoscan for assistance in repairing this car.
when active the car will not start.
I notice the central Electric has 1 fault code 01044 found, however i am not sure if it is responsible for the car not starting at times.
seeking guidance
Thursday,02,July,2020,18:13:43:12672
VCDS Version: 20.4.1.0 (x64)
Dealer/Shop Name: Shift Performance
VIN: WVWZZZ3CZBE722292   License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 25 2E 36 42 44 46 4F 52 53
          56 62 72 77
VIN: WVWZZZ3CZBE722292   Mileage: 56190km-34914miles
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 06J 906 026 FB    HW: 06J 907 309
   Component: MED17.5             5844
   Revision: AAH18---    Serial number: VWZCZ000000000
   Coding: 040400101C070160
   Shop #: WSC 05314 000 00000
   VCID: 6FE9B6C87EAC8CFEE2-803A
               U1017 - 015 -  - Intermittent
                    Fault Status: 00101111
                    Mileage: 56190 km
                    Date: 2014.11.20
                    Time: 14:03:01
                    RPM: 879 /min
                    Load: 42.3 %
                    Speed: 2.0 km/h
                    Temperature: 78.0°C
                    Temperature: 56.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.208 V
Readiness: 0000 0001
   Part No SW: 02E 300 053 M    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 2202
   Revision: 06454104    Serial number: 00001811220429
   Shop #: WSC 04940 001 00001
   VCID: 1F498608CE8C5C7E12-804A
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --026---    Serial number: 00000104321416
   Coding: 0003443
   Shop #: WSC 05311 000 00000
   VCID: 62CFCFFCBD7E31967D-8036
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Fault Status: 00101100
                    Reset counter: 135
                    Mileage: 55913 km
                    Date: 2014.10.05
                    Time: 15:30:01
                    Speed: 5.0 km/h
                    Hex Value: 0x0001
                    Voltage: 14.00 V
                    Bin. Bits: 00011111
                    Count: 12
                    Hex Value: 0x0000
                    Reset counter: 175
                    Mileage: 56139 km
                    Date: 2014.11.03
                    Time: 14:57:07
                    Speed: 12.0 km/h
                    Hex Value: 0x00C5
                    Voltage: 13.25 V
                    Bin. Bits: 00011111
                    Count: 13
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 05311 115 00000
   VCID: 7EF79B8CE1C6F57679-802A
   Part No SW: 3C8 937 049 S    HW: 3C8 937 049 S
   Component: Bordnetz-SG     H53 3101
   Revision: 00H53000    Serial number: 00000004151505
   Coding: E1848F8B00041A0047970F00170000000008FB475C40017C174000000000
   Shop #: WSC 05124 000 00000
   VCID: 418D207018B84A8E44-8014
   Subsystem 1 - Part No: 3C8 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 300610 010  0603
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     090910 054  0403
   Coding: 00209133
   Shop #: WSC 05124
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08791024971444
   Coding: 100101
   VCID: 326F7FBC6D1EE116CD-8066
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 03091003240001
   Coding: 010180
   VCID: 27599EE856DC94BE6A-8072
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__302 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PHNGUW.
   Coding: 0012338
   VCID: 4C9301442FFA97E6A7-8018
   Subsystem 1 - Serial number: 6332MTS649072270
   Subsystem 2 - Serial number: 6342MTS665142210
   Subsystem 3 - Serial number: 6351HTS6DBV2E9KJ
   Subsystem 4 - Serial number: 6361HTS69S43E9KJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0136
   Revision: FF010038    Serial number: 20100906100100
   Coding: 0982270002
   VCID: 6BD1A2D882B470DECE-803E
   Coding: E20000
   Part No SW: 3C8 920 970 K    HW: 3C8 920 970 K
   Component: KOMBI         H03 0305
   Coding: 440F00
   Shop #: WSC 05314 115 00000
   VCID: 346379A49F0AEF26DF-8060
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0172
   Revision:   H14       Serial number: 1021G10903011D
   Coding: FDA8FF06000613009003
   Shop #: WSC 07737 898 09549
   VCID: 2C5361C48F3AB7E687-8078
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 7AFF979C35EED95645-802E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
01176 - Key
                    Fault Status: 01101000
                    Reset counter: 136
                    Mileage: 55962 km
                    Date: 2014.10.13
                    Time: 20:31:07
                    Reset counter: 172
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Revision: A1001003    Serial number: 7668564896
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000001
   VCID: 72EFBFBC6D9EA1160D-8026
   Part No SW: 1T0 959 701 AG    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0308
