Hi. I'm thinking that I would like to start out with VCDS lite just to start out. I sort of want to make sure I'll be keeping this car for a while. If so then I'll upgrade after I have the money.
Questions....
With VCDS lite, can I look at the value blocks of sensors?
Will it diagnose bad sensors like oxygen sensors, crank(rpm sensor)?
Does the lite version come with a cable? so far I have looked at a few of the ebay cables and none are able to be hooked up to a 2000 Passat. Not really sure why? I also read about the chip set in the cable that works better, searched for that and did not have much luck either, maybe I'm just not looking hard enough. What cable would you recommend for starting lite if you're able to say, I would understand why you wouldn't.
Questions....
