Hi all,
Audi Q5 (stock, not modified) started to give some whistling noise under the hood, from the Oil separator/PCV valve, small hole on top of it was drawing air at idle, the rubber diaphragm was fractured. So I changed it for a new Oil separator (06K103495BL) from a local Audi dealer. I thought it fixed the problem and I drove the car few miles and wished the check engine light would disappear, but it didn't. So I thought I will have to get the HEX-V2 to clear the codes and move on. I got it and did the Auto-Scan, found out that not only it had diagnostic trouble code P2279 for Leak in Air Intake System, but also some other codes too. So, please tell me should I do some more repairs or checking before I clear all fault codes? Also at Audiworld forum somebody wrote that a new updated PCV-valve requires the ECU to be updated, is this true, should I got to Audi-dealer to update the ECU? Here is the Auto-Scan..
And here is OBD2 / Current DTCs
Monday,22,June,2020,14:56:39:61968
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8R7EA027487 License Plate: EMR-372
Mileage: 128830km-80051mi Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 42 44 46 52 53 56 62 69 6D
72 77
VIN: WAUZZZ8R7EA027487 Mileage: 128830km-80051miles
Address 01: Engine (J623-CNCD) Labels:. 06L-907-115-V1.clb
Part No SW: 8R2 907 115 HW: 8K0 906 264
Component: 2.0l R4 TFSI H09 0008
Revision: --H09---
Coding: 2A2A003A243601022000
Shop #: WSC 06192 000 00000
ASAM Dataset: EV_ECM20TFS0218R2907115 001009
ROD: EV_ECM20TFS0218R2907115.rod
VCID: 73B3DA881B3A09935E9-8026
7 Faults Found:
17179 - Databus
15101 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [237] - -
Mileage: 128803 km
Date: 2020.06.10
Time: 12:23:17
Engine speed: 1443.50 /min
Normed load value: 10.2 %
Vehicle speed: 52 km/h
Coolant temperature: 104 °C
Intake air temperature: 48 °C
Voltage terminal 30: 14.589 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 675 s
MAP_MES_SAE: 34 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.041 V
FAC_TPS_1_SAE: 11.718750 %
FAC_LAM_LIM[1]: -0.157 %
14873 - Camshaft Position Sensor B Bank 1 (G300)
P0366 00 [032] - Implausible Signal
14874 - Camshaft Position Sensor (G40)
P0341 00 [032] - Implausible Signal
15102 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [096] - -
Mileage: 128828 km
Date: 2020.06.10
Time: 22:22:19
Engine speed: 795.25 /min
Normed load value: 12.9 %
Coolant temperature: 55 °C
Intake air temperature: 39 °C
Voltage terminal 30: 13.105 V
Unlearning counter according OBD: 37
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 8 s
MAP_MES_SAE: 44 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.821 V
FAC_TPS_1_SAE: 10.156250 %
FAC_LAM_LIM[1]: 0.000 %
15094 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [032] - -
Mileage: 128828 km
Date: 2020.06.10
Time: 22:22:19
Engine speed: 789.00 /min
Voltage terminal 30: 13.085 V
T_AST_SAE: 8 s
MAP_MES_SAE: 44 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.816 V
FUP_H_SAE: 11570.0 kPa
15093 - Leak in Air Intake System
P2279 00 [040] - -
Mileage: 128803 km
Date: 2020.06.10
Time: 12:23:17
Voltage terminal 30: 14.609 V
STATE_LS_SAE[1]: CL
T_AST_SAE: 675 s
MAP_MES_SAE: 34 kPa
FUP_H_SAE: 18200.0 kPa
Part No SW: 8R1 927 158 M HW: 0BK 927 156 AM
Component: 0BK 20TFSIRdW H16 1002
Revision: --H16---
VCID: 48C95D64323CDA4BDBB-801C
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AF HW: 8R0 907 379 AF
Component: ESP8 quattro H09 0030
Coding: 2DDDCC01
VCID: 045189544E143E2B773-8050
Part No SW: 8K0 907 064 GG HW: 8K0 907 064 FG
Component: BCM2 2.0 H12 0633
Coding: 01A54000000000000000
Shop #: WSC 06335 000 00000
VCID: 7BA3F2A833EA41D3069-802E
Subsystem 1 - Part No SW: 8K0 959 754 H HW: 8K0 959 754 H
Serial number: 0813000099856010
Part No SW: 8K1 820 043 R HW: 8K1 820 043 R