   Revision: 12101005    Serial number: 0001484667
   Coding: 0013B7
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 7CF39184F7DAE76657-8028
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001649078
   Coding: 000090
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 209    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 316D70B0A818DA0EB4-8064
                    Fault Status: 00101101
                    Reset counter: 176
                    Mileage: 56190 km
                    Date: 2014.11.20
                    Time: 14:07:37
                    Voltage: 13.13 V
                        DU
                    Temperature: 55.0°C
                    RPM: 883 /min
   Component:    KSG PQ46 ELV 043 0612
   Coding: 19910A0001860E76360494157008DFCE507801
   Subsystem 1 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HORN H11 9004
   Component: Neigungssensor  004 0611
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Component: EZE_2         H14 0172
   Revision: --------    Serial number: 1021G10903011D
   Coding: 01030100
   VCID: 66C7D3EC91564DB691-8032
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 032400046891
   Coding: 000006
                    Reset counter: 170
                    Mileage: 55958 km
                    Date: 2014.10.10
                    Time: 22:28:55
   Part No SW: 1T0 959 702 AC    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0308
   Revision: 14101005    Serial number: 0001477412
   Coding: 0013B6
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 79FD8890F8E8D24E4C-802C
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001642926
   Coding: 000090
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   011       Serial number: 00000000385530
   Coding: 0000057
                    Reset counter: 176
                    Mileage: 55913 km
                    Date: 2014.10.05
                    Time: 15:30:01
                    Voltage: 13.50 V
                    Count: 108
                    Speed: 4.0 km/h
                    Hex Value: 0x12E0
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  040 0167
   Revision: 00000001    Serial number: VWZ1Z3K3554036
   Coding: 0100041004
   VCID: 62CFCFFC7D7E31967D-8036
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 051 730 D    HW: 1K8 051 730 D
   Component: Telefon       H03 6900
   Revision: 00003000    Serial number: 00000A07806233
   Coding: 402120
   VCID: 285B9DD45BC29BC663-807C
End-------------------------(Elapsed Time: 03:00)--------------------------
The immobilizer in this car is physically part of the Central Convenience module.
You can see that they both have the same hardware part number: HW: 3C0 959 433 AR
How often does this problem occur?
"01176 - Key 008 - Implausible Signal" can be caused by a bad reader coil, or a poor connection between the module and the coil.
PS: Got you verified, moving to Car Repair Support.
NostraJackAss
Car this old I'd over lay the D2 or consider immobilizer removal in engine ECU.
Stabilant 22a should be applied to connection's.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Can you post Measuring block 001,002,003 of 25-Immobilizer controller?
Shift Performance
Trinidad
C?ID=96348
Tuesday,07,July,2020,18:01:41:12672
VIN: WVWZZZ3CZBE722292 License Plate: PCS6259
Mileage: 56193 Repair Order:
Address 25: Immobilizer (3C0 959 433 AR)
17:58:40 Group 001: System Status
Yes Engine Start permitted
Yes Engine (ECU) responds
No Key Status
2.0 Number of adapted Keys
17:58:40 Group 002: Key && Adaptation Status
Yes Variable Code authorized
Yes Key Status (Transponder)
Yes Fixed Code authorized
6.0 Immobilizer Status
17:58:40 Group 003: Lock Times && System Status
0.0 Lock Time Immobilizer
0.0 Lock Time Engine
0.0 Lock Time Transponder
0.0 Immobilizer (LED) Status
Shift Performance
Trinidad
C?ID=96348
very often now
Shift Performance
Trinidad
C?ID=96348
No Key Status
Jetta 97
C?ID=81680
This is very strange, Key status is not good , but all authorized, I would suspect something is wrong with CCM
No Key Status
Shift Performance
Trinidad
C?ID=96348
No Key Status
agreed i was thinking that.
scarley
I don't know for sure but it sounds like you are having a security issue. I don't have security issues experience with Jettas, but you may need to purchase a new computer and flash the SKIM before removing old computer. I don't know if VCDS offers this service, if not you will have to buy even more expensive software. There is also the option of buying a computer with a deleted SKIM. Don't know if this is exact
my your issue but something to consider especially if you are stuck in a no start.
Jetta 97
C?ID=81680
VW is not Dodge or Chrysler and do not have SKIM.
They have immobilizer system which can be programed with out flashing ECU/Immobilizer system , and his car is Passat not Jetta .
