Hi All,
I've been running into a lot of issues recently, and after whittling down 20+ errors, seized calipers and more, I'm stuck.
I'm not 100% sure on how/where to start tackling the electrical errors VCDS is reporting
Any help would be appreciated!
Tuesday,30,June,2020,15:01:58:32472
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWAK73C47P102951 License Plate:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 53 56 62 65 72
VIN: WVWAK73C47P102951 Mileage: 204300km-126946miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 3C0 907 115 S HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 02616 444 52565
VCID: 3039157C9624BE0BE3B-8064
Part No SW: 09G 927 750 HJ HW: 09G 927 750 FP
Component: AQ 250 6F 1068
Revision: 00H69000 Serial number:
Coding: 0000072
VCID: 005985BC6604EE8B53B-8054
01682 - ABS Wheel Speed Signal; Rear Right
013 - Check DTC Memory
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 109 A HW: 3C0 614 109 A
Component: ESP 440 C4 H018 0001
Revision: H018 Serial number: 0668209297
Coding: 0013755
Shop #: WSC 00028 028 00001
VCID: 1C61D1CCEAAC2A6BAF3-8048
Reset counter: 162
Mileage: 198014 km
Date: 2019.09.08
Time: 19:22:26
Fault Status: 00101101
Fault Frequency: 12
Reset counter: 197
Mileage: 204150 km
Date: 2020.06.17
Time: 18:27:32
Part No: 1K0 820 047 GS
Component: Climatic PQ35 120 0606
VCID: 7BA3F2500FE28D53069-802E
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004623672
Coding: 14848F0340041A00470000000F00000000285D435C0001
VCID: 6C81C10C7A8C1AEB9F3-8038
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 101006 003 0205
Coding: 00046997
Shop #: WSC 00028
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 N HW: 3C0 909 605 N
Component: 17 AIRBAG VW8R 031 2522
Revision: 12031000 Serial number: 003B2PP366KF
Coding: 0012599
VCID: 313F10789D2EB703EC5-8064
Subsystem 1 - Part No: 3C0 959 339 B
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 0000000003H799
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332MSME150E0E005ÿ†63
Subsystem 5 - Serial number: E0E005ÿ†6342MSME152463463ÿ†63
Subsystem 6 - Serial number: 463463ÿ†6351HTS6GIE457D66ÿ†63
Subsystem 7 - Serial number: 457D66ÿ†6361HTS6GIECGPC60ÿ†63
Subsystem 8 - Serial number: CGPC60ÿ†63727TS66HB0JQH6Iÿ†63
Subsystem 9 - Serial number: 0JQH6Iÿ†63827TS66HB0FPU6Rÿ
Subsystem 10 - Serial number: 0FPU6Rÿ
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 N HW: 3C0 953 549 N
Component: J0527 0015
Revision: 00006000 Serial number: 3C5953507AK
Coding: 0002013
VCID: 372B2E60734A6933A21-8062
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 971 A HW: 3C0 920 971 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007205
Shop #: WSC 02616 444 57731
VCID: 2313EA30D7D215936E9-8076
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C06B140B81
Coding: 3FFD0E04D21002
VCID: 211FE038CDCE07837C5-8074
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0003
Revision: 00005000 Serial number: 1166279TR1N906
VCID: 6D87CC08419613E388D-8038
Part No SW: 3C0 959 433 AK HW: 3C0 959 433 AK
Component: IMMO 051 0383
Revision: 00051000 Serial number: VWZCZ000000000
Shop #: WSC 02645 444 69262
VCID: 73B3DA7027B2C5135E9-8026
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1123
Revision: 32008001 Serial number: 00000076069115
Coding: 0001205
VCID: 3B2332504F624D53469-806E
00109 - Left Mirror Turn Signal Lamp (L131)
Fault Status: 01101100
Fault Frequency: 12
Reset counter: 175
Mileage: 204239 km
Date: 2020.06.21
Time: 19:36:11
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.135 H07 1806
VCID: 3431196C623C822B873-8060
Component: KSG PQ46 RDK 051 0219
Coding: 13910F8001862E521004141FF08A0F0E085800
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1123
Revision: 32008001 Serial number: 00000547669122
Coding: 0001204
VCID: 3C21314C4A6C4A6B4F3-8068
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 E HW: 3C0 907 801 E
Component: EPB VC8HC003 013 0003
Revision: 013
Coding: 0000013
VCID: 2411E92CD2DC12AB173-8070
02443 - Control Head
Fault Status: 11111100
Fault Frequency: 14
Reset counter: 158
Voltage: 12.01 V
Count: 40
02433 - Supply Voltage for Right Parking Brake Motor (V283)
011 - Open Circuit - MIL ON
Fault Status: 11111011
Reset counter: 156
Mileage: 204144 km
Date: 2020.06.18
Time: 11:18:17
Voltage: 11.49 V
Count: 117
02442 - Function Lamp in Control Head
Fault Status: 00101001
Reset counter: 197
Mileage: 204160 km
Date: 2020.06.18
Time: 00:03:18
Voltage: 11.80 V
Count: 65
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Reset counter: 156
Mileage: 204144 km
Date: 2020.06.18
Time: 09:55:41
Voltage: 11.39 V
Count: 116
Fault Status: 11101101
Fault Frequency: 160
Reset counter: 175
Mileage: 204296 km
Date: 2020.06.27
Time: 21:26:07
Voltage: 13.87 V
Count: 236
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7K1125249
Coding: 0100040004
VCID: 619FA038814E47833C5-8034
02633 - Antenna for Satellite Tuner
Reset counter: 169
Mileage: 204239 km
Date: 2020.06.21
Time: 19:22:25
00856 - Radio Antenna
Fault Status: 00101011
Reset counter: 214
Mileage: 204299 km
Date: 2020.06.27
Time: 02:11:36
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1113
Revision: 12005001 Serial number: 00000000941628
Coding: 0001168
VCID: 3E253B445C70587B617-806A
Component: RDK 0440
Coding: 0100101
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1113
Revision: 12005001 Serial number: 00000000921929
Coding: 0001168
VCID: 3FDB46405B7A51736A1-806A
End----------(Elapsed Time: 01:26, VBatt start/end: 14.0V/14.1V)-----------