Component: KLIMA 1 ZONE H02 0121
Revision: A1000000 Serial number: 01210720130129
Coding: 6429008000
VCID: 372B2E984F42A5B3A21-8062
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000652826102
Coding: 2600C0108034AFC00081400300001D0D001C670826090201000004004401010200020024000000
VCID: 7AADF7AC3CD078DB1DF-802E
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 130710 H11 0050
Serial number: 90243014130627004207
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 21559618
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001507134717
Subsystem 4 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 6 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 9F98CAB6000000000001
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H47 0610
Serial number: 003JPDB0CH7L
Coding: 30463431313030303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
Serial number: 6334MSME7B56285EV
Serial number: 6344MSME7C540E64Q
Serial number: 6352QSME71322B58G
Serial number: 6362QSME0635054CD
Serial number: 63732SME113A3D66%
Serial number: 63832SME113A4E482
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862MGK000R0
Coding: 000017
VCID: 48C95D6432BCDA4BDBB-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 930 E HW: 8R0 920 930 E
Component: KOMBIINSTR. H35 0563
Revision: 00300000 Serial number: WX573YN7E
Coding: 138622000B010008010000
VCID: 3635239C48485CBBB97-8062
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 D HW: 4H0 265 105 D
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20130605003437
Coding: 4D4401
VCID: 2313EAC8EBDAD9136E9-8076
Part No SW: 8R0 907 468 L HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0056
Revision: 1V080027 Serial number: 2741V1370380AD
Coding: 80CF07FF00
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 30192301561461749561
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Serial number: 13194000632011200410
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0508
Revision: Serial number: 0000069046737
Coding: 011002205C00440004
VCID: 4FFB7678D7D20D739A1-801A
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0007117356
Coding: 100000000001
Shop #: WSC 23230 001 1048576
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D75450052EC72320D-8010
Revision: 00002001 Serial number: 0311749209
Coding: 0100062820B930808430053680040047
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0508
Revision: Serial number: 0000069070666
Coding: 011002205E00440004
VCID: 4EC56B7CD0D8047B917-801A
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 30000000084124
ROD: EV_ParkiBrake_AU48.rod
VCID: 392F28A079D6B3C3545-806C
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8R1 035 186 N HW: 8R1 035 186 N
Component: Concert3 H09 0470
Revision: 00000002 Serial number: AUZ5Z6M1928999
Coding: 0500048204058500455B071000
VCID: 40D945441A8CE20B13B-8014
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000069096805
Coding: 010002204000240004
VCID: 46D5535C38A8CC3B297-8012
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 D HW: 8K0 907 383 D
Component: Anhaenger H09 0100
Revision: 1G001001 Serial number: 00000193927741
Coding: 0109080000000000
Shop #: WSC 25397 000 00000
VCID: 35372490554E57A3B0D-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B2332A8736A81D3469-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000069096770
Part No SW: 8T0 862 335 F HW: 8T0 862 335 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005667221
Coding: 0010390
VCID: 3D273CB0617E8FE378D-8068
End----------(Elapsed Time: 01:38, VBatt start/end: 14.6V/14.7V)-----------
Tuesday,30,June,2020,12:32:32:61968
VCDS Release 20.4.1 (x64): Generic OBD2
Mode 03: Emission related fault codes
Address 7E8: 1 Fault Found:
P0068 - MAP/MAF <-> Throttle Position Correlation
Address 7E9: No fault code found.
