Hi Everybody,
I have a Golf that has been suffering from flat battery issues, possibly Covid related and therefore lack of use.
As I had alarm horn issues, I replaced that, experience shows that these often cause problems.
I also had no comms with rear left door module but customer did not want to buy a new one due to cost. She was aware of the central locking not working on that door but wasn't bothered about it, she just failed to tell me about it beforehand! Of course, I had already investigated the problem by then and when I plugged the door module back in it worked for just enough time to log a door open message and the interior light was now staying on. because of the "I didn't want to spend that much effect" and the "it wasn't doing that before it came to you" problem, I bought a used one, fitted and coded it. More to confirm that it was the module and not the wiring than anything else. That now works fine.
The problem I have is that the right rear window goes down when commanded up and vice versa. I simply can't remember if I tried that window when it came in. It seems that this is a relatively common problem with no easy remedy and can be caused by flat battery issues. I just want to be sure in my own mind that it is not related to what I have done with the other door. The coding of this window appeared wrong as well and I corrected that easily enough.
Is there anything that can be done using VCDS or should I replace the motor? Seems stupid to have to change the hardware to fix a software fault though.
Monday,22,June,2020,11:18:43:20505
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 20.4.0.1
Dealer/Shop Name: Response Diagnostics 01732 863344
VIN: WVWZZZ1KZ7P067969 License Plate: AD07BEJ
Mileage: 124290km-77230mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7P067969 Mileage: 124290km-77230miles
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 1010
Address 01: Engine Labels: 03C-906-056-BAG.lbl
Part No SW: 03C 906 056 DP HW: Hardware No
Component: MED9.5.10 G00 9029
Revision: 66H09--- Serial number: VWZ7Z0G8105251
Coding: 0000072
Shop #: WSC 00028 028 00001
VCID: 74E3E08117EB362616-8020
000152 - Intake Air Temperature Sensor 2 (G299)
P0098 - 002 - Signal too Low - Intermittent
RPM: 10200 /min
Load: 100.0 %
Speed: 255.0 km/h
Temperature: 215.0°C
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 004 - Open Circuit - Intermittent
Fault Status: 00110100
RPM: 10200 /min
Load: 100.0 %
Speed: 255.0 km/h
Readiness: 1000 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0019073
VCID: 73E1E39D12E5311E0F-8026
Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
VCID: 7BF1CBBD3AB5795E57-802E
00898 - Control Circuit A/C compressor
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006891853
Coding: E48D0F2700041500471400001400000000087B075C0001
VCID: 6CD3F8E14FDBEEE6CE-8038
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 140307 020 0501
Coding: 00038805
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 300307 020 0105
Coding: 00208933
Shop #: WSC 00028
10 Faults Found:
01117 - Generator Terminal DF Load Signal
Fault Status: 01101000
Reset counter: 118
Mileage: 124293 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.20 V
Reset counter: 118
Mileage: 60976 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.30 V
Fault Frequency: 94
Reset counter: 155
Mileage: 124245 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.30 V
Reset counter: 155
Mileage: 124245 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.30 V
Fault Frequency: 52
Reset counter: 155
Mileage: 124245 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.65 V
Reset counter: 155
Mileage: 124245 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.30 V
Reset counter: 155
Mileage: 124245 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.30 V
Reset counter: 155
Date: 2005.09.13
Time: 31:63:63
Voltage: 5.00 V
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 155
Mileage: 124245 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 9.60 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 155
Mileage: 124245 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 9.55 V
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD14C4M6
Coding: 0013112
VCID: 3D7505A56421B76E29-8068
Subsystem 1 - Serial number: 6332MSME17606F42C
Subsystem 2 - Serial number: 6342MSME182F443EN
Subsystem 3 - Serial number: 6352QSME254D470DP
Subsystem 4 - Serial number: 6362QSME26763C0FT
Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
Component: J0527 036 0070
Coding: 0002022
VCID: 75E5DD851C912F2E21-8020
Component: E0221 002 0010
00895 - Cruise Control Switch (E45)
Part No SW: 1K0 920 973 A HW: 1K0 920 973 A
Revision: V0003000 Serial number: VWZ7Z0G8105251
Coding: 0003403
Shop #: WSC 52994 001 1048576
VCID: 2B513BFD8A5529DE87-807E
Fault Frequency: 25
Reset counter: 155
Fault Frequency: 9
Reset counter: 155
Mileage: 124209 km
Time: 21:04:12
Reset counter: 155
Mileage: 124245 km
Time: 00:00:05
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 260307F1001873
Coding: 3D3F034007000003
VCID: 2F692FEDBE4D55FEAB-807A
7 Faults Found:
Reset counter: 155
Mileage: 124245 km
Time: 00:00:02
Reset counter: 155
Mileage: 124245 km
Time: 00:00:01
Reset counter: 155
Mileage: 124245 km
Time: 00:00:27
Fault Frequency: 61
Reset counter: 115
Mileage: 60976 km
Time: 10:33:42
Reset counter: 155
Mileage: 124245 km
Time: 00:00:01
Reset counter: 155
Mileage: 124245 km
Time: 00:00:01
Reset counter: 153
Component: IMMO VDD 1610
01176 - Key
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0988
Coding: 0000692
VCID: 387B14B14B039246FA-806C
00096 - Drivers Door Central Locking (Safe) Motor (V161)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.068 H07 1806
VCID: 35651D855C116F2EE1-8060
Mileage: 124220 km
Temperature: 14.0°C
Voltage: 5.80 V
Voltage: 5.60 V
00003 - Control Module
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085FC690FC00
VCID: 0301B35D4245019E1F-8056
Component: LIN BACKUP HORN H07 9001
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
8 Faults Found:
Reset counter: 155
Fault Status: 00110010
Fault Frequency: 19
Reset counter: 155
Reset counter: 154
00323 - Vehicle Inclination Sensor (G384)
Reset counter: 153
Reset counter: 154
Mileage: 124245 km
Time: 02:12:19
Reset counter: 155
Mileage: 124245 km
Time: 00:00:02
Reset counter: 155
Mileage: 124245 km
Time: 00:00:02
00830 - Convertible Top Control Module (J256)
Reset counter: 155
Mileage: 124245 km
Time: 14:52:21
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 397D11B570098B4E05-806C
Part No: 1K0 035 186 T
Component: Radio GR0 020 0023
Revision: 0002006S Serial number: VWZ2Z2G3035239
Coding: 0040402
VCID: 3779178D461D9D3EF3-8062
00857 - CD Changer Unit (R41)
Address 62: Door, Rear Left
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Component: Tuer-SG 005 0913
Coding: 0000192
Shop #: WSC 00028 028 1012545
01814 - Supply Voltage for Door Controller; Rear Right (J389)
00123 - Outside Warning Light/Door Exit Light; Rear Right
End-------------------------(Elapsed Time: 01:59)--------------------------
