Hi Folks,
I have a 2015 Golf 7 GTI (Australian Delivered) that came in with a faulty ABS controller. I did not get to see teh car when it first came in, but the ABS module was non-responsive and couldn't read. A replacement unit was obtained, installed and coded online with ODIS, but was the wrong part number and so there were a few faults that couldn't be cleared. One of those was the indirect TPMS.
I looked into it and obtained the correct module and coded the car based upon the coding suggested by ODIS, but it still had issues. I took a look at the fantastic spreadsheet for the Mk100 Conti ABS from one of the forum members and was able to adjust the coding to suit, but there are still 3 errors that I can't clear.
I have posted a scan of the vehicle after having spent some time getting all visible faults cleared and there remain just these 3. They don't appear to affect the car and show no lights on the dash, but I would like to clear them nonetheless. I hate faults, even cosmetic ones. I don't know if someone has flashed or modified any of the modules in this vehicle to cause these errors to show.
01 Engine - 17178 - Databus U1123 00 [039] - Received Error Message (Likely a result of the errors in Modules 03 and 17)
03 ABS - 8314 - Check Coding of ECUs on Powertrain Data Bus P1647 00 [009] - - [FCAN: Coding of ESP and TSK does not fit together]
17 Instruments - 16776969 - Databus U1121 00 [009] - Missing Message [LDW_02 keine Kommunikation]
This Vehicle does not have LDW and I'm not sure what TSK is (Traction Control ?)
It's a fairly basic spec GTI. Anyway, scan below and hoping someone can shed some light on these issues.
Regards
Steve
Regards
Steve
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 42 44 52 5F A9
VIN: WVWZZZAUZFW307500 Mileage: 85736km-53273miles
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0010
Revision: --H13---
Coding: 0A1D00324424050B2000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM20TFS0215G0906259 001014
ROD: EV_ECM20TFS0215G0906259.rod
VCID: 6B83C14D130EA453969-803E
17178 - Databus
Mileage: 85736 km
Date: 2020.06.30
Time: 21:32:40
Engine speed: 807.75 /min
Normed load value: 9.0 %
Coolant temperature: 100 °C
Intake air temperature: 36 °C
Voltage terminal 30: 13.242 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
SEG_AD_MMV_ER_L[3]: 6.5308 ‰
Readiness: 1010 0001
Part No SW: 0D9 300 041 T HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 05853104 Serial number: TFK01503021878
ROD: EV_TCMDQ250021.rod
VCID: 290FFB45D9727643245-807C
Part No SW: 3Q0 907 379 Q HW: 3Q0 907 379 F
Component: ESC H42 0610
Revision: 00000000 Serial number: 60795000000467
Coding: 01FA93A134202973077C060041C3A980C92C94E0608295F7004200B8C209
Shop #: WSC 01234 564 99999
VCID: 48C95EC16238AF4BDBB-801C
P1647 00 [009] - -
Reset counter: 11
Mileage: 85736 km
Date: 2020.06.30
Time: 21:32:40
Part No SW: 5G0 907 044 BC HW: 5G0 907 044 BC
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120004200100001005004012101400
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 698FBB4519F2B643E45-803C
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AG HW: 5Q0 937 084 AG
Component: BCM MQBAB M H18 0137
Serial number: 01011507500355
Coding: 03001842C24102FB0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7DA7FF157D7A3AE338D-8028
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150304 042 0551
Serial number: 150312142626
Component: RLHS 037 0059
Serial number: S5Y15M03D24H19M41S45
Coding: 90A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1504810GW
Serial number: 00000000000061848033
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391507704779
Coding: 0031151011
VCID: 3D273F153DFAFAE378D-8068
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H16 0115
Serial number: 14021541350200
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 76B5E039584C69BB797-8022
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0HAASU
Coding: 98CCC000000000005C00000000C800000065
VCID: 41DF43E541029E031C5-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 803 15
Serial number: 35767000000E9174731V
Subsystem 2 - Part No SW: ----------- HW: 480 001 803 15
Serial number: 358670000006F86DB316
Subsystem 3 - Part No SW: ----------- HW: 480 401 903 15
Serial number: 3516502C319EFD21026E
Subsystem 4 - Part No SW: ----------- HW: 480 401 903 15
Serial number: 3526502C519EFD20421F
Subsystem 5 - Part No SW: ----------- HW: 480 401 903 15
Serial number: 3556502C719EFD23F35$
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150316400760
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3FDB451D37F6E8F36A1-806A
Part No SW: 5G1 920 756 HW: 5G1 920 756
Component: KOMBI 301 4310
Coding: 27AD090873800008000F7A001400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009043
VCID: 6A8DC4491CF4BD5BEDF-803E
16776969 - Databus
Reset counter: 11
Mileage: 85736 km
Date: 2020.06.30
Time: 21:32:36
Part No SW: 5Q0 907 530 AB HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1204
Revision: -------- Serial number: 0003284662
Coding: 030100342F085900EF0002689C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011020
ROD: EV_GatewLear_011.rod
VCID: 71BFD32531224E83AC5-8024
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H10 0101
Serial number: 29150000592870025126
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 6681136003
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 100315BC912028
Coding: 003E02208001040000000000
VCID: 42DD4CE94404851B05F-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005555441
Coding: 0D0000
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 8103
VCID: 372B2D3D1FC6D0B3A21-8062
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 070315BC702482
Coding: 003E02208E01040000800000
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005589007
Coding: 150000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 846 A HW: 5G0 035 846 A
Component: MU-S-N-ER 041 0430
Serial number: V1F02203150415
Coding: 02730008FF00000011510001000900001F0203960100010045
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 270BFD7DCF664033321-8072
Subsystem 1 - Part No SW: 5G0 919 605 D HW: 5G0 919 605 D
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9RS407BVG
Subsystem 2 - Part No SW: 5G0 919 866 R HW: -----------
Component: ROW 2015 --- 0031
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150307200488
End----------(Elapsed Time: 01:38, VBatt start/end: 13.1V/13.1V)-----------
